View Full Version : Honda CRX / EF Civic (1988 - 1991)
- quick question, oil pan.
- JDMB18GSR INTO CRX
- OT: how to bypass emission??
- Are EF and EG A-arms the same?
- 89 SI SHELL NYC
- Car troubles continue......got a question
- Waterpump froze?? please help
- 90 CRX Si leaking in the rear......Someone help.
- Easy cable VSS question, pic inside
- i need some info on ECU codes
- Wiring Gurus heres a question---------SiR engine harness to DX harness
- Crx Custom Trunk/Hatch Pic (need help)
- WTB: CRX door handles/key slot
- Went to the junk yard today.
- Type R intake manifold on a b16?
- question on carpet???
- Got me another EF!!!
- Welding?
- How big of a difference does TPS make?
- 84 civic ?s
- White smoke coming from exhaust
- a serious spanner wrench
- 98 b18b AXLES
- crx overheating not getting heat
- Help...What B16 Should I get?
- FOR SALE
- Power loss at low rpm (1300-2000)
- Good body shop in MD??
- Steering wheel---1996 CX fittings?
- B16A idleing
- Wings west door caps on 89 si?????
- Hooking up VAFC in my 90 si hatch, does my wiring harness have the vtec wire?
- EF8 clip what else should I get off it???
- EF9 Parts for 90 CRX
- JDM head lights for EE8
- hesitation problem please help....
- Pillar seat belts in 89 Si CRX..
- Which Dart Block to use
- 88 crx jes died for no reason? pls help!!! i need to get it running b4 school monday!!!
- Magnaflow Muffler...
- wtb 91 black crx interior peices
- BOOTED!
- Halo Headlight Nightmare
- 90-93 teg brakes with d series... will it work?
- ghettodyne, need someone to me help using it
- CRX R.I.P
- online service manuals~
- ls/vtec fuel/bog issues
- which clutch? d16y8 with crx si cable tranny
- shifting problem
- weird as hell
- Finished mpfi conversion.. but getting codes 7 & 9
- Speaker fitment for those that WANT to know
- Installing lexan on CRX 88-91
- water temp gauge install help...
- CRX SIR bumper fit Civic HB
- are crx and hb exhaust the same?
- engine swap question
- problem with MAP sensor ... help ????
- are your wiper arms loose????
- help with vtec switch
- Carfax please? Pretty please im begging!
- What are the Torque specs for the head bolts...
- a6 tranny on z6 motor.
- Head Gasket?
- dumb question
- anyone with a 96-00 ex greddy turbo kit?
- I NEED DOHC ZC CAM POSITIONING SENSOR!
- knocking noise in front end
- SIR2 intake on a D15 head?
- what aftermarket ignition
- Turbo civic v1.0.. phase two begins.....(pics)
- This can be right, can it?
- Went to the junkyard today!!!!!!
- coupe more crx questions spindle stuff and wiring harness stuff
- Does anybody know who does inspection in Easter PA??
- Pics of racing harnesses
- what color are the sprint extreme springs???
- request pics of Y8 swap!!!!!!!!!!!
- EG Hatch front end on EF.
- where to buy 1990 crx rear window modlings and a roof molding?
- What is the Firing Order?
- d16a6 lying around?
- need help finding out whatz wrong with my car
- has anyone tried.....don't want to be first....
- b18c5 into a 1991 honda CRX Si...
- quick question?
- Obd0 to Obd1 wiring?
- i got hit!
- cool lookin intake manifold for D,B,H series..
- to the Administrator; problem with Netscape browser being able to select Icon
- tag lights on WW body kit????
- 1989 crx hf idle surge with stock motor but defroster will stop surge for 3 -4 mins? Help!!!
- What year cars had door mounted shoulder belts?
- Will DOHC ZC Intake Man fit D15b2??
- what to do
- jdm 4 door front on a h/b?
- WTB 90 hatchback si Connecticut
- Steering wheel shakes at low speed
- ls ecu in 1991 civic si
- Ebay cheapie short shifters...anyone buy one?
- CRX Carbon hatch
- CEL #7
- anybody got pics of a edelbrock or skunk2 intake manifold on a 4th gen d series civic???
- If my B16 TB doesnt have the Map sensor mounted on it, can i still use it on a y8 head?
- should I get rid of my hatch?
- water pump? b16
- What can i keep??
- sohc zc block question
- coilover question
- 4 to 5 speed?
- B18 Interchangeable Replacement parts?
- anyone running a boosted d16a6???help
- 3 seater rex?
- ARP Stud Problem...
- If you had a Crx Dx lying around.....
- mpfi wireing???????
