View Full Version : Honda CRX / EF Civic (1988 - 1991)
- which clutch
- crx swap question
- vacuum lines question
- Head Gasket Thickness
- anyone know how to remove the tailgate trim?
- Fuel pump wiring diagram?
- How to remove glass headlight from 91 CRX HF
- Can you use OBD0 harness and sensors on OBD1 manifold?
- Integra Tranny Question
- Engine Head Identification? *pics*
- obd1 ecu wiring questionnn
- tire vibrates
- Aftermarket lower ball Joints?
- got it started
- Clicking on Slight Turns after new parts installed
- Lower Ball Joints
- NEED HELP !!!!
- Hondata S300 QUestion
- VSS and VTEC engagement
- front lip for a 1991 4dr civic
- Gen 2 CRX Moon Roof Convertion
- Updating my headstuds on my EF????
- diy distributor install ?
- What did everyone get for CHRISTMAS for your EF?
- Wondering how to wire up the four injectors in a crx dx which has 2
- need answers help please?!
- crx headlights and corners
- mini me
- Password JDM strut bar clearence issues
- can I put an eg shocks on my 88 dx hatch?
- trying to pick out a new exhuast
- My 1991 STD
- crx hf info...
- Interchangable ?
- the boosted rex sends her christmas wishes to all her brothers and sisters..
- Dimming dash lights, cutting out, now nothing.
- MERRY CHRISTMAS!!!!!!
- 1.6L ZC DOHC Turbo
- da cluster in an ef
- Quick question on EF hatch interchangeability...
- car wont start
- 96 spec lude fogs on sir or 90-91 rex?
- I Need Help With a 90 Civic !!
- the ef project.
- is this the one.?
- jdm front end conversion?
- CR-Z (cough CR-X cough) concept pics
- Just Bought A '90 4-Door, Have Swap ?'s
- how to? CRx 88-89 dash. Retrofit 90-91 cluster cover.
- warm up car
- CRX vs. 4dr EF
- How to open my hood? wire broke off..
- EG seats into CRX. need advice
- Heater and fan controls not working or lighting up
- project civic 89 + 4wd
- civic si-r front lip
- DOHC ZC question
- wanabe jdm fog lights
- dohc zc and d15 questions
- carb legal Turbo in any honda?
- crx fuel injection conversion help
- scary wire gremlins!!!
- Parting a CRX HF ----swap question
- Need suspension
- Need Input on this EF hatch.
- pm6 c00...
- Ground Control Question
- clutch cable
- ef hatch NEW PROJECT
- question about a crx
- black smoke
- need help on my tranny swap.
- ZC piston rings options
- CRX TACH QUESTION?
- Weird OBD0 -> OBD1 Problems with idle.
- Converted auto to manual, can I just plug and play a manual Cluster?
- **OBD0 Engine CEL Code List??**
- wont start
- ef hatch anber corner lights
- ECU 37820-PJ1-7521 pinout diagram
- code 7/9/41 on obd1 ls swap
- battery and oil light?
- Rear Disc Conversion
- cps/ swap failure
- s1 trans??
- oil ABOVE sparkplug; loose camshaft bolts
- Battery light on all the time
- d16z6 swap idle issues ( code 14 )
- timing belt for ZC/Y8 Combo
- TPS WIRING! Need to know what wires are.
- OBX turbo manifold(d16y8)
- unusal problem
- Project 90 Civic
- Clutch choice for stop and go traffic
- '96 Civic Sedan Engine?
- Question about torque converter on automatic ZC
- Very Noobish B16A tranny question =(
- What do I have? OBD0 or OBD1?
- 88 rear lca's
- steering ratio?
- no air filter=bad gas millage?
- DOHC ZC Intake manifold?
- Trunk Mats? Liners?
- is it true?
- type r seats in 1991 crx????
- Torn Si CRX Seats
- rhd crx conversion
- check engine light doesnt turn on!
- bad distributor? noise and now no start!!?? help
- Is it worth it to get an engine diagnostic on a 1989 Honda Civic DX or is it too old to tell anythin
- swap failed
- honda sand rail
- ECU Fuse keeps blowing, 90 Civic EX
- same old rear disc swap - finding conflicting info
- obd0 ecu connectors
- clutch
- Honda shop in Pa/Md
- My b16 (sir1) dies at idle....need help from the wise.
- CRXs handling is super touchy. Too touchy. What can I do to make it less precise.
- cowl hoods...Where can I get one
- M/C resevoir's interchangable?
- After install of brake booster..
- b16 stumbles when driving
- code 8 and 21
- need help w/ my fo do
- How much does my 91 STD Hatch weigh?
- DPFI to MPFI OBD0 VTEC schematic ?
