View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Where to buy Wings West RS kit?
- Maximum Ebay
- B16 with nitrous
- Engine building How to's and links
- Greddy sp1 axle back, does it bolt onto the stock axle back location?
- shift linkage
- WTB CRX HF Exhaust system w/Cat
- couple questions
- 1989 CRX sohc Cam Gear
- Project: Pegoda STAGE 1
- Magnaflow exhaust lengths?
- D15B Vtec wiring
- B16 turbo
- Radiator specs on '91 civic
- Swapping from SOHC non vtec to SOHC vtec
- Pics of worn synchros?
- mounting my intercooler
- springs on 1990 civic hatch? help plz
- What do theeeeeese do!
- Price For a 91 CRX Si
- 1988-1991 civic hatchback carbon fiber spoiler
- gameboy for tunning??
- LS Crx Owners Enter
- i think i just f'ed up my new carbon friber hood and a question aboult it
- Question about B20/VTEC
- Suspension is fucked, worth fixing?
- =)I love gettin' new stuff
- door removal on crx? easiest way..
- EF8/9 Carbin Fiber Lips - GB?
- what shoes to use /w aluminum hf drums
- What head gasket for ZC?
- carb'd 2nd gen crx?
- dual-port to multi-port conversion
- Traction bars - Ride quality
- oil jet (asap)
- b20 crx
- 90 civic si free no title? take it or no??
- possible clutch tranny problem (clutch wont engage)
- B16a Crx (stock) Time Slip: COMMENTS?
- Automotive Conversion Formulas
- Engine swap in Richmond Va
- crx suspenision problem..???
- Buzzing noise from IACV area?
- stillrunning extremely RICH$$$$$$
- car overhearing.
- D15 Turbo internals- What are they worth?
- just bought a 1990 civic...
- 89 civc dx distributer need help
- 88 crx rear shocks to a 89 crx dx
- d15b swap questions
- i did my D16Y8 manifold swap!!!
- OBD 1 data link connector
- Fake J-Racing intake
- where can i find zc pistons??
- Old distributor VS. New distributor
- wtf? please tell me what happened
- Newb Question.....what is this in my engine bay?
- Being bored
- How to keep glass from chipping even more? Superglue maybe?
- Hacked Xmember, is it a problem?
- -roll cage-anyone here with one in a hatch?
- can someone take a picture for me?
- CODE PROBLEM!
- all motor sohc questions
- Taillights, instrument lights all went out, checked fuse plz help
- crx hybrid vtec hook up on b16 need help....
- b16 as of 9-22
- PASSWORDJDM.COM
- give me usdm and jdm diagram!
- Clutch trouble / replacement questions
- trany sound
- need to pass state ref..swap?
- pics of JDM SIR
- WILL SELL SOUL TO DEVIL FOR EF9 REAR BUMPER
- B16A a good deal or NO
- SOHC VALVE COVER..
- Need help refining search,
- Does anybody in here knows how to wire up a vtec?
- lower control arm
- Need source for performance parts '88 CRX
- Getting ready to burn chip for ecu. Anybody have program?
- fs crx in chicago 1300 obo
- Need remove battery tray?
- no0b comming from VW world, with questions....
- need help on swap
- how to change seatbelt harness..crx
- Looking for stock fuel pressure info...
- what color is the plug on radiator fan?
- jdm b16 has been dying but finally died all the way today help!!!!!
- code 15
- 92+ B16 cams VS 97 GSR cams..
- B18a1 swap in a 90si hb
- invidia EF8 exhaust on EF9
- N'gine overheating
- Motor Builder?
- some questions about my sedan
- searching for engine in Washingto state seattle area. or internet shipped.
- hacked paint job.......fixable?
- Need Help- H22 in CRX problems
- 93 integra rear disc on a 88 rex?
- h22a in crx what do i need??
- TURBO CRX...CLUTCH question
- '91 sedan;dohc zc;a/c : what bracket?
- ticket for ref
- Necessary distance from fan to header?
- Turbo vs. ubercharger?
- NOBB
- 94+ integra seat help
- i need help with my swap
- omni power
- Not Sure If This Was Posted Yet (FourthGenHatch Stolen)
- 93 si rear disk brakes
- which layer?
- motor mount trouble
- B16 motor what else?
- Why is my CEL on the dashboard flashing?
- JDM SiR Cluster:little door open indicator wiring. if u have one please read
- Modifications for a gsr turbo swap into a 1991 dx civ
- mini or b16
- anyone here switch to obd1 distributor on 1'st gen b16a
- zc no run
- h23 v-tec???
- any1 knows this crx?
- Going to paint 91 ef hf soon need help...
- Temp gauge and speedo not working after ZC swap...
- ECU codes
- 1991 crx 1.5 won't start after running awhile
- cel code 2?
