View Full Version : Honda CRX / EF Civic (1988 - 1991)
- b16 y1 tranny 5th gear swap
- Vtec controller & pm6
- Wings West body kit ? i have searched
- Possible trade
- b16a1 swap for 88-91 Civic/CRX in So Cal!!!
- tdc sensor?
- Crx Toronto crew.(pics)
- Ignition timing Q's on 89 Civic hatch SOHC 16valve.
- codes???
- ac compressor ?
- auto B16 hp?
- 1989-91 civic hatchback wingwest kitt
- 88 Civic Offset?
- need help on finding amber corners for 90/91 ef
- 2 resonators worth it???
- 1st gen SIR B16A ECU. PR3
- Problems that need answers....
- Mini me, Worries me!
- help: fuel gauge
- Questions about Mugen chips...
- For those who own an EK
- quick question about a6 cams into D15
- wont rev
- computer help!!
- 89 DX 4dr fuel pump doesent always go on?
- cable/hydro b-series clutches different?
- My new VISION DC mirrors! PICS!
- jdm fenders
- Removing cable speedo drive
- MSD external coil conversion
- WTB 88+ CRX SoCal
- mini_me
- Want a faster engine, but still want air conditioning.
- 88 Gauge Cluster
- how much HP on th D1.6 zc sohc motor ?
- edelbrock coilovers
- Problem with ceremic brakes.
- WTF is wrong with my hood....
- JDM Front End Question
- codes problems after mpfi
- momo seats on crx. what will i need to bolt them up
- what type of exhuast on ls/vteck 2 1/4 or 2 1/2 inches?
- anyone?
- Conversion question
- '88 Civic hatch high/waving idle problem once warmed up...
- TX Inspection - Problem never heard of. Need help!
- Crank Pulley Bolt What Size socket?
- hesitation/miss/something. Please help me!!
- crank pulley?
- CRX problem
- Axels
- d16z6 im
- jdm b15b wiring questions
- need some half shaft advice
- best year for a crx
- distibutor ?
- Help Anybody know the Fuse diagram for a 90 civic si
- Mount question?
- What motor was in the 1991 SI?
- Octane questions for a 90 Civic Si
- ls swap
- New Suspension-$800.00 to spend-what to get?
- Spoon VTEC controller-info, uses, compatability?
- will this work?
- fog light wiring
- b16 wiring diagram neeed!!!!!
- Which belt should i use?
- Difference between Y8 and Z6 crank pulleys? searched...
- need help with v-tec not working!!!!
- VIN NUMBER
- Electric oil pressure guage
- E-brake cable woes!!
- Check out my 89 civic hatch Project let me know what you think ?
- please help, need crx/civic wire harness
- turbo hach
- timing gears will it work?
- changing rear wheel cylinders
- starter question??
- balljoint prob
- 90 civic starting problem...help
- What do you guys think? Should I get a beater eg hatch?
- b20 or h22 in crx?
- crank shaft pulley bolt , which way does it loosen??
- Paint?
- Anyone running the real CRX jdm climate control?
- Hood Doesnt close right???
- Just got shocks need help.
- WANNA GO FASTER!!!!!!
- 89 civic hatch Q!!
- my car is pissin me off wont rev at all no throttle response
- f/s 90 hatch
- b16-T, or b18C-T
- Opinions on these bronze wheels?
- CEL blinking but no codes?
- Obd0-obd1: Wont start.
- What color should i paint my rex?
- Installing Fog Lights
- Is there a eay i can run 0bd1&2 engines with my obdo vtec harness?
- attention all 4DR fanatics
- What happens when...
- 89 Si Hatch Stalls
- Ignition switch, 89 work on a 90?
- I need help from someone with a DPFI car (or knowledgeable)
- crappy a/c unit dicinagrating
- wiring diagram help
- CRX motor swap....
- Car keeps dying thought it was Main Relay.....
- Damn CRX won't start....
- 16"s VS. 15"s on a CRX....
- suspension or frame is bent,help me...
- timing techniques
- what color should i paint my rex
- droping a type-r
- wanting to drop a type-r engine in my 97 civic
- hasport b16 wiring question?
- b16a1 with a b16a2 intake
- problem with turn signals help!!!!
- invidia catback good or bad?
- idle problems with my b16
- anyone with ZC..
- MY new 89 civic hatch project that i have been working on , tell me what you think ?
- Mysterious car problem, nothing works!!! EXPERTS!!!
- cool
- She is almost done i cant wait ! , what do you think ?
- gas tank
- Wings West front bumper lights
- b16a1 to b18a1. Is it worth it?
