View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Installing used AC system
- Need new suspension - so lost
- If the D motor goes...
- just pick up a hb w/b17
- front wheel bearing
- Replica EF9 Side Skirts?
- removing a layer from OEM head gasket??
- eibach spring open house 2011 meet
- kinda new EF owner/ whats that sound?
- What should I do trying to swap to vtec
- Is this normal
- Calling all Colorado members
- What lug nuts for sportmax 002 on extended studs
- code 4: my mpfi harness or bad dist?
- pretty sure its my axel going but......
- Economy Indicator Light '88 CRX HF
- crx with ls vtec and wont go in 4th... help!!!!!
- b18c swap in civic 1988
- 91 crx hf zc swap computer/fuel issue
- mpfi swap help!!!
- is it just me?
- D16A6 will not start
- 88-89 to 90-91 CRX cluster swap problems
- 89 si 4 short ecu code?
- 91 dx auto no spark. Checked igniter/coil
- ZC intermediate shaft with non IS block
- 1990 CRX DX Speedo Issue
- Suspension Bushing Help!
- Oil light will not come on
- Smokes at high rpm
- surging idle (searched)
- Dizzy conversion harness. si plug repin to non si plug
- Guage Covers
- needs some help
- Stupid CRX Starting problem.
- 88 crx dx sputtering and running lean!
- my results after going thru brake diagnosis steps, help narrow down problem??
- >>>88<<< crx SI... brake swap question.. I searched.. help me..
- Main Relay's
- d16a6 head milled ?s
- crx ignitor
- Dpfi to mpfi if I press the gas it dies
- Valve lash problem
- b18a swap runs SUPER rich and sputters!
- h23a1 swap help
- CRX suspension recommendations?
- My EF Build Thread
- Swap
- 89 Civic Bumper question with fog lights
- Burnt valve?
- jdm ef8 power folding mirrors question
- D15b7 paired up with d16a6 harness and d15b1 trans, possible?
- six sigma header
- 91 civic hatch need some answers asap
- Interchangeable ef parts
- Wagon RT!!! any thoughts??
- CRX HF SWAP HELP????
- mini me not getting spark!
- cv axles
- sedan door wont lock
- Crx problems
- Official B-Series Transmission and Clutch Guide
- Dpfi to mpfi swap. I'm losing my mind!!!!!
- B17 build questions
- 88 Crx HF, B16a, Crx Sir tranny, Y1, help?
- b18a swap bogs and makes popping sounds @ low RPM
- B-series oil pump screw part number
- Dumbest question asked on HT
- 1990 Civic LX misfiring
- 1991 honda civic
- CRX/LS Dashpot Control Solenoid and MAP Questions
- GAS PROBLEM!!
- intermittent starting problem.
- turbo question
- Sun strip?
- obd0-obd1 and dpfi-mpfi
- My 90 sedan ex wont shift out of 1st...
- ef sedan bseries swap
- stock alternator belt d15b2!!~~//??
- Motor shipping
- headlight question
- NOT ENOUGH LOW!!!
- New to the forum
- restore sir headlight lenses
- My hoopty 4 dr build thread
- 91 CRX fuel problems
- Crx Exhaust.
- Rather noob question...side molding removal
- How to remove throttle cable from the pedal
- Which Axel goes where?
- Seat colors and patterns?
- MY NEW 100% STOCK 90 CRX SI
- Car just dies then runs 5 min later???
- z6 and a6 question
- Fly wheel bolts
- code 16 help!!!!!!
- Straight piping
- just purchased a 91 civic hatchback dx
- Coilover suggestions ..on a budget
- Motor Swap
- Hood Spacers
- Crank angle problems..
- Wanting to swap stuff from my '90 Si project to my '90 DX, some questions.
- 1991 Civic DX 1.5 L refused to start
- Fuel issues (90 DX with DPFI)
- My new Si. :D
- hydro cable trans!!!!!!!!!!!!
- Motor won’t crank after replacing head gasket…
- 2 swaps at once (89 crx hf <-> 90 crx si)
- front lower control arms
- DPFI to MPFI
- CRX Si with DOHC ZC Swap? What is the DOHC ZC?
- Y8 intake mani on d15 questions + pictures
- Need some quick help
- Lookinf for rear blinds for my wagon where to find them???
- crx problem help!!!
- B18a1 Idle Issue!
- LS vtec vaccum line and idk where it goes... help?
- E85 on tuned turbo b18a1?
- EF Corner Light Help
- Problem after wire tuck help!
- Running Problems
- car runs crappy and wont rev up
- My seat dilemma. 91 CRX DX
- Distributor question
- car wont start. not a swap problem...
- 89 crx: battery light flicker/sputter at 1k rpm/CEL downhill coast at idle/
- PLEASE FREAKIN HELP! d15b1 DPFI
- Touch up paint
- CRX rear conversions question help!!
