View Full Version : Honda CRX / EF Civic (1988 - 1991)
- map and tps...color of wires, how to tell different?
- 90 teg auto to manual swap--reuse auto axles??
- FAILED Cali smog please help
- JDM EF9 sidemarkers questions.....
- AC in b16a swap?
- Crx w/ b16..what turbo kit
- i need help, which exhaust???Pics needed!!
- How much do you plan on spending this year?
- aur intake systems.....
- Quick question please help..
- Just pulled off the water pump, now I have an oil pump question...
- What is the valve lash on zc motor....
- just got 89 hatch what to do?
- WTB: CRX climate control and gauge cluster 89 SI
- Where does YOUR temp gauge needle usually sit?
- Custom Exhaust $$$
- Bad Rack Symptoms
- Whats do you guys think of this setup
- b18 swap or turbo'd d16???? need some advice here guys.... pro's and conn's
- 93 GSR price?
- Do i have everything needed?????
- fuel resistor box??
- .how hard is it to take out side windows in an 88 crx?
- Whos Running a B18B in there Crx/Civic ???
- ZC Headlights
- ECU Pin locations....
- MPFI swap help
- how much did ur alignment cost?
- going to osaka today, advice??
- gas mileage of b18's in rex?
- gsr in to a ef.....
- 98 JDM ITR 5 lug suspension which means in EF8?
- new to hondas, need help with door panel
- timing problem
- intrgra console
- Front sway bar??
- which bearing? (trani noise)
- Anyone using integra ST rear swaybar w/ integra (DA) Suspension?
- Those with Rota wheels, inspect them
- how to install wing west door/side pieces
- Settings on Cam gears
- EF steering wheel, same as DA/DB?
- any one selling siR lens for crx?
- 4g civic si IM vs. d16z6 IM
- coilover question
- question on codes
- post pic of your ef
- Another clutch question. ACT related
- Anyone have a TEC distributor coil like this for sale?
- Problem with door locks.
- difficulty on motor swaps, b16 compared to b18?
- the power of my sohc (dyno)
- EG civic lip on crx
- how may degrees of camber
- hybrid compression question lsrods gxpiston z6block and head y8headgasket..
- Timing Questions
- question about suspension on crx's and 92-95 civic
- how much is this worth? (my car)
- B20-Vtec and Emissions
- ZC engine
- Regarding 1/4 mile time
- Is this a good deal??
- Anyone renew their registration? (California)
- ecu upgrade, adds 5-15 hp???
- Civiv Headlight Question
- problems with B16 in 90 civic
- speedo cable
- side view mirrors question.
- gutting the hatch!!
- B16a Exaust Question
- How tight do I set the timing belt tensioner?
- help code four
- ed/ef question about dash; yes i searched................
- lug bolt removal from drums?
- VTi on Honda Motors Online
- AEM camgears
- pedall assembly
- ***clutch pedal misaligned?!***
- timing belt
- anyone in sacramento/davis area have a 1st gen b16 ecu i could borrow?
- anyone using Dexcool?
- in my my door got messed up today, can someone help??
- Paint
- seat bracket question
- Intake air temp.
- ***help-car wont start?***
- a6 fuel rail on y8 IM, yes or no?
- Ls/Vtec head gasket q's
- questionable value on B16A
- white sludge under oil cap?????? wtf????
- d16z6 / a1 piston question
- Clutch question(throw out bearing)?
- How much would you pay for this car??
- amber corners on ebay
- clutch problem
- wiring for jdm crx taillights?
- 2002 LX Coupe Dashboard Question
- Should my cousin trade a 1988 CRX SI for a 1991 Accord EX Coupe?
- 90 Hatch: stupid seatbelts in door, driver side broken? how to fix?
- Has it been done?
- rear camber question
- Electrical problem.... HELP!
- What rear lower tie bar with ST sway bar?
- Car won't start, wierd scratching/buzzing noise
- Colorado EFers?
- panhard bar for 1st gen
- Intake Manifold Questions
- anyone know the d16a6 piston to dome height?
- god damn im tempted.
- Can't get my civic going!! Please help!!
- hf distributer on a si motor
- tranny making whinding noise?
- Engine Wiring Idea...
- California bar sticker...
- Turbo or supercharger in a CRX with a B16
- CRX Emblem on back Center tail-light piece
- H&R coilovers
- My worst fear is coming true........Emmisions
- Squeeking in Front Drivers Side Wheel Area of 90 Si Any Ideas?
- is there any diferance between the engine bay of a 4th gen and 5th gen hatchback ??
- www.jdmpartz.com
- Terminator wings (?)
- VIS zc hood? any opinions?
- is $4500 too much to ask
- heater problem not sure if its the thermostat or blower
- ebay short shifter & strut bars Qs
- majestic parts list ?? wtf is going on!
