View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Brake Upgrade for '91 CRX Si
- Hasport Hybrid Axles Install
- ECU chip help
- Some problems with B16a
- turbo b16 help pls
- d16a6 block, vtec head, which belt tensioner?
- Buying help...
- which knucles to get?
- grommet head gasket etc! which one
- temp gage
- VSS Wiring Question
- dizzy td-28u? whats it for
- what springs do i get?
- cluster illumination / lights
- Help splitting tranny case?
- My 91 hatch build up.
- Bad thermostat?
- new to crx forum
- THROTTLE BODY ?????
- obd1 question, which wire on the ECU goes to the check engine light?
- Steering rack issues?????
- obd-0 B16A Dizzy Rotor query
- will 91 integra seats fit a 90 civic
- I NEED HONDA HELP ASAP PLEASE!
- d16a6 swap questions!!!
- fuel rail ?
- 91 Integra tranny in my 91 civic?
- tranny problems!!!!
- D16y7 Swap into 90 hatch
- Trying to find pics
- auto transmission problem
- Cutting above rear fender well.
- i need help finding something for my car...
- Vtec on ef
- rev limit at 7700 w/b16a w/gsr cluster
- How light did you get your ef?
- i got a d16 question
- cel-fuel
- DA spring/struts fit on ef?
- help with jdm b16
- just bought a crx corner lights turn signals arent working
- fast question.
- tranny
- A6 dizzy options
- Anybody got that picture of the CRX painted spoon colors
- Boost gauge light
- Just lookin for some input. 90 hb b series
- Timing adjustment?
- y7 head on z6 block?
- Broken Rocker Bearing or Something?
- Steering booster? *GASP*
- b18b complete motor no tranny
- momo steering wheel in crx need spacers?
- Crxpwr1 Project Log ( Bunch of pictures)
- CRX 91' starting issues
- Underhood Fuse box
- Your steering wheel?
- Does a B18 hang lower than a b16?
- crower cam question
- Transmission dipstick issue
- heat- help plz
- OBD1 LIMP MODE QUESTION
- My K24/K20 Turbo Crx.... (Pics)
- what cars came with 16" steelies?
- Widest Wheel
- swap problem..
- crx on pinks allout
- clutch adjustment
- pistons for D-series
- my 4g4d
- Si timing belt cover...
- trailing arm??
- Engine bay detailing questions
- cold start issue.
- what kind of head
- Where's a good place to get amber corners? Don't bash.
- low budget 10.2" brake upgrade?
- jdm zc itm missing sensor mount
- will 88 si rear end bolt up to a 91 si
- tsnoobie question?
- crx si throttle body on d15b2
- cel crank angle sensor
- Replacing Axles, stay loyal to honda or save $$?
- Which axle?
- hood release problem
- FUSE BOX HELP! What plugs in???
- advancing timeing question.
- car slighty hesitating
- my 2007 race car after my accident (1990 ef hatch)
- 92 gsr vacume?
- Finishing up my B16 swap, questions on a few plugs...
- Car has trouble starting after its warmed up
- Weird cold start issue
- Have a 91 CRX DX im restoring, what should i do for power now?
- throttle body
- cluster going nust...
- Some please Help?
- No name headers ?
- (Check Engine Light) -Please help-HURRY
- ebay ecu chip.
- power window questions, autodown & rolling up after turning off car
- here are mine, ef sedan
- OBD II Conversion
- help with wiring tbi 2 mpfi
- B20 CRX wont star after first start up. help plz
- help with fuel gauge and pump
- prelude seats into EF
- ls sprak question
- Crx Doing a H22 Swap
- side markers installation
- tranny swap question
- NEED HELP WITH MINI ME ASAP
- what clutch can i use
- quick question
- I need help on my ls-v
- HOW DO I!?!?!?
- Heat/Coolant/Temperature sensor
- replacing rack end bushing what else do i need to buy
- dpfi tps same as mpfi tps?
- 02 wire up
- GSR CLUSTER/NEED HELP
- Replacing A/C vents
- Calipers compatibility help
- 89 civic seat rails for bucket seat?
- power loss
- how to hook up a shift light.? (not a diy)
- what makes the fourth gen special to you??
- Cusco???
- Mini_me questions?
- b18a1 in CRX vacuum lines?
