View Full Version : Honda CRX / EF Civic (1988 - 1991)
- any meets in the LA area??
- Oil In Distributor Cap? Please Help!!!
- how do i add 2 more injectors into the IC pipes for my d16a6
- A6 block to Z6 head more power? Ya right.. What's wrong!?
- crx and 4g's are they all pieces of chit?
- crx seats/headrests.
- Swaps arent that worthwhile...!!!
- Can i use this radiator? 91 CRX HF : help me out.
- Tuning a CRX B16A Help please
- I must find a solution: B16 o2 sensor(s)/ECU problem
- Anyone have heard about sprint suspention product??
- meet
- Is a D16 really any better than a D15??
- b16a Y1 axle problem help
- New Noise that goes away when I push in clutch.
- Shhhhh.... I want a quite exhaust any ideas?
- im a new owner of CRX!!!
- i messed with my wires now my car wont start....
- ST sway bars (another question)
- Dohc ZC + Nitrous!!
- Where can i find a good quality zc
- whizzzzzzzzzzzzzingggg alternator
- My car is FIXED....got my Action clutch installed....Wastegate replaced (56K warning)
- what should i set my aem fpr to
- Brakes ? help.
- quick appearance question
- Any Tips or suggestions for Emissions?? Post them here
- plaese help
- 15's on a rex, what series tire?
- WANTED:88-91 CRX rear bumper
- will usdm si gauge cluster work w/ b16a
- Wheels and Tires
- is it worth it?and will it fit?help fast!
- how hard is it to replace the head gasket and what should i use?
- Code 3,5,7 on a D15
- ZC: What are the axels out of?
- HKS ZC Cams ...!!! 10.3mm & 9.0mm with 256 duration
- best header for ZC???
- B16 1st gen install please look at this pic what did i do wrong.
- New Car
- bolt pattern for rex
- i need help on a swap
- ZC inner CV boot repair...which car is the axle off of?
- Need to have a key made, can I use one of the door locks?
- where can i get the jdm civic hatch side skirt and rear lip?
- I need pictures of dpfi -> mpfi
- What size piping for NA car
- Looking specificaly for a pic of a CRX With Flared fenders....
- trunk latch problems
- rubbing noise only on left turns, please help?
- Advan TC?? help
- Big swap! Have you seen this?
- 91 Front lip?
- Switching a CRX from Automatic to Manual
- HELP!!! fuel pump removal
- 84 civic 4dr whats it worth??
- Shift linkage removal in 1st gen CRX? HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- used clutch
- 1987 CRX for $200. Is this a good deal or not?
- DIY custom exhaust
- brand names of headers....
- i need an engine please help me
- biggest disc brakes in rear w/15" wheels
- who has the codes for b16 jdm
- std-si conversion
- need home depot lip help
- Quetion about a 91 crx
- for support bumper and foam piece. need a fornt bumper in GA
- 91 STD rear sway bar install
- WHOSE SELLING THERE B16a 1988 CRX SI...!?!?!?!
- The car hesitates and bogs. Fuel problem?
- Need rear bumper in San Diego...
- help with stock brakes....
- please repost pic of all black CRX with WW wing, from an old post about someone selling their swappe
- Is Oil cooler standard on B16 1st gen??
- ANyone Need Stock CRX Steelies/Front and Rear Bumper?
- I need help
- blk crx slide
- noise in suspension
- JDM b16a swap on 89-91 CRX want advice
- Horrible Vibrations!!
- Determing a bad motor mount: Engine moves now..a LOT
- where can i get this bumper lip??
- ZC Turbo Dyno chart, need some help
- B16 safe for turbo?
- if i bore out where the exhaust and intake manifolds come together with my engine will it increase p
- found an SiR front end got questions about it...
- Welcome me to the CRX/EF forum
- Can i use my crx alternator w the ls motor
- PR4 throwing code 5? need help
- ditch the crx for another car, or????
- Just got my ZC Dyno
- Just Wrecked My Car..
- Sunroof Visor?
- another problem
- i took off the restrictor plate under the carb and my idle went crazy.. why?
- Not having much luck..... Anyone here interested?
- ecu reprograming
- b16 intake manifold
- FS: z6 Fuel Rail w/ injectors
- Cam Gears for a ZC ... once and for all :(
- Flywheel performance?
- anyone ever heard of division 13 racing?
- wtb: 88 civic seat rails
- jdm front end?
- JDM D16B, info and answers needed!
- axle nuts 32mm?
- LCA question
- My car was stolen!
- Hood swaparoony
- need rad clearence.
- Gude Performance
- Stupid Question...Should be an easy answer
- What color are the stock corners on a 91 Civic Si?
- removing front bulkhead
- where can i buy a cheap radiator?
- END OF SUMMER BASH!!!!!! North-East Honda Tech...
- MugenEF7!! Found something for you!!
- what should i do???? NEED ADVICE
- Upgrading Grounds on motor.
- 5Zigen Fireball Exhaust Systems.....