- pm6 ecu on d15b2
- to the person who stole my car...
- Questions on Adj LBJ's, Steering, Suspension, axles etc
- ef blinkers problem?
- 86 CRX SI, D16a1 with supercharger, just died and wont start....need help...
- 90 civic hatch fogs????
- You can't have nice things
- 91 SI Dreamsicle
- JDM EF8 fog lights bulb size?
- b17 into ef questions
- dohc zc block decking question
- question about d-series
- 91 hatch motor build
- PCV Question
- Brake Bleed Issue
- B18C Cam caps
- CRX with ls vtec wont rev past 3000 rpm
- 88-89 to 90-91 Gauge Cluster Swap...F.Y.I
- Harsh riding CRX on Sportlines/Koni: Other options?
- whats the easiest way to tell if my fuel pump is working?
- 90 dx misfire/sputter
- Civic si hatch wont start with key
- Axle Back Exhaust Questions
- Can anyone tell me whats up with my EF
- 1991 civic power window problem
- Factory crossmember/ tractior bar bolts stripped wtf
- HELPPPPPPPPPP!!!!!!!!!
- b20 in CRX ecu help
- New Main Relay: STILL NO FUEL OR SPARK
- REX REdo Help question
- anybody know step by step on sohc zc
- Replacing rear trailing arm bushings.
- Stereo wiring fire car wont start. Help!
- what is this?
- Bringing my Civic SI out of it's 3 year coma!
- DA trans bracket Q's for B-series swap.
- tuning a vafc... mini me swap
- EMERGENCY!!!! Rear T-Bracket Help
- Crx console options
- Sticking idle on dx DPFI
- Swapping seats in 88 crx
- Hard idle sweeping
- Brake questions - dirty fluid, 10k miles?
- water pump or head gasket or?
- d16a1 Trans swap
- HELP! Swappin a 95 obd1 B18B1 into a 90 crx si
- CRX owners in Tennessee for parts...tech help
- 91 Si fan not working
- newly purchased 91 Si...window question
- 1990 D16z6 wiring issue
- ef hatch with ZC/OBD-1 swap bogs when full throttle
- jsinher3 work in progress thread
- CRX with B18 & B20: Hood Clearance with Innovative Mounts
- why do my wipers hit my hood?
- Frame the same width?
- 4spd tranny on a D16Y8?
- b18b1 timing issue
- 91 dx hatch with a k20?
- crx engine with dual carburetor
- cant seem to find any info on...
- Speedo Issue
- 91 hatch axle issue
- obd1 cabin harness into ef 4door
- EF8 motor mounts vs 90-91 integra mounts
- working on my $150 civic
- Ls Crx starting problem?
- Ugh please help! 91 civic wont start
- stock brakes -> integra brakes -> bigger brakes?
- a smoother ride again
- swaping climate control
- my suspension build.
- DC ITR EF Dash Swap Pics
- Thread Pattern for Transmission Bracket Bolt
- general sunroof maintainance questions -90crxsi
- Clutch chattering at higher rpms
- How many miles are on your EF?
- Crx with ls vtec problems. need help
- strange running problem
- 91 civic si build
- 88 crx installing header need help asap
- shudder at 110 kph? help...
- Chase Bay CM1 Engine Harness
- Crx won't stay on
- Ignition switch
- ideas for good spots to draw cold air from on crx, safe from water?
- recaros njoy in ef
- DC sway bar
- anyone have pics of CRX with shark-fin style antenna?
- Does anyone know if 90 civic dx cabin harness will work on a 91 crx dx?
- ran out of gas filled up and no start?
- 91 civic ef problem..
- 89 civic 4dr linkage???
- NEW problem with EF B16. Help
- D16a6 in to non-si '90 Civic hatch.
- CRX stage 3 clutch - pedals/cables breaking.
- car wont start help asap!!!!!!!
- 90 honda crx si b18a1 starting problems
- b16 swap timing off
- injectors leaking gas..HELP!
- SUSPENSION HELP!!
- 1990 CRX HF SETUP 4 trade (anyone close to South TX.)
- FNG Here, wanting to know about VX engine install to CRX
- Rod bearing problems!
- o2 code 91 si
- civic idles fine but stalls
- cv shaft seal leak
- Where can I find a rebuild kit or pistons and rings for a 1988 HF
- 91 Civic slow battery drain.
- 1991 Honda Civic EX Washington love
- CRX SI FAIL!!!!
- knuckles??
- Jdm ef9 headlight bulbs?
- MSD Dizzy Cap
- HELP!!! BRAKE PROBLEM
- Help with valve cover.
- Indiglo rear garnish
- HELP!!! 89 ef
- 88' Crx Si Door Panels?
- Transmission Leak
