View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Need guidance before ordering B16.
- pictures of the crx i picked up for 720 shipped!
- gsr cluster
- woohh hooo my parts came in today...
- h22 full swap
- Finally fixed motor mounts
- does anybody have....
- What's a good, quiet, stock looking exhaust?
- Symptoms of deteriorating TO bearing?
- SIR rotor replacement?
- will 02 civic si seats fit
- Upper Molding for 88 Honda CRX
- st rear crossmember??
- What else could it be??
- Where to find 90-93 teg throtl. cabel? CHECK"D bone yards
- i have everything for my swap(b18a in a crx hf 88) what else do i need to do?
- vibrating coming from front of my car
- trouble Code 7???
- Flooded
- ST sway bar in the way of exhaust problem
- where to get main relay....
- sohc vtec in ef.. pros and cons???
- Anyone read Honda tunning "CRX guerilla TURBO"
- tokico illuminas/skunk2s VS. TEINs
- post pics of your exhaust - trying to decide what i want
- idle trouble with Y8 manifold swap!?!?
- any pics of crx's with 96 gsr wheels?
- 97 DOHC Del Sol rear discs swap fit 89 CRX si?
- who has a GSR cluster??? i can't get the speedo or fuel to work??
- 89 integra motor into a 89 dx hatchback
- Lowered car..stock ride? Possible?
- DFW peeps, I need help with tranny and clutch install
- WW RS Bumper: Fitting a Civic one on a CRX
- When your engine lift is broken, what do you use?
- coilover question b/c i am ignorant when it comes to this..........
- extra spring on coilovers...question.
- wheel bearing needs to be replaced?
- d16a6 to d15b7 swap
- *Project Update*
- what do you think of these wheels *rare jdm ssr*
- Which Idea for a Throttle Body do you like best??
- Crx=Hatch passenger side mirror?
- engine sits to low..HELP
- zc pistons in y7
- so i wanted to order a catback exhaust for my 88 hatch, but...
- type r header on ef
- integra suspension on a crx
- obd0-1 conversion wont start
- D16A6 Dizzy
- zc motors
- Place racing crossmember???
- Japanese translator needed for few lines...
- need help asap!!
- ef squad stickers
- Changing water pump
- Tranny/clutch help!
- Fender compatability
- jdm cluster install
- What harness and ECU do i use for this swap???
- SOHC Vtec Swap Questions
- 91 crx si engin
- Difference between Mugen-style and Techno R body kits (tried appearence forum)
- how much do you guys think i should be able to get for my set up??
- New guy needs a little info
- 88-91 crx and civic hatch exhaust setup the same?
- first year they made a regular civic.. no hatches.. help FAST!!!
- WANNA buy some 92-95 civic ish....
- zc/d15b2 oil pan similar
- what came first
- ITR Manifold in CRX
- NissanS!
- Free source of the factory service bullitins
- spoon coilover springs on ghetto coil perch things?
- Tein Springs
- Need help A.S.A.P
- What kind of cluster is this?
- no heat?
- Head Gasket How to??
- DAMN these adjustable shift linkages!
- Need help with CRX parts
- DIY Trunk Brace work on the CRX?
- Search is busted..... 88 different suspension than 89?
- v 20
- Camber Correction on a lowered 91 rex
- Crx still running hot
- fuel pump install?
- anyone know of any chassis dynos in new yorK???
- I just installed an LS shifter>
- obd 1 distributor on obd 1 car.
- Search down... Need pics of B series Mounts to weld etc.
- will 88-91 civic si ecu fit all honda civic models 88-91?
- Putting the oil Pan back on.
- What if i dont change my O2 sensor???
- how do u become a site moderater?
- tranny flush and fill question?
- max drop w/ tokicos
- will 4dr axle back fit on a hatch?
- Mitchell On-Demand System Program
- Sparco seats worth $600?
- hf 88 crx do i have to do anything to my harness for a b18a?
- d16z6 to play with.....
- New here, Just wanted to say "Hi"
- CRX INTERIOR PATS ....................!!!
- crx exhaust
- Negative camber question
- will it rub?
- CF+CK sunroof
- Spring rate chart link needed..
- carbon fiber lip..
- Auto Meter Shift Lite
- my first ef
- Frustration!!!
- Anyone looking for some Eagle Rods??? ZC/D Series
- which proportioning valve for rear disc?
- Using a Skunk2 Rear tiebar for Harness mounts....
- 87 Mugen CRX
- anyone running a p28 ecu with electronic VSS????
- Under car muffler
- My B16 swap is done...(LOTS OF PICS)
- Installing Tenzo seats into CRX (do I need aftermarket brackets AND sliders?)
- What kind of radiator fluid are you using?
- car keeps turning off
- Clutch cable problems after swap....
