View Full Version : Honda CRX / EF Civic (1988 - 1991)
- 90 Civic Stuck In Park Gear
- MPFI swap w/ auto trans?
- 91 Civic 3dr Si Seat Belts
- third brake light on hatch
- Center Console
- Quick Transmission question
- 91 crx si fuel pressure regulators fail
- b16a fuel rail issues (PR3-2)
- 90 crx si extremly loose shifter
- CRX "Clay Bra'd"
- short throw for all you crx guys!
- CRX Koni Yellow + H&R Race Springs Bottoming out (Help!)
- 88 CRX Evaporator / Freon question
- Code 9, cyp?
- help please! no spark, 91 ef hatch si b20b
- Sideskirts for an 88-91 civic hatch
- traction help
- Z6 running a little rough?!
- Any Tips for repainting the window trim?
- SI HF front bumper support different than DX?
- DOHC ZC drivers side motor mount bracket question
- B16 civic sudden bog issues
- 4x100 Advan bottlecaps?
- CRX oem radiator ATF cooler fittings ???
- I really want one of these rides!!!
- How to quickly boost performance?
- ef with ?? front end....Confused yet? me too
- wheels and tires offset/ fitment
- CRX Body Harness Question
- rear bumper support
- How to Convert my 90 civic w/ B16A from OBD0 to OBD1
- Mugen 22mm rear bar. Anyone have pics!?
- 91 civic DX jdm b16 a axels and rotors
- Zc dohc hesistates downhill
- power steering help!
- 1990 Civic DX HB Seat Bracket problem
- 88 civic dx d16z6 swap NEW
- 91 CRX ZC Idling issues.
- climate speed/fan blower dead?
- motor mounts to raise the motor?
- Ef dpfi to obd1 prob no start no nothing!!
- **sir hood wont close** HELP
- going b series.need help.
- 1990 Civic Si Hatch HELP!!!
- obd0-obd1 problems/no start
- i have clicking noise on the front right.passenger side
- Photos of CRX with Password carbon brake ducts?
- which rear toe kit for ef 91 civic?
- Another Wheel Question
- Crx hf not getting mpg it should
- obd1 dizzy hardwire to ecu
- asking quick favor
- building up a d16 block vs doing a b16 swap
- compression
- multiple codes help
- conversion harness ? dpfi-mpfi
- question on kill switch
- GSR Cloth Seats
- A build you might want to look at.
- b16a obdo pr3ecu need help please!!
- beefed up the hardware
- o2 sensor question
- 1990 civic hatchback dx interior
- '88 Civic with a nasty rough idle
- 1991 Civic Wagon Progress
- SiR Lips
- Replacing Cylinder Head
- Successful start up but not so successful
- CRX onto A 6x12 open utility trailer
- Axles.. (Grrr..)
- Carb sticker any one D-670
- B16A oil filter removal
- DOHC ZC Throttle Cable Question??
- Z6 swap help?
- 89-91 civic hatchback help buying parts please
- 88 civic DX top out
- Pics of CRX on H&R Race Springs (reds) and a question
- distributor question
- My 90 ef hatch "red lines" at 3500-4000
- installing a resistor in 1898 Cr-x SI
- boosted crx problems
- B18B swap in my ef? or ZC head?
- cut off toggle switch on crx 91 si
- 93 Honda concerto d15b2 help.
- 1991 CIVIC HATCH ED9 LIP HELP
- 91 sedan hood doesnt close all the way...
- i drove car with plug wires in wrong order on cap, can that damage anything ?
- Car sputters and then shuts off..help please!!!!
- CRX DX black breather box on back of block - one bolt holding it on or two??
- Suspension Help >_<
- Eeny, meeny, mint, moe D15B
- New crx rear seat
- new fuel filter and tank new relay new fuel pump
- B16A idle
- How I fixed code 20
- b16 with ac
- Rocker arm bolts fell out. Did I put them back in correctly?
- Car hardly running, check my work
- Why does my 90-91 Si Drivers seat have a permanent gangster lean ??
- If you had $700, what suspension setup would you choose ??
- can't find size dimensions of stock CRX muffler?
- need help finding places to buy new OEM (rubber) Rear Trailing Arm bushings ?
- d15b7 ticking
- Jdm b16a oil pan replaceable
- need help crx shocks
- shift rod seal
- Headlight/Hood questions
- ignition timing/dizzy replacement help
- obd0-obd1 help
- should I even bother trying to get my idle correct with exhaust leaks ???
- crx 91 si wont start replaced alot already
- Idol issue maybe?
- Car cranks, Main Relay doesnt click.
- EF Touch up paint still available
- crusie control
- 1990 ef sedan cluster help please.
- Girlfriends 89 Civic DX STOLEN TODAY - Coon Rapids MN
- b series swap problems.
- Full Hydraulic Trans. In A '90 Std. Hatch
- ECU Pins
- HELP!!!!EF Hatch 90-91 rear bumper support / reinforcement
- tokico shocks, do i need bump stops?
- Going nuts trying to get rear defogger working
- Why does my 90Si not like to turn on when the weather is warm?
- ef wagovan suspensions
- detonations and misfire... help...please
- GSR into EF hatch question...
