- dash vin removal and install
- severe shutter!!!!!!!
- B and D series transmission bolts same?
- Gauges??
- h&r race springs on our ef's
- b16 redline at 7200?warm up issue
- Paint ??
- DA A/C for EF!!!
- jhammond_82's slow build thread
- how to get paperwork for a salvaged motor?
- ZC/Jdm motors in IL
- What clusters will fit
- Replace Fuel Pump
- Dohc Zc
- 90 civic EX with b18a1, Power steering?
- EE Wagon.
- radiator swap what to use???
- Cheap homemade build???
- b16 wont start
- Zc ?
- how would i go about puttin a turbo on a honda CRX SiR (Vtec) 1991
- Accord Euro R
- CRX OEM foglight questions
- Gude?
- Rear Brake Help!
- Anyone had seatbelts replaced under lifetime warranty?
- 7 led flashes on ecu
- D16a6 valve seals.
- j1 tranny
- dohc zc engine questions.
- bulb shockets with jdm bumper lights
- PG7 for MPFI swap?
- b18a1 wont rev past 4k on pr4
- Has anyone used the Autotaser to keep their EF safe?
- The Ef Blockoff Thread
- axle question
- d16y8 swap trouble
- 235 60 14 drag radials fit ok?
- mpfi swap
- 91 Dx hatch with ZC swap Smoking after Warmup
- Reverse light issues.
- windshield removal-89 rex, HELP!!!
- will dc4 interior and a da front lip go on my sedan?
- Blower motor problems
- Failed Smog Test Once Again
- blinker side marker blinker light
- Fuel problem or engine problem?
- Need help. 91 civic si w/ jdm b16 swap
- FAQ Manifesto
- HKS or RS-R exhaust
- identify my exhaust
- jdm p30 ecu, chipped but still hits speed limiter.
- need help, something is wrong with my hatch
- Need help with this Crx HF please.
- Pulls a little to one side when i.......... help plz
- front end rattling
- Speedometer doesn't work.
- Please help me out i wanna redline too!!!!!!!!!!!!
- Rare JDM siR CRX rear seats?
- how to take of under drive pulley for jdm b16a
- wtb: ef clock block off
- Need help
- need help on removing broken bolts
- MC/Prop Value
- Power mirror and power window swap on a wagon?
- Car will not start??????
- check out my $100 car!!!
- 91 hatch issue
- in your honest opinion...
- jdm power folding mirrors
- Help my fuel cuts out!
- d15b2 alt on a d16z6
- Effects of Performance Radiator Caps?
- Looking for Civic Wagon Pro's...Simple suspension q's...
- What ECU to replace Zdyne? B20B boosted
- twin 40 webber carbs
- lowering?
- h22a in ef hatchback
- B16A1 VTEC rpm-signal in a 1988 Sedan? How to realize?
- power window motor
- DA Auto Seat Belt Question
- mpfi swap question
- Fuel Cuts OuT??? why???
- how to put a passenger side mirror onto a stock 91 civic hatch
- Turn signal don't work
- full-race radiator upper hose help
- Need an new Driver seat.
- K20A3 swap
- Side draft idle problems
- need helps guys.....
- what code is it?!
- hx wheels fit ef?
- What engine could fit a 1987 honda civic crx 1.3L?
- Innovative D series motor mount replacement issues
- rich and possibly flooding?
- Smog Test CRX Si w/B16 Fails
- New block for 1.6 SOHC ZC
- EG coilovers on EF!
- crx dash into a hatchback
- what ECU code is 19?
- Need some help please.
- have problems with engine codes and car overheating
- Crx poor starting
- EG Civic And Wagovan
- Price now for a K20 or K24 swap now?
- how to check the check engine light??
- 88 civic dx just changed head gasket help!!!!
- #4 injector will not fire please help!!!!
- what it takes to push a piston
- dizzy question!!
- Overheating problem
- b16 pistons in a b18?
- radio and heater help.
- Coolant problem.
- door problem! bugging me.
- B20 Help!
- 89 HF or DX?
- couple interior questions.
- camber adjust
- Rear discs!
- Jdm Front Q?
- car heating up?
- crx o2 sensor
- still Newb (kinda new member post)
- 91 hatch having trouble staying alive. Help.
- Need some transmission info!