- My new toy (coilover)
- Quick ?
- Quick engine question?
- carb'd
- A few questions
- JimFab crossmember owners....
- H&R Or Neuspeed
- Can someone tell me where the EF comes from?
- pics?
- Car got hit-AGAIN
- Back hatch
- can I use a cam gear with an aftermarket cam?
- gauge clusters
- This one is for all those one who need info on SOHC vtec swap info........here you go
- Can we use d-series vtec springs and retainers?
- Compression numbers. Whatcha think?
- Brake install Q's
- Paypal $$ for T-shirts!!!! (Im dense)
- how do you take off the front filler piece?
- Stock Ride Height on 90 Si Hatch
- Ack I have F***ed myself
- need help. (wiring)
- Looking for a canadian dealer of Koni's. Need a good price.
- intwo b18 questions....
- got a couple questions bout a head swap. please help me out.
- Help diagnose my lack of brake power.
- About to buy some SS Braided Brake lines Question about who to buy from....
- engine coolant drain plug?
- tach wire at ecu?
- 92-95 Hb aftermarket lip on 88-91 HB bumper?
- where do i get the front under tie bar?
- help me please !
- 88 crx, b18, 12's?
- d16y7 into a 90 dx????
- y8 in my crx
- Rattling noise coming from head area, valve adjustment?
- That's great.... i have a HOLE in my floor
- BBK 70mm TB-CAI wont fit
- d16 power from my b16
- $10,000 plus a crx
- some help
- Cf hood question
- For the ecu chipping experts
- PCV Question, searched the archives...
- Have a strange Problem
- please help with FUMES
- help, car wont go in reverse
- Aside cB18 Engine swap info
- Wiring and ecu questions?
- Where to mount sparco 2" seat belts (Clubman style) in an 89 CRX
- What is this bolt hole for?
- which side is cylinder 1?? timing belt side or distributor side?
- d15 starter prob
- ST rear sway bar: 88 vs 89-91 differences?
- where do i find Forced Induction performance valves and springs for a ZC??????
- What to do wit my crx
- My CRX is giving me a headache. Clutch problems! Help me out if you can please!
- performance d16 springs and valves
- How much restoration have you gone through with your EF/CRX??
- Want to SLAM 88 hatch without breaking suspension. Ideas?
- Can anyone vouche for Blacksheep?
- lowered crx...needs floor jack!
- Please help! LS motor wiring
- ls swap, need to know some stuff
- Does an si TB fit on an hf manifold?
- crx body styling
- Rebuilding Head (did search)
- 91 Std Hatch sway bar install??
- Decent fuel pump for my swap.
- CRX costs $$$ to obtain and secksor.
- what headlight bulbs can i make fit in my jdm headlights????
- quick question about main relay
- Do 4th gen civic si's have speakers in the back?
- code 23, knock problems
- I'm out here in Phoenix
- KYB AGX install help?
- Anyone's stock tachometer suddenly die?
- what needs to be done to put an si gauge cluster into a std civic???
- Method to temporarily drop idle???
- will my a/c setup work in another crx?
- help with SI wheels!
- p/n for maininput shaft bearing
- Mpfi Swap
- Rebuild Kit...
- a 4G, a sohc vtec swap and a VAFC?
- hybrid,itr ,prelude,ex , integra, break upgrade
- help with headlight rewiring on jdm front end.........
- WTB: 1989 CRX (HF or DX ???)
- B16A distributor firing order needed. thanks.
- my car drives like shit :(
- that pieces I need for a power steering in ef8?
- Want Factory 90-91 CRX Fog lights????
- Whats everyone think of my setup???
- Well this is weird
- itr head
- 94+ honda/acura pressure plate w/ 90-91 disc any forseeable problems?
- 205's on stock 5" wide rim?
- b16 qeustion?????
- quick help please
- b20 vtec
- JDM EF Spoiler???
- aahhh the jdm front end im getting is white please give paint advice..............
- dx vs. si cam timing
- N20 bottle mounting....
- Are civic injectors the same flow rate as integras?
- Place's that sell NEW or mint used MPFI?
- would this cause the car to not turn on??
- mpfi swap help, i have bad luck or something!!
- swap need help first timer
- Pic of Tanabe Hyper Medallion on a CRX
- corner light blinkers not working, HELP
- Something seriously bent (I Think)
- water problems.....
- confused about crower...
- Help, I did something stupid!!!
- do you care if the resource.crx.org comes back?
- n20 on stock b16
- 88 CRX Tails on my 88 Hatch. Fitment Questions.
- crx tails in hatch?
- is it easy to replace the clutch, brake, and acceleration bracket?
- Can someone tell me what exactly is different between obd0 and obd1?
- skunk2 IM on b16
- quick tranny question S1 tranny.
