View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Whose CRX is this?
- covert dx intake manifold to si manifold on ef civic
- keys for door
- F20A?
- Interior Question: Guts or NO Guts?
- crx and hatch hoods
- Fender Flares
- largest tire for crx. (width not height ;))
- strut bars& tie bars worth it? what does it help?
- Has anyone fixed bubbled sunroof vinyl?
- CRX shitty run
- upgrading throttle body
- motor swap
- is this kit worth it (bushings)
- tokico struts and h&r race springs
- buying tranny.. Need advice.
- ZC Motor?
- NEW CRX AND HONDA OWNER!
- Head Gasket & torque information needed for D16A6
- 90-91 civic special edition??????
- tail lights not working
- How much faster?
- need help with torque specs
- Removing the crank shaft pulley bolt
- is it posable to build a jdm d15b vtec to run with a b18b. Both are in a EF
- Car shop or myself
- coilover install
- Shock tower paint chipping, do you have it?
- 300 rpm idling
- I need advices on CRX knuckels!!
- d16a1 crank in d16a6 block?
- hoods
- Need to pull clutch/pp in CRX does it come out the bottom or the top?
- so i got bored today and i went out to clean my interior...
- any suggestion to open hood with broken latch, 87 crx
- Full Race Bar installed w/ pics
- problems with vtec
- PW0 or PR3 OBD0
- widened exhaust
- Radiator?
- dropped alignment
- Which cluster for 91 HB..89 Teg or 87 Lude?
- VTEC with a MSD Switch, what to do with Oil Pressure Switch
- how to check dizzy power. oHms/ volts? igniter, coil! HELP!!
- 2 problems left with my Z6 swap
- Building a d series killer!!!
- D16Y7 Distributor on 90 Crx SI?
- Where can I get center caps for my swirlies?
- JDM Fog / Driving Lights on USDM 89 CRX universal? replica? oem?
- mpfi troubles!
- least expsensive place to buy tein basics?
- stuck in fifth
- 92+ Civic Front Suspension on CRX
- Whats the best intake swap i can do?
- Sedan Power options
- Need advice on rust...was told a cut and weld is the only way
- b16 crank in b18
- Mini-me swap guys question!!!!!!!!!!!!!!!
- 91 CRX DX shift linkage removal
- Surging....
- ZC in a 85 crx si
- b16 problem
- no spark Jdm 1G B16 crx si. Ran shut off, stuck in rain HELP!
- need help with aftermarket tach
- did anyone else have this problem? ugrent
- Carbon Fiber Hatch Opinions
- Trial User
- modifers crx
- Setting timing without engine started
- buy or fix?
- how much more hp from a d16a6 with vtec head
- will 96-00 struts fit a 91 civic hatch
- after driving in snow the day after car wont start, please help
- 14b turbo question
- high rev problem
- 91 CRX HF Cluster
- 2005 CR-X Project and "My First Project" 56k *Beware*
- need some quick help... EF mangs
- Electrical problem (Dash Removal)
- Any new info on concept 2005 crx?
- Trying to wire up power locks to unlock passenger side while inside car. How do I do this?
- 91 Civic not starting - need some suggestions
- RPM taking to long to drop
- how can i make my hatcy really fast
- CRX Si starts then dies, I smell fuel, what's wrong?
- need some help
- obd-2 type-r in a crx?
- Mugen front end CRX
- rumbling/shaking while making lefthand turns...stumped
- USDM front end in Japan?
- y8 intake manifld on crx , how do you have intake air temp sensor?
- header haha
- D16Y7 Built Bottom End with A6 Head???
- D16Z6 intake manifold VS D16Y8 Intake Manifold
- koni yellows with what spring?
- need some help on my distrubitor
- Foglights -hatch-
- Help w/ NOS nitrous setup
- Warm stalling problem with b18c swap
- JUST OPENED A NEW STORE IN PASSIAC NJ
- Anybody ever use DH-racing or Benson for sleeving?
- Is compression to high????
- replacing rear engine mount
- Serious sunroof PROBLEM!!!
- Caliper swap
- URGENT!!! CAR DEAD ON STREET!! No Power, No Cranking, No Charge !! FRIEND GONNA DIE!!!
- swap ?'s
- 215/50/r15 on crx? h&r wheel spacer? anyone using them?
- Need a little help... B16 information
- problem with my swap
- swaps
- going to the junk yard
- help on wiring on engine swap
- WTB: AEM Fuel Management
- How much is it worth, and do you want it!
- Will DC2 harness bar fit in CRX?..modify?
- Removing the roll pin
- batt light still comes on even after new batt and alt help plz + engine tips
- how much are nice Si seats going for?
- Engine harness help needed badly!
- where do they come off of???
- Tein or Omni?
