View Full Version : Honda CRX / EF Civic (1988 - 1991)
- CRX IdleE KILL !!!!!!!!!!!!!!!HELP!!!!!!!!!!
- Question about TEIN springs need help
- 90-91 rex si
- header maintenance
- jus wonderin...
- mugen bodykit or leave it oem??
- squeak!
- Deetz's crx rebirth -been parked for 7 years
- gsr cams in B16
- quick tranny question
- LS rebuild
- obd1 conversion - vss sensor
- im having trouble starting the car..help please
- Just had an alignment - whoah, am I screwed?
- typer cables
- Swap Questions..
- HOSES
- Spark but no fuel...woes on obd1 crx. please help...
- 91 si prelude rear disc fit a 91 civic si
- DIY: CRX SIR EF8 CLUSTER INSTALLATION???
- DC suspension
- should i gut my car?
- honda civic EG or ek side skirts on a crx ??
- 89 hatchback bumper filler
- Purge selenoid removal
- noobish questions. please help anyway
- Brake Gurus: HELP!!!!
- Gaging Interest: Hydraulic Transmission --> Cable D-Series Mounts
- gsr block
- 88.91 Civic Logo Needed - For New Floormats
- omni power
- just to confirm
- auto, manual cluster
- Are all d series oil pan gaskets
- funny idol issue and strange dash light blinkers
- 89 CRX brake/suspension swap
- 91 CIVIC OBD0 ECU PROBLEMS
- headlight options..
- Suspension diffs in 88 CRX Si ?
- wtf does this thing do?
- just curious????
- Vacuum line problem w/b16
- anyone interested in a 4 door ef?
- best d-series header....
- seat belt lights come on when brake pedal is pressed...
- where to get a twin pass radiator?
- TOKICO HP
- curiosity killed the cat. V6age.
- new header...whatdya think???
- 1985 Honda Civic 1.3L 5speed
- Fender plastic screw stripped
- chipped ecu
- I think I blew a turn signal bulb...not sure though.
- Vacuum Lines. What do they do?
- B16a Fuel Pump
- jdm b16.. oil cooler leaking coolant?
- head gasket help
- rear shock mount bolt
- Check Engine Light, 1990 Civic, Help!
- axle trouble :-(
- Front Bumper Support Help
- side moldings
- Redline at 3500 rpm!!!
- my ef build
- Part to my door is broken...fix it?
- zc ecu ....
- Side mirror compatiblity
- valves makin noise?????
- plugging dashpots
- d16a6 stage2 or d16z6
- GSR powerd EF.. BOGGING QUESTIONS!!!! help me!
- Fuel Injector Questions.
- 88-91 crx steering wheel splines differ ?
- throttle sticking
- eg and ef brake rotors
- 88-91 CRX door cap removal?
- HELPPP MEEEE
- WHAT BORE IS...?
- tread lockd?
- I DONT KNOW WHERE TO PUT IT IN!
- was this anyones old car?
- Seat pan swap--DA to EF
- Bull frog cams?
- about at the end of my rope....
- ac belt replacement in 89 sedan
- obd1 alternator and obd0 alternator pin outs needed
- cel #9
- wtf is this connector??
- my temp gauge going crazy!!!!
- 88-91 L3 trans
- my crx
- wont stop overheting
- 1990 CRX front end
- clutch cable snapped ???
- My Little White EF 4 door
- VTEC Not hitting
- quicky
- need a lil help with motors
- HONDA CRX SIR ON FORZA II!!!!!!
- Help plzz
- need opinion brake upgrade for 88 crx hf
- 91' civic DX hatch .. what to do and minor problems
- heeelllpppp tranny question
- Starter No Power???
- crx sir smog check for reg
- How much do you think my car is worth??
- need help asap
- Need diagram for 90-93 integra fuse box 5 spd.
- 87 honda crx si doesnt want to start
- turbo problem
- SPARK PLUGS
- spring swapping question
- got my axles heres my baby
- Clutch cable for B-Series Crx?
- radiator ???
- Hx Rims Drag Radials... What Size??
- JDM power folding mirrors
- motor help???????
- Get Rid Of Annoying Door Open Beeping??
- no fuel no spark
- 1989 ef honda civic OEM Lip
- obd0-obd1 conversion harness.
- Post obd1 conversion issues
- Ef D16Z2 Homocinetic joint
- 87 carb swap to d16y5
- dpfi to mpfi swap -[major problems]-
- power folding mirrors?
- rsx rear trailing on on civic 4door do they fit?
- Ksport coilovers, will they settle?
- CRX RADIO WIRE DIAGRAM?
