View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 89 to 91 guage cluster swap
- Headgasket Installation
- Anyone looking for a turbo, for a homemade setup?
- Eww...Ground control and Tokico HP's...Someone help me out here Please
- Putting on the head
- M/C and Brake booster upgrade
- Torsen LSD for 400$! ?
- mini me?
- J-oem Hatch
- my crx is lowered 2 in. and i might need some new shocks
- can someone post steps in doing a clutch job
- What tool?
- Oil Cooler?
- Y-49 paint available in rattle can?
- OT: but any of you interested in a JDM EF9?
- Stock Throttle Body Size. D16A6 vs D16Z6 vs D15B7
- Pretty CrAp TaStIc 1/4 mile times...
- exhaust
- Price for a stock tranny on a 90 CRX si
- Brake converion comming along.
- Fuel and Spark Problem..HElp..
- Did I get the wrong pad's??...
- B16ers I have a question for you
- hf harness wiring problems with b16
- steam coming from the oil cap!??!?!
- Piston Question!
- what's the difference
- ground
- Performance questions about Maintenance!
- looking for cars for sale in GA area
- trailing arm bushings????
- zc techs please
- water damage?
- engine swap
- Help with ecu code 16~
- HELP!!! Locked keys in car and can't get to spare...
- b16a distributor
- msd ign
- external coil
- do NOT...
- ecu upgrade
- What wheels do you have, I need some cheap rims.
- vtec not working--ecu is throwing code 22...
- stock 88 crx tails for sale..
- wiring an external tach....
- What Makes our EF's better than the domestics?
- rice or border line...be brutaly honest!
- info on y8 swap
- y8 head on d16a6
- Length of window crank handle?
- times for a b16 rex????
- is it possible in a HF?
- can you help with stock wheel specs
- swapping a 91 gauge cluster in a 89?
- 02 sensor install on ZC?
- Pirelli P700-Z 205/50VR-15?
- CRX SiR lights FS
- dyno #'s hp loss w/ a/c running?
- Found a Civic Si with 87k for $1500!
- What Do I Need To Make My Car Run In The 12's??
- CRX Track video... as requested.
- Any here using the Ingalls camber kit for 88-91 CRX ?
- ew4........
- Can someone tell me where I can find a Toyota 3EE Engine(Website)......I bought a tercel and I am se
- bogging @ 7500
- b16a wont start.
- MSD RPM module acting funny??
- How do I know if my water pump is going bad?
- How do remove A/C evaporator assembly?
- ls motor
- where can i find a ef-8 mugen copy front bumper???
- Raxels/driveshaftshop/other axles poll
- weirdest thing is happening to my car
- Planning for building my B16A
- distributer for 1st gen b16a , which ?
- Mugen CF48 on my crx???
- pricing and other questions
- what all do i need??
- what would you do!!!
- adjusting TPS?
- Spring rates ??
- Shift light installation
- New Suspension parts, anything else(reminder)
- o you know if the d15 d15 and d16 crank pulley
- Trouble Codes Pt.2
- ok whered it go?
- brake/hub/knuckle compatabillity question
- How much this 90 CRX DX worth?
- Stalling problem
- enging swap question
- ground wires.
- 88-91 crx side mirror?
- 92-95 Civic SI Seats In A CRX
- Spring Question
- how much is a sunroof worth?
- Post pics of your exhaust on your CRX's
- need help asap!!!!!!!
- b18 swap into 90 crx hf running rich with code 43
- drum brake
- CRX fenders and Civic fenders?
- I Need Help....
- I sold It
- Stupid Question...I want to find out more about....FDM, and the HB Squad...
- Removing axles
- hpc mounts
- Oil cooler
- tortex's new header
- timming question
- Mixed Information?!?!
- just found oil cooler on old block....
- just got the motor out.....
- b16 crx, vtec trouble
- lowering question...
- ay0 EF sQuaD ! ! !
- How do I go about Vtec'n my D15?
- Possible engine swaps for 86 CRX?
- Got So many offers I thought you guys might want to see the New Prices!
- Easy question for you guys
- ZC Crank Seal?
- Ques. on quarter panel fix on crusty crx
- Fuses
- Help me brainstorm: CRX N/A Drag car
- Little bit of TPS help?
- I think the expression is Shaved?
- please help with my car.....
- 89 Hatchback
- crx running rich
- hey where is trinty??????
- few questions about mini-me
- just some inexperienced owner, PLEASE HELP
- DFW,TX people.
