View Full Version : Honda CRX / EF Civic (1988 - 1991)
- SUPER rare spoon ef cluster....
- crx axles, all years from 88-91 swappable?
- can HF pistons be swapped out for Si pistons???
- 95 ZC swap... i searched, and found nada...
- Knuckle/Brake Question
- What you love about your 4G hatch!
- Toronto
- I finally got it out!
- b18c5 18c1 or h22a
- D-Series Swap Woes...
- stripped CRX
- pass side mirror
- Zdyne ecu for sale
- Questions on mounting Optima/Moroso battery box in 2g CRX
- Help!!! Bumper removal - w/pic
- pray for me....
- how long will my motor last with N20?
- How much power can a Hondamatic transmission take?
- Alternator Problem...please help!
- HOw do I tell if my ecu is shot?
- Power windows in the Rex anyone have them and what do they think of them
- help!!!
- you spend my next 1500 dollars
- Just gave my baby a bath...
- AVO Sport Evolution is crap???
- which pulley mark do you time to .....
- car won't start after a good bleeching...............
- Amber gauges / heater controls / etc. ??
- doing a zc swap
- zc engine or d16z6
- Just curious..
- raene, or anyone else, please answer (or try to)
- help, gsr fuel pump install on EF??
- Please!!!! I need help, my car won't start
- I finally got the Rex started!!
- painted calipers
- Swap help
- crx and hatch goodies
- d16z6 Compression....
- Oil light? comes on
- any preference clutchnet or ACT?
- best tranny for a d16y8
- afordable cam gears for B16
- front brake upgrades
- DRAG RACING IN NY fri may 31st
- b16 auto swap
- Which Civic Forum for my 86 Civic Wagon?
- Parts for 89 crx hf and B16
- Alright i still need help, newest update with pictures of everything.
- sedan ppl: hatch bars work in sedans?
- Timing Belt help on B16
- Question about front brake upgrade on 89 CRX Si (Type R big brakes)?
- Testpipe.com
- h22 civic
- seats for 4dr with auto-belts
- 91 civic si with stock motor, can i use an ecu from a DOHC integra to riase my redline
- 1st gen/2nd gen parts interchangable?
- Installing turbo timer help!! ?
- trunk sensor light?
- Seat sliders for aftermarket seats? (search sucks!!)
- has anyone done compression checks on ZC's?
- What type of Turbo do you have?
- vtec head on a d16a6
- ZC redline....
- Ls/Vtec SI vs. B16CRX SI
- 91 DX hatch, TACH Calibration help??!
- Can't figure out how to remove hatch struts...
- Dual exhaust a 4 cylinder??
- JDM 4-1 Header Clearence?
- awesome kill!!! jsut have to share w/ fellow 4th gen hybriders, mods can move if u want...
- Timing Belt Shifting
- CRX engine swaps??
- Who is using rewelded mounts in an 88-91? Axle issues?
- Hey i need your guys opinion..
- Quick Question ??
- Please diagnose
- will my old distributor work?
- Anybody have a list of...
- Where did US ZC motor come from?
- Can you get full amber corners for CRX's
- Tell me if this setup will run!!
- Sleeper Make-Over!! Need Help!!
- Help me PLEASE!!!
- swapping a sunroof?
- found a crx
- HELP need info no converting cable to hydra tranny
- Vision corner markers???
- Does D16A6 have a vacum operated Fuel Pressure Regulator for use with ZEX?
- Rust!!!!!!
- Away from board for a while..........
- front fenders
- Quick Help! Please
- Paint question in pittsburgh
- brake swap for front 90 hf
- Damn.. Im becoming a post whore!
- The before pics!
- CRX wont go
- ingalls kit w/87-89 integra arms
- headlight conversion??
- anyone know of any nopi discounts
- gsr/ef clearances
- code 17 engine speed sensor :(
- d16a engine swap for 150.... come pick it up im in dfw..
- Need some questions answered ASAFP!
- Help HELP help HELP b16a swap is in, but its not running correctly. need response quickly....
- how much did u spend on your DC jdm 4 into 1 header
- clear corner conversion
- What do you guys think about Kumho tires?
- Battery Problem
- exhaust leak
- Weve seen b16 times....what about ZC's??
- How much for the Y1 cable Quaife tranny?
- Open downpipe
- whats a d16y8 head worth?
- pics of my homemade FG hood
- Painted Bumpers
- 88dx to D16z76 throttle cable
- Need help with d15b2 to d15b7 swap
- JDM cluster installed... problems.....
- can you complain against a insurance repair??
- are D16 and D15 rods the same length??
- ever feel like your car hates you?
- How much for a CRX Si gauge cluster?
