View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Can I lower my '85 REX with coil overs????
- Misfiring problem...
- '88 Civic HB Rally Car?
- Aftermarket Steering wheel...
- 88-91 civic dx eperts needed...
- 89 parts
- can a 89 integra ecu be put in a 90 Civic
- 40 MPH in 4th, odd sound?!
- Need an idea what do build.
- Anyone put 99-00 Si seats in 90-91 civic??
- Squeaky Clutch???
- Gauge needle
- what OBD is a 1gen b16a
- Center Caps for Kosei
- sorry dudes, need some ZC wiring help RFN!!!
- need help! my Trunk wont stay up when i open it! please
- Authentic JDM body kits for Civic hatch ?
- Suspension
- what should I do with my marker lights
- Zdyne questions before sending.......
- Engine code help
- team prototype?
- Anybody know where to Locate these hard to find parts???
- How much could I get out off my crx rear interior?
- which door panels??
- just got my nos....
- any news................
- anyone in fl .....wiring dx to si
- K2 vs philips 6000k HID
- My car doesn't look lowered! 1989 Hatch
- Wheel balanced perfect?
- bumper support/ bumper questions
- help me please!!!!!!
- Resetting stock d16a6 ecu?
- saw some raybrig bulbs.. interested
- Anyone looking for a 90 Si center console?
- Will Y8 intake manifold (AT) work with Pm6 ecu????????
- Advice on installing coilovers...
- opinions on aftermarket pulleys?!
- whats a stock crx usually run?
- 88-89 bumper, same as 90-91?
- does anyone rember the kink with the rear aftermarket lower control arms?
- ¿ I'm annoyed with my Suspension setup! Opinions please ?
- just for hoods....
- vortech super charger on b16a in 91 crx?
- anyone have any pics of offset exhaust?
- need some ideas here....
- check out this strut bar..anyone seen something like this before??
- 90-91 CRX clear corners that fit? Where? What?
- 91 si rear hub and 91 teg rear hub, are they the same?
- Ok, smog ref stories
- What's the best way to hit 14's?
- advise please
- Any sites selling motors??
- zc on zex..
- D16A6 and ZC stuff
- dpfi to mpfi done but idles funny????!!!HELP!!!
- Which quiet muffler
- Side Marker Placement
- who on here used to sell the tranny rebuilding kits?
- Jacking points?
- Who has had their car repainted?
- 90-93 Teg cluster in 88-91 crx
- Does the 1st gen B16A (pre-OBD) have a knock sensor?
- WHO has the Most BOOST on A SOHC(d) motor
- Air/Fuel Ratio Gauge in crx???????
- 90-93 GS-R gauge cluster
- wheres a good place to get a stock si engine?
- JDM CRX stock motor mounts???
- need to know what pistons to order.
- Black Si interior...
- question on distributors... non obd vs obd..
- would this tire size rub on my car- 205/50/15
- New mod: Amber gauge cluster...
- Your Advice NEEDED!! B16a1 Turbo
- air ride
- Question about aggressive cams?
- passing state inspection
- just another d motor pic:
- swap prices
- Got myself a CRX (new to this forum) *pics*
- valves, valve springs + retainers
- MUGEN intake for sale
- Need swap info for D16Z6 into 91 CRX HF
- Do not look in this thread.
- 94 tegra console
- please take my teal turd si
- Crap, I just realized my CEL doesn't light up when I start the car! Could you give me some advice?
- Code check???
- Will these JDM headlights fit my CRX? *pics*
- 89 integra intake manifold fit on 90 civic
- JDM bumpers?
- girlfriend got in wreck today,,,,,,,,
- roof problems
- ZC Cranks but I get nothing...
- ? about 89-91 crx si
- muffler silencers?!?!
- B20 question
- Car still overheating......after T-stat change, and fan still works
- Blue Anodized Paint for CAI ?
- Needed Today ASAP!!!
- 91 civic si tach is bouncing!!
- b16?
- how much different?4 to 5 speed trans?
- clutch cable doesnt reach on b16 swap...
- anyone in ATL wanna donate a fuel pump?
- People With Fender lining and 205's
- question about 96-00 hatchback
- Need help with my CRX cluster!! please
- whoo, i might own another 4g, need advice...
- Message for Admins....
- some ?"s on a PM6 ECU on a HF motor?
- How do i take out pins !!!???? dpfi to mpfi!!!
- D16A1 Turbo Project Part:1
- h22 1 gen crx?
- *HELP* battery light fading in + strange electrical problem
- can i use a lightend crank pulley of a ls/gsr on my 1st gen B16??
- I need a header for my ZC, New OBX or used DC, 4-1 or 4-2-1 HELP
- Need help fast...opinions on this muffler...
- Dyno - Near Delaware????
- Leaking tails!!! (did a search)
- Which power lock to buy
- b16a1 thermostat
- fuel system compatibility
- will 90 crx si brake rotors fit on the 89 crx si?????
- Got my tranny re-build kit!!
- Z-10 equipped
- My car died this morning!! HELP!!!!
