- Interested in a quick rear seat re-cover "Build" thread?
- Lowering problem!HELP!!!
- Vxs on 91 Si
- D16z6 swap...tranny question
- how many posts do you need to view the classifieds?
- water pump
- clutch question
- thermostat!!!
- does your hatch leak?
- running lean
- hatch fenders
- uneven crank
- how do i check error codes on a 88 civic
- no spark
- Anybody know the wheel bore size on '88 Civic?
- Quick opinion on driving
- help
- confused about reservoir
- what saab turbo for a6 dd
- Need help with front mount question
- p72 vs. p28
- MAP sensor and purge question
- rev limiter gone with boost
- PIC REQUEST: DA front lip on ef hatch
- Lowered 91 Civic EF Problems
- injectors not firing?
- help problem with xenocron chipped pm6?
- steering jerks
- spark plug ?
- need help!!!
- how much should I as for my shell ?
- NEED SOME HELP
- zc motor in hf?
- 90 CRX Si: 98 B18C1: Battery Light on intermediately
- 90-91 crx owners help me out hazard switch plug
- Starts and Dies when Cold
- Aftermarket Aluminum DA Radiator Fitment
- LS-vtec or b16 (my bad)
- using timing light?
- Interior shots
- Which is better rear brakes for 85 1st gen CRX ?
- THE BEST tranny for a D15B?
- i know another mpfi ? stock map or si???
- Is it possible to put disc brakes on a 1985 CRX SI ?
- Where should I be looking for a turbo kit (partial) for my d15b?
- steering knock ???
- Questions for owners of 99/00 Si/SIR alloy wheels on your EF or any 15'' rim
- Need help
- frost inside windwhield
- axle question
- I need spec's on how to cut b-series shift linkage
- LS-vtech or b-16?
- timing belt???
- Will an AUTO harness work??
- ppl running pr3/pw0 on d15b/d16 vtec
- confused abt bars
- Hot start problem(searched)
- does anyone make a fully adjustable upper control arm for the ef?
- Opinion plz
- B16a
- Optima yellow top
- HF head swap? will it help?
- 89 crx si mini me swap help?
- Function / Omni Which is better
- BAD TRANNY???NEED HELP!!!
- ongoing timing problem, 90 Civic Si
- post your roll cage!
- Z10 CROSSMEMBER
- cusco or tanabe??
- steering wheel Q?'s
- Crx catback exhaust fitting an 88-91 Civic
- Which teg seats will bolt in my ef hatch??
- ZC problem
- need seat reals
- using mad break fluid???
- So, here's an Interesting Idea to get an SiR in the States...
- my ef 4dr dx wont start car has history its long but i need help
- brake Lights stay on all the time. Need help find out the problem.
- 86 4wd wagon, 4wd sticking???
- advice from experienced biulder's needed......
- 91 civic si hatch plus jdm
- Halp with my 91 crxHF
- building a sohc zc...
- Issues after a Transmission swap
- Got a CRX today.
- tps from DPFI
- transmission and axles
- ITBs
- Will a civic hatch front bumper support work for a crx?
- Weird rough starts?
- Crx non A/C set up question
- v8 crx dragster
- ball joints
- Ignition harness plug? where does this go?
- coilovers vs springs?
- EF/CRX specific FS and WTB thread?
- Driver seat
- Supercharge or Turbo?
- ls swap what heater hose?
- Will a clutch from a ys1 tranny work on a 99 si tranny? there is no transmission forum so i dont kno
- Climate Control Block off Plate?
- Why is this crx selling of so much?????????????/
- What size in a 91 CRX HF Fuel Pump??
- Sedan vs Hatch Weight & Space difference?
- Brake slave cylinder upgrade for CRX?
- HF Axle question
- S2000 Speedometer In A CRX?
- 12.36 Street Tyres ALL MOTOR AH!
- New 91 Civic Sedan. OpenTopic
- 90-92Intrega cross member on 1989 civic si
- Ball Joint Issue
- new megan products
- i need your opinion on fuel pump issue
- <!!!HELP!!!> LS SWAP in CRX
- wheels.
- D16A6 Head onto a D15B7 Block but with Pistons and Crank from the D16
- fuel pump
- anyone know the difference
- throwing code for injectors but having symptoms of tps failure?
- Dumb axle question
- Anyone get full width radiator to fit with full-race traction bars?
- will the jdm ef9 front end fit on a crx?
- help with my rear seats
- No Heater! HELP
- possible tranny's to bolt to a6?
- MINI-ME HELP
- alternator
- car looses power and shuts off
- fuel in crankcase?
