View Full Version : Honda CRX / EF Civic (1988 - 1991)
- C-Pillar bars gallore
- wilwood big brakes and tranny question , please help
- Suspension install. (Attn tech guru's)
- see .. you can go to jail for rice.
- windshield wipers (not blades but whole wiper) is all over the place
- bogs at idle when first started and engine coolant temp sensor
- question
- crx concept...
- anyone know if i can use a 92-95 throttle cable for a sohc in a hatch
- Would this cause sloppy steering?
- accord struts
- Which alternator for my Z6 equipped CRX? Aftermarket pulley?
- where should i go to get a motor installed
- need help with obdo-obd1
- HELP my car died and wont start
- Whats going wrong?
- CRX hood cable reRouting...
- ZC Exhaust Cam Gakset
- Car Stumbles Upon Acceleration!!!!!!! B16A Help!!!!
- ZC engine = gold?
- ZC tranny question
- Please take a quick peek.
- CAR WILL NOT START - HURRY! JOB INTERVIEW!!!!!!!!!!!!!!!!!!!!!!!
- catbacks opinion
- LS turbo piping...will it fit a CRX?
- I need some opinions on exhaust.......
- since u guys do this kinda thing all the time, thought id ask u.
- d16z5 + civic Si
- Carbon fiber hood without pins?
- Is there any difference between 88-89 CRX SI and 90-91
- The UN-mini-me ?
- Apex'i N1 silencer
- Swap ?'s (b18c1 into 91 Si)
- ef digital clock?
- Lsvtec Question
- Anybody in here NOT have a headliner in their CRX?
- Can I put a ex or a crx si head on my crx hf?
- Si tranny took a shit on me
- Spension Shocks and Springs For 91 Hatch what is best?
- coolant fan not turning on? and VTEC not kicking in.
- clutch switch question?
- Best/cheapest place to buy a JDM front for a 2nd gen CRX?
- will they or/can i make these fit?
- tail light filling up w/ water
- obd 1 p75 diagram...
- need help from Kentucky people ...
- has any1 had to upgrade fuel pump after b16 swap?
- 88-91 best year to buy??
- B16a bore size
- what compression on mini-me ?
- DPFI to MPFI help
- Ground Control Coilovers?
- side marker template?
- Need help changing dual port to multi?
- int. shaft length
- Cap and Rotor
- ef si engine harness ??? thermo switch related
- Any good DIY Fiberglass Body Repair Articles?
- check engine code 12 - 1gen b16a
- Which steering wheels witll fit.....
- Questions
- AEM CAI setup
- B16a Turbo Kit
- Fenders/Hoods
- What is this part called in this picture....
- Ebay front lower tie bar.... will it fit on crx with b16?
- Mini-me Question (Best Route?)
- instrument cluster probs
- wich is the best head for a B20..
- about the dohc zc
- I need YOUR A/C belt tensioner pulley!!
- low 14 sec NA Sohc motor?
- MTF through VSS hole??
- Which filter to use with B&M oil cooler + relocation kit
- h22a into a crx
- Cleaning headlights
- Nor Cal Dyno Day June 7th, cheap!
- Got SiR bumper, need headlights, bumper lights, filler plate. Anyone got these 4 sale?
- What's a good downhill racing (initial d style) setup??
- people with y8 manifolds qs?
- d15b intake manifold
- problem with my crx
- would anyone be interested in a carbon fiber roof?
- pics of my 91 si freshley painted
- tranny question...
- Good names, for rear tie bars?
- Factory wheels
- crossmember?
- 91 hatch 93 gsr motor for sale real cheap or trade
- Mini-me Timing...Help!
- quick ef question
- b16 almost starting making poping noise??
- Best all motor SOHC non-vtec cam???
- best lowering springs for 88 CRX with B16a (1st gen)
- any one have a j's racing lip for sale
- headgasket help!?!
- where can i get a preformance chip?
- smoke i need help!
- bseries, maxrev, ef?
- new here!!! pics of my b204thgen
- need advice
- Has this happened to you?
- Automatic staters work in 5 speed trans?
- B16 funky prob.
- b-series shift linkage
- what hood to get oem, fiberglass shell hood, exc
- A/c Compressor Clutch won't engage
- Integra rear disk brake ?
- SOHC Vtec lope question??
- a quick question about throttle cable??????
- smokin 91 si hatch
- My rad fan
- Aftermarket wheel - need a "hub" ?
- WTB crx tranny
- Car starts without clutch
- Help! I need a clutch
- Tires
- Radio and tach dying!!!
- my pickle fork is worth its weight in gold.. what other tools are?
- Does anyone know ?
- B18C5 Question
- 90-91 ef sedan ??