- what exactly do i have to do to my axles to make them fit? 90 si b16 swap integra axles
- which clutch?
- Cleaning Fuel Injectors
- just got 92 integra front brakes have some ??????
- Throwing codes 7 and 9.. what to do?
- How to tell what engine I've got
- oem clutch............nessesary to break in clutch?
- How much is this worth???
- *911* D Series Swap Help!!
- Should I?!?!?!?
- which cylinder to put da 2 02 sensor???
- DC/EG race coilover susp into an EF???
- Who in here has a head package for a SOHC?
- Long story for a quick question...
- Do aftermarket plug wires make a difference??
- Would a 92-00 ex civic DC Header fit for a ZC engine in a CRX
- turning sounds harsh
- how will my std handle with a b18a
- 96-00 civic hatchback drakgray interior
- Check it out Turbo Project Mini-Me #2 (DSM TD05h Turbo)
- Turbo for my LS powered hatchback
- b18a hybrid question ~
- swap help please !
- b16a overheating?
- Throttle sticks and goes wide open..
- FS EK custom eshaust!
- fuel pump relay
- jdm armrest!
- Anyone running H&R Race Springs?
- car starts and dies real quick
- Fitting 89 integra ecu in to 89 si box
- 1st gen CRX with B16
- RESCHEDULE!!! End of Summer Bash Sept 28
- 1 peice tenzo-r in crx...
- Need Help!!!..86 Civic Crx
- Snickety 5 Speed
- New updated pics of my car - new setup
- does any one know where to get the cyber knock off wing?
- 92 civic si gearbox(any suggestions)
- someone please explain
- What tails look better: 88-89 or 90-91?
- KYB GR2's + Ground Controls?
- third gear grind...
- Dyno'd the 2.0 (still needs tunning)
- Any reason to add an MSD ignition, cap and blaster coil to an all motor B16?
- Info that i know will help all of us!
- rpm gauge sticks
- Wooohoooo...Just got a full D16Z6 swap!!!
- springs vs coilovers
- d series Headers all the same??
- pics of my 97 gsr cluster in 90 crx!
- ARGHHH!!! Broke the TPS during the ZC swap :(
- how do i know what axle goes on which side??
- Windshield question?
- Will 93 Del Sol Si rims fit 86 CRX HF?
- Who has the white 4dr w/bronze subzeros in SB?
- what are good rods and pistons for a b16a, going all motor
- Hmm...B16 has TWO O2 sensors, but my DC 4-2-1 only has a spot for one???
- 91 std too slow...
- What clutch for zc tranny?
- My Adventure in Wiring (Lots o' Pics)
- Generic Mugen Front Strut Bar
- need help quick: crower valve lash settings??
- Clutch Adjusting Question 90 CRX Si
- B18B/A guys. Question about timming.
- car starts and then dies quick
- Quick question about a d16z6 swap.
- have to sell my Crx. :(
- JRSC fitment in CRX SiR engine bay
- 91 seats dont fit 89 Si... need help..
- anyone using a spoon program in a PR3 or PW0????
- obd0 hatch to obd1 jdm b16a motor....
- mini me + NOS???
- clutch question
- Wings West Body-Kit
- Lets go Karting!! Vegas/Cali/Ariz folk?
- CRX making some funny noise..
- need springs?
- Best Honda rims for drag racing?
- a/c 911! wat do i do with the wires n cables since i took my a/c off?
- acceleration question?
- a/c for 91 civic in va/dc/md
- 90 JDM lights???
- ZC head on si block
- Got on the dyno today
- will itr rods and pistons fit in a b16a (cable)
- Dual SideDraft Intake Manifold for a ZC DOHC..ZC
- timing a b16......
- 1stGEN crx, rear shock problem HELP!!!! PLEASE!!!
- ZC Motor is going in!! Need quick tips!!
- Does a silencer affect torque or HP?
- Question about gutted CRX.
- my ecu light is going crazy
- b20 in a crx qs?
- 4g meet in san diego
- what wire is the fuel wire on the guage cluster plug??
- JDM S1 tranny + ACT Stage 3 Clutch = HELP???????
- roll call for owings mills meet!
- URGENT help plz, almost done w/ my b16 swap, what header?
- need ecu help
- zc dohc help please!
- Camber kit help
- help my friends CRX
- Could you tell me how to locate the manufacture date on my B16?
- b16 shift linkage
- Anyone need help installing indiglo's in a civic?
- which clutch for b16???
- Engine codes.
- Stud torque spec, which bolt, and Beam Torque wrench?
- Overheating!
- b16 troubles
- HELP! Boosted B16 running lean?
- besides place & z10, who was making xmembers for us?
- Drop forks
- anybody got any 02 sensors for sale for a 90 DX?
- JDM folding power mirrors
- 94 GSR dash into a civic/crx
- B16a distributor rebuild???
- Can exhaust go out the right side on a CRX?
- D16A6 Forged Componets
- it has begun!
- will vtec engage with a bad tps?
