View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Mounts issues! Just finished b16a OBD1 & cable YS1 into 90 crx dx.
- Cut and Welding Linkage for B tranny swap?
- please help... cyp trouble code help 09?!?!?!
- cracking inside cabin...or buzzing...what?
- Civic hatch 92
- somethings wrong??
- H&R race springs. kinda looks like stock.
- D15b7 in a 1987 civic
- Transmission Questions
- output shaft
- Things I can't find...
- do you think it would be worth doing this??
- b18c5 turbo
- OBD1 OR OBD2?
- B16 or B18C?
- power folding mirrors (defrost wires)
- 89 service manual for a 91
- Honestly whats easier IM to swap and do the wiring; a d16z6 IM or d16a6 IM onto d15b2
- computer question
- What would you do?
- Crx seat weight
- wtb! 1.5 or 1.6 block
- need a new block
- whats ur favorite Suspension set up for 4thgens
- 89 crx taillights wont turn off.
- no power in the ecu. what do i need to do?
- What transmission is this?
- can u put a dohc zc head on a sohc zc block
- what trans is this?
- GSR in Hatch Questions
- ***90 integra ls motor (b18a) in a 91 CRX Si and all 4 DA brakes on 88 CRX DX *help me*
- pic request: gauge cluster at night
- Fuel pump doesn't prime, Main relay?
- clutch fits but pressure plate doesnt line up to flywheel? whats up?
- faded seal on front door/top of window
- wtb! 1.5 or 1.6 sohc block
- Where should I get a Koyo Radiator for my CRX?
- Where to look for a JDM rear seat for 91 CRX
- b16a timing belt install questions
- cutting up rear speaker panles for autopower
- OHHH....help needed
- 1992 Crx B16 swap questions..
- Fuse box wires
- Head
- Secondary fuel filter location
- Odyssey power rear window?
- 2 sets of plugs in less than 1 week
- wan li tires
- Spark Plugs and wires 91 civic dx.
- Anyone elses rex eating starters up ?
- tranny problem
- crx bushing...
- crx running 2 rich
- hood clearance question... ??????????
- Another Clutch Question for a Si tranny and ZC motor
- D16A6 Swap, Oil Coming on Driver Side Bay
- need help quick
- Rear strut braces (ef civic -> ef Crx )
- 88 crx with h22 traction problems ? i know go ahead laugh , but still need help!
- REQ: STD w/ DX tranny to ZC/Si Axle Grocery List
- NEED HELPFUL TIPS ON HOW TO HOOK UP MY 1990 SI HATCH
- 90 hatchback carbon fiber spoiler?
- j's racing intake in crx???????
- D15B2 Head conversion
- Just wanted to share my 89 Civic project with yall...Any reccomendations?
- what clutch for an 88 tranny?
- How much is my B18C Rex worth? (56K warning)
- Finally got a replacement car...
- B18A into 88-91 Civic HB
- Vehicle Speed Sensor??? Help Please!
- Anyone ever try to mate upper and lower interior door skins together?
- D16AZ?
- Falken Azeni or similar...experience?
- Y-49 and spray paint
- What gaskets/seals do I need for the bottom end?
- afc+z6 head+ crx ecu= what wires to hook up?
- More Wiring woes... got CEL codes though (20 and 21)
- question about obd-0 ecu
- Axle Install, Ring Clip Issue
- crx hf to si swap help
- need help deciding
- oem bushings for cheap
- Front lip for 90-91 CRX
- where to buy crx rear fender arches/dog legs
- Sweet 1991 CRX si for Sale.
- Zdyne ECUs..
- Stumped. 1100 RPM idle still, just plain stumped
- Best way to check 1st gen b16 from 2nd gen
- weird tranny problem.
- CHEAPEST place to buy B series mounts?>
- oem fog light question
- CRX and HTS suspension, has anybody done it yet?
- Pics of my friends EF
- Headlight position / adjustment
- CRX window off track, need help!
- CRX rear speaker size
- Strange Lighting Problem
- length of si throttle cable
- 1st Gen Civic/CRX B series Questions
- very strange starting problem on 91 civic hatch
- Is my ECU crap?
- my civic or the mazda 3
- WTB: 88-91 CRX 1.5L HF complete motor
- Rust in my sparkplug hole
- Project... is it worth it?
- serached but theres so many answers my p28 is it AUTO OR MANUAL
- CRX is totalled what should I do with the engine?
- PG7 ZC questions'
- North Carolina HT'ers?
- need help with the back of my 90 civic
- wings west kit owners enter.
- B16 RPM Limit
- d17 vtec in a ef?
- b pillar molding
- car smokes... what is it??
- FOR SALE 1989 Honda CRX SHELL with EXTRAS
- 88-89 taillights on 91 hatch
- what manifold is this...
- Getting rid of Automatic seat belts
- EF7 CRX and Civic EF9 hood are they the same?
- i need help badly
- SOMEONE FOR CHRISTS SAKE
- which block with which head?