- Ok u guys want a good laugh
- Full-Race traction bar
- who makes aftermarket replacement D series mounts?
- Any one using the TURBONETICS Turbo system for the b16a crx?
- DPFI to MPFI with MPFI harness on b16
- A/F Cobalt Gauge
- sun roof leaking
- rear solid axle and front cross member
- valve adjustment
- need engine swap link
- running without a crossmember?
- SEARCHED: ECU depinning tools
- Quick question - AEM cam gear timing
- best seats???
- type r mini
- wheel bearing!!!
- My intro here to the EF world...
- a day after christmas hydrolock story......
- Crower stage 2 cams for B20
- Need help finding a EF hatch info site.
- d15 or z6 wtb
- **The hardest decisions ive ever had to make...I NEED HELP!!!**
- valve adjustment(labor)
- 88-91 d16 ZC for sale
- Fuel flooded #3 Cylinder
- Spoon or Hks Filter?
- what cap and rotor
- 5th gear popping out on it's own
- is this high mileage for a 91 civic hb?
- doing a mpfi intank manifold to a a6 intank manifold....
- crx armrest/ cupholder
- Tranny trouble. Need some advice.
- Gas mileage down from 350+ to 200 Miles on a tank....WTF
- Will a 90-91 clutch fit on my 89 crx?
- ::poll:: will i ping with 11.5/1 comp, no race gas and a good tune?
- Wiring my hatch for the gen 1 b16
- 94 and up integra dash????
- fuel tank capacity
- z6 vtec selenoid question
- NEED HELP ASAP PLEASE!!! pulling bumper after being rear ended
- Help guys
- EG cargo cover work in EF
- CRX bumper on civic hatchback
- crx door interchange
- HIDs in the ef body (post um up)
- Question: 99-00 si JRSC fit inside 90 hb si b16a1 hybrid?
- b16 swap
- Fender is buckling...
- what USDM front lip is this!
- THE BEST SITES FOR CRX PHOTOS MORE THEN YOU CAN THINK OF HAVE FUN
- Z6 swap- rpm switch activated vtec??!!?? --(searched)
- groundcontrol or omnipower coilover kits?
- tranny grind?
- obd0 conversion harness really needed??? look
- oil on sparkplug
- transmission housing
- SIR Doors, Seatbelts, and Powerlocks.
- sir front end
- Where did you get ur Crx SiR Front End Conversion From?
- civic 4 door seat rails same as hatchback??
- amber corner
- Another member to the family
- CRX HF??
- Wheres the best places to buy a FiberImages SiR style CF hood for USA crx?
- dohc-zc timing belt
- crx hard brake lines
- Running amp wires
- CRX Questions.. NEWB
- nippon-motors.com
- I want to buy a CRX HF
- OFFICAL: What Did You Get For XMAS (EF only)
- Clutch Cable Installation
- Coolant Tube Broke (pic included) - What to do?
- What does it take to do a rear disk brake conversion for an 88' CRX Si?
- wiggle.. help!
- WTB: Place Racing front crossmember
- input shaft bearing
- HELP ME ASAP
- what do i need to do to boost my car 6-8lbs?
- I'm looking to get a tranny but do i need these?
- Snap right on tranny
- noise when turning
- EF reliability
- (SEARCHED) SiR Headlight question: Use USDM headlight mount?
- Timing Question....How do you align camgears too crankshaft?
- How to install new front headlights
- code 17 i cant find it
- yes i know anwered many times probably, mpfi help a.s.a.p please!!
- Going to be ordering a ZC real soon
- New hatch that I got, Deal or NOT?
- which kind of wiring harness?
- **HOW DO YOU INSTALL A SHORT SHIFTER?**
- exhaust question
- Hasport Axles on b16A1 convertion
- window visors
- 0-60?
- ecu obd1
- Why cant I find mounts?
- electricity problem RE neon lighting
- Anyone using an OBD1 Ignitor in a OBD0 dizzy?
- Pics of rota auto-x...
- superchips ecu UK company ???
- help
- trade 1993 civic / crx
- intakes
- OBD0 Vtec Gasket
- take a look at my web sites
- all motor times in the bahamas
- newly updated 1 g club site need feed back more to come over holidays check us out
- 86 crx swap info (b16a)
- Honda PM6 ECU 90-91
- I NEED WIRING DIAGRAMS FOR POWER FOLDING MIRRORS AND POWER WINDOWS
- merry Christmas
- Help put ls injectors
- crx b-series mounts
- Anyone got ???
- installed new distributor, car turned over once, then died immediately. now it won't crank...
- EK short shifter work in crx?
- which tires??
- how to tell the difference between cranks
- PM 9-6?
- B16 swap question
- b19 heard of it?
- custom red
- airbags???
- 96 hatch d16 engine into crx
- merry christmas
- Intercooler fitaments on EF's