- Distributor questions 88 & 91
- any go from 16's to 15's?
- dash lighting
- cel p0505 after replace head gasket
- rubber part in rain gutters pops out
- what parts to use
- Dash brake light stays on...?
- I need your extra dizzy, pretty plizzy
- Hybrid Build Up. Who Knows There Shit. Need Compression N Clearance help
- how would this setup run?
- Converting to power locks, windows, cruise, etc. What do you think of this plan?
- fuel psi problem on jrsc d16
- EVERY ONE PLEASE TAKE TIME TO READ!!!
- Accord se wheels on ef
- Swap questions plz help...
- hood clearance
- 1991 b16 civic
- CRX swap question
- Covert 0bd0 -0bd1
- b16 dyno results
- 91 CRX Si w/ b17A gsr and more
- Tranny/clutch Slip Problem
- can u run 110 oct on a stock b16a1?
- 1992 LS cold start problem
- air intake vote
- Problems with ECU wiring
- 91 Civic DX woes/New member
- how much bhp does a 89 civic si hb have stock
- stainless JDM ITR 4-1 header
- need help...1.5 acting weird
- Running Rich, Searched past posts, cant find solution.
- 88 crx rear drums to 90 si conversion? HELP!
- when i hit the brakes, my dash lights up!
- Cheap CRX built
- brake pedal stuck?????
- EG suspension In EF
- Vent / A/C / Heater controller conversion
- $450 for SRJC d16 good deal?
- car wont start sometimes
- ::conversion harness:: service signal help
- bar around steering column
- d16z6 vs DC ZOHC
- is this worth it??
- sorry to post AGAIN but need a lil help
- gt styling side skirt
- need a lil help from the forum
- Civic Picture Thread :: PICS ONLY::
- B engines and oil temps
- Adjusing my clutch cablle.
- b16a1 shift points?
- Spoon Wheels, do they still make them 4 lug? HELP!
- are all d series throttle bodies the same?
- Clunk in the rear brakes!
- I need CRX wiring help! 1988 D16 into 1991 Chassis
- A6 and Z6 intake manifold question.....
- windshield
- 91 d15b2 trouble code 16 won't start
- Mini me D16z6 head to D16a6 block question.........
- where can i buy rear discs for 89 civic si hb
- ok getting rolling chasis crx
- sway bars diameters?
- Cheapest place to buy OEM shocks? I don't need performance ones...
- help would i have trouble putting this header in my crx?
- Location of the CRX Map Sensor?
- front disc brake conversion question not asked
- The LS came out!!!
- burnt out starter?
- wrecked CRX
- check engine light blinks twice??
- 91 Honda Civic DX
- Submodels civic EJ9
- wtb kit ww/mugen kit for 88-91 crx in chicago
- Your opinion on the Energy Suspension Bushing Kit.
- Distributor troubleshooting. PLEASE help
- 4 door power locks on CRX?
- Wiring help!
- quick question about valve cover
- Clutch noise / Tons of exhaust smoke
- what is an old stromung worth?
- 84-87 tranny same as 88-91?
- need help quick!!! cam cap removal please help
- lighten flywheel for 87 crx si
- Block Cleaning
- Front bumper light connectors
- Found a new daily driver possibly (91' EF Si)
- D15B JDM Vtec vs Mini-Me
- WTB CRX MUGEN/WW KIT IN CHICAGO
- eBay parts any good?
- Puc Request: Polarg H4h's/Raybrig H4h's in JDM headlights
- DOHC ZC engine question
- turbo rebuild
- Linkgage... did i F anything up???
- 400kw CRX
- to keep or not to keep?
- QUICK HARNESS QUESTION
- Horn wont shut off?
- my crx has a hydro tranny....swap question???
- anyone ever try this bracing??
- Where could i get a glass roof?!?
- price of clutch
- Quick Weird Question (zipps up flame suit)
- Please help!! turn signal problem...i already did a search...found no answer...
- Universal B-Series Parts
- Turbo manifold question
- i have no codes and my vtec is not working need some help thanks
- anyone have the new Password JDM carbon fiber lip for SiR??
- Suspension Problem... Go Foward - Negative Camber, Go Back, Pos. Camber???
- Oil smelling like gas
- DIY amber corners?
- HELP!!!!! Broke alt. bracket bolt when changing water pump.
- To anyone running a pw0 ecu in your civic.
- whats cars are these ecus from
- (searched) knock sensor on d15b vtec.
- grounding kits/oil dipstick
- Round of applause for EL Vap133 - very dedicated, great enthusiast
- Need vacuum lines chart of a d16z6 short block into a ef
- iat sensor location>
- Knock Sensor issues
- Need help FAST!!!
- 90-91 Civic / 89-91 CRX "Passive" Seatbelt Poll
- CRX GSR swap check list
- Seatbelt beeper/buzzer