- Over filling the oil?
- running rich
- car just dies sometimes
- CODE 5 PROBLEMS
- PG7 MPH fuel cut off?
- 1st gen b16 cank annd rod bearings
- adjusting drum brakes
- 85 CRX Si Front Camber Mystery
- New owner of a 1991 CRX SI w/ZC (stock)
- My awesome experience with a major fitting manufacturer...long :)
- DPFI -> MPFI Swap Opinions
- would the tranny fit?
- P30 or P28?
- Camber kit Question
- lip question
- crx problem...not starting
- S1 b16 tranny gearing?
- which is best ls, b16, or a gsr
- D16A9 Stock fuel pressure at rail?
- b16a axles problems
- Flywheel tool
- tranny question(SEARCHED)
- Stolen CRX---->LOS ANGELES,CALIFORNIA 8-2-2004--->LIGHT BLUE HF
- ebrake light doesnt go on
- obd0 ecu plugs
- how to star my crx in second gear ???
- can i do mpfi swap if i have a car thats burning oil
- Civic Won't Start in the Morning but works at night.
- Can I remove this?
- CRX+German autobahn@146 miles per hour + KABLAM= ouch
- engine swap
- d15 dizzy
- My new lip!( Pics !)
- what would cause a car to pull to the side when braking?
- ECU for a Mini-Me in a 89 Hatch
- Swap starts in 3 days, and I keep finding crap missing or messed up
- What parts do I need to replace my brake lines
- Is it worth it with a .../ Does it matter?
- turbo
- Any one run Falken Azenis tires on a 15in rim on your rex?
- paint bumpers !
- i want the best suspension bushings
- FAQ: Wiring Harness Plugs (What are their names/Where do they go?)
- fucked starter
- can you mini-me a DX engine?
- WTB CRX Si harness?
- car wont start
- prices on a crankshaft needed
- need help, crx 1.5 starting trouble
- help needed with crank pullie bolt
- taking care of b16 engine
- Whats the best swap for the best price for my 91 hatch
- Bitch....Shift Linkage Pin Removal, Tried But No Luck
- which ecu to use?? help needed
- carpet or no carpet
- CRX HASPORT MOUNTS
- 89 si engine
- Zex Install. Where Do The Vacuum Lines Fit and Fuel Jet
- need help ASAP: alternator plug and socket aren't matching up
- NEED HELP ASAP
- Turn signal leds, lights when brights are on
- flywheel/tranny question
- Need some reviews... Looking for a set of softer 'sport' springs...
- couple of short questions
- Helm's manual
- wanted ZC engine
- leaking water???
- Tranny...
- Why is it
- autozone vs straight from honda
- Hood Latch Stuck
- Where to buy side molding for a hatchback
- info on 87 Si CRX
- Help CRX wont start Think its the starter
- B16A AC HELP!!!
- Mini me Problems.
- 90-91 CRX C-Pillar Bar
- been out of the game for a while... now i need a lil help knowing whats what - 89 si h/b
- Street alignment settings for CRX - suspension experts please!
- how to tell axles apart
- pricessss
- where to buy new head/block dowel pins
- which coilovers???
- b16a CRX need help ecu question
- pin refernece for gauge cluster?
- A/C Removal, Any tips?
- plugs, leads and fuel treatment
- New pictures of my CRX Turbo =)
- magnaflow muffler offset-center, center-center, offset-offset???
- Zex Purge Install. Wiring Explanation Has Me Spooked. PIC
- Motor mounts Sir 00 to civic 91
- complete instructions for b16a1 swap in 89 civic hb
- obd1 converion plus MPFI
- CRX door visor/rain guards selling for almost $300!?!?
- Hate to ask, can someone run a carfax report for me.
- Is the d15b vtec built strong enough to boost safley
- Rear Speakers
- Need help put a gsr cluster in 92-95 civic?
- Does this caliper/knuckle look like an SI??
- knocking sound when i start my car?????
- GSR ni a CRX?
- 88 crx throttle position sensor voltage settings
- Another MPFI help question
- What car is right for me?
- 03 SI seats in CRX
- Male to Male brake line adaptor... May be called a coupler. Do they exist?
- Will bumper fit
- Need advice: Should I rebuild the motor in my rex or buy a new one?
- Tach dropping off and sudden loss of power?
- experience with password jdm
- b16 obd1 or obd0
- d16z6 pistons and rods into d16a6? searched didnt find anything
- Just say yes or no PLEZ! (wire harness)
- searched just a few yes or no questions about minime swap
- NEED HELP HURRY!
- when torqueing in steps, is this supposed to happen?
- Couple Things
- HELP!! code 43 ??????
- exhaust will not stop smoking.
- did first oil change on b16, smelled like gas in the oil?
- Will an 89' DX speedo fit into an 89' Si cluster?
- Gauge locations
- oil pressure
- pic request....EF armrest..in an EF
- thought i blew my piston rings, anyone know what this is?
- looking for suspension advice
- Just blew my motor (i think)
