View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 5600 RPM fall out.
- how-to add a footrest / dead pedal into a civic or crx PICS
- help!!! motor wont startt
- rear caliper question
- dohc zc header ??s
- few things i can't figure out..
- Switching to power options?
- my crx is dying down
- Possibly looking into getting 91 SI Hatch
- help with door panel!
- Looking to do a Swap
- failed inspect for... blinker lights. help plz
- crx single vtec bogging, cant figure out.
- can i keep spare battery in car? or will it die?
- B series motor what intake?
- Motor / Engine Identification
- should i get this motor?
- hood for crx zc
- ZC head modifications
- Searched Searched Searched couldnt find shit
- Car Is Cursed
- my first build
- 91 crx engine/automatic tranny swap
- Stiff front upper bar!!! Ed7(ef9)
- injector grommets
- pop while turning, help please
- Few simple questions about EFs
- auto trans: shift lock help
- 4040 prop valve ABS
- Radio Harness
- clutch pedal question
- High Idle Problem
- Using an Auto ECU
- b18a1 swap wont start
- seat needed for my crx
- sohc zc valve adjustment
- clutch break in
- More Help
- gsr swap running lean low fuel pressure help!
- Canadian crx vs. US crx, differences
- how much would you pay for jdm ef9 seats?
- loosing top end power
- Can anybody link me the thread where the dude put an s2k engine in a CRX
- Draining brake fluid. How?
- help with d16z6 swap
- 91 HF gas fume inside
- '87 CRX Si exhaust on '91 STD hatch?
- D15B Block with HF Head
- Where can I buy a Honda CRX 80 amp Fuse from?
- ED8/ED9 Suspension Differences
- Put hf engine into civic si Wont start
- How can I measure Fuel Consumption? DPFI?
- Looking for Performance shops in Sacramento CA
- Rad. Fan?
- Does a ZC hood clear a B18?
- Helpppp
- how to swap i 94 gsr on my crx hf any help
- Helpp. Head bolts?
- New EF owner have a question about manual trans fluid
- Seatbelt replacement
- does anyone know????`
- Help again puzziling ef9
- D15B2 with D16A6 parts.
- steady rpm's/speed highway then dies then back alive??
- obd1?
- Advise
- what would happen?
- ef amber bumper lights?
- Swaps, Where did you get yours....
- ef lips
- please help asap,car won't start
- 89 gauge cluster question
- My alignment numbers good?
- difference between....
- roof racks??? for a ef???
- help trying to set the timing on a 89 crx 1.5
- 1991 honda civic hatchback
- turn signal short
- Are there any good performance brake shoes
- Carbon Fiber Fenders
- ECU code #15
- What size is the center bolt on the steering wheel?
- 91 Crx front end on 88 hatch
- 88 crx si bumper on 88 civic hatch.
- Help!!!!
- ^^crxjarred^^ very slow build thred!!!!
- Jdm front end?? Need help...
- wholesale low price jordan shoes
- Which B20 is the High Compression 1??
- Need new rear bushing, no idea where to get them
- OBD0 to OBD1 wiring question w/pictures
- 91 hatch dash swap?
- civic spring rates
- i need help with my throtle body prob.
- help with this sensor
- Will the 99 Si rear disc assembly bolt up?
- Brand new!
- How do you guys get to the TB Tensioner bolt?
- HELP!!! del sol seats
- HELP!! mpfi swap wont rev over 2500 rpm.
- D16A6-B18CR=Not enough fuel pump?
- b16 running on 2 cylinders
- Need a couple of sunroof parts
- How tight should i tourque my rims on?
- ATTN: Los Angeles EF Sedan Owners!
- brake master cylinder ?
- B16a ???
- 4 Speed vs 5 speed transmission
- wtf is hondas sealtbelt warranty?
- Help with d16z6 is a 88 si cel
- 91 dx with d16z6
- HELP! Headgasket replacement
- US Army goes JDM!
- kteller 2.5 inch exhaust
- Losing power and a couple other issues; help!
- california state ref/bar'd help
- Specs for Engine Builders
- rear disk conversion problems.
- what distributor to use for DOHC ZC motor?
- Timing ??? PLease Help me
- Looking for a ef9 si or sir!!!!!!!!!!
- Map sensor questions
- do i need a press to install energy suspension bushings?