- damnnnnnn
- 1988 CRX Intake Swap
- Undoing a WW kit, or the permanentability of one?
- B16 swap... axles...and speedo cable???
- spoon stoker kit
- front squeaking sound
- Need Help
- Ok to use used CV joints from junkyard?
- civic sedan wont start..
- nothing on first try
- CRX WIRING QUESTION!!
- tranny fluid
- HELP! With Codes.
- code 15....what the hell???
- Where to get Good Hood Pins that dont rust?? Going on Carbon Fiber Hood.
- jdm d15b aftermarket support
- Jacked This ECU from the junk yard
- another brake promblem
- head swap?
- Suspension recommendation for race only CRX
- What kind of LSD is this?
- Thermostat wont open, its cold out and im freezing my a$$ off
- CRX windshield fit an EF hatch?
- quick tranny question
- whats the diffrence between the vis hoods and the seibon hoods?
- 88-91 JDM b16 clutch question.
- Looking for a carbon fiber valve cover for D-series?? Anyone know where I can get one??
- So here it goes...
- jdm crx si (dohc zc) glass top?
- checking engine
- any help with cel codes
- Power windows??
- D15B1 cam specs
- 88-91 sir civic
- does 94-00 rer disk integra fit my my crx 1990?
- B20B motor swap NEED HELP!!
- Need help with radiator fan...
- Need quick valve specs! Help fast
- Speedo Problem
- vote
- will an 88 si distributor work for 91 ?
- car shutting off
- Bad Thermostat???????
- will eg seats fit in my ef
- crazy starter/ground wiring problem
- 91 civic hatch std
- temp gauge
- battery?alternator?starter?wiring problem?
- OH NOES Not another build thread (who uses 56k anymore?)
- wobble
- buying brake pads
- wtf help master rex
- Does anybody have pics of the OBD0 to OBD1 O2 wiring...
- CRX NO START
- what's the differnence
- Car died while driving
- dsm 450cc blue top injector help?
- NGK Spark Plugs
- Anybody running the DRAG DR-20 Wheels?
- Is this correct? AC delete firewall plug?
- doing hf to si swap...what to do with vacuum lines
- Quick Question Guys
- zc swaped rex
- obd0 obd1 and dpfi mpfi conversion
- Exhaust Questions?
- Bolt on the Head for an Engine Block Heater on a 91 Hatch?
- need a crx hf vacuum diagram...because i dont have one...
- Help with wiring
- ecu chip question
- question about b16 swap into ef
- ctr...naturally aspirated or turbo?
- Who to buy from
- wondering if they make aftermarket polished or etc stock D-series engine mounts?
- Good place to get skunk2 dual bend shifter?
- Just wanted to say hi.
- mpfi help!!!!! relay wont stop clicking help!!!!!!!!!!
- zc tranny question
- CRX Shocks & Struts Qusetion?
- Anyone Want to trade all motor parts for turbo plus cash??
- Whats the best B-series intake manifold?
- Camshaft install
- D15B in a CRX
- carbon fiber hood question
- 91 d16z6. putting in an o2 sensor?
- timing a d15b2?
- how much should i expect to pay, total.. (b series EF)
- CODE 4 AND 8 OBD 0
- Full Race Turbo kit Inter cooler install
- center console question
- i need help
- Half-Radiator for CRX
- need a hood for my sedan does any company make an aftermarket one?
- anyone have the eibach sway bar kit for crx?
- My CRX complete makeover.
- rod knock on dohc zc motor
- crx black halo lights and corners
- my ef build up
- b16 smoke
- hydrolic tranny in ef
- a new member
- New fuel Rail.
- STREETWERKZ complete CRX build-up. Lots of Pictures. (56k start saving for that K swap)
- car idles high. no FITV, cleaned IACV
- o2 sensors for header
- seat thread
- cant get ride of code 5!!! :thumbdown:
- 89 CRX Stolen from Mira Loma, CA
- Skunk 2 pro coilovers set up - Opinions?
- cranking no start on b16a.....help...
- steering column joint... how to check?
- WET DRIVERS FLOOR!??!?!?!...drivers seat dry? wheres it comming from?
- ZC front end to SiR front end?
- poor and need help with clutch.
- ok so i got 1000$ to put together a turbo...
- oil leakage.. Help
- It's back....... code 4
- Want to add power locks Whose kit/actuators work best
- Aparently I'm thoroughbred fanatic.
- Photoshop/Pic Request
- Knocking noise from suspension or drive train...
- Has anyone ever made their own mounts for the 87 crx b-series swap?
