View Full Version : Honda CRX / EF Civic (1988 - 1991)
- why does my shift light stay on?
- simple question about vac lines
- best sohc turbo kit
- Whats wrong with my car?
- Few questions.....please read
- B18A CRX
- car starts / putters then dies
- crx ls turbo fitment?
- how many wires on thermo housing ground?
- code 15
- where can i go to post a pic on h-t
- ecu running rich
- jdm hotness now. for how long??
- part # for the Main Relay in a 90 civic lx???
- d16y8 and vtec controller in 88 si (what wires)
- the compression test b16a second gen
- b16 swap
- prop valve for a rear disc swap
- ls vtec in an crx?
- intermitiate starting
- DPFI question/theory... your 2cents please!
- turboedit / pm6 question
- CRX sunroof drain tube locations (searched)
- T-Bone? Where are you?
- ICV
- STRUT TOWER BARS QUESTION!
- how much do crxs weigh?
- help me get running!!
- How to identify an Si tranny?
- hatch wont start?????
- Please help me with my z6 vtec wiring problem
- **OVERHEATING CRX**
- How much is it worth... ???
- eBay Traction Bar / Crossmember ?
- Y7 block in an 88 CRX?
- JRSC or 50 shot nos in a b16a with ctr pistons
- motor for the rex
- how to wire a switch to check obd1 engine codes...
- 90-93 teg cluster into ef
- what tires are you guys running? 16" rims only plz. :)
- FORGED PISTONS
- motor swap
- obd0 to obd1
- fuel filter
- Are 88 and 91 CRX doors interchangeable?
- New here, need CRX ignition help...replacement motor, but not modified in any way,
- track width difference due to trailing arms
- Turbo Qustion>
- Will a VTEC controller help me??
- tach install green wire to the ecu??
- f/s jdm b16a stuff
- jumpy tach, trouble starting
- B16a turbo
- quieting the rex
- Alternator Replacement
- Ball joint help!!
- lookin for pass. fender and door in MA area please help
- 1991 CRX Si Dash into 1989 LX Sedan... Possible?
- Stupid Question
- Exhaust Manifold Question
- Prop. Valves
- rpms going up and down?
- b16a1 pass smog?
- Searched Vacuum Diagram for b18a
- B16 mounts...
- '89 B16 CRX suspension suggestions
- What does chipping ECUs actually mean.
- IAT mod? does it work?
- d16a6 IM vs d15b7 IM ?
- Which would be an easier mini me.
- What plug and Gap?
- Anyone have experience with the Boomslang obd0-obd1 conversion harness?
- Short shifter question help
- cams
- wat motor is this? i got the pic now'
- Hoodlatch problems
- Trunk lock help needed
- Mini-Me or ZC swap?
- Suggestions for engine/tranny swap?
- trailer for a civic lol
- need help with b16
- Help-- Bad rings? with good compression? is that possible?
- rebuilding JDM tranny...Can you use USDM parts? What parts to use?
- Y1 trans with LSD problems(very common?)
- VAFC SETTINGS!!! PLEASE HELP
- 89 std hatch with 32805mi
- Vacuum Hoses
- DX and Si
- Original height of a 89 CRX?
- crx dx compatible a/c compressors?
- B16A problems
- stock 91 civic flywheel weight
- The last pictures of my car before it leaves this world...
- boosting my crx
- CRVtec in a CRX
- strut bars for 92-95 civic fit 90 crx???
- where can i buy EF-1 cams?
- Throwing a code 9
- car runs a bit rich, seems a bit sluggish, stutters please help!
- anybody ever use sound deadner in there rex?
- Question about jdm civic/crx front ends>
- Pic Request: Apexi world sport II on EF
- throttle problems
- Check Engine Light
- vtec x-over
- Does the brake booster off a 93 Civic EF fit a 91 CRX Si ?
- Fan not working...car gets rather hot
- QUESTION?...cold air intake and sucking up water...
- b18b swap sensor troubles
- 88crx si catalytic converter?
- P28 error codes, how do I read them?
- cam worth it?
- what are you lowered on?
- from teg to rex...*pics*
- extra wire in 1st gen b16???
- gsr cluster in ed chassis?
- East coast body kit dealers
- DX,SI,EF?
- Replacement quarter panels?
- Wheel Q's
- Brake problem. Pads don´t brake across entire surface.
- jdm front clip
- Alternator
- Looking to buy a fullbody coilover kit in the near future, need some help deciding
- doing my own paintjob
- having trouble removing a zc tiiming belt cover
- dragnet DRAGNET...............
- FS:88-91 CRX PARTS FOR SELL
- 88 crx hf and no bumpstops?
