View Full Version : Honda CRX / EF Civic (1988 - 1991)
- HELP! Mini-me not starting
- B16aY1 passenger side wheel locking up. possible axle issue
- Stock D16A6 missing after warmed up when hot out
- OBD I conversion help, runs fine with pm6 and td-02
- honda crx si starting problems
- Lowering Civic hatchback with oem struts
- 89 hb b16a6 swap wont fire please help
- Clutch Install- Car Shakes
- Where to find pg6 pistons? Or something comprable
- d16a6 Timing Belt Change
- Is there a difference between 88-91 A6/SI distributers?
- 90 EF Hatch Wheel/Tire Questions - 15x8, 205/50/15
- Stripped Trans Bolts...
- Weird one: Oil Leaking on Passenger side of Civic
- 88-89 to 90-91 Cluster swap
- The new daily driver. 91 civic ef.
- My First Project Car (CRX)
- EF Hatch Beater, to be or not to be?
- Speedo Cable
- interior
- Changed spark plugs today - Oil on Plugs ?
- PW:jdm battery relocator and hybrid motor clearances?
- 98-89 parts compatibility
- HELP! oil fouled plugs and bad compression
- PL Premium Polyurethane adhesive for WW door caps?
- Will 89 civic sedan cluster fit on 90 DX hatch ( manual )
- New to the site !
- Anyone selling a 91 crx dx complete wire harness??
- 1991 civic no crank
- Clutch problems...
- b18a1 into 89 crx hf obd0- obd1
- 91 hatch wheels 205/55/16 tsw rims rub like hell
- 91 Hatch Seat Ideas/ Racing Seats?
- 1988 HF - Throttle Body replacement
- New Member Need Advice on '91 Civic Si Build
- oil pan gasket question.
- Ref a 90 ls in a 91 ef possible?
- car only starts with jumper cables
- Auto Accident 89 SI what now?
- Beyer's Build Thread
- need manual for cr-x sir. has anybody links?
- Rookie Swap Help!!!
- How many miles/kilometers are on your EF?
- How much braided line for ef hatch fuel assembly?
- engine swaps
- 91 EF HATCH QUESTION
- tach and engine temp gauge going weird
- little bit of water in oil pan.
- DOHC ZC Oil Filter Question
- fuel pump ?
- 91 hatch not starting shortly after stopping.
- Source of oil burn?
- Gsr smog ref'd in a crx help
- Apexi VTEC Controller
- 91 hatch dx steering problems :( Help me
- dp to mpfi questions
- 1991 Honda Civic DX Fuel Issues?
- d16z6 ef hatch problem. main relay?
- ef 4 door radiator support
- will a 90-91 civic front bumper support fit a 90-91 crx
- B16A injector wiring HELP
- Serious Help Needed with DOHC ZC, please!
- 91 EF HATCH
- Want to buy used lowering spring for 91 hatchback
- Hunting idle caused by sticking throttle
- wiring help!
- weird problem
- Dash Lights and more
- Help with EF 91 build
- 3 major problems with Gsr swap. CEL diagnosis? limp mode? Vacuum?
- Codes 8 & 9
- MPFI
- N18 Nigara CRX meet, Largest CRX meet in the world, July 21st
- 89 crx hf NO SPARK HAAAAALP ME!!!!!
- ecu codes need help
- speed sensor cel!
- Full Race Traction Bar, Innovative Mounts, B18CR, CRX
- My skunk2 throttle body wont bolt up to my 91 hatch Please Help do i need a manifold
- Car wont start help
- D Series header
- bad idle slight knock running not right b16a
- 1990 civic hatch..project rat rod
- Rear Brake Upgrade Question
- bent valve, piston ok?
- b series trans lever isue
- smog test
- Vtec issue
- 89-91 vs 92-00 civic rear suspension PasswordJDM
- 91 DX TACH WIRE
- cadin harness for 91 si
- EF Suspension Tale
- Fitting dr20's on to my Lowered EF Offset question!
- crx 91 si front bumper will it fit 89 crx dx ?
- energy poly master kit
- 91 ef si d16a6
- BRIDE seats
- Red-Rocket's 91 CRX slow build thread
- '88 CRX Project Build
- LED Cluster Bulbs. I want to update the look of my cluster
- 25/40 prop valve?
- 91 DX Wont start...
- CRX H22A OBD2 Swap; can it be done?
- High Rev w/Brake/issues
- 88 crx d16z6 swap code 14 and code 20
- mini me in crx
- 91 ef HATCH SEATS.
- Main Relay, Honda Vs Aftermarket
- Axle hole plug? -searched-
- I think i have the worst MPG on a stock EF ever
- 1988 Honda CRX Build
- d16a1 obd0 CEL 8
- head gasket issue
- my 91 civic hatch project
- Guage cluster in French???
- HELP with 89 Civic Si B18b1 swap!!!
- ls non vtec build
- Window visors that almost fit
- db2 engine harness into 91 si help!!!
- Need help getting my ED civic bar'd.
- CRX SCCA Club race video ENJOY
- Walbro wont turn on???
