View Full Version : Honda CRX / EF Civic (1988 - 1991)
- older civics
- Mystery Wheels...anyone recognize these?
- CRX won't shut off!
- gsr head vs. b16 head vs. type r head
- I hate to admit it, but I'm stumped...
- CRX GSR mount issue...
- Buying hasport mounts, what durometer are you guys running and how do you like it?
- Car won't start if started a few times consecutively.
- seatbelt locked up
- bumper filler on hatchback (did not find answer in search)
- Will 88 Si srings fit on a 90 HF?
- Tein SS with Pillowball Mounts...your experience.
- Speed sensor
- pic request: crx on h&r race springs
- Sir rims on an EF?
- USDM Shell, EF8 Complete CAr, can everything be swapped over?
- stock crx si fuel line pressure
- b18a into crx HF problem
- An accord alternator on a CRX
- where is the VSS?
- ------>Question about pillar trim Look Inside
- turbo questions
- a/c recharge gurus need help with oil
- 88-89 door moulding removal
- where to buy "race chasis" stuff for crxs?
- Ideal for Gas
- FNG with a question on his CRX??
- b16 issues!!!!!!!!
- how to wire the cas sensor ???
- How much do you have invested in your EF? ***Post it up***
- I got one good quick question
- Code 6 coolant temp and 9 CYP
- Harness question
- Best way to install rear motor bracket when droping b series in?
- rear disc part name??
- is a 90-91 intgera engine harness the same as the 90-91 crx si ?
- Bare EF shell build up Pics,Questions,and Comments.
- 1990 ef with b16 distrubutor
- What Should I do?
- b16 crx alternator removal help please
- ROSS RACEING PISTONS
- swap help
- 88-91 CIVIC EF MATS ?
- anyone get good radio reception?
- d16z6 mini me swap questions
- Pressing a bushing
- technical: vtec solenoid quesion
- Notchy Gear box and Popping out of Gear
- DPFI-MPFI b16 conversion gone to hell...
- crx clutch question
- Paint tips..
- sounds from front
- i know what i'm doing but can't find the info i need
- slow revving problems!!
- dash removal
- need help removing axle
- headunit mounting help
- for you crx guys
- :::::PROJECT EF9 EAST SIDE::::
- B16 Cable Trans HELP
- car wont start with key
- performance valve train.... best hp gains!!!!
- Stock (Auto) 91 Civic DX hatch stalled and won't start
- My little Crx
- 88 Civic DX upgrades
- What causes bad gas milage
- My Project ED6
- 91 CRX DX
- crx lip
- 2000 Si Seats in a CRX...possible?
- how to wire up jdm power mirrors?
- Exhaust rattle!
- NC REGISTRATION no notary
- disconnected spart plug question
- crx sunroof
- Deep dish stering wheel for ef
- Painting door moldings
- Need to clear up something....torque and Horsepower..
- Del Sol Seats Into EF
- radiator fan relays keep blowing!
- nead help on brakes
- 215/60/14 on hx rims on my 90 civic si??
- So I picked up my first STD !!
- Wire Tuck Problems
- 91 civic Si /EG front need a write up
- cps wires i search so gtfo flamers
- Parts buying advice wanted!!!
- Lost all coolant, question...
- ls vtec civic problems
- Car wont start have spark fuel just cranks over0
- Almost done my car, teaser shot :)
- anyone kno code 8 on a b16 ecu
- Rotor sizes that will fit
- oil pressure switch
- does my trannie have oil cooler lines????
- quick multi-port swap question
- quick AC Question
- How do you take off code 2,7,9,and 22!!!!!
- Tps sensor
- head swap
- help problems with crx
- ls tranny with gsr motor?
- 88 CRX DX My new $1100 car.
- 90 si ef code 16 question
- d15a3 block & d16z6 head?????
- rapid moving speedometer needle
- Aftermarket Dipstick for Manual Transmission
- head swap question
- JDM Exclusive Si Interior
- Any of you 90-91 guys have shitty fitment of aftermarket corners??
- how do you get the aftermarket slimfan to sit against the rad....zip ties,,lol
- B-swap, speedo doesn't work now
- feeding the speedo cable through the firewall??
- obd0 to obd1 conversion question
- I am throwing code 6 on my b16a, I replaced it and still not working...
- **Clean Autotrader CRX FS nj, *not mine but its clean!
- Water Leak in Pax side hatch strut - and How to remove rear nozzle
- Code 4, Crank Position Sensor not again!
- tweel ( tire with out air )
- CRX DX and B16 axles fit?
- odd ball motor swap
- is a apexi S-AFC II usless
- Are 88 and 90 SI hubs the same? CRX only!!!
