View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Break Lights
- is throwing a code 7 Throwing a co0de 7 TPS
- air/fuel ratio gauge hookup question
- s2k Radio into CRX, was I dreaming?
- what is a 89 civic si weight?
- is it worth putting a h22 in a 89 civic si?
- what would i run with a stock b16a1 in a 89 civic si?
- quick seat question
- What do you think my car is worth?
- Tips for axel removal
- d15b intake mani or d16a6?
- b18c1 hydro tranny for sale
- Exedy clutch + stock remanufactured flywheel possible?
- swappable parts from a 95 integra
- Custom bezel made
- climate control
- New crx, gotta stop the oil leaks
- help what is the fastest way to do lowing springs!?
- crx with mini me wont start
- Si tranny on a Hf motor will it work
- i need help installing a b18c1 in my 1990 crx
- d16z6 boost post your setups!
- cx 5speed axles
- ef suspension
- Authentic Crx floor mats ??
- Headrest removal?
- d16a6 boosted and n/a post your setups!
- F20b in a crx
- 1/4 trap and 60 ft. times?
- my crx project pt 1
- Name that part with PICS
- Quick compatability question....
- 1/4 time for this setup
- d16a6 cam into a d15b7
- question about heater (already searched)
- AWD Wagon resources.
- What kind of springs go well with agx adjustable?
- Anyone, Is there any difference between EF civic Pedals and Wagon pedals?
- starter question
- d16z6 vtec experts needed!!!!
- Pics of Rear Cargo w/speakers?
- 3rd brake light not working!!! CRX
- Hi all from the UK...
- timing belt installation
- ok b16 revert question
- Problems!!! B16
- Si Harness
- Please! I need answers for my application.
- 88-91 civic hatch JDM front END
- need some answers fast
- help with mini me swap
- know anything about this crx?
- Civic coupe exhaust fitment
- Which one?
- Race Question
- Timing Belt Question : D16A6 + D16Z6
- seat question
- crx wired to obd2b and aem 1010 box
- jdm crx bumper questions?
- CRX climate control fix with civic faceplate?
- Would this MSD product suit my needs?
- will a knockoff mugen kit from a hatch fit a CRX?
- 2 new project cars for cheap tell me what u guyz think
- Wheel well trims.
- new starter>?
- Removing Steering Wheel...
- anyone using mega squirt???
- What front nose is this?
- Re: AWESOME CRX
- steering wheel play
- uberdata obd1 p75 with data logging cable
- rear brake swap
- My CRX symptoms
- cf front and rear lip
- swap american zc in crx
- for all the SOHC ZC pepole?????????????
- Dash wiring difference in 88 hatch and 90 hatch
- dpfi to mpfi wiring for pm9 ecu with conversion harness"HELP"
- Vacuum hose routing diagram for a 1985 honda CRX
- Injector testing?
- Cable vs Hydro, ITR vs B16 tranny
- New CRX owner needs engine swap info
- Seats for a 91 Hatchback
- obd1 injectors removed resistor box!!
- looking for a b16 crx
- $280 good price for ground controls new????
- NEED YOUR HELP
- anyone have this happen with a b series swap b4?
- $750.00 Good price for paint & bodywork?
- how much clearence is needed for srp pistons??
- Headlight strobe lights...
- Eagle
- Dynos in or near Ohio???
- head
- ZC MOTOR PROBLEMS!
- zc boggs out really bad needing help
- help main relay arghh
- refferee dis-aproved my mini me swap in CA so it's a new motor
- Honda 161822 still around?
- Finally someone with a H22 Crx video!!! :)~
- good spring rate and height?????
- dx to si intake manifold swap, need help
- EF B series guys...... Question on winter heating?
- B18a Swap into 91 civic...alternator & starter?
- ECU has no power. car turns over but ecu no flashy HELP
- B18 into a 1990 Hatchback
- 90crx SI 1.6 axle's
- Everybody's doing it!
- crx wire tucking
- duckbill wing?
- TurboEdit PM6???
- D15B Swap
- need help adjusting headlights!?!?!?
- a6 pistons in y7 block
- UH OH! What Would You Cover This Up With?
- is this worth it?
- stock radio wire setup
- Ek Rear Trailing arms onto EF *SEARCHED*
- Interior parts for sale...
- Finally the pics...
- 90 civic si jack points and jack stands
- Tranny tech: S4C guts vs YS1 guts
- Difference between the ZC Headlights and the USDM Headlights
- DATALOGGING
- PLEASE HELP-- NO SPARK NEED TO GET TO CLASS TOMAROW!!