- wont start please help......
- b18 ef four door t/b ?
- D16 v-tec and my 1990 Honda Civic Hatchback
- Speedo question!!!
- shift linkage.....
- can you keep AC with zc engine???
- wy is my car still overheating?
- Ugh Tie Rod help
- why does my car smoke
- about CRX motors
- roll bars and roll cages
- Should I do a valve adjustment after valve seals
- question about distributor on jdm d15b
- clutch/throw out? help
- Starting problems (car #1)
- emanage
- Corner lights
- 88 Civic DX Sedan, Intermentant Wiper Problem
- help!!! crank but no start!
- Help! Diy headgasket!?
- b16a starter
- gauge cluster?
- how do i replace my window?
- Rattle tech!/ Cluster swap
- what can be taken out?
- some pix of my painted EF
- mini me swap
- I just ruined a perfect cf hood!
- $800 what should I do...
- CRX EFI main relay....
- 91 hatch ac question
- 90 wagovan
- It's time for rebuild EF/d16a6...
- 88 rear struts vs da and 89-91 ef struts
- password jdm battery relocator
- Do d15 head gaskets have issues?
- ignition question
- hf to dx for a swap
- door moldings.
- ► ► for sale / would like to buy 88-91 crx/civic parts only ► ►
- I need some advice on a 89 civic
- 90 crx rear disc brakes on eg?
- Suggestions so I can search...
- D16a6 build
- fog bulbs
- Burnt valve replacement
- dohc zc idling problem?SEARCHED
- Tranny Broke today???!!
- Another Brake Rotor Removal thread, but easy question
- b16 timing??
- b16a2 swap
- how it works
- Recommend me parts for my project.
- speedometer
- GM parts one an CRX.
- Think Its Time For Me To Build An EF
- oem fiberglass hood?
- Help on JDM HEAD LIGHTS!
- 89dx caliper same as 90dx?
- obd2a Vs. obd2b for obd1 crx conversion harness
- FAN switch location?
- d15b2 to d16z6
- sunroof rattling broken drive plastic piece
- 4 wire o2 wiring
- keeps blowing relays...
- idle problems
- my $100 car build update
- Brake diagnostics.
- What Octane?
- ZC tranny on a b16a?
- Radio question
- 88 suspension question
- What Valve springs and Retainers?????
- obd1 o2-obd0
- 90 CRX Si w/ B16 and CEL 6 & 23
- what to do with piping when installin hot air intake
- CRX SUNROOF question
- Rear speakers.
- CRX 91 Si Alternator questions!
- d15 diffrences
- CRX HF OBD-0 To OBD1 / Problems
- Quick supercharger question.
- Zc id
- Weird transmission issue
- DOHC ZC Issues
- pic request: CRX with Roof Rack
- hondata
- radiator fan will not kick on?!
- b18b obd2 in 91 crx si?? help
- removing the rear quarter windows
- Having a hard time shifting from 1st to 2nd.
- k20 + RBC + USDM hood??!?!??!!
- Dash removal????
- B16a swap in my 88-89 Hatchback
- Short Shifter, Aluminum or Steel?
- jdm zc nose cut
- Head bolt question
- Swapping suspentions
- 88 civic, dpfi to mpfi, hits rev limiter at 3800 rpm?
- arp extended stud problem
- 88 Crx Si Suspension Help
- Power windows in 91 hatch?
- Rewiring temp gauge, dropped pin in dash....
- Rod Bearing Help??
- B series Vtec locker/sliding/syncronizing/blah pin
- Please help!!! Bad idel on a mpfi swap
- ARE these pistons good for ls-vtec?
- Replacement motor
- Head gasket issue
- Alternator hell!!!!!!!!!
- changle knuckles during swap?
- A Diet Plan That Actually Works
- NEED WRITE-UP. DA cluster in 91 civic.
- 2nd gend prelud fog light on crx?
- ef9 sir steering knuckle code?
- 88 civic power steering help
- RPM gauge started jumping.
- reading ecu trouble codes
- broken motor mount
- Help guys with exhaust
- What to with a D15b2??
- Need Help and Opinion! B16 Hydro Tranny
- Where to find 88-89 ef sedan tail light
- b16a running really rich
- i love my crx
- Need help how to remove small black rubber?
- Horn Issues
