z6 swap 91 crx si axles?
Old Jul 21, 2015 | 11:32 AM
lsvtec_hatchback's Avatar
Default z6 swap 91 crx si axles?
im doing a d16z6 boosted build in a 91 crx si. I was going to use the z6 hydro tranny and do the hydro conversion. ive been searching but I cant find a for sure answer on which axles to use. do I use the axles for the crx or axles for the transmission. thanks for the help
Old Jul 21, 2015 | 12:54 PM
jlicrx's Avatar
Default Re: z6 swap 91 crx si axles?
crx si axles
Old Jul 21, 2015 | 01:18 PM
alright thanks I wasn't sure. ive read use axles for whatever chassis and ive read use the axles for the trans ur using
Old Nov 4, 2015 | 04:25 PM
stewdabaker's Avatar
ok, im necroing this... only because I have to ask..
What is the difference in you reading it somewhere else or here?
One guy on one website tells you to use CrX Si axles and you are ok all of a sudden?
I don't even know if he is right or wrong, but you blindly believe this guy for what reason?
You didn't even mention the folks that say to use 90-93 teg axles (not sure how that works tbh)
also, ive been searching this topic for 3 days and ive yet to find a good informative write up on the differences in the civic axles that are out there.
any links anyone?
Old Nov 5, 2015 | 08:21 AM
v4lu3s's Avatar
RTFM
Ed and eg axles are different lengths. If using the stock transmission type in the stock chassis stock axles are what fits. I understand the hydro trans conversion uses the eg axles though since it sits slightly different and better matches those lengths.
ricardo13d
10
Oct 6, 2009 01:37 AM
the_rex
Mar 23, 2008 07:44 AM
Ajohatch
Northwest (Sales)
Nov 10, 2005 11:48 PM
Samurai
Sep 17, 2004 07:24 PM
sic2kSi
Dec 17, 2002 08:39 PM