- Windhshield Wiper Fuse keeps blowing...
- My car won't start, ground problem. please help.
- Quickie
- help! it dosn't stop cutting off!
- Stock 95 Ls Red line
- Stripping
- Freakin !@#$!@#$ Why does it have to be so difficult?
- 90-93 integra front lca's shorter or longer?
- True or false?
- b16a boosted
- JDM D-series intake manifold install
- any nova/md ef/crx people??
- mini me swap .............confused
- what et should i expect?
- does the ED9 chassis exsist in america? or is it just europe?
- links for h22 swap into CRX?
- ZC leaking oil.....whats seals are there?
- HP/Tourque Q's
- 94-01 teg center console in an EF?
- were is the Extra Fat from??
- what is the difference between the Dx 1.5 and the Si 1.5 from a CRX
- crx-b18c1 itb?
- ****** 88-91 CRX Exhaust Pics.... searched, looked at archives, still unchosen
- DRIVE PULLEY HELP NEEDED
- j-spec autos
- K20 swap wtf?
- b17 worth 800?
- car problem..
- suspension problem..
- d15
- carbon fiber door sills
- b16a2 and tranny
- Tell me what you think...
- rev limteder moves?
- Camber kit to reduce front - camber?
- Where canI get a si lip for my 91 hatch?
- Manifold
- plz help on SOHC Vtec onto a D16a
- Questions about Knock Sensor and 2nd O2 Sensor/bung
- b20 or h22
- h22 or B16???
- $$$honda$$$ weres my green
- oil pressure (or complete lack of...)
- will a crx hood fit on a 4dr civic?
- 89 CRX Si - Car wont run. no fuel and fuel pump doesnt turn on.
- entire gauge cluster just stopped working
- Right gaskets for mini me?
- CRX Problems Doesn't Start NEED Advice
- CRX Newbie
- "si style guages"
- Smogging Crx's!!!!
- 92-95 civic SI Brakes & Suspension on a 91 CRX HF
- More things learned - B18C1 Project
- 92-95 DX head on a6 block?
- pls help in swap
- d16a1 swap help
- O2 Sensor Problem...
- my crx wont rev it barely idles any clues?
- Free Turbo
- swap info needed please !! crx si- ls
- Check this bad ass civic out... anyone want a sound machine?
- HELP!! crx w/ zc problems (maybe timing related)
- engine swap
- flywheel and rpm switch question
- ZC
- Used ecu
- 1987 HONDA CRX (Bad Boy) Just bought.
- I think my speedo cable fell apart.
- This sucks
- ......help..... how to replace speedo cable ?
- MB racing rear bumper
- Sleeper ?'s
- Searched...but nothing....88 CRX motor swap???
- SPC Performance questions:
- Im stumped
- Problem with my hatch
- door hinges
- SHould i buy this car for 3900?? and swap parts with mine????
- Which vtec controller for mini-me
- fuel rail leaking help
- vtec engage
- Stainless Steel Brake Lines
- 91 h/b b16a Tokico Illumina
- Black Box on Throttle Body (1.5L)
- crx/acura motor suggestions
- SIR Guage Cluster in 89 Crx DX
- exhaust piping size question ?
- My Trusty Tach (Seach Found No Answer)
- gsr gauge cluster in 91 crx
- Relocating factory mounts for B series: anybody done it?
- QUESTION ABOUT JDM BUMPER SIGNALS
- Painted mirrors, pics.
- Has any one hear of or have this nitrous kit
- EF armrest question, CRX vs Civic
- DX I/H/E 1/4
- Huge loss of power
- remove fitv???
- Swaps almost done need some help
- b18c-r swap into crx...shopping list?
- crx b16 b18c5 swap question?
- «« AH! Please help! Auto tranny will NOT reverse! :p »»
- How to know the number of splines for CV joint of 90 civic LX
- what problem will i have if i do a H22 swap in a crx
- OEM part question for '89 CRX HF
- what is the best motor to build up?
- Poor Baby
- d15b oil eater
- injectors
- crx with civic si gauges?
- RE:
- itr crank pulley on a b16a1 ?
- oem fenders
- Code 22 - Vtec Oil Pressure - Still engaging VTEC
- speedo cable question???????????
- Fluidampr clearance
- honda HX wheels pricing
- KYB AGX's pros/cons??
- removing back hatch tintss!
- "crx b16" vs "crx b18c5"
- 89 hatchback dx
- wire a relay for my fan switch
- how much for back middle piece for 88' EF?
- Which center caps on HX wheels?
