View Full Version : Honda CRX / EF Civic (1988 - 1991)
- new to crx
- What steering part to buy to solve my problem?! Pic/Searched
- Piston to Deck Height for D16Z6 with PM6 Pistons...
- Timing Belt Question..
- switched ECU's and this happend**WHY?**
- D15 (seriously) motor debate
- HOW-TO: ignition switch wiring rebuild - radio shut off , turn off , click off
- ZC to B18c1? Any input.
- 1990 Std Hatch Part # Needed
- wiring help for b16a swap
- Is my vaccume correct?
- my question about EACV??
- my CRX...
- smog
- B16 w/ITR pistons...what would the compression be?
- Ls swap
- (MOD APPROVED) Someone selling Tein Basics?
- Chick question about a sqeaking issue...
- jdm itr cluster
- ZC Head
- really need help im pissed off!
- 90 CRX Si: B18A1; PR4 ECU; Red Blinking Light and cylinder 1 no fire
- Help stupid person locate the radiator fan plug
- New to Civic scene
- battery discharge while driving
- got an alignment... need help quick
- Black headlight housing
- H22 is it worth it?
- Finshed Crx Paint job.
- WHO WILL WIN..? EG CX w/ B18A1 Stage 1 Excedy Clutch or DC2 GSR w/ Bolt-ons
- si exhaust mani on a DX/STD
- question about si/hf crx differences
- anyone have or see these crx fenders up close?
- Bought a pair of rt-615's today.
- Need help here please
- looking for super charger for ZC motor in 91 HF
- waped all sensor into B16A1 Distro problem
- Jdm Crx Sir headlight cleaning?
- mount vibrations
- Cable Trans identification, please help
- help!!! ASAP, i need to get my hatch running (distributor)
- quick question...
- someone answer me quick....
- starter problems
- Restoring my CRX
- A few Carpeting Questions
- A/C Repair options
- HF trans/DX engine compatability
- B18c in CRX, need help!
- Greetings looking for engine advice
- fully built and i mean fully built!!
- Sloppy SHift Linkage
- Hairline Crack in plastic capped radiator.
- 1st time with my crx on the track
- OG Civic gets 10.1" brakes and 2 piston calipers.
- OEM Si Seats? Made by Recaro?
- this is so funny
- CRXers running Ground Control
- crx tranny help
- D16 tranny weight?
- Dam calm down people your buyin up all the EF's!!!
- Where to get headwork done on d16a6?
- Caliper options?
- CRX weight
- shock tower to shock tower distance
- RE: 1988-1991 JDM B16A Swap Going TURBO
- 88 Sedan fender on 91 hatch and tail light ?
- cost of nitrous
- HELP WITH LINKAGE ON B16
- 90-91 clutch on 92-95 flywheel?
- obd-o to obd-2 how to?
- EG carpet fit in EF?
- Cheap & quick CRX
- just had my first accident and....
- EF + B18 = hard??
- Any of you CRX or Hatch guys try these yet? Seat bracket question
- 8 valve VS 16 valve HELPPPP..
- how many of you are running all motor d series?
- restoring heat
- TPS
- Neon vs EG Rad
- chip with vafc
- pulleys, underdrive and oversized
- fuel pump
- Online Service / Repair Manual for 90 DX
- what the hell the right motor?
- Idle control & cutting out cat
- Video from my last Autocross
- clutch prob
- What is this? Stock HF motor.
- Wanted you guys to see this
- removing my ac system
- car over heating and idles funny
- lo
- How long do I have to be a Noob?
- Wacky SiR Gauges
- vtec issue on crx with y8 swap
- XRC SEAT BRACKETS QUESTION..
- Horrible Gas Mileage need help. *read* >190 on full tank.
- Anyone Got Torque Settings For A D15b2
- wiring diagram for fields vtec controller to pm6 ecu? help!!
- Need bumper help
- Perfect 99 GSR head for sale!!!!!!! also blown GSR bottom end for sale great for rebuild!
- My new project 88 dx....
- What else can I do while I'm replaceing oilpan/gasket?
- B16A
- CRX Questions
- CRX cluster in a 88 dx hatch and thermostat problem??
- couple questions
- d15 b7 cam
- D16Z6 CRX turbo question
- Clutch Question
- i need a si tranny
- Brake Problem, HELP!
- body kits?
- Will DC Sports 4-2-1 99-00 si header bolt up to my stock exhaust?
- Oil Cooler anyone?
- help needed
- RAN MY CRX AT RACE TRACK...
- frends vtec not kicking in?
- VTEC BUTTON!!!!!!
- Oil is blowing past my oil filter o-ring WTF
- is a delta wastegate
- DA knuckles provide +1 deg of camber correction? Any proof?
- new 4-1 jun header = OVER HEATING b16?
