View Full Version : Honda CRX / EF Civic (1988 - 1991)
- swap problems b20 in crx
- Crx keeps dieing. Need Help
- grinding while turning over
- Stupid, But 2 wheel burn out?
- Prelude wheel.
- obd0 si dizzy spliced for obd0 dx dizzy???
- d16 engine witha d15 tranny-HELP!!!!
- can any one tell me....
- b18b1 hatch swap not starting
- transmissions
- Looking for a D engine
- got a new 90 ef with crazy acting mini me
- vtec lock
- guage cluster and dash options??
- LSvtec help
- White residue corrosion on Ignition coil lead ?
- compression on paper
- 1990 crx si with b18a1 swap won't start
- CV joints or steering rack?
- dark grey si emblem; used on what car?
- 90-91 ZC Headlights questions
- need some mpfi swap info
- Fan size on PWR Full-race radiator?
- a lady pissed on my hatch today.
- 1990 ef sedan suspension upgrade
- hatchback exhaust on a crx
- Getting back in the game
- gsr burning oil
- mini me vtec problem
- Broken Axle?
- Uhh...alternator belt question.
- **Clearance issues, requesting pics with AVID mounts**
- seatbelt warning light? HELP
- Dual point to multi point problem need help ASAP
- b16a1 parts at pep boys...
- honda crx 88 dx.....helppppppp
- front tow hook
- Dizzy hole
- Alternator Belt Issue
- P28 on Boosted SOHC ZC: Doe's not want to start!
- Tech Help Please, 1990 Civic DX won't start
- '90 CRX Si Drive Axle Won't Come Off
- pic request for fuel best looking pressure gauge
- Turboing my Ef D16A8 need advice plz
- D16z6 with DOHC ZC Tranny
- need a radiator support?
- 91 crx cluster bulb help!!
- megan coilovers? good or bad?
- help for friend: battery light is on
- ef sedan transmission swap
- eletrical help
- eg suspension into ef
- ebay 'dropzone' coilovers with 'springtech' shocks
- Will D16Z6 manual starter work in a stock D16A6 CRX Si?
- the mini me runs
- flat header
- flat header
- sedan cluster in hatch?
- '91 Sedan - Can I Convert Automatic Seat Belts to Standard Ones?
- ZC and axles, same as Si??
- 89 Civic ND alternator - Mitsubishi OK?
- B16A IN 91' CIVIC STD WONT START (help)
- Sohc Zc question
- Easy fix or.... Not so much?
- lil bit of water on flywheel and clutch......
- cylinder head bolts sequence
- are hf and si dash harness compatable?
- how much horsepower am i going to get out of a mini me swap
- Vibration noise after suspension change?
- CRX strut rod length?
- crx b18a1 quarter mile times
- Cel code 9 (cylinder Position)
- Can't stay logged in
- Blinkers and hazards dont work
- oem oil cooler rubber gasket
- how high can omni's go?
- sticker and exhaust
- Car wont start unless roll start. Cranks fine
- gsr disc conversion on a 90 ef
- 91 sedan what to do
- Stearing rack fix?
- DA Seats
- HID wiring question
- 92-95 4 door ex rear discs on '88 EF hatch?
- A funny noise, and it is irritating...
- Tranny
- 87 hatch b16a exhaust options
- i need a heater hose diagram for a 88 honda civic dx jdm d15b
- beaks lower rear tie bar
- 3 step/phase vtec?
- noob question
- mini me help
- wiring prob.ef
- code 6 water temp sensor mistery
- fuel pump good and relay good no fuel
- turbo b7 mini me
- couple questions about my gas
- transparent fil or paint over amber on taillights
- IACV issues
- Quick Taillight Question
- ebay coilovers?trust or fail?
- b16/gsr dizzy question.
- Replaced entire front suspension, -2.5 deg. camber?!
- anyone wants to trade their fenders with mine
- oil pressure
- LS vtec oil leak need help
- wire tucked my new motor...
- td01 or td02 dizzy?
- Mixed up cams? aftermarket no markings
- My rear jacking points are rusted out. Can I get my car on a lift?
- engine troubles..
- turning over but nopower at fuel pump
- Question about JDM UKDM Rear Garnish on USDM 91 CRX
- **89 Si kill switch issues i need help ASAP!!!**
- ef si seats!! need help
- dashboard lights, clock, radio not working! help
- Changed alternator, now battery light is on
- avid mounts...