- Anyone make trips from PA to Florida for business ??
- my 89 Dx
- Can you help me???
- fuel cut of really early? and kinda sputtering up to speed
- 90 dx hatchback build still learning
- Not idling engine code 9
- 90 dx swap?
- EDM Rear Fog light Help
- Question about rear seat headrests for JDM/EDM experts
- 89 civic obd0 to obd1 pin a16???
- Starter won't turn over.
- EVIL EF9 RHD MY CAR
- core support interchangeability
- 91 sedan w/ LS wiring issues
- Interchange of front mudflaps 4 '91 CRX
- 91 hatch ls swap questions
- lights on dash without key even in!
- is it OK to drive w/o the AC evaporator ?
- Need help on deciding what direction to go with new project ef.
- Distributor question
- rex b18a1 coolant temp guage not workin. also gas purges
- stripped timing belt tensioner bolt.help!!
- why flickering batt light?
- Will Trade d15b7 for EF civic H Mount kit!
- d series swap question
- im getting a smog check in cali. so what do i need to put back?
- CRX race car won't start after new fuel pump
- obd1 accord distributor in a crx?
- My ED3 just got Jacked from Montclair mall in SoCal
- Idling and 1st gear problem
- Vacuum routing and EAVC
- 1990 Hatch Locks
- How Would I Read/Scan my CEL Code?
- Possible Head Gasket? 91 Civic Si
- who's got the better deal ENDYN or Bisi
- Installing 93 integra master cylinder, do I need to change the booster too?
- 1990 honda civic dx
- Bolts with Darco Coating
- Rotax 215 supercharger on dohc zc d16
- Is 88-89 CRX DX seat foam the same as 90-91 SI seat foam ???
- Rear seat headrest cross reference
- looking for vti civic ef wiring from dash to ecu
- rack and pinion play
- ground to fuse box question
- b16a first gen problems staying on\//////
- Holy Blank Batman we failed smog
- Wire Harness Refurbashing Question
- Exhaust removal... need help
- Is EF9 a subset of EF? Please educate me.
- Main fuel line question concerning fittings...
- ef seats
- How hard is it to re upholster seats?
- Skunk2 Pro Series Intake Manifold clearance
- Air Intake Kits
- Exhaust Leak... -_-
- Tokico bump stops ?
- EF Hatch Has Spark and Fuel Pressure, NO Start
- ls into ef sedan
- Chassis swap questions
- Help me fix my oil leak please!!
- Timing off or need more fuel?
- 91 EF sedan suspension swap
- Just got a CRX sway bar in my hatch
- Help people I need someone that read code on obd1 video inside
- Clutch issue (Squeaking)
- Thermostat suggestions
- New honda water pump defective?
- fuel pump problems
- 90 civic hatch turbo
- bent Axle?!
- facelift cluster swap question
- B18b1 idling high when cold start need help
- can i go 4 pots & 12.8in rotors
- Chasebays Fuel Tuck for CRX, anyone used it?
- Highway speed front end shake
- 1990 civic Zc issues. please help
- ZC ECU in my car?
- What is a good ECU?
- Difference between B16 Engines?
- My 1990 Crx SI Build Thread
- 93 integra parts car, what to swap onto my ef?
- Clutch compressor will not work
- carfax.com and history
- Thoughts on my suspension setup .. :D
- Engine Swap Advice!
- Ef Lips
- 1989 CRX Si Project
- k20a3 fully built....Is it worth it?
- jdm hood latch?
- Door Ajar/ Interior Light Problems
- Just mpfi, or more...
- EF3 power window problem
- Brake lights dont turn on
- car wont start, starter clicks only once when i turn the key
- 90 crx si brake upgrade questions.
- My 88 EF Sedan Build! (7-6-13)
- Need a close up picture of the logo on the OEM floor mats please.
- 90-91 turn signal lamps fit 88-89 ????
- How to keep your obd0 injector clips for obd1 swap..L@@K
- steel or chromemoly sway bars
- Anyone using the ST 51140 Rear Sway bar? need advice on fitment
- 1990 crx SI updated my front bumper from OLD to new =) with paint of course.
- Help Identify These Plugs For Obd0-Obd1 Swap Stock 91 Si Harness
- MKIII Jetta Recaro Seats in a 90 Civic HB?
- D15B2 AC idle pulley mounting, is this right ?
- How to install a/c in a 91 civic with a d16z6 swap?
- Rev limiter at very very low rpms?
- 91 civic d series turbo build
- 91 DX: wire harnesses inside driver & passenger doors?
- 89 sedan transmission problems
- "Fiberglass" coming out of brand new catback exhaust ?...whatttt...
- d16a6 manifold help!!
- 91 crx b18b1 fifth gear keeps popping out need answers thanks
- Gsr swap in a crx ? about crank pulley
- new to the EF civic (gauge question)
- Need help diagnosing a shaking suspension problem
- Full Exhaust!
- Traction bar EF vs DA
- H series Knock off mounts?
- Rocker assembly where do these bolts go?
- Rocker assembly O-ring not fitting. What kind of O-ring is this?
- Second opinion for swapping engine cost
- wagovan random code 16?