- have you seen these bumpers before?
- Body Kits
- ZC head VS Y8 head
- Do all D series motors have the same BLOCK?
- Type R Hosted Chicagoland BBQ - All Are Welcome
- radiator fan problem
- shaving head for ls/vtec
- what guage wire to use? fuel pump.
- TECH ? - VSS: Vehicle Speed Sensor
- o2sensor,cap,rotor for 1gen b16a
- not sure what to do about my tranny?
- painting side mouldings
- some lower ball joint ?'s....
- another rear sway bar question (reinforcment)
- eibach sportlines
- help me identify my civic..
- i hear there is a restrictor plate under the throttle body of STD civics...is it removable? what wil
- car won't pass inspection
- es oval mounting?
- how long will this take?
- AHHHH!!! my transmission is going dying,what do i do?
- Alternator problem...HELP me out guys
- cam to crank syncronization
- quite exhaust
- so i wrecked my civic today.....
- vtec activation switch needed when using a 92-95 Si ecu??
- coilovers for 89 Civic hb
- swapping mounts
- vis carbon fiber hooods
- Hey got a ?.....Friend wants me to buy his 87 SI motor?
- Does anyones PM6 does this??...........
- zc / d16a ecu
- Headerpipe to Cat gasket part #??
- over haul
- Car Show in The Dalles, OR
- B16 or SOHC Vtec?
- How to install HCP front mount
- B16a JDM engines really with low miles??
- Bone Stock 1990 Civic CX blowing white-ish smoke...Any Suggestions!?!
- MPFI/engine swaps
- My leaky hatch
- Any clue as to what this thing is worth?
- code 20 help????
- will crx bumper cover fit on a hatch?
- tech: cars eating oil
- Question on wheels.
- What CRX body parts fit on 4g HB's?
- Project Turbo-ZC in full effect. New Pics/Need opinions...
- CRX front bumper on 88 Civic HB...will it bolt right on?
- What lugs for extended studs and aftermarket wheels
- B16A1 Secondary o2 Sensor Problem
- Spec of 4 door
- Stock CRX Speaker Dimensions? Any info needed.
- B17 trans and YS1 trans???
- Clicking noise???
- I Need Opinions On Tire Sizing!!!
- ZC setups...E/T...1/4 time...
- how much is my crx worth?
- what wiring harnes do you use for a type r motor in a crx si.
- Help me pass smog...
- STD to SI head swap?
- people with b16a1?? questions
- Good Suspension Set-up???
- STR rear diffusers???
- pm6:injector pulse? help!
- quick brake line fittin qs/92+into87????
- Gutting the Bee-itch.
- mods for torque
- Dual gauge pods, 92-95 ones fit in my car?
- WTF is wrong with my gauge cluster?
- Fuel Tank Teg to Civic
- apex vafc on d16z6...
- EF gutted w cage pics
- '00 Si B16 into an EF???
- ?? for ls/vtec with pr3 and ls distributor
- Carbon Fiber Hoods
- What is needed? D16Z6
- changed my mind about the zc
- 89 Civic LX 4D...
- will the exhaust manifold from the DX civic hatch fit right on to the standard hatch motor?
- Aerogear hoods, z-3 fenders, kits
- are hood pins safe?
- DOHC ZC - Thermostat information needed
- What engine should I go for now?
- 91 EF help....
- vx rims??
- best suspension setup
- crx dash swap
- I"m doing a swap soon, and i'm looking for guidance
- Which one should I change?
- experience with place racing front crossmember
- oil pressure switch?
- AEM cam gear timing?
- best Lowering springs and struts for ED9?
- si or hf....?
- Supercharger on Si motor?
- 89 Civic head swap Q?
- 90 dx----si bumpers
- Any EF CRX Put a timing belt on while engine in car.
- B16A1 swap
- Looking for 88-91 Civic HB/CRX in Central Florida area...
- Type R trans???
- Civic/CRX related parts FS and others
- Spoiler for 1G CRX
- are ZC and d16a8....
- Question about 5Zigen...
- spring rate question
- bad starter??
- Fixing to get my zydyne pm6 need advice
- Is it worth the buy?
- how much did u get your b16a complete swap for?
- pics of my crx/motor swap post what you think
- brake pads?
- Purchasing car w/ cut harness.
- Anyone NOT using the manifold brace on their D16??
- Tranny Questions
- do any of you use the msd activation switch for your vtec?
- Ok, it works, CRX Track Video
- Rear lower control arms: compatable from a 96+ civic?
- t/b ported
- JDM ZC Motor Identification..... as opposed to USDM DOHC phony
- Fawking fitting on brake line going to MC is stripped...WTF do i do now?
- Rear Disk Brake On CRX ?
- z6 intake question
- Lock up control solenoid??? wiring gurus please help
- Turning a d15 dx motor into a si motor.
- What are some of the sites that have.......??????
- ? about future motor swap? I need some guidance
- Replacing my driver door window
