View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Clutch On Verge Of Dying?
- will B series internals fit in a ZC
- Electric water pump Qs ?
- best place to get ecu chipped???
- How do I fix electronic load detector on 89 CRX DX???? what replacments can i use?
- apexi-v-afc/ any gain on n/a motor?
- Where can I get wire hardness conversion ???
- Conversion Complete Part 2 - Brand new facelift and brand new rims!!!
- I'm lookin for a b16 cable tranny
- code 15 what do i do to fix
- B18 Worth it?
- wings
- supercharge
- Engine for 85 crx?
- Wierd starting idle-starting LOW then high on B16
- Anyone selling an obd0 pr3 ecu in here??
- HASPORT b16a a/c bracket?
- Where is the code on cable B-series trannys??
- Does any one has an extra TPS ?
- will a b18c fit into 89 crx si?
- Any First Gen CRX's here?
- Rear speaker help
- chassis question ef vs ed??
- HF Mini-me? found nothing in search...
- Built ZC In and Running.....
- 13 inches wheel info
- Here is my baby, tell me what you think..........
- Engine codes
- Need your experience with the state ref pleaseeeeeee help
- help what crank angle senor to use in b16a
- For any one with Del Sol seats.
- Sway Bar Question
- Does '90 CRX Si Have a Rev Limiter?
- New Civic owner -- Questions on changing oil & Maintenance req. light
- BAck up lights
- Hybrid CRX problems
- engine bay sizes
- ZC VS MINI-ME?
- I know this is a stupid ? but I need help.
- GSR cams in my B16A, pros and cons?
- Jackson Supercharged B16 in a 91 CRX Si....two part thread..need feedback
- Will a front bumper cover for a 89 Civic hatch fit on a 89 CRX ???
- Its been a long weekend... *1 or 2 pics not work friendly*
- attn june aka civicefhatchback
- Newbie question?
- do i need an o2 sensor?
- 2nd 02 senor for b16a
- what computer is in a 93 teg ls?
- B16A1, B18B1, just did a "torque vs horsepower" search and found some interesting stuff!
- BAY AREA MEET?
- Which engine(swap) is the best for highway driving?
- Spoon VTEC controller for a mini-me swap??
- 88 crx dx help car is revving high then just dies.
- jdm cr-x headlights...
- Help! Idle Problems!
- Found out why my tires slam into the wheel well
- How do I get more fuel??
- How do i tell if a b16 is usdm or jdm
- anyone have a radiator for sale?
- What year/model Honda uses the ZC non-vtec motor?
- post picture
- 1991 Civic HB DX
- get ready for amber corner lenses!
- can i put a A6 or Z6 head on a HF block?
- wheel weight
- Car Problem
- Z-10 radius arm kit owners.
- mini performance ?
- 92-93 Teg Front End on 90-91 CRX
- Do my valves need to be adjusted?
- CRX to 92-95 front?
- 1.6 vtec head on 1.5 block?
- side moldings
- Does EF9 have the following?
- spoons
- Rear Sway Bar Size
- J's racing front lip..where to buy?
- ef pics.
- EF9 JDM front end install
- MPFI & SEFI? Difference?
- D15 engine give away
- Back-up light
- how much do you guys think?
- lx or dx valve cover on d16z6..
- Check out my 007 Nitrous setup
- b16 CRX'S SLOW???? POST YOUR TIMES!!!
- Tokico adjustable shock question
- Broken HAsport mounts! Anyone else have this problem?
- Need a little help with my vacuum lines...
- anyone running b20 in here?
- code 15 help...
- prelude steering wheel install
- slower car after ITR cams WTF!!!
- pics of my new crx
- rear speakers
- question on front end conversion!!
- What engines can I use, mine is Siezed
- stock is bettaR
- motor mount question.
- Why don't it work?
- GSR Seat question for you guys
- oil in spark plugs
- 89 DRIVERSIDE APC projector needed
- Where to find JDM front end for CRX?
- fair price to sell my d16 swap for?
- DPFI to MPFI, DX to Si ?
- zc tranny - HELP
- swap finally done!!!!
- please post pics of turbos with a/c and specs
- reaisticlly speaking (and I'm drunk now)
- Holy poop on a stick it is possible...
- Possible Nor-Cal Dyno Day
- gsr into a crx need info asap
- So what is up with those designs for the EF/ED front lip?
- CRX problems, debating selling, need help/opinions guys
- new times
- SCCA legalized EF's for F class production racing
- JDM ZC ECU ..i need ecu map with wiring explanation ASAP!!
- Short shift, what ia actually shorter?
- 1987 Civic or CRX suspension questions.....
- zc fuel pressure(already searched)
- Where to find ClubSi website..........anyone.......pls...........
- Water coming out...?
- EGR block off valve on ebay?? How does it work and how do you put it on?
- CIVIC EG
- 93 LS swap into 90 HF
- Finally got turbo...........
