eBay radiator
Has anyone had any success installing the eBay aluminum 2 row radiator? I got one and it won't fit in the stock lower mounts. It hits everything on the way down. My bad for being a cheep ***. The China outfit I got it from is giving me crap about returning it. Has anyone has successfully put one in without hacking the car up?
Yep, gotta trim the threaded bosses on the bottom of the rad. I cut them to about 1/3 of their original length, enough thread left in case I ever need them again, but you cant actually put a bolt in them when using the stock crossmember.
Also, if you still have your AC condensor up front, the stock top rad brackets wont fit. You either need to make new longer brackets, or remove the condensor (if you arent running AC).
illaborate978
May 10, 2007 11:12 AM