- will a DA driver side motor mount fit my b16 swapp
- b20b 0bd0 89 crx CPS code
- Crank angle sensor in B20 swap
- Tires and clearance question
- AC recharge questions
- I cant read japanese, can someone take a pic of there interior fuse panel...
- *PIC* E-brake only engages one wheel, cable stretched?
- HELP I NEED A TPS
- 91 sedan auto seatbelt help
- honda civic ef4 long shaft
- treasure i picked up at a socal junyard for 30 bux.........................
- Question about back-pressure.
- where is ign relay for 90 civic hatch
- Rebuilt Honda Engines in Cali?
- jdm sport camber kit ??
- help need.camber kit
- will starter work if i only have one of the two mounting bolts holding it on ?
- How tight should THIS and THIS be?
- 88-91 crx si jdm honda 3000 for sale
- Auto to Manual questions ( 90 DX hatch)
- Fuel Pump or distributor or spark plugs? most likely cause?
- 1990 automatic ef with bad tranny
- oil presure problem please help
- 89 crx b18b1 swap need help please!
- Pics of different front ends EF9/EE9?
- Cheapest rebuild possible
- stock hubcaps
- 5+ year old rotors go out of round? Sure looks like it
- 1990 Honda CRX HF Climate Controll... Automatic ????
- A new beginning for the front end...
- bent radius rod?
- Honda 1991 CRX Mugen Project
- Honda from Hell, need wiring guru
- autometer air/fuel ratio gauge not working...bad02
- D15b1 timing issue on my 89 STD Hatch
- crx electrical problem
- Distributor Bolt is Stripped
- oil leak
- Rare parts for my Resto/build. CRX SI
- A little help please?
- [Nicolay45] CRX EE8
- D15b "chugging" low load
- Brake problem
- B18C1 Turbo Build Help/Opinions
- Cany anyone confirm a RHD rack end bushing is the same as LHD?
- OBD2 to OBD1, What to do about pcv?
- Under hood wiper fluid nozzle
- First time clutch replacement
- biggest POS on here!
- Strange problem with my front corner lights
- skunk2 intake ?
- crx obd0 to 0bd1 misfiring no codes
- Lil Help.. Please on Air Intakes!
- diff in usdm and jdm front bumper?
- Should the rack end bushing have ANY play?
- Would a re-man steering rack come with a rack end bushing?
- CRX Build - Vol.2
- Semi built gsr untuned drivable?
- CARB legal vs. NON CARB legal Cats
- Bumper filler panel 88-89 vs 90-91?
- crx JDM B16
- 91 EF HATCH HELP.
- what do i do?!?! so much rust!
- DTC CODES on my ef
- D16z6 spark issues. Help!
- CRX B16A
- CRX Bogging and Dies Out
- 91 civic with d16z6, CEL 4 ???
- EF 4dr JDM Whole front clip?
- Inner tie rod boot ripped, necessary to replace?
- Does anyone have
- D16A6 removal, not sure what this is
- CRX B16B swap help?
- Hey Honda-Tech, good to be here but my Passenger Door Lock is Jammed
- if turning crank by hand, should the cam gears be turning too? (with no timing belt?)
- 1991 EF with an LS Motor is running really rich
- d16z6 low impedence injectors
- ED to EF Headlight Question
- 90 si hatch project
- 91 ef d15b1 wont start after dropping gas tank
- OBD0 Codes 1 and 43 - O2 sensor Question
- is running an engine without coolant for a very short time ok?
- 91 ef hatch build tips???
- 1991 Crx Si
- A/C guru's, please lend a hand
- 1988 CRX hatchback support struts
- Front brake caliper options
- Picked up a 91 SI for $500
- 88 crx si swap 91 ls motor...
- Found a civic wagon for $200
- Crx - Prelude Master Cylinder Upgrade questions
- Does this sound like a bad igniter?
- CDM power tray mod
- Single cam ZC Help!
- 91-93 teg rear brakes on a 89 hatch
- Hardened plastic vs Ceramic wire harness
- i bought this hatch for $800
- b18c swap code 8
- Crx B18b1 swap issues
- Are all relays the same?
- WTB: Coolant Temp Sensor PLUG off of harness
- Ebay -Upper control arm with ball joint
- Ehh hello Honda-tech
- lsvtec oil loss and tb problems
- Unable to reconnect right radius rod
- Civic Wagon Bard B20
- 91 Ef hatch BRIDE SEATS
- Steering rack question?? Power vs manual!!
- My CRX seats are killing my back
- 91 civic wagon 4wd, o2 sensor/ tps, help
- JDM Parts
- 1990 Crx HF daily project
- both fans on when engine is cool
- 89 Civic Si w/ D16A6 power loss
- How long are obd codes stored on the ECU
- 91 crx si special edition
- CRX Not Charging/:
- hot....
- Body flex solutions?
- my crx all the sudden sputters...help!
- b18a gutless under 4k rpm, bad throttle resolution
- Is this an 89 style rear LCA. Better than 88? *PICS*
- Fat Five curb rash. Help?
- d15b1 throttle body vacuum leak issues
- Main Relay?
- Auto air con, how the tempature control works?
- Lost a rod bearing
- 1991 Si front wheel hub