- Turbo Company
- Bad cat?
- Ef brakes - can you lock wheels?
- NEEDS THESE IF YOU HAVE THEM??????
- 90 DA cluster into my 91 CRX?
- alternator/starter swap
- PLEASE HELP bought a 91 crx today and it has some engine problems
- how much to pay for a rebuild engine/tran?
- Gauge(s), FUEL Light!
- clutch cable install
- Building B18A into Civic STD Wiring Harness...where to start?
- sohc zc block dohc head???
- Would this tranny work?
- DUAL POINT TO MULTI POINT QUESTION
- b16 header question
- trunk slammed and now won't close?
- obd-1 conversion
- Stick with D16A9 or go for a B series swap?
- nos ?
- 1989 HOnda CRX HF
- best trany
- Fenders and Doors
- picture request
- Need help replacing lug on hatch
- i now own a 91 crx with a zc swap, i got it for 1g
- Engine light on
- 88 crx door options
- I need to celan my valve train and my cam shaft off from my z6 vtec head ....
- Fixing window
- Off Topic
- another question
- only front shocks
- Yall Give Some Input
- jg elderbrock camshaft
- which color is the power wire in my FAN RELAY
- WILL 90-91 CRX BUMPER LIGHTS FIT AN 88-89 CRX?
- Brake question
- Need help: Engine crank but won't start
- 17" rims
- where is my fan relay, my fan wont stop running!!!
- obd1 4 wire 02 sensor?
- dpfi to mpfi
- gsr cams in a b16a?
- Starting Probs
- My crx before
- picked up JDM D15B 3 stage Vtec......needs ECU# 37820-P2J-003
- odyssey pc 680 install with small problem?
- my new Si
- 3" exhaust question
- having trouble with gsr front brakes on the crx.
- GSR seats in an EF
- 89 crx si idling weird
- what do you guys think i should do about this crx for sale?
- Really weird clock problem in 88 CRX Si
- D serious Turbo manifold
- Radius rod problems..
- polished crx wheels
- ball joint and dust seal
- should i buy this EF???
- where to find DOHC decal
- JDM glow plates, who has them?
- Hub/spline question
- NRG quick release... whats it like?
- 15,16 or 17?????
- Brake line question
- the diff. between REINFORCEMENTS?
- timing question
- valve/head trouble... perhaps a floated valve?
- turbo???
- H22 Or B20?
- oil comming out
- i need a new motor
- header help
- wiring up heater
- obd-0 to obd-2 distributor wiring
- crx shell for sale chicago land area
- need help intalling the SIR traingle piece in the rear
- Help, need support... krazie1 = SCAMMER PLEASE READ!!
- How Do Generic Coilovers Ride?
- Sedan Swap
- Fields question?
- Honda CR-X (EF) problem
- quick qeustion about T-belts
- Does anyone know if there's a subculture for chevy Blazers?
- Need info QUICK PLEASE!!!!!!!!!!!! ASAP
- Shinchan CRX EF8 New blog - Ohlins, Spoon, Function7 and others
- does anyone have a ef with an obd1 b18b1?
- gen 2 rear disc question on 91 si hatch
- Distributors...
- 91 civic swap
- FINALLY B SERIES help 16 swap 170hp jdm
- sirII b16a running obd0 now has iacv issues
- shut down/power loss (ideas)
- DOHC ZC ??????????
- OT: Some TRUE EFs you can import!!!
- Heater blows cold air and I live in Colorado.....sweet!
- civic 91 engine conversion
- What parts do you need?
- Need tips for removing original 19YO exhaust manifold from stock motor
- Easy fix to some shifting problems....pics
- NRG Coilovers
- question on z6 or a6 head
- What do you do to protect your car from getting stolen???
- are these equal to each other
- tranny/shfiting problem - 88 crx si
- Fuel, gas milage
- 91 ef sedan interior?
- OBD0 to OBD1 Questions
- looking for b20 vtec video
- Crank pulley remover tool
- !!!PLEASE HELP!!!
- ef9 project!
- oh man this looks good what you think?
- Spoon Vtec controller question
- AEM fuel rail????
- Mugen wing for Civic?
- TDO5H complete! dseries trbo kit!
- wtf? tunr heat on = no heat or fan and radio shuts off
- I think my 88 civic will fail smog test..what could be causing the grey smoke?
- another k20 swap progress thread
- replacing steering rack and pinion *question
- Tranny fill up?
- 1991 dx 4 speed to a 5 speed
- Motor mount inserts help
- my mini me