- question about vafc II
- 89' Civic ECU Error Codes (16,17) Price i should expect?
- New Car Purchase or Not
- CRX b16 axle bind driver side...
- CRX with bad fuel smell inside the car
- Quick STupid Question>>>>>>>>>>>>>>>>>>>
- Help Suspension
- Electrical Wiring
- Replaced my b16a passenger axle last night
- obx catback diameter?
- B20 start up help please
- OBD2 injectors OBD1 ECU????
- b16 help?
- Help with motor mount
- 88 Civic Distributer problems??
- b17
- I feel stupid to ask this but Front motor mount bolts. What size?
- 91 crx Si
- 91 Sedan: Not turning over. Only starts when push started! Need help ASAP
- JUST FINISHED SLAPPING MY HEAD ON!!
- 57 mpg? That's so 20 years ago
- Opinions on a trade?? EF 4-DOOR for a DA INTEGRA W/ LS/VTEC
- Innovative Mounts Hydro Conversion, cannot get into gear when motor fired up ***HELP***
- Full Race traction bar, caster angle?
- anyone know how to drop a motor out the bottom?
- help me please
- JDM EF8/9 SiR front knuckle/brake assembly for USDM CRX problem
- auto vs manual engine harness
- alternator woes
- 3000 and rising
- DPFI -> MPFI swap, need advice
- removing window trim?
- obd0 to obd1 conversion
- del sol seats in an EF?
- ****** ITR suspension on EF ********
- 4 wheel drive conversion for 90 hatch
- 91 CRX Steering squeaks?!?!
- Hitting a BUMP causes my car to go into limp mode??????????
- Need to find ef sedan door moldings brand new. Ideas
- HELP!! CAR DIES AT IDOL... POSSIBLY ECU? (89 CRX B16--SiR
- y7/a6 build (rod type)
- CRX WINGS WEST BUMPER ON A EF HATCH??????????????
- HELP can't decide B16a or B18b(ls) for my build....I just can't choose.
- Symptons of a Bad Distributor
- Trowing code 1/4/15 need help CLUE LESS
- 89 crx ecu problem...
- d16y8 head lots of questions please help... im a nooob
- Tps/ sensor/
- crx si to obo to ob1
- Okay, so I just bought an 89 CRX HF w/ a B16A swap...
- NOOBIE From THE Orange county
- looking for a part number
- so close to turning over
- B16 VTEC Problem! Stumped...
- help with rebuild
- Clutch Cable help
- ((((complete wire swap?))))))
- New Irish Member
- Proportioning valve distribution
- Transmission parts
- 1989 Civic Si ED7 dash removal?
- brake problems
- relocate battery ???
- sohc zc questions
- alternator problems
- brake kit conversion
- Main Relay / Distributor Question???
- DPFI to MPFI B16 88 DX Hatch Misfiring
- Fuel pump question
- Hydrolic cluch convert to Cable cluch
- 89 hatch build!
- Horn sounds automatically when i go fast or hit a bump and brake!!!HELP!!!
- Engine harness big 8-pin connector, blk/yel wire?
- quick question
- Possible Alternator/Batt. problem?
- automatic tranny convert to manual 90 civic si
- b16a dizzy question
- my ls swap ef hatch is not running
- rpm's jumping around after d16z6 swap ??
- help with obd1 pinout
- will the 91 hatch P/S mirror fits the 91 sedan?
- Bodykit Help NOT A RICER
- What can i do with my D15B2?
- Car won't start, frustrated...
- The easiest brake upgrade you never knew
- yet another, another, ano... wire tuck. help needed.
- hood latch cable replacement
- Thanks and so long, from Wes V
- 90dx vss gsr wiring
- Procedure for installing a different Camshaft?
- Valve adjustment
- windshield wipers
- rmf narrow header questions
- CRX wont start ***clicking
- california BAR. question
- 1991 CRX Si or 1990 Civic Si
- Front bulkhead question
- code 43 need some help
- 91 CRX / 605hpGSR GT35R/// 91 CRX HF D16 Turbo project #2
- plz i need some help
- Crx window question
- VIBRATION DURING ACCELERATION
- Blinking Seatbelt light on cluster
- fuel pum question and e-brake cable
- power steering rack questions
- P06 SOHC VTEC or non-VTEC?
- Crx turbo kit.
- Noob with a question
- blox exhaust
- problem with b16 ef
- WTF? Weird EACV problem and Coolant problem
- NO compressiong
- Battery Crx Dx
- aligning front end... fenders, hood, headlights and bumper
- DA front end on an ef?
- EF & ITR PARTS!
- I need some help with prop valve/ brake lines.
- B18C1 Swap
- D16z6 swap