- holes in bumper
- D16y7 in 89 hatch, fans wont turn on ?? missing sensor?
- fuel pump problem HELP?
- Selling my SOHC ZC powered CRX!
- Looking for a previous post!
- d15b vtech with mpfi auto swap Q's
- Uberdata, Turbo edit
- alignment help!
- Quick ????
- help!!!!
- Chipping ECU
- b21a1
- needless to say i'm a little pissed (damage in parking lot)
- My am/fm radio plug is cut!
- D16a6 Dizzy work on a D15b2?
- What should I do with this crappy engine .... (pics)
- New Member! Need more POWER!
- Installing Rear Speakers on 91 DX?
- Anyone run the Buddy Club spec II exhaust?
- will a6 alternator work on ZC?
- WHAT BUMPER IS THIS? cleanest lookin ive ever seen!!
- Who here is running the EG rad? What kind of temps are you running?
- Strange Electrical Problems
- rattling
- how much coolant needed in the cooling system?
- MPFI/Z6 swap.....CEL code 8 help
- obd 1 conversion help
- crx problems
- sway bar bushing size??
- zc swap into 91 crx si
- What should I do to fix my frame?
- What shall I wear in court today?
- D-series headers...
- MY new Ef Project...
- what is this, and do i need it?
- My CRX project :) ***56k go get some lunch***
- Help with suspension...
- is the 88 crx fan shroud compatible with the 91 radiator?
- swap mount trouble
- crx turbo question
- easiest motor swap in a 88 crx
- Need help with how to read multimeter for TPS voltages.
- I need torque specs for rod bolts on a zc.
- ran my stock dx hatch finally friday!!!!
- '94 eg - SELL or TRADE FOR CRX !!!
- JDM FogLights on a USDM Front Bumper?
- 2007 concept crx
- jdm side moldings?
- Anyone with links for a 92-95 Civic online Helm manual??
- Need Tuning Help!!!
- crx hood question.
- Question about lowering b16 into engine bay
- OMG! I am so pissed.
- Front end clunking.. Is my wheel going to fall off?
- who would be interested in 8PT and 10PT rollcages ???? ROLLCAGE NHRA
- 91 B18B1 Question??
- Code 23, Knock Sensor?
- One Mirror?
- Newbie chick to crx
- anyone heard of/running hondata obd0...help please
- UKDM cluster problem / question
- antanna??
- distibutor not getting power
- CRX ITR
- Auto trans not upshifting after swap.
- B16a2 stud Kit????
- 3m Window Weld, kragen or pepboys dont have it
- clutch and tranny question
- fuel pump ?? dx & si ??
- Carbon fibre hood
- Anyone seen this CRX before?
- going to turbo my mini me
- hey guys im getting a rex turbo question
- black stuff coming out of my exhaust!
- Ebay body kit ( WW replica)
- invidia?
- Y8 obd1 mini me ??
- y8 intake manifold with obd0 injectors and sensors.
- fuel not pumping
- Anyone have B-quiet in their hatches?
- Pics of my prelude steering wheel on my CRX
- cargo cover doesn't fit on my 89 HF?
- 91 Integra cluster
- Help with MPFI...I have triple checked everything..........
- ZC distributor *LOOK**LOOK*
- ARGG still code 4
- header/crossmember clearance
- How Do I Put My Head Back On????
- Is my Crx setup any good? check it out
- Fuel Supply Problems...
- fat fives on a hatch???
- ?? What Wheels Are These ??
- What is with CRX Resource?
- Do Honda dealers still sell gaskets for CRX's?
- What tps sensors would be compatible with a DOHC ZC tps sensor?
- Wheres the MAP sensor on an OBD0 vehicle 89 CRX HF
- DOHN ZC power band lose. help??????????---------
- Help me question
- SKUNK 2 INTAKE STICKER
- Anybody have a Neuspeed frnt strut tower bar installed on a CRX or CIVIC?
- Wiring?
- missmatching tires, what do you think?
- Wiring diagram for OBD 0 to OBD 1 needed
- A/C
- too lazy to search
- Motor mount problem on b16
- Custom Turbo VS Drag Turbo kit. B16A
- Transmission gear interchange?, yes I did search!
- Faster And Safer
- B16A
- gettin ready for a swap!!!
- 85 crx interior
- wanted:ef sir parts
- looking for sheetmetal portion of power sunroof
- What intake manifold?? please help
- Engine Swap Problems.
- EF Squad stickers....
- FJO tach reading all messed up?
- B16 EF help
- question about brakes
- ==========> timing belt help!?!
- Hasport Hydro Tranny Mount on real EF9?
- Whats needed in putting my motor obd 0 in a obd 1 car
- what is error code 5?
- d15b2 valve lash specs?