- H4 HID's in JDM housing question
- Wheels and Rims for an 88 crx
- installing CRX SI leather seats
- nifty d16a6 cam website
- vtec opinions
- quote from JHP.com
- Motor Mounts
- Where is the best place to sell a modified CRX/
- b16a o2 problem solved and gas info
- torx bolt size on 90 crx door
- look at this crx for sale
- TDC Problem
- DPFI-MPFI swap AFTER b16a swap
- swap, tranny questions
- please post your pics of...
- B16a Swap into a Rex
- first swap, need help.....
- OK, who needs a carfax!!!! :)
- nooobie ZC swap questions.
- need car fax..
- any help appreciated
- twin turbo ls
- does anyone know where to get a b16a or a b16b
- Ef forum...
- any body in new jersey have a 89-91 si wiring harnes for sale??
- D15B dizzy work on D16A6?
- how much is too much..is it rice or is it clean
- Front Camber kit making noise's
- bad breaking vibration?
- jdm backseat for crx
- **What are good cams that go with a supercharger!??**
- anyone have pics of an apexi ws, greddy sp, or hyper medallion?
- stripping out a crx
- Need any input on a cel 8 after d15b and mpfi swap
- anyone have turbo LS w/ b16 tranny?
- Vibration at 30-40 mph? helpppppp
- whats the sanden model number for a 91 civic a/c compressor?
- dohc zc valve springs?
- 91 CRX USDM SIR Type raised hood!!!!!!!!!!!!!!!!!!!!!!!!!
- how much does a LS/B16 cable tranny weigh?
- HELP me PleasE!!!!
- being able to rev up to 7,000 rpm's on stock crx si motor
- ok, this is stupid, but...
- installed STR throttle body, can't get TPS to set properly...
- Mods to D15A3 (first gen Si)?
- front upper strut bar
- new to crx, need help
- Need Help on 88-91 Weight differences--Doing Research
- HELP!! wiring problem??
- Dynoed ZC today!
- CRX headlights and rear tower bar?
- how's my time?
- ****Supercharging an Ls in a Civic hatch?!****(Read!)
- CTR rims
- ooo nooo im grinding 3rd what to dooo!??
- fiberglass work
- Finally took pics of my C-Pillar bar
- Best rubber for CRX Si wheels?
- new engine
- Si lip for hatch
- help please no vtec
- what cold air intake should i use on my crx?
- best price on B16a SS header that will fit a CRX
- H&R springs for the 91 crx, Sport or Race?
- need some help posting pics
- Please read about posting..
- HELP ME!!! Serious problems with replacing axle on 89 CRX Si
- ZC Torque Specs?
- pics of my '89 si....unfinished
- Timing wont line up?
- mini-me, did a search and this wasnt in the archives
- cut and spliced distributor clips?
- To swap, or not to swap.
- Your opinions on Yoko AVS ES100 (195/60R14) or something similar
- Which tranny is better?
- dang varmit!!!
- which rear tranny bracket to use?
- 1st Gen CRX Si + ZC DOHC - Can someone point me to some good info?
- oh man its gonna be wild!
- ebrake problem with gsr brake swap
- gears are not going in properly
- I just got a crx!!!!
- Found Oil :(
- spark plug?
- Vibration Help
- for all the 90-91 civic/crx
- Still get a CEL B16a help!
- what can i do to make the y8 fast?
- Specs/Engine code for 87 CRX Si
- will a t3 turbo w/tubular mani fit on a zc w/o buying smaller radiator???
- Coolant Temperature Sensor (ECT) on B16A PROBLEM!!!!!!!!
- Getting engine codes (Everything is wrong with this car!!!)
- Radiator temp Sensor... Wheres that little wire?
- are all del sol radiators dual core?
- Would this help to quiet down my exhaust?
- 91 crx si ?
- Need Opinions On Mounts
- Vtec wiring (b16a1)
- 91 crx b16a or b18 and why
- ECU options...
- Bottomed out ... now lost a small piece of tranny casing
- How much HP does my engine have?
- distributor question
- oil light stays on
- which wire on the tps is the sender on d16a6?
- Difficult to shift
- how to: mounting a sparco rev in an 89 civic si (56k is a maybe)
- like CRXs? heres a nice read...
- HELP! crx steering rack removal
- idle adjustment for b16
- My JimFab experience...
- APEXI vtec controller?
- Best/Cheapest place to buy ZC motors for 88 CRX Si
- how to tune a Field's Vtec Controller Air / Fuel settings
- just finished reassembling my engine today and i ran into one problem
- jdm d15b , what kinda timing belt? thanks
- Vtec oil switch check engine light comes on and off.
- civic and crx sunroof panels the same?
- tps broken or not broken please help me out!!!
- HARD to put into GEAR!
- some pics of my suspension install
- think a dremel would cut a spindle nut?
- CRX Question - ITR Rear LCA
- I have to brag
- mini me ?'s
- hf->si 'swap'
- HF from DX (exterior)