- starting problem W/ DPFI
- (Quick Help)-extended studs-from 90-91 si
- B18 throttle body on DOHC ZC?
- 90 crx starter problems
- Vacuum hose kits ? Where to buy ?
- ed3 startup to build up
- usdm 89 2 bulb headlight to ef9 1 bulb help
- Starting problems
- help with bumper and fender
- having problems with my 3" thermal exhaust
- How do i take it off the shifter ??
- Few ?'s on my newly purchased swaped ef.
- Tuning ?'s
- Installing Aftermarket Tachometer
- starting problems
- Cruise Control on LS
- wire tuck, need wire
- Proportioning valve rear discs
- No compression...
- Bswap into 90hatch ?
- NEED help- front strut bar
- help with timing belt...
- what is wrong with my car?
- Si Seats Recline Problem
- B16 A/C Bracket
- what valves i need help!!!!
- side draft question
- 90 crx taillight in 91 civic hatchback
- Wrecked the crx:( need some info on my motor
- obd2 b18c1 in 1990 honda crx si
- B16 Drivers Side Oil Leak
- Axle too short???
- Valve stem seals. D15B1/2 --> D16Z6???
- mugen seats prob ??? what seat rails ????
- 90 rex to mpi obd1?
- ZC problems!!!!!
- CRX Headrest
- awd civic
- timing belt off a tooth?
- Map sensor?
- Have a quick question
- i have searched and searched and searched
- sir front end conversion on crx
- loose timing belt.
- couple questions about efs, mainly double checking
- pics of black hatchbacks...
- crank pulley bolt
- carbon headlight intake for ef
- dc2 rears for ef hatch
- 1991 DX CEL, not sure what to make of this....
- ZC swap problems
- Skunk2 rear control arms
- AWD 6spd trans on mini me?
- d15b1 mini-me?
- 0BD0 B16 Computer
- Quick question regarding B-series swap and header
- Two Easy Ones - Alternator Belt Tension, and Distributor Rotor Replacement - HELP!
- timing belt cover trouble
- fuel line identification help needed
- What axles needed for a zc swap?
- CRX Starting Problems - again
- EF9 SiR Rear Bumper Questions?
- Car Wont Fire Over
- turn signal woes
- crx b16a idle issue????
- I need some help...
- Overflowing gas tank
- Radiator hose
- loss of power after driven for 10min
- Install tips: Lowering Springs Neuspeed for 89' CRX
- turbo d16a6
- Have a seat.
- How to remove and install EF Door Sills
- ef obd1 block and obd0 head?
- CRX because the deal is a total steal.
- B16B valve clearances
- Anyone try these traction bars?
- Can i get help identifying my block.
- Majestic honda/ Del sol DOHC engine wire harness CA emmissions bar for b16a
- map sensor
- Judge these headers?
- I got a mini me for my ef
- shifting to reverse..??
- Hydro to cable - Flywheel
- 89 civic si power door locks
- Type R Intake Manifold?
- jdm headlight install
- ZC Axles
- Trans not bolted to motor... and drove
- code 12 whats it mean
- how to remove gauge needles?
- d15b2 rocker arm torque specs
- someone identify this please!
- Wiring Trouble plz Help!!!
- 1991 Civic transmission seal leaks Help!!!!
- BAR question
- cooling fan problem...
- stolen EF Please help!!!!!!!!!!
- Sometimes my CRX won't stay cranked.
- code help?
- b series mounts
- Shifter help
- CRX wheel alignment?
- b16 swap cost
- manual transmission stuck in gear need help
- B20 Build....questions
- Fat Fives - What Tire Size?
- C-Pillar bar for CRX
- where do i get?
- D15B7 with D15B2 intake manifold
- Crazy shaking at partial throttle only - What could it be? (91crxhf)
- Code 9 or 4 WHA???
- Are 89 civic spindle/hub/knuckle assembly the same as 90?
- TPS Sensor
- Rear mud flaps?
- GSR in my CRX; help w/ Motor Mounts
- 88-89 vs 90-91 CRX bumpers
- mpfi confusion
- REAR disc problem
- #2 cylinder not firing...
- 91 CRX b18 swap tire wear help
- Radiator fan won't turn on
- 1990 civic cx hatch died while doin 70 k
- Quick Question