- VHT Nite Shades Users
- EF hatch suspension install?
- trying to find a ws2 exhaust
- sohc vtec, need help!
- b18a1 crx swap help
- seats reupholstered??? where and how much
- civic 1990 ex
- CRX HF injector flow rating
- Overheating still?
- Stripped Timing Belt Tensioner -- HELP!!
- b16 knock sensor
- japanese crx brochure
- Spanner wrench for coilovers
- IT COULD HAPPEN TO ANY OF US... WE ARE NOT INVINCIBLE!!
- just put on my WS2.....
- im new
- Carbon Fiber Hood
- help with swap please
- cleaning up engine bay on 88 crx
- CRX SIR Spoiler, does the regular usdm wiper fit?
- i want to put a new motor in my crx but i have a question???? what about a b18b
- help wit pics
- zc to sohc help
- EF corner lights
- looking to buy a 90-91 lx 4dr sedan. sleeper project
- Hey wats up guys new here
- B18A Transmission Issues
- 90 crx turn signal plug question
- tein ss coilovers
- My Swap
- question about b16a obdo
- tps sensor?????maybe????
- tranny question
- help tranny
- 91 hatch starts but will not idle(PLEASE HELP)
- ITR 96 spec 4x114 lug pat on ef?
- 300 mile trip... clutch slipping?
- What's up I'm new
- CRX D16Z6 SWAP CONFUSION WITH HARNESS AND MANIFOLD
- blox cams?
- 82 civic
- Driveshafts
- Foreign Objects in Old Oil Pan. Car Seems Fine? HELP!!
- MY ENGINE IS HOT
- FS: CRX EF parts, Lips, Camber, GSR Rims
- 92 ls integra cable transmission clutch ?
- v tec engine swap
- how to mount corner lights
- Water Temp/ Battery Meter / Oil Pressure Guage Wiring?
- No VTEC Engagement?
- Shopping for camber kit, need opinions
- 90-93 DA cluster diagram help
- SOHC ZC A/C Bracket?
- Swap Question
- Seats For A 1st Gen Rex
- Anyone hear of Avanti wheels?
- 1990 civic dx work with a 91 crx dx
- im lookin for a ls 1.8
- Is this car done??? Code 20 ELD OBD-0
- Cluster Wiring??
- b16 head with gsr cams helppppppppppp
- 91 crx Si Clutch fit a z6/y8 tranny?
- for all the retards who actually think i kick my dog
- help
- map sensor gone bad????
- tail Lights Won't Turn off [wtf?]
- quick direct...
- Ne help Near south central PA
- switching ecu
- will the rims fit
- 91 crx auto to manual swap problems
- 88 hf. swap si. jumper not working for timing
- Daily driver 91 CRX auto... what to do?
- EF Problem
- ZC swap into CRX Si trouble
- d16z6 swap wont start need help!!!!
- DPFI->MPFI->OBD0->OBDI ...Tandem Control Valve?
- front rotors
- DA Crossmember/traction bar on a EF8 siR????
- so before i get pissed and kick my dog. Undredrive pulley?
- temp. fix for an injector o-ring tear?
- Knocking noise
- Infamous Roof Leak on 91' DX......Suggestions?
- h22a engine on crx-vtec?
- NEED HELP ASAP!! crack block symptoms... (hope not!!)
- obd1 conversion question
- Yet another overheating issue .
- Cluster Swap
- Weird Overheating Problem
- 91 honda crx tranny
- slow96coupe's Build thread :)
- what suspension is everyone runing on there drag EF
- Gas tank swap?
- Vaccum Lines
- desicions, desicions, desicions...
- iacv problem?
- Quick? wich tranny bracket for EF b-series hydro tranny
- my 91 hatch project
- crx & EF9 folding mirror?
- Safe driving with a Jdm b16a;. need advice
- Coolant hose vs Fuel line hose ?
- ??????INTAKE MANIFOLD???????
- DPFI to MPFI question regarding intake manifolds
- converting to obd1 ?'s
- Batery Light on, Car dies(Not the alternator)
- Civic SI tranny swap into 91 Dx/Std need Civic SI axles?
- how much is my car worth????
- I searched. D series hydro mounts?
- Need help, 89crx tail lights stay on when ignition is off
- how to convert OBD0 to OBD 1
- crx fender flairs?
- need help
- best clutch
- crx spoiler mounting
- 4speed to 5speed DX worth it?
- License Plate Bracket for non OEM Bumper
- Random Main relay click / ecu power seems to shut off
- automatic to 5 speed
- Need some advice here
- Messed up Big time
