NGK Spark plugs, opinions?
Planning on picking up some NGK spark plugs for my DOHC ZC CRX, from what i've heard NGK's are the best so of the NGK spark plugs what's the best? Iridium IX? Laser Platinum?
How often do you plan on changing them?
Should be able to run 86-89 Integra plugs as they have a lot of similarities.
I typically run the G or V power plugs in my cars.
http://www.rockauto.com/catalog/more...id=372&jpid=12
OP, for your need, NGK Vpower copper is the best. They are relatively cheap and they have the best conductivity beside silver. For DD, they should last you 30K miles.
Laser Platinum are better than Iridium IX. They are the best plug NGK offers for the D16. If they had Laser Iridum, those would be the best (but they don't). Irdium IX are cheaper iridium plugs with a regular ground strap. The "Laser" series (both Platinum and Iridium) use a Platinum ground strap. They last much much longer than V-power nickle plugs. They also have a silicone coating that reduces deposits.
You can find the Laser Iridium plugs for the CRX very cheap on ebay.