- 90 civic with b16a Oxygen Qustion
- convertingcrx from auto to manual transmission
- magnecor
- Gasoline smell coming from vents?!
- vacuum stuff?
- LAUNCH CONTROL
- Re-drill '96 DC2R wheels to fit an EF?
- electrical problem....why cant cars ever be easy?
- Interchangability?
- good springs to go with tokico blues?
- 89 hatch Dohc ZC no sparkPLZ HELP
- B16a tranny
- Spark plugs and mpg
- No Spark! What is wrong with it?? Help
- vx head
- Brain Dead
- what is the best rear lca for my 91 si????? best brake upgrade?
- 9Walmart synth - is it worth it?
- In need of help spark problem is driven me nuts
- d16y8
- How do i get full access?
- 5 lug question
- engine starts in START position but then imediatly dies when put in RUN position
- valve clearances?
- vtec solonoid question
- taillights blowing fuse
- what is this?
- searched but cant find thread
- possible seized engine
- vtec speed sensor
- isthis my VSS
- New EF won't start.
- help pleassse noob question
- Tail light Removal issue.
- HEY EVERYONE CHECK OUT THE RULES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Help...How do you remove the shift linkage from a transmission?
- cheap exhaust header... is it worth it?
- slow motion assembly
- crx si rear disc brake question
- rack and pinion
- Wheel bearing
- been too long, need help upgrading obd 0 to obd 1 (Turbo b20)
- bumper lights
- b16 tranny
- No power to Heater Blower Motor?
- WATERNECK FOR OBD0 B16A HEAD???
- Skunk2 test pipe interchangeability
- Will 92-95 si sunroof fit a crx si??
- clutch pedal just crapped big time.
- what would you guys do tranny swap
- Quick question on what plugs these are....
- CRX ETD traction bar vs Innovative traction bar
- anyone ever bough oe style upper controll arms on ebay
- motor for my 90 hf
- CRX bogging bad
- code 43
- Change the color of interior lighting
- Power steering in a sir??
- Grinding noise during deceleration
- wtb jdm b16 head parts, upper radiator hose water neck...
- goin to the junkyard wendsday
- transmission question
- spark plug wires
- obd0...obd1? ay corumba
- Radio removal & ac vent replacement
- i have searched for jdm zc wiring diagram for distrubutor
- CAR WONT START
- boost help
- CRX Camber help
- just a quick bushing ?
- where can i find new factroy black carpet?
- REV LIMITER HELLP!!!
- 88 hf cluster and 89 dx cluster the same?
- Anti Theft Technology Sleep better @ Night
- Everyone read the rules, check it out!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!
- Please read the rules!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!
- They tried to jack my car! Couple questions on ignition switch wires.
- car wont start wont even crank over.
- 2007 FL CRX Meet Pics!
- Jackson Racing SC - B16 Owner question??
- cel on dash not on ecu
- EF DC QUESTIONS
- my car boggs underload
- B16 EF block question
- D15B Swap into an EF
- Freakin wierd ECU code
- starting issue and warm idle fluctuation
- order parts help with rear quarter panel window
- 91 Si Hatchback seat swap question...
- climate control
- name what's causing this sound!
- ls no vtec.. need help!!
- crx HEATER core
- 91' hatch shell with full interior and good primered body. whats it worth?
- will a B or D series throttle body work on a dohc zc
- would you pay $2000 for a 91'crx shell w...
- eg springs on ef
- valve stem seals
- real difference?
- Going to Look at a 91 CRX DX Auto Tomorrow...We need advice
- B16 CRX crusing issues.
- Metal Shavings in my oil pan!!!! Time for a rebuild???
- My first ever attempt using bondo...crx is the test mule
- My b16 swapped CRX gets 30.5 MPG...is this about normal
- what is this?
- Jdm taillights 91 si hatch whats involved in wiring?
- imput shaft bearing
- having dizzy trouble
- Oil pressure sensor wire mix up
- No cluster lights or tail lights
- A little mini-me clarification
- were can i get a obd0 distributor????
- OBD0 -> OBD1 conversion woes. Only two legs on distributor?
- Copper "hairs" inside dizzy
- Honda / Import car owners in California....................
- 90 Hatch parts to 88 CRX
- Modified CRX article
- innovative b-series mount on order. what rear mount bracket to use
- whats a good alternator brand ?
