View Full Version : Honda CRX / EF Civic (1988 - 1991)
- K20
- NEW - Slow ZC
- CRX maplight install...
- mugen pro2
- tach problem
- swap issues
- 4th gen coilover to 3rd gen
- 4spd conversion to 5spd
- Pretty fustrating...
- Just installed Walbro 255 and now have code 9. DOHC ZC
- custom exhaust
- Throwing Code 1... O2 sensor. Fuel question...
- ZC pistons
- Want the Foglights Like The civic in last month's HT?
- Interchangability of CRX Rear Interior Panels?
- Rear struts and LCA attachment help
- B16a swap into '88 civic dx hb
- B Pillar Outside Window Sash Removal?
- Replacing sheet metal on crx
- Door charm going off when i shut door i need to run new wiring i think.
- Darn MINI ME swaps
- 91 CRX Fuel Pump Installation How-To?
- swaps for 85 crx si
- klanking noise
- 195HP CIVIC 1991
- dont flame... need a little help though..
- What axles... just got off the phone with raxles... Gsr engine/ tranny/ int shaft
- new alternator
- jdm ef8 frontend on a ef9, Would it works.
- greddy vs custom catback
- How would i modifiy a 90 civic hatch?
- D series spark plugs same as B series?
- What octane for 18 degress timing on a D16A6?
- Real time programmin of honda ecu how to's!!!!! no need for hondata!!
- Need Help for Spraying
- need oil help
- key lock hood pins vs regular hood pins ---> pictures anyone?
- D16A6 head with D16 vtec bottom end??
- tranny question need help...
- integra front on a civic
- Has anyone installed a sunroof in there car?
- road race/autocross suspension setups
- aftermarket rear lower control arms
- Missfire OR what??
- Thinking of getting a Sedan?
- which clutch for b16a jdm Y1 tranny?
- Turbo Vtec or non-Vtec?
- HIDs in CRX/EF anyone have them? 20 questions :)
- Walbro Fuel Pump Help. * Experts Only Plz *
- Clutch Pedal Feels Odd. HELP!
- D16A9 for 450 ?
- ZC Sedan Idle to low =\
- B16 Turbo'ing advice needed!
- Need help...car wont start~
- What Honda low compression pistons for turbo?
- just picked up my first crx today!
- 1st Honda
- Wiring JDM EF fog light switch
- a6 with nos
- gimme some good sites to help figure out the best swap
- O2 Sensor help!!!
- Climate controls
- adjustable control arms?
- wtb 90-91 crx si tranny
- d16z6 in '88 crx si runnin pm6 ecu
- Buying a CRX, couple questions.....please help
- tranny
- Has anyone evr done it is leaking bad 94 EX Sunroof in 88 STD???
- replacing head...
- CRX Subframe?
- Door Panels Question?
- Rear Suspension for 88???
- What mods should I do??
- 88 C-Rex si < Dats Waz up!!!!!!
- the drag gen 3
- New steering wheel
- Axel moves Up/Down on Intermediate Shaft? Half Shaft Bad?
- tach, temp and fuel guage just stopped working tonight? What could be wrong?
- VAFC wiring
- Suspension Woes 89si/90si *Is my mechanic wrong* ???
- seat belt location on your crx
- a6 parts on z6 motor
- picture requests...vx and hx rims on ED?
- DFW GSR THEIVES!!!!!
- Valve adjustment
- installed teg dash in my 88 hf
- CRX w/ Half Radiator , what crossmember works ?
- got an idea, ultimate rice mod (pedal assembly)
- Post ur 1/4 mile time
- need HELp
- SUSPENSION VIBRATIONS !?!?!?!?!? HELPPPPPP!!!!
- OBD0-OBD1 hatchback problem, any solutions?
- Small things that make some HP
- Post pics of your EF 4dr
- wings west question...
- How hard is it to change the rear crossmember.
- wtb turbo
- From 88-89 to 90-91 bumper conversion
- where is the transmison plug on a y1 tranny
- COMPRESSION
- the woes of grinding....
- 1994 civic dx swap into 88 hf
- eibach prokit camber question
- 88 hatch door fit on 91?
- HOW TO INSTALL INDIGLO GUAGES IN A 89 CRX SI
- Clutch interchange?....
- crx being parted out...
- What have you broken at the strip?
- Any LS/Turbo Crx????
- smog check in s.f.
- Front bumper question
- Skunk2 ECU Need INFO!!
- Full Integra DA Disc brake conversion! Help --> Upper Control arms (UCA) are hitting fender
- installed ST sway bar, my thoughts!
- Fuel pressure on a b16
- Swap problem - Crx b16
- Anyone curious about high-speed blowouts?
- Intercooler??
- ok, some confusing stuff that i need someone to clear up, then tech question
- What next?
- OHIO: 88 Civic DX Hatch 65,000 Miles Automatic $500 Blown Motor
- H&R Ultra Low Coilovers (NEED PICS)
- can vaumm lines being hooked up make a car feel like its missing.