- my b16 is slow :(
- thoughts on place racing crossmember
- Name this cluster :)
- dual point to multi
- Zdyne and new injectors! YAY!
- MSD RPM Activated switch for Vtec, few questions reguarding fuel..
- Relocating cLimate controLs
- vtec engagement
- 91 crx Si ecu??
- sunroof rattles anyone?
- what kind brake fluid do i need to buy?
- News About Gude
- Removing front anti roll bar without dropping linkage?
- ZC guys.. how'd you port your exhaust mani's?
- My B16's compression test results!
- B16A, Bogging, Hesitation, bad idle, vtec?, rich, the fix!!
- B16A1 Parts?????????????????
- remove rear seat out of hatch?
- H23 in a CRX? good? fast?
- 92 civic lip on 91 crx??
- what times with b18c5 ??
- Just got another rex!! some engine advice
- drilling holes for seatbelt harness (CRX)
- Let me hear about your torque steer....
- Help with new rex
- ST Rear Away Bar + MX Exhaust = Won't Fit?
- lowering a 1st gen CRX?!?
- Help with b16 injectors and what to use?
- which axle seals?
- fuel problems
- skunk2 low tie bar ??pics
- shift light to activate vtec
- will a crx si hood fit on a 91 4dr dx
- First Gen Code
- need help, color code...
- anyone covert their crx trans to hdro?
- Looking for Opinions
- Getting crank pulley off...with engine out of car???
- took my car to the track saturday......
- Interesting dashpot findings
- thermostat and plug question
- budget turbo in honda tuning!!
- Cool D-series post of the month :-p
- dc headers for less than $319
- Help with CV Halfshaft!
- Do I need a new fuel pump for B16 swap???????...help
- B16 IM on a D16a6........HELP!!
- have motor prices went up?
- need your guys help
- WTB: Civic/Crx
- Sad Ending..
- lowered....now what?
- How do I install an RSX 2003 Gauge Cluster into 91 Civic?
- give me a ballpark people...how much $ to straighten out my back end?
- Acuple of problems, I need help.
- Will 90 LX cluster w/tach "plug n' play" into 90 DX? w/o tach
- EF CRX a/c fit into EF sedan?
- 75 shot alright for......
- How can you tell if it is an si tranny?
- Took her to the dyno....
- have coilovers.. need shocks..
- 91 JDM Cluster
- Sunroof In my 91 DX Hatch
- eg brake upgrades for 16" wheels...
- Mag Request: Urgent
- rear trailling arm problems...
- Neuspeed short shifter
- 5th gen Stock seats in a 4th gen?
- eibach springs....
- distrubor differences for crx/civic
- brake booster question.
- rear disc brakes question
- hood ??? what you think??? thanx guys
- 90-91 Acura steering wheel?
- Carfax please
- Question on Plug Wiring on d16y7 MPFI swap ?
- Help! Car will not go into reverse... (B16 w/ Y1 Tranny)
- Problems
- Todays Noob question Gsr springs fit ef?
- b16a in a crx wiring diagrams
- Si Cam in Dx Question: how much retarded or advanced if installed in stock dx position???
- bumper question???
- shock question?
- No speedo
- CRX seats into 90 STD HB.. how to fit them
- Quick question. Are EG springs the same length as EF springs?
- sold my 88si today, but i got a CBR for it!
- custom angel eyes... heres how!
- ZC wiring questions..
- Problems reving?
- EK sideskirts fit EF's?????
- cupholder.
- Ready to drive it off a cliff!!!!
- Touch Up Paint
- Koni Yellows install question
- Noisy injectors? valves? B16
- Fields, Apexi, or cheap ass RPM switch for mini me vtec control?
- quick questions about mini me
- Si head and intake mani swap on HF block.
- How Much For A B18B Swap???
- will an Exedy clutch hold any turbo setup
- crx si tranny with moded b16 questions
- Can I get away with this?
- Can I use the GC coilover Show Kit for daily driving?
- ------>>> NEED TOURQUE SPECS on main caps and connecting rods
- please help!!!!!!!!!!!!!!!!!
- D15 Build-up
- 88 rear LCAs
- D-Series Tranny interchangeability
- what is the best for the money?
- Help Remove 88 CRX Si Gauge Cluster
- Puddle of water inside my hatch today.
- si to vtec harness soldering
- quick question on replace rear hatch struts
- fast idle...
- 88' engine harness fit 89' si with b16 swap..
- how much should i sell ecu's?
- Who makes c.fiber hatch lids for EF Civics?
- tilt steering wheel
- tried to get an alignment yesterday, but they couldn't do it...
- HomeMADE Turbo Setup Pic by pic!!!
- **what axels?**
- noisy belt
- Does anybody have a part number for colder plugs for turbo?
- zc turbo vs b16 poll
- post your INTERCOOLER setup PICS
- crx wacky idle
