View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Well people are bitting so might as well show!
- 91 hatch with 92 Gauge cluster?
- how much for a wiring harnest?
- How to Remove the Dash from a 91 hatch dx?
- intake
- Project Tweak: PWR Barrel WAIC install into CRX
- need wiring info for CRX
- Super duper rich....
- b16a2 problems
- starting fluid
- question about dpfi to mpfi
- Can someone post a GOOD wiring diagram for OBD2 dizzy
- Any good mounts?
- EACV
- intercooler piping
- p1298 codes
- what cold air intake
- how to modify your trans for your hasport hydro converion kit.
- b16 idle wierd
- 0bd0to0bd1 problems !
- anyone know wut ppl r using for adjustable wing?
- engine rebuild kits
- FAQ Painting bumpers flat black
- How to fix my ebrake help
- zc needs new rod bearings
- anyone have SiR front end with VENTED CF hood?
- 13.8! Impossible
- Big problems!!! HELP!!
- compression test on b16
- cant get my tps off....wtf?
- My 1st CRX + Swap Questions
- Drum to Disk??
- ecu light flashing
- 5 wire oxygen sensor for 1987 CRX HF
- Will Motor Be ok?
- weird brake issue!!! i need help!
- 1988 CRX DX?
- New Toy!!!
- Si final drive wanted
- powerband
- Totally Screwed...
- how to tell if l/b or s/b
- electircal issues
- Rev Limiter
- Neuspeed front strut bar for CRX... does yours touch the hood?
- Y1 grinding.
- ZC DOHC
- Rust repair quarter panels
- Part name?
- air/fuel guage install
- need help with friends crx with zc motor
- Were to buy DIN Plate to hold 3 autometer gauges in place of radio?
- 12.5 ef four door
- CRX non JDM power window conversion
- extremely weird ecu problems
- boucy tach after mpfi conversion
- HELP
- Not Vibration but a noise..
- throttle body
- omni
- making sunroof out of fiber glass
- Fiberglass
- civic door question?
- dx hatchback
- quick ? about hmotors online
- Secondary clutch kill switch?
- Question about cheap catalytic converters off ebay,are they ok??
- Starting Problem
- Remember the guy that put OEM B series mounts in his HB and flipped it?
- wiring harness
- d16y7 head
- just wrecked the si last night
- I Got me a rex :) make that #3
- crx with an obd1 motor how can i wire the dizzy to the obd0 harness?b16b18c
- For your protection
- momo del sol hub into ef
- wires
- neuspeed springs worth getting?
- NEED Experts ADVICE!!! STARTING COMPLETE CRX REBUILD- want opinions!!...
- got a quick minime ?
- Head torque specs?
- Please for the love of god help
- crunching and popping
- clutch vibration while engaging only below ~1800-2000 rpm
- quick idle question..
- CRX MOULDINGS??
- 87 Civic 4WD Wagon, Idle issues, overheating
- *Official* Rate Your Favorite EF Thread
- i need a windshield
- More mini-me starting problems
- Rev???
- Eibach Pro & tokico Illuminas
- Went shopping today...
- lo- jack or alarm.......????
- my dumbass brother lost the keys to my crx
- It finally happened to me too: Crx stolen this morning @ Huntington Beach, CA. Pls read.
- Camber Kits for 90 Civic Si hatch?
- Anyone got a pic of OBD0 si dizzy plug?
- WHAT ALL REAR DISK'S WILL FIT A 89 CRX SI
- someone please help me and just send a PM
- swapped ef alternator removal??
- improving headlights?
- how to get my 91 civic aprowed?
- A/C and heater
- hooking up V-TEC
- t3/t04b + hf manifold + A/C = success
- d16y7 + DPFI Any Info?
- Civic needs a clutch, need input.
- anyone got pics of how to make shift linkage
- How to tell injector clips apart?
- Anybody knows where to get carbon fiber trunk lids for civic 88 HB?
- 7700 rpm???WTF
- oil is spark plug area
- wiring harness question for dual to multipoint fuel injection swap
- crx door panels how to remove
- ef hatch: 4 lug type-r conversion
- MY NEW CRX
- Starter kill amp rating?
- b16 in a 4wd civic wagon
- d16z6 head on a d15b1 block will it work with out hooking up the v-tec????????
- jdm paint colors?
- how do i wire jdm power windows
- crazy coolant level
- joining the crx family
- integra seats in a crx
- low boost factory internals , does any one kno?