- how did you mount your eg raditor in your ef
- wire up ls engine
- no tach
- wire up 97 ls motor with 96 civic harness
- car STILL wont start!
- anyone else have this problem?
- HELP!!!! axle issue
- which belt for hasport a/c bracket on a b16?
- 1989 CRX Si Ignition Timing
- Wheel Question
- Quick question on y1 tranny
- s2k rear shocks on ef?
- CRX and civic shifters the same?
- installing a speedo
- radius rod bushings
- do i need a new fuel pump?
- Crankcase Breather
- Turn Signal Fuse Blowing in EF, always happens when I click the signal lever...
- Do i need new hubs to put on my ef for a swap?
- Windshield
- How much does a stock DX fuel pump flow?
- Went to pick-a-part today
- help
- what do you guys think about these rims ?
- d16z6 vtec crx swap?
- IACV Wiring
- bad rack?
- Zeitronix With Hondata s200
- D16Z6 / D15B2 mini-me distributor problem
- MY ENGINE FELL OFF WHILE I WAS DRIVING
- hydro clutch gsr into a integra cable tranny?
- A/C Belt removeal to facilitate Alternator belt installation Question
- Clutch problems
- doing a mini-me swap have some ?s
- Individual throttle bodie air box
- 2nd gear+ tick, wtf??
- great, now i need a new hood.
- for all you ef fans.. that like eg frontends
- 13" wheels on crx ?
- compensator arm
- 14 degrees BTDC + or - 2 degrees? no color?
- Rubber Lip???? (USDM fit i think!!!)
- rear toe
- turn signals r not working
- 88-89 or 90-91 bumper
- p72 hook up
- Getting Jipped?
- a/c question
- few mods on 89 stock hatchy
- Looking for PICS of headers with TWO O2 bungs welded in....JDM B16A1
- JDM rear hatch pics
- turbo mini me need some advice
- Lets Play: What would you pay?!?!
- Sohc ZC Tune up parts?
- HASPORT cable to hydro conversion, VS Innovative Cable to Hydro conversion
- Oil Filter Swap Without Draining Oil?
- Need IDEAs for the REX
- Turbo CRX project question
- info for crane cams
- Abrupt Timing Change - CamGear Retarded Itself 10 Degrees!! Easiest Fix? Whyd It Happen?
- cams
- WTT glass top
- 2 ga or 4 ga for a battery relocation ?
- d16a6 cams
- can i sawp vave covers???
- Last question about body parts, who is fastest in shipping?
- need help with wiring
- help, they wont let me bring my car back with me
- dohc zc bar certified in cali
- what bumper is this?
- Skunk2 Cam Install Help
- bolting up hasport a/c bracket?!
- mpfi IAT sensor wires
- Anyone have a D16z6 for sale??? in good conditon!!!
- need help fast!!!
- ls wiring?
- what exactly . . .
- Difference Between 2nd gen Crxes
- DSM injector install
- D16y8 CompleteChangeover into CRX
- help! 89 si dashboard in 88hf crx
- car running funny
- Any EF8's Out there with 100% clean body no dings or rust??
- TDC Position
- was wondering if anyone had this pin out instructions
- B16a Axle question
- Mugen Replica front bumper fitment.
- Anyone need an exhaust for a crx?????
- spring question
- 91 CRX HF swap, IM LOST!
- Sorry for being ignorant... camshaft seal question
- 1990 Crx to 1990 Civic
- terrible incabing fuel smell
- 90 Si/D16A6 removing tranny bolts (engine and mounts)
- engine build
- bulbs for ef9 front end???
- need help!! transmission problem
- my 90 civic dx
- how much oil
- b18a head swap to a b18b??
- fenders
- 90 Si/Clutch job/safely supporting engine while tranny is removed
- Anyone have teins with the EDFC
- my rex is trippin
- ZC what is this thing on CAM?
- Brake Issue.
- for people around san diego or SoCal
- code 9 ??????
- hood wont release
- Bottom end blues .. PLEASE HELP !
- CRX Si Sunroof opens doesn't close
- Replacement bulbs for 91 civic can some on let me know what ones I need>?
- My ef is wrecked....
- 89 Si
- Couple Swap Wiring Questions
- whats needed for a mpfi conversion on d15b2?
- problem with ingall camber kit
- 90-91 ZC/Si headlights in an 88 CRX?
- 89 crx SI ZC motor swap questions pls help me out
- 89 Civic Hatch
- After Market Cams for a dohc ZC??
- b16 wont rev past 2500rpm could this be the dizzy wiring backwards?????
- I am throwing code 4 on my ecu(PR3) and 24 ?????
- Pic request: EF w/ Eibach Pro-Kit
- GSR shifter in EF linkage
- TB is in need of some help?
- 3 step meguiar wax system