- Does any one have Carb numbers, Sticker, or Papers for a air intake system?
- B16 exhaust/exhaust question...
- Gc
- Looking at a 87 HF
- dx hubs work w/ b-axels?
- Fuel pressure riser (did a search)
- Largest Tire Possible
- resetting ecu...
- ware to find 5zigen fireball alex back for 90 si?
- overheating issue
- clutch break-in
- hawk hps or ebc greenstuff...
- biggest wheels
- can't find cam
- What suspension with B16 swap?
- Riken Wheels?
- Wheel question
- Problem with swap...HELP..
- 1/4 mile times from E-town in my low-buck Turbo crx
- Sedan Seats in a Hatchback
- Picture is self explanitory...
- Trouble Codes
- a/c trouble
- Completion of my swap....
- TEG axels on EF HB with ZC engine and trans. Question?
- which lightened flywheel for b16?
- buddy club front end
- MORE ECU questions.
- Hakuna Matata......I need to know if I have any worries with my new ZC and a Zex Nitrous Kit...50Sho
- looking to buy a ef hatchback, need you guys help.
- pls help on ecu code
- Anyone going to Maple Grove this weekend?
- zc intake manifold
- PG7 or PM6
- Type R Brakes without doing 5 lug
- my std hb wont start after crash
- G-TECH anyone have one?
- Air Box
- This is driving me NUTZ!
- calling all photoshop gurus
- Civic Type R steering Wheel
- ecu wiring..HELP...
- where to get a interior harness?
- WTB- EF cowl
- Si-r Front End questions.
- ok no flamming.... I need to picture my car dropped 2.5" so hacksaw time.....
- Skunk2 mani wroth it ???
- Carfax question
- 89si, but no rear discs....
- b18a & teg brkes
- 15x6.5 +45 offset...which size tires?
- overheating
- need helpfinding code
- Taking the ZC apart for minor cleaning.
- Why won't my car start? Can you solve the mystery?
- could i sell my stock 88 dx ecu?
- crx console in hatch
- which driver side axle matches a J1
- cf sir hood?
- pr3/pw0 differences?
- anybody have pics of crx or civic with sportlines?
- Central Ohio EF Meet Pics
- crx back seats......
- Sloppy Shifter
- mugen
- I need wiring diagrams
- Fuel pump help!!!
- older Integra muffler on EK?
- GAS HAND doesn't work :(
- What shift knobs do you use?
- Motor delema.... EF sedan
- where can i get Place Racing front cross member for CRX
- 90-93 Integra MC bolt to EF?
- Anyone wanna trade trannys ?(LS)
- Need OBD II B16/B18C distributer yeasterday!
- what's this??
- How many of you guys need Syncro rebuild kits for Y1/J1/S1 JDM tranys.??
- Funniest Nickname I've ever heard for a CRX...
- trouble with crx, 1st gen b16
- ECU Blinks all the time
- Brake booster/mc help needed...
- Looking to buy a crx, what should i stay away from/look for?
- More problems with the swap!!!
- what's your mini-me?
- pics of the grocery getter!!! bwahahaha! link!
- I think I have the ugliest hybrid in existence...
- problem during swap
- Where to find fiberglass OEM replacement body parts?
- Boost problems
- Who's going to Hot Import Nights in Atlantic City?
- what do you think of this
- I need '90-'91 Civic EX Spindles!!!
- anyone going to midnight drags-orlando,fl?
- B16a hasport Shift Linkage??
- in the middle of a swap.....NEED help
- 2 90 DX doors and a hatch, anybody want them
- head swap
- Where to add weight for better handling?
- Synthetic oil in transmission?
- wb A/c parts
- dx breaks vs si breaks
- Dropping my hatch
- 99 civic headlights
- need help fast: how do i remove the driveshafts?
- Crx Might Be Sold On Monday
- thermal or DC sport
- Mod Carryover?
- Where to get exhaust gaskets?
- Nitrous on the stock D16A?
- b16a motor mounts did anyone else have this prob!!!!
- Integra anti-sway bars on a 90 hatch
- EF springs/dampers on an EG
- JDM front end install
- What Type Of Engine Would I Swap Into a 97...
- How much does A/C weigh??
- Anyone need a factory hatchback spoiler?
- i sold it
- anyone know the 4 door page
- Who knows where I can get those cheap rear lower tie bars for my 88 CRX Si?