- Double DIN radio in my CRX. "pics"
- My one off CRX gauge cluster
- Obd1 Conversion Question
- 91 civic, no title should I buy
- need help changing seat belt clips
- b16a swap help!!!
- ITR interior in EF Si...
- tming check
- crazy steering help!
- does anyone have this brake kit
- this is red_si 's mom...please help...
- roll back cable odo
- headgasket replacement
- parts for sir's (where to find for the best price)
- compression
- O2 Sensor
- which springs to choose for crx race application
- speedo doesn't work what could it be?
- Rally Rex
- which tranny for turbo SOHC ??
- New JDM stuff I got today....PICS
- JDM Conversion, front lip?
- Suggestions
- Can you roll back a electric speedo???
- eg lip on ef
- d16z6 swap into 88 crx si questions..
- Steering problems
- crx wheel offsets question
- DC front sway bar on CRX?
- 91 crx si
- I think I found out why my car boggs when I slam the gas...
- Looking for EACV for 91 honda civic hatchback si
- getting my car swap tomorow!!!!
- 3M Windo-Weld = Good
- can anybody???
- Just bought 89 civic 4dr
- start up problems
- crx engine stuff
- Crank Pully Bolt is Impossible! *horror story* *pics* GOD!!!
- anybody know what this is?
- crx sir cluster anything else needed?
- Follow up on my stolen CRX
- air/fuel gauge installation help
- toyo proxes on 14 hx wheels
- Dash Swap
- much better link
- Convertable REX
- koni and skunk 2
- a thought
- cracking windshield
- weird lines by transmission ground cables. what is it?
- torque specs?
- Does anyone know how to convert a 4 wire oxy.sensor into a 1 wire?
- my car just shut off on the freeway
- spark ?
- 90 Honda CRX Si....Sunroof problem.
- weird stuff
- Door doesnt cloes right having problems????????
- my rex
- AHHHHHHHH!!!!!!!!!! I need help ASAP!!!!
- d16a1/zc trannies??
- Just found out about this site
- should i...........???
- Crx Wheel Wont Come Off, WTF
- compression test procedure info needed
- cam or header
- ground controls for 1st gen rex
- mpfi swap... HELP!!
- obx catback any good
- si or zc tranny?
- Tranny fill points
- Bottle Locations
- can u mix sir parts......
- What do you think about these rims?
- meet in ca
- IAC / EACV lines.. where do they go?
- which ecu should i use for my b16 swap????
- cutting carbon fiber?
- Civic Type R LSD in my cable b16a tranny
- coilover in front and H&R in back?
- problem after dpfi-mpfi swap
- NICE! Finally some love for the ED's!
- Rear Brakes from a 90-93 Integra on a EF hatch...
- JDM License Plates
- dohc 1/4 mile
- turbo zc dohc
- where can i get a trunk bed for my crx.?
- Undecided EF Civic
- heater core !!!
- no heat in 88 lx
- quiet exaust for rex
- BIG Bseries motor mount sale!!!!!
- All you Z6 guys
- Problem with 90-91 Integra CLUTCHMASTER CLUTCH on Y-1 cable trans
- What Alternator to USE???
- External Gauge wiring hook up
- Lights going out!!! need help
- help me choose a wheel
- whats a good stiff spring for my rex
- anyway to get a h4 bulb to fit h4h socket?
- front disc brakes?
- Just wanted to say it was fun!
- Amber corners for 91 Si?
- Water in gas tank?!
- What is the difference between y8 mani and y5 mani? performance?
- vss obd 0 b16 ques.
- well i killed a hatch
- h22 in a a 4g??
- >>>D16Z6 swap need MAJOR HELP! CALLING ALL EXPERTS!<<<
- Thermostat Q
- Master cylinder from 93 teg non abs cant find an answer to ? HELP!
- coming back to ef world
- for the guys who have swapped!
- CRX wheels on 95 EX
- So an EG is a CRX?
- What is this??? (massive)
- JDM fenders w/ usdm front end...????
- can fried cps make car run like krap??
- B16 swap>90 CRX HF
- WANT TO BUY COMPLETE D16A6 IN SO CAL!
- i need a wiring diagram for b16a using 90 crx si harness!!!
- 90 crx si for sale
- EG crx?
- Opinions on AfterMarket Catalytic Converters?
- Check my other post i think im buying a y5 instead of y8 mani, will it work on a y8 head?
- center console in 89 civic
- front radius rod looks like a semi circle
- mpfi swap with d16z6 intake manifold
- zc clutch/tranny/ axles???
- thermostat?
- ?HELP? Where to bolt down seat belt harness?
- nevin norstrom
- DSM fuel pump in EF
