View Full Version : Honda CRX / EF Civic (1988 - 1991)
- What cams for my P&P B18a1
- vafc?
- What do you think, Front mount CAI. Pics.
- koni yellow question
- pg7 questions!!
- Car's acting strangely....
- Dizzy that fits D16z6
- dirty sleezy cheap cheating n2o
- HEy Q about a b16 swap in a EF
- TORCHING SPRINGS,Installed new shocks, it raises the car lol, HELP
- CPS MPFI Swap Wiring
- just got the obd0-obd 1 conversion harness from boomslang
- should i get kyb gr2 shock for my 91 civic si or something else
- AVID motors mounts
- HELP!!!Headlights wont work!!
- front clip
- question about master cylinder
- My "fun" experience with the rear suspension on my CRX
- CRX AC
- turn key no power.....
- CTR cams
- PLEASE SIGN THIS PETITION TO SAVE NHRA DRAGSTRIP "ENGLISHTOWN"!!!
- Looking to buy CRX
- Latest pics of my setup.......56k warning
- Ignition Coil
- slight oil leak.... wheres it coming from?
- Which readiator hose goes were???
- Tuning problem.
- zc rocker arm help
- obd1 dist in obd0 car?
- HF to SI engine wiring, please help!!!!!
- boosted B16 or B18C1 all motor..............
- sohc swap questions
- mugen power
- HKS turbo timer install
- Starter problem help ASAp
- Hood clearance help
- cam belt change
- help with my gsr swap
- Where does this hose go on DOHC ZC IM?
- crx lsvtec with pr3 ecu
- How uncomfortable would 17's be on a CRX?
- ST rear sway on a SEDAN?
- 94+integra seats into EF?
- Rear disk brake swap questions
- tire size 90 crx hf
- What crossmember/traction bar kit fits big headers?
- converting from dual port to multi port?
- B16 sputter?
- Need a measurement in 88-91 crx!
- 90 crx dist on y7? 90 crx dist on z6?
- check engine light came on, ecu had constant light
- d16z6 head+d16y7 block equals what comp ratio?
- Fitting a P28 ECU into stock location in CRX
- lsvtec for 1500.00
- which throttle body?
- engine swap
- anyone got a manual rack they feel like sellin?
- Hondata Troubles
- How To Adjust These. Throttle Cable? (I forget name dammit)
- Cable Tranny B16 101. Need help post your expierience.
- i change the O ring on 1989 CRX DX IT WAS LEAKING FILL THE RADIATOR UP CAR WON'T STAR DAMN IT NEED
- d-serise axles
- obd-2 help!!!!
- Hamp oil filters
- LCA Bolt Unremovalbe, How Do you Guys Remove Stuck Bolts Without Air?
- Help - breaks to put on my 88 CRX si
- SMOG/REF Question(s)
- fiberglass hood?
- Anyone in New Mexico???
- Cold air intake???
- which crx would be faster?
- master cylinder.
- d16y8 intake manifold swap *searched*
- 89 Crx DX with 93 b18a1, a/c question!!!
- Anyone from the North Eastern US?
- Installed Vafc now CEL code 8
- ASAP HELP! Changing coils, do I need this sleeve? Comparitive pics
- Distributer problems!!!
- 5.0 stock VS HF B stock series WHO WILL WIN??
- VTEC or LO-TEC
- wheel stud[S] stripped......crapola!
- Bad ECU?
- What is this green crap?
- d-series mounts
- Car not starting help...
- 94 civic suspention on 88 civic
- cracklingat 3000 rpms coming from exhaust.
- speedometer help needed, picture inside!
- what is tHIS thing?? out of z6
- Changing the alternator...HELP!
- would a dohc dizzy fit a 90-93 ls motor b18a
- K20 CRX Pics ??
- DA disc brakes conversion
- 4 wheel disc breakes ???? on a crx
- Are 90-91 EX knuckles heavier than Si, DX knuckles?
- my ef wont start need help
- new to the forum
- Will a 92-95 Civic alternator fit a 87 CRX?
- Vtec wiring Pin in a8 already (pr3)
- What sensor or valve controls this?
- which fenders and doors could fit my 90 crx dx?
- Do I have to use threadlock on the 8 main flywheel bolts? (B18C)
- Front/Rear WTF EASY SUSPENSION QUESTION
- new forum for only va,nj,ny,pa
- custom 2.5" exhuast vs stock exhuast w/ cutout w/ 2' pipe
- Ecu light???
- Crx X-bar bracing??
- HOW THE f*@$ DO I DO AN MPFI SWAP!!!!!
- will integra console fit?
- Thinkin bout a pre 92 hatch
- v tec switch
- Maxspeed coilovers on a Crx
- d15b2 head parts on a d16a6
- my friends hatch got broken into
- Alternator question?
- SI cluster into an STD civic
- y8 manifold into a d15b2...
- interchangeable coil for B16?
- motor swap....no start
- just bought crx shell
- crx dx - JDM 92-95 Civic CX/DX (d15 v-tech)?
- FS: Tein ha coilovers w/integra type r control arms, S.T. Sways, pm6 ecu's!!