- Quarter panel window clips came off...
- I need some help with my B16A.
- quickquestion
- Which seats sit lower than stock?
- axels ????
- My CRX I-VT
- CRX B17a1 Won't Start Sometimes
- are starters exchangeable?
- Car Wont Start !!!
- disregard
- 89 crx SI idle problem! hiizzeeelp:)
- Hello
- *EE questions 'PARTS'
- WOW look at this ****en crazy !!
- 1991 Civic. b18. wont rev past 3500?
- EF9 REAR MAPLIGHTS ?
- EF H-series starting problems
- traction bar questions
- Crx coilover sleeves on EF hatch?
- ++NEED HELP!!! Throttle issues, car idling at 3k rpms!
- engine light wont turn off, no start...
- integra t bracket for b16 swap
- rod difference? a6-z6-dohc zc
- bracket for crx b series swap.
- d16z6 motor into an 88 crx si
- B18 turbo build questions..
- mugen valve cover ???
- 1990 Si
- diy motor tensioner/shock absorber
- 1990 hatch tranny issues
- engine swap info needed
- 89 CRX W/ B16a swap squeal on acceleration.
- melting alternator belts
- sedan rear seats. what else fits?
- burned ecu and electrical issues
- Okay so I cleaned my IACV
- Jumping tach in stock 91 si
- Alternator help
- obd1 conversion, solid cel, tried some things
- crx project
- EBAY H22 MOUNTS??????
- Best way to lower my ef sedan with factory springs
- 88-89 bumpers on a 90-91 hatch question
- starter question
- quick clutch question
- wanting to strip interior
- Rough idol and misfire
- YET another crx brake problem:(
- P29's in a6?
- Thread Request
- EF Sedan MAJOR help
- EF h series swap info
- D-series torque settings
- Newb with a 89crx introducing myself
- idle problem
- Trying to get some info on my clutch
- 90 ef hatch which axle bseries
- White Smoke! Help!
- code problems
- 90 ef what axle?????
- 1990 ef civic
- Strange Knock
- high compression zc
- 1991 CRX dx build thread
- No start after CAI install
- Fuel pump will not shut off.
- zc transmission
- USDM Hood on Jdm front
- HID Projector Retro fit
- b20a5 in a crx
- crx transmission HELP!
- Need help with purchasing decision....91 crx hf with ZC
- CRX si w/ b17a1 questions
- cel on b16 obd0
- help nothing after swap
- Spraying B16A before crossover?
- B20 or ls B18
- loss of power and fuel pump Q's
- skunk2 exhaust problems
- EF motor mount question
- 1991 Ls seats into 1991 crx
- new pump/main relay...still wont start
- Replacing Ignition Control Module (Igniter)
- SiR WING help!!!
- trans and clutch delema
- B16 - Which would you choose?
- EF Headlight Removal Question..
- Memory-Fab/Nagisa auto seat rails.. users chime in.
- Seats ?
- No Mass Air Flow sensor ?
- My new 91' si hatch
- MY GF's 89 HAtch was stolen from COmpton last night!
- I screwed up my ignition! help!!!
- Weird bogging problem
- partial throttle problems
- 91 ef sunroof
- ef 4 door question
- JDM/USDM Black Housing Headlights
- dohc zc clutch
- 91 ef SIR SWAP FUEL PUMP HELP
- sohc zc Qs
- wobbly rearview mirror help
- ECU help....
- Tanabe Under Brace (Front)
- Crx B16a swap bog?
- B20 in CRX... Good Idea?
- crx weight reduction questions
- B20 on a CRX?? Good idea?
- NEED HELP W/ REAR FOGLIGHTS
- 89 crx corners???
- crx traction bar question
- b16 tranny help
- 91 Civic A/C Problem/Question
- Hood/Filler/Headlights interchangeability.
- crx kit on ef hatch?
- b18c1 swap. on crx si
- axels fittings!
- eg or ek rear shocks???
- ECU problem
- slid into a curb bent lca need help
- 2KRacing.com we are a new Sponsor, Great to be here!
- CRX ED9 1991 Air Intake Manifold?
- CRX w/ b17a1 value?
- Clean starter or replace?
- Car hard to start in the Morning ..Help !!
- zc turbo
- Code 16 Problem...!!!
- Hub Question
- Switching MAP sensor wires for OBD1?
- HELP ME OUT WITH MY CAR!!!
- Car dies When driving Reverse in wet weather?
- b16 swap issues