- shock is frozen
- emissions removal
- got some new dubs, off set question *pics*
- d16a1 intake manifold
- 4-1 header for d16a6
- 91 civic HB with 90 DA Breaks
- Rear hub/bearing problem (yes i searched.)
- OBD0-OBD1 Conversion complete but I'm getting a CEL
- 95,000 kms crx ? what is it worth ?
- Car cranks, but isnt firing.
- what wire is this?
- Need Some help! Rear disc conversion
- Injector/FPR ???
- dollar for dollar what is your best mod for suspension
- installation of jdm front seats...........
- omni power i think i got screwed
- need help finding 4th gen special edition pictures.
- MAJOR PROBLEM...PLEASE HELP!!
- Torquing bolts question d15b2 need right now~!
- engine question
- 91 si rex motor in and out for build
- Vacuum tech question.
- im stumped
- How to Remove Rear seats from 91 hatch?
- cams
- where can i find or buy chrome to chip my ecu for a turbo?
- WTF Is This? Back of intake right side? ive got no plug for it....
- no hoist to take out motor
- knock sensor help
- Willl GSR Leathers Fit A 89 hatch or Sedan?
- 94-01 teg control arms
- I need a photo of a coilover for 1G CRX / Civic
- rear mount ?
- help ive searched
- Body work needed... straighten out headlight frame
- denso o2 oxygen sensor pinout connector plug pins (for searching)
- ecu help!
- Anyone seen the movie "The axle in the trans?"...
- where to buy mouldings? JDM or oem?
- 4-1 in a ef
- top hats
- got a good question, i think
- E-BRAKE
- bouncy bouncy bouncy
- Need help!
- How hard is it to put carpet in?
- Cleaning out my garage - crx and mr2 stuff
- Need help With My EF Hb?
- fisrt project ever
- taking my drum brakes off
- need help
- some how lost signal in corner light
- swap guide
- New Guy - 1984 Honda Civic SCCA Race car - Old Old School Differential question
- Fuel level reading problems
- Anyone Found A Way To Use an SiR Airbox/Tubing with an Upgraded Throttle Body?
- how much can i take off a head?
- CRX thieves caught in North Texas. Anyone you know?
- awesome another problem help please
- 92-95 dohc ZC
- Hey guys, introducing myself.
- Will JDM spec fenders fit the USDM front end?
- 2nd gear grinds but other gear is fine
- whats involved in an lsvtec build?
- Tach Not Working At All - 88 Crx Si Why???
- Brake problem
- clutch cable help
- SRACHAD I need help with my Accord climate control swap
- K24 for sale for so cheap!!!!!!!!
- Does anyone make a CARB legal header for an 86 CRX Si?
- Do i need the factory line that connects to the valve cover from the old airbox?? PICS inside
- hate these damn thing
- DC sports header part number for 86 CRX Si?
- Finishing Up the Ls-t Sedan!!
- how's this for a RESONATOR
- 91 crx si burning lots of oil
- 91 crx accelerating problems?
- rpms keep jumping
- Rebuild or Replace....that is the question....
- Real rich.....?
- ** help quick **
- Auto to 5 spd problem on '89. Reverse lights won't work.
- ZC question From OBD1 to OBD0
- what do you think my 4 door is worth???
- What Intake manifold is this?
- Questions for CRX Tuners
- Need with motor swap
- jdm look amber 90 91 crx bumper lense
- check engine light
- ecu prob
- Vitara pistons and D16A6 info
- Need painting tips for bumpers
- where did you mount your hids!?
- brake master cylinder
- humming people humming
- DPFI--->MPFI:: IAT plug?
- need help withloud exhaust
- Chipping pm6s, does anyone have p08 fuel maps?
- civic and crx interior difference
- Ignition switch going out? Any insight would be great...
- What car is this cluster out of?
- what's teh differnts
- Track width and how it effects alignment (wheel offset/width question)
- Button Ignition
- Silencer welded in exhaust, undo?
- tourque spec please ....
- Im buying an 88 crx si and have an ls already
- crx sunroof removal?
- tach problem
- i need help with my rex its puffing smoke when i get into the throtle
- different in sx and std
- d15b2 and d16y8 head CR
- cable to hydro crx h22
- adjusting timing belt tension
- Where to put guages in a crx????
- Please Help! Civic wont start.
- IT STARTED!!! First build - *VIDEO* Wont Idle, Sounds Rough. Diagnose me
- got the car runnin but serious problems :-(
- Brushing with lowering kit
- Wheres a good shop in or around Cincinnati OH
- F**K, Need help quick!
- which way to go...N/A...or ....BOOST???
