Ecu pin wont stay in
Old Jul 1, 2015 | 12:00 AM
Lee McHale's Avatar
Default Ecu pin wont stay in
Im doing an mpfi swap and I may have damage one of the plugs when I was depining it. now the pin will not click and stay in. It is loose and will come out when pulled. What is a good way to keep the pin in?
thanks
Old Jul 2, 2015 | 11:45 AM
sstupid's Avatar
10 Year Member
Default Re: Ecu pin wont stay in
The pins have a little tab of metal that sticks out and holds it into the plug. If the tab snapped off, you need a new pin. If it is just bent down, you may be able to pry it back up so that it will seat in the plug. You might be able to source pins from vendor, but the pinning pliers are very expensive.
Oh, also check that the pin is the right side up in the connector hole. If it's turned upside down, the tab won't have anything to grab in the connector.
Old Jul 3, 2015 | 10:24 AM
Lee McHale's Avatar
you were right I just needed to pry up the little tabs on the top because they had flattened. After I did that they clicked into place. Thanks!
Old Jul 3, 2015 | 11:39 AM
sstupid's Avatar
10 Year Member
Awesome!
Luke G.
Sep 6, 2009 06:49 AM
M-EJ1
Mar 16, 2003 06:50 PM
boot machine 5000
Sep 5, 2002 07:03 PM
CivicEx95
Apr 26, 2002 05:24 PM