- Pics of friends B16 CRX
- Fuel Pressure for B16a swap?
- engine swap/prices for auto
- 88 si seats into a 90 crx?
- These people are crazy!!!
- gauge cluster?
- axle removal
- My Hatch! Opinions
- MO, TX, KS, and OK racers...import drags at MoKan Raceway
- B16 swap - how to remove hubs?
- non OBD JDM B16A/US B18A distributor plugs
- Noobie question
- What's that smell?
- D16A6 Chip- Good or Bad???????
- Need help on finding Momo
- Safe to run full advance?
- synchros for S1 and Y1 trannys?
- OT- glad i have a light civic hatch and 2 crx's
- HELP HELP HELP
- Extremely long post on water leaks and rust
- where's the fuel pump relay
- Im about to install a clutch and flywheel what to do!
- D series question...
- D15 build up
- Is a B18 that much better than a ZC?
- B16 swap
- Anyone have pics of Yellow EF with ROTA/SPOONS? Thanks!
- just drove freinds type r b18c civic
- What's with all the redundancy in stock air intakes?
- can I use a 97 ex distributor with a p28 ecu?
- Question for 89 Crx gies with 18' rims..
- need answer quick! about suspension for ef
- What kind of suspension??? What kind of brake upgrade??
- Weird clunking noise at 2.5k
- I'm new here, just wanted to show my '90 si with B16 swap
- honda 19884-87 tailights
- how do you post a pic
- interior pics
- Central Ohio EF Meet on June 8th
- valve adjustment
- clutch cables doesn't fit on b16a please help!!!!!!!!!!!!!!!
- A/C in a B16a?
- Fuel Injector question?
- Dom aka jdmb18civichatch
- Paint Experts! Read.
- locked myself out of my civic!!!
- clutch/tranny/crankshaft problem..
- Power Steering
- Has anyone put new carpet in thir civic hb?
- WTB: BALL JOINTS
- Rear trailing arm offsets and differences....
- Using a si cluster, where does my redline began with an LS\VTEC setup?
- Thermal R&D catback exhaust
- Has any one ever done B16B or a integra type R in a 4th generation?
- a/c in b16 hatch?
- Should I sell my wheels?
- Rear Suspension
- ZC Oil Pump
- H-T Meeting in Atlanta on May 25th
- My crx will not start...
- Finished B16 swap
- B18 in a 91 Civic Si
- Any CRX/Civic owners w/fmax turbo kit on their D16a6...feedback needed
- Fuse Wiring Diagram Needed - 92 Civic
- LSD.........what in theworld..........
- FS: 1991 Honda Civic STD w/ JDM B16a
- Intercooler ?
- intercooler piping
- Broken gas gauge?
- Do solid amber bumper lights or corners exist for 4th gens?
- 88 CRX Questions
- i need help with a fuel problem
- paint my steelies?
- Need your help.....
- What problem does this sound like...
- FS: b16 ef
- LS Engine Harness
- Ran the B16 at the track for the first time and.......
- What kind of seats does everyone have?
- I want to move my battery in my 90 DX REX
- OT. interior question?
- The REAL DEAL with sohc vtec swap
- would this work/fit on a d16a6?
- anyone who wants to do MPFI conversion
- Cat melted shut ....
- 91 crx is an EF7 right?
- Quick question "please"
- performance injectors?
- can a 1.6 vtec head fit on a 1.5vtec block
- Ef si weight?
- Should I time my ignition?
- Wanted ASAP: Helm's manual for 88-91 Civic/CRX. Cash in hand!
- Advice to Speed Up my Slow Hatchback
- Tires and Rims
- valve cover painting?
- MAP sensor problems PLEASE HELP
- wtb 90-91 rear tailight canter piece for a hatch
- What does the knock sensor do?
- So which one flows better, the B16a1 head or the GSR
- Who's got an LS\VTEC setup.
- custom power windows on a ef crx????
- C's short shifter
- Im about to purchase a car (EF9)from japan, i dont know if im getting a good deal or not...HELP
- Brand new Clutchmaster clutches.. group buy.. check it here..!
- i need floormats
- '90 Civic Hatch Seats (I did a search.)
- is this d16z6 worth it?
- will a zc tranny work with a d16z6(halfshaft)?
- B16-88 CRX DX
- Side mount intercooler price?
- My Turbo Rex project - comments please! (big pics)
- SHOW ME PICS OF RELOCATED BATTERIES
- Water leak in Civic Si
- Painting the hatch
- es muffler on EF
- Which spray paint works best on RIMS????HELP!
- JDM B16 in EF9 doesn't fit! HELP!!!
- I think my release bearing is loose, How serious?
- Dx Tranny Help
- No power to the starter, "i dont believe"
- Need the right offset for 91 CRX si
- how to get tighter steering??
- POWER STEERING ON EF