- My new CRX
- converting to r134a, how do i put the oil in?
- Ignition timing
- FS 89 crx si tranny san francisco
- HKS Sport Exhaust on 4-Door Sedan?
- what tweaks can i do to my d16z6 motor to make it a little bit faster??
- intercooler piping setup
- cutting out crossmember for turbo
- The Worst Day of my life so far...
- vtec test, '90 Si HB, b16a1
- CRX Timing
- Vtec or no Vtec For emmisions?
- what headunit do you hace in you EF/CRX?
- sohc zc questions...
- Info on installing MSD pro cap
- when do you need a new battery?
- Help!!!!! trouble with rear tranny bracket on swap
- MPFI Distributor Wiring Question
- leaks in crx
- start up problems
- Help on intalling b18c to crx dx automatic
- Water temp sender adapter for autometer gauge???
- SPEEDOMETER CABLE!
- solid center counsel
- Hondata Stage 2/3/4
- When do you shift.
- b16a motor mounts
- Polyurathane Motor Mount Question
- help with z6 swap
- Intake draining my battery
- dx/si calipers are they the same
- on what cars will my b16a1 power steering work on?
- dimming headlights
- i want one wipe
- Injector/ecu advice
- Got my rear brakes done, work great as a parking brake but not e-brake
- Brake pedal goes to the floor?
- just got a jdm b16a
- What is my CRX worth?
- Little update on my Twin Turbo ls/vtec crx..
- crx radiator fan on 92+....
- 1.5L dpfi to si mpfi conversion question
- h22 swap question
- Rear disc Conversion toe-in
- What axles do I use!!! B18c with hydro into crx????? Help
- why wont crank sprocket go back
- Zc swap help
- SUSPENSION?? VIBRATIONS!!!!
- where to get a jdm spoiler?
- I need a ZC compatibility parts list.
- motherf***er, i got the wrong engine, what should, could i do
- HF best for swap
- What do i need for ef rear disc brake swap?
- Vent Removal
- CRX WHITE FACE GUAGE INSTALLATION
- NOTE: b16 and jdm stuff for sale in classifieds
- Calling all Cali B18c ef's with skunk2 manifolds
- Rear bumper brackets?
- which igniter for b16a?
- window help
- front suspension
- paint
- B16 B18 1/4 times what are you running??? (mods, times, car)
- Civic Si Office Chair
- What are these Emblems? Anyone have more pics?
- JDM CRX Front End Conversions. Where to buy in Canada?
- Anyone have a bike rack on their EF?
- zdyne ecu install
- Gen 1 teg front seats in a hatch?
- 300,000 miles on my d16a6 TODAY WOOHOO
- attn; jamie
- Any crx ecu other than dx in san diego
- Brake lights
- tie rod install question/concern
- idle probelm after swap????
- Newbe Swap Help
- moonroof/sunroof issues.... psssh....
- d-series motor list
- Will 90 Si exhaust manifold work with HF motor?
- seat rails for 88-89si civ hatch
- Will 89 CRX door pannels fit into an 88?
- Door panel question
- .....has anyone retrofitted a dc2 axleback onto their ef?
- I need a better ratio steering rack (fewer turns lock to lock)
- 5 lug in ef9
- Where can I find a Complete A/C Setup for my car?
- Which starter in your ED/EF?
- stumper (ecu code)
- Crx is getting slower for no apparent reason...?
- wiring with b16
- GSR EF.
- pg7 ecu questions
- Which exhaust do i want for a 90 DX? Any ideas???
- ZC..................??
- Booster/MC question
- civic to crx
- LS VTEC HOW RELIABLE WIT THIS TYPE OF INTERNALS>>>......... 99 ls.
- what to look for when buying a b16a?
- Ground wire for the 91 CRX Si fuel pump?
- whats the price
- Exhaust?
- Honda-tech bumper stickers?
- Y1 Clunking noise....
- Pressure Regulator Cut-Off Solenoid Valve
- Need to see pix of 88-91 civic hatch's...red paint /w red bumper's
- fuel gauge
- PWO ECU CODES?
- hondata question please help
- Another ECU code I need deciphered...
- Please read this, I really need help. Im stumped to a new level....
- what lip is this?
- CTR UnderDrive Pulley on a B16 Not a Good Idea?
- Which Hondata to run on a DOHC ZC CRX?
- Too big a wire for wiring Vtec?
- Power Trunk Release?
- What AEM EMS to run???? Anyone?
- HELP, START MY CAR!!
- What Crank fits D15B Vtec ??
- trbo fuel management
- ebrake cables
- Flywheel Size and Compatiblity
- Switching from 88 DX Rear Suspension to the 89-91 Rear Suspension
- exhaust piping
- Check out this old school DIY
- Problem with my rex??????????
- 90/91 Cluster question...
- 87 Rex gets a b18b is it possible?