- CIVIC TURBO
- What struts/springs will fit my CRX
- Car won't stay on....no acceleration either
- itr suspension on ef
- need some help
- The "stay open door" things that suck...
- questions on motor purchase
- d15b2 + d16z6 mini-me, what wiring diagrams for ECU and ignition?
- weight reduction?
- another problem with the car, i think maybe alternator?
- wich is the right spline for a dx?? someone enlighten me quick!!! tranny problem
- jdm b16a starts and then stalls
- Battery relocation civic
- how do i take the door panels handel off my manual windows?
- Painting engine
- unsatisfied,need more power!!help
- part buying problem
- Bought 89 CRX ... is B16A too tall for bonnet?
- Rear suspension problem and Eibach Pro-kit *pictures*
- b16a & YS1 Clutch Qs
- B16A into CRX Qs- swap in progress...
- Hone/Hot Tank Cost
- need helppppppppp!!!!!!!!
- info on a wheel for an ef!!
- help....radio wires?
- WW Kit VS Sir Front End
- What cluster should i put in?
- Squeeky clutch pedal (tried wd-40)
- what do you guys think of this? light crank pulley...
- es master kit. pics.sleepy and tired..
- car smells like gas inside'
- different vtec solinoid for a head?
- Prelude injectors(92-96) in a D16a6 <fuel newbie>
- need 13 inch wheels please help
- Wat motor is this?
- cant fix high idle on z6/y8 in an ef with b18a1 tb SEARCHED
- Engine Swap Help
- 88 rex for $2495 ?????
- 1/4 mile time
- Replacing crx fuel filler hose
- radiator
- Bad Ass CRX
- 2000 Civic EX D16Y8 swap into 91 CRX Si?
- you guys be my kelley blue book!!!
- How must sould I sell my hood for
- HF to SI transmission swap... now i have a messed up idle. HELP
- fuel filter
- just got an 88 hatch wat should i do?
- fog lights hook up
- N10 thread (who showed up)
- VIS Double Sided Carbon Fiber Hoods?
- HELP!!! I dont know what to do.
- What Engine is BEST for a '91 Crx
- Stripped bolts on rotors. How do i overcome?
- back firing
- anyone have rota GROUP N wheels?
- DX to SI tranny build
- 87 crx carberated to b18a1 swap
- flywheel question
- My new purchase.....
- 99 SI cluster in an EF
- mini me running rich
- please help.no power at fuel pump/ key on/ new main relay.
- Painted side skirts.
- want to do a 5th gear swap in my b16
- oil and spark plugs?
- EF9 - EF8 Front End?
- brakes,,, they are garbage, please help, car is a 91 honda civic si
- compression test results: pre obd b16
- Senor Questions
- intermediate shaft question
- **quick question for auto to manual swap...axles and pedals**
- D-series or B-series
- suspension questions
- New wiring equals 12 whp
- Anyone have any install pics of eg side skirts on an ef, and instructions?
- how much money should i get for sellin a good running 89 civic si eng
- az race mounts?
- oil gauge
- Hood clearance with b16 on a stock 90 Si?
- pic request
- whats is a eng balincer? thats not the right spellin
- Clutch Slipping when HOT!
- sir front with usdm bumper
- Lost and Confused
- TURBO CRX?!!?!?!? HELP!!!!!
- First time I can't figure out why the beater isn't starting, HELP
- How many of your friends understand the Ef passion???
- Correct ball joint removal
- ¿? CAN I FIT A k20 IN A 89 CIVIC ? ¿
- radiator
- ls cluster into 91 civic hb?
- 278 transmission trouble code
- SOHC non-VTEC ZC, or DOHC ZC - Which One and WHY? (Specific Situation Here...)
- homemade turbo setup
- Changing Clutch on my 1988 Civic 1.5i - Manuals and Schemes?
- my NEW crx ....LOOK!
- Will RSX gauges fit into my 89 Hatch?
- Prop Valve
- Bogging issue ( yes there are lots )
- 1991 CRX FAn always running? WTF!
- over reved the zc.
- 9 qrts of oil cause a rod nock? ( serious )
- Another Alternator Problem :(
- What is the largest size tire that will fit my 15" rims on my CRX?????
- ME and the crew at the track
- DOHC ZC cant get check eng. light to go off
- MPFI ECU into DPFI car?
- paintin carpets
- i need help
- energy suspension master kit for 88 crx. help...
- crx for $300 should i get it?
- cluster says full always
- Your power source? Engine bay pics!!!
- 2000 integra type r for sale ......................
- which driveshaft to use on crx with zc motor and ls teg tranny?
- Need help on my 88crx w/ zc motor
- 2.25" F and 2" R Drop on CRX HF
- thinking about these wheels
- 99 si gauge cluster in 88 crx,problems, help please