- Crank pullie bolt on a D16A6
- tranny problems with my crx
- How To Modify A6 Dist To Fit Z6 Head ? PLEASE!
- brakes??
- hesitation?
- Need a price estimate on a B16A1 OBD0
- stupid question
- ZC DOHC In A 92 Civic DX??? Will It Work???
- ASAP need to know by tonite!, will 91 crx seats bolt up to a 90 hatchback std?
- searched already. 2000 Civic Si cd player install question
- Money Back Guarantee
- ef suspension upgrade
- vti cluster problem??
- brake upgrade
- D16a6 clutch same as D15b7?
- crx wire colors and ecu pin outs (repairng hacked harness, some wires are the same)
- Emissions in wisconsin
- ls swap
- Possable engine swap question.
- TPS Aftermarket Suppliers?????
- Help on my 91 Hatch
- Problem initial starting engine, or re-start after shutdown, please help...
- Anyone wanna finish the b16 swap in my rex?
- Clutch/ Flywheel question
- cel 17 ?
- Question for those with H&R race springs with Tokico Illuminas
- wiring harness
- Rear Wheels locked
- locate speedo cable?
- MOTOR SWAP D-16Z6
- FS..........((((alot of 4th gen civic stuff))))very cheap
- MPFI DPFI Wiring Diagram??
- which tranny is better?
- DC2 Seats in EF
- VAFC wiring help
- Is my flywheel too light?
- acvd
- OEM foglight kit installation instructions?
- Won contest
- Pics of my 1991 Crx Si (56k dont worry)
- stupid deer
- At what point will traction be an issue?
- which heads will fit my engine?
- Smog ref questions
- went to the track last night..
- Nevada folks please answer...Rusted cars in Nevada?
- Tighten mount bolts. TIPS???
- ZC in 88 DX HB part throttle miss
- Valve cover gasket
- GSR or B16 head for ls/vtec?
- CRX/Civic rear arches the same ?
- //////SCAMMER ALERT WA State.\\\\\\calling all WA guys
- EF8 JDM Climate Control ***Done the Search!!! 673 Topics, No Info!!!!!!!!***
- D16A6 / D16Y8 mini me article
- 87 civic DX?
- I need some help and parts
- wheel spacers
- What's it worth?
- seatbelt warranty?
- CRX battery relocation
- What upgrades to do my D1 vtec???
- FS: clutch, ctr door panels, dash block off tray, stock door mirrors
- is it ok to run this ecu?
- wtb EF cluster W/ tach
- Will these body parts fit on my cars??
- wherre can i buy a knock sensor?????
- VTEC studder/hesitation HELP PLEASE
- DOHC ZC Oil Pan
- Where to get this lip
- I blew up today :(
- need help with a turbo ?
- Writing a paper
- My Motor Build 56K DIE!
- Who wants to give me some specs on this motor?
- windshield help!
- 90-91 CR-X owners w/ amber corners, can you please post pics? (searched)
- 14 sec n/a d16z6, possible???
- Video diagnosis.....
- Place racing axles for a b16 in a n 88 dx hb ?
- rattle on timing belt side + leak
- NEED HELP WITH ENGINE MODS!!!!
- injector resistor box?
- 88-91 Civic hatch runners on a CRX..will they fit?
- How much power you ls/vtec guys making?
- Get her to run!!
- s2000 motor and tranny
- God pissed in my CRX today....
- Guage cluster question
- ....b16 hesatiation prob....plz help
- what is the best manifold?
- 87 CRX engines?
- someone want to make my life easy?????
- CRX + B18C5
- code 16 mpfi help
- real pm7 ecu on ebay 99 buy it now(not my auction)
- Swapping door window glass
- Which engines come in a four door?
- b18b in crx
- FAQ: removing flywheel using nothing but a ratchet, 17mm 12pt socket and 9/16th box wrench? no preob
- Removing Tailgate Upper and Lower Trim Panels (CRX)
- B series swap in a 89 civic
- 150mph speedo for a rex? WTF?
- tail light problem
- fuel pump (short somewhere?)
- need help picking out new muffler
- Stick with a d15 or go with a d16
- Better to loop or cap off cable VSS for b series?
- Type-R internals in cable casing
- CODE 5 [SEARCHED]
- does anyone have a 88-91 crx si distributer.
- which oil for y1 tranny?
- Codes 1 and 7
- NEED HELP W/ JDM DOOR PANELS FOR CRX
- Cup holder questions
- Engine Swap Starter Help
- Ls header fit on a 1st gen b16???
- Is it safe to ride on chopped springs.
- IF YOU LIVE IN WESTERN NORTH CAROLINA BEWEAR
- Main Fuel Relay Part Number Help
- Some updates on my CRX project...(PICS)
- Stay in the Honda Game or Nissian 240
- RC Engineering balance/blueprinting results
- b16a ys1 clutch (already searched)
- 90-93 rear disc on 89 STD
- Can i put eg springs on my crx?
- Jumpy Tach
- WHAT OIL WEIGHT TO USE ?