- Changed my headlight housing today
- Hatchback, Sedan, and CRX Taillights
- ZC swap ?'s
- CRX exhausts
- high water temp problem (long)
- what is needed for a b16 to fit in a 90 civic hatch?
- I need everyones OPION!
- How much N20 can a D16a6 block and d16z6 head take???
- I know I know BUt tell me what you think I will run!
- Some Ideas......
- hf to si swap
- roll cage in CRX for drag racing?
- crx si seats in civic
- how can i check if my main relay is bad ?
- Does any have pics...???
- 88-91 springs??
- So, my CRX was on its last leg.......
- B18C1 tranny?
- Please help!
- b16a with gsr ex. and type r intake cam
- Y8 intake manifold to d16a6. does it work?
- Strange idle, HELP!
- CRX Engines
- shift points??
- DPFI to MPFI distributor wire question.
- Anyone know how to rebuild a starter?
- WTF???
- how much for HX wheels?
- I need some help!!!!
- fuel guage problem.
- JDM Cluster For sale!!
- overheating..
- Radius Rod damage...tell me if this makes sense to you.
- What Parts for MPFI Swap?
- D16Z6 motor swap...engine won't rev past 3250rpm
- My crx is throwing a code 6 what is it?
- What Is Done To Your CRX!!?? (No BS)
- 98 ITR adj springs on 88 CRX?
- I need some serious help!!!!!!!!!!!!!
- CRX with JDM CTR Engine
- I need a bumper.
- What cv boots for SiR axles?
- It wont come out!!!!!!!
- Fuel guzzling 89 CRX Si
- tranny mount question
- Have a question that needs to be answered quickly...
- ZC-no spark
- B16 wiring bad, trying to fix errors - what are these wires for?
- speed sensor ?
- Installed an AEM cold air yesteday :)
- Has anyone here had their mini-me tuned on a dyno?
- 90-91 fenders....
- who makes mounts for H22??
- Removing parts need help!
- How much b20 Vtec gonna cost me?
- Help with fuse blowing after B16 swap.
- I need a Crx!!! Is ANYONE selling one???
- jdm style CF hood for usdm front
- Please help with headlight question
- new to this forum
- H22 in CRX do-able?
- rough idle?
- Built B20 Frankenstein + Gen2 Civic = ULTIMATE SLEEPER!
- hf hub/spindle for b16 other than si.
- How in the hell do i post pics
- Good ZC bolt on mod site?
- front bumper cover removal (4g hatch)
- Can you remove pass. Headlight without taking off bumper??
- what color is my car??? name??
- Engine is in the car... first pics!
- Pics of my Under Construction Rex
- just bought a 4th gen hatch...
- My turbo came in today
- whats the normal price on installing a kit without painting?
- is the WW RS kit direct bolt on or does it require molding/shaving??
- Bought a CRX lastnight!!
- rear brakes???
- ANOTHER Mini-Me question
- Just got a Digi cam...my ZC turbo pics.....
- Just some more recent pics of the S2K and CRX!
- electrical system diagnosis? how to?
- Clutch Cable Problem
- Anyone know what a SI Cluster and CRX rear discs should go for?
- Is this a reasonable price for a crx?
- What plugs do i use for the JDM Cluster ??
- I miss my EF :(
- anyone have integra mirrors on their crx?
- Need help on power
- Will a 90-91 Civic Si cluster work on my 90 "Auto" DX?
- Passing Emissions Testing
- Dohc Nightmare (long)
- Any Ht Members from Fay NC
- for the one's who have laugh of me whit my crx/integra
- ls/vtec time???
- Can I use a z6 manifold with an mpfi swap?
- Blown KYB AGX shocks
- ht member spotted
- Plug gaps for the ZC
- v-afc in crx
- WTF? Engine wont align properly w/ HCP kit. Need help!
- does any have pics of mugen mr5's on an ef?
- does anyone have a spec sheet for stock ZC's
- JDM S1 Tranny
- Si front lip on a DX
- desktop dyno2000 help
- Need pics of exhaust
- NJ/PA H-T Members
- DC header on b16
- Can anyone help post pictures of CRXs w/ Neuspeed/H&R Race springs?
- Legality of B16 in California
- The faded trim aling the bottom of the crx
- Cheapest Carbon Fiber Hoods!!!!!
- which crx is it?..dumb question
- Need an 89-91 Si Tranny.... (nor. cal. if possible)
- where to find turbo for zc
- what thermostat?
- New Paint Pics (lots 'o pics)
- xenon and matrix headlight bulbs
- Which camber kit
- estimate on tranny and clutch work?
- trans
- H22 in CRX
- exospeedAMCRX
- cooling problems
- Help on a shop
- Rear struts on hatch.
- For your information!
