- d15b2 Question's.
- OBD0 CEL code 17 .... wtf.
- Help with shocks
- CRX Seats
- 91 hatch 'modest' build
- Need help with racing seats!
- D15z1 head swap
- electrical issues
- My clutch is making me crazy
- crx engine harness 88, 91 differences
- 89 crx bumper options
- New 91 EF Hatch owner/build!
- Having trouble finding some tranny brackets.
- b20b timing
- Deadly Crx Crash
- passenger side seat belt problem
- Running rich
- Coolant temp gauge not working
- Half shaft issues
- code 24?????
- Distributor problem?
- Please help me find my old crx
- My Rex doesn't start :/ help
- Chargespeed rear wing LED
- cam gears
- odd cooling question
- Odd noise from valve train
- wiring CKP sensor
- 91 civic need help
- DIY for timing belt & water pump replaced
- Crx Interior Questions
- jdm front end
- running ac fan instead of radiator fan
- D16z6 idle surge
- Video Project, Show it some love! EF
- Climate Control lights do not work - '89 Civic
- Redline synthetic shockproof gear oil in tranny?
- 91 Hatchback...
- IGNITION WIRING
- quick transmission question..
- window molding question.
- 1st civic daily driver HELP!!!!!
- DIsk brake swap on 90 Civic EX sedan
- really high idle
- Broken bolt on rear upper control arm
- radiator id?
- alt belt issues
- H2b 91 dx
- Installed headers, burning through gaskets?
- Mini me swap help
- OBD0 - OBD1 Dizzy Jumper
- crx b20 obd0 to obd1 conversion
- whats best for a swap
- b16 cable trans issues
- dumb seat question
- trans issues
- exterior window clip part # question
- Coilover: which one do u choose ?
- 89' HB STD turn signals
- Main relay or fuel pump
- ride hight problems :?
- JDM EF7 calipers?
- crx a/c
- 9o civic hatch fan control switch
- 88 hatch cluster options
- Want to buy CRX cargo cover and divider in blue.
- Cam broke now time for MPFI swap
- ac help
- Best tire size for 15x6 with 35 mm off set?
- H2B Swapped Crx Burnout Video :)
- Tranny problems/ d15b2
- Car will not even try to start
- ef8 hydro conversion clutch question
- highlight relay location
- 1990 Honda civic EF brake lights
- Minime or B series Swap?
- 1991 Hatchback wire
- quick ? bout tie rods
- 99 prelude seats in 89 crx?? will it work?
- Very slow EF Sedan build!
- Jdm sir to edm headlight fitment issue ( crx )
- 0bd0 vs obd1 injectors with resistor box
- obd0-obd1 distributor wiring. Is this acurate?
- Brakes: 88 Crx SI (JDM) same as 91 Prelude SI?
- EF3/EF6/EF7 Radiator support
- Fitv, no plug on harness
- Wiring Issues
- 89 Civic Delete help!
- EF Sedan Fogs ?
- CRX b20
- 91 civic brake problem
- 91 civic oil pressure switch problems
- 1990 Honda crx part number for headlight question
- 88 to 91 Civic Hatch : wheel/tire/suspension fitment
- SO-CAL EF Enthusiast " 6/23
- Radiator fan mess. Help?
- need radiator
- Ignition coil question.
- Question about RT4WD/6-Speed tranny...
- ef sohc mounts same as da mounts?
- mini me probs, been searching for hours
- Civic Not Starting
- AMA: Aak Me Anything (engine related) school project
- dual point to multi point HELP!!!!!!
- MPFI into DPFI car... How to?
- Check engine light
- Popping sound from front end & tram-lining
- wtf vtec?
- 91 crx si wont start/ no spark/ complete disaster with new motor
- h22a alternator issue
- clutch problems
- 89 Civic Si hatch won't start ?
- 1990 CRX stock build.
- Burning LOTS of oil, help?
- single fan to dual fan radiation
- ef si interchange parts with the other EF models?
- 91 crx Si Won't Start
- kill switch info reward= mulah
- Need help
- RHD K20 wagovan build
- civic ecu pin out problem
- alt surging???
- D16A1 quick question.
- obd2 sohc zc goin in obd0 rex
- Throwing on some 15x8s
- d15b2 mpfi boost?
- D16a6 head on d15b6 block??
- ls swap ecu issue?
- Em2 cluster in ef...can it be done...
- 88-89 crx fender to 90-91 crx question
- B20 question/theory
- How low can i go on stock struts?
- EF SEDAN SQUAD
- Just got a '91 Crx HF there's some problems...
- B series oil pan question.
- rear disc swap conversion questions.
- ef cluster problems
- tach only works while cranking engine
- Going from MPFI D15B2 to OBD1 D16Z6 got a couple questions
- b16a issue
- aftermarket power windows
- PLEASE HELP? b18b1 diagnose?
- Starting Problems
- Ef charespeed wing
- Anyone recognize these parts?
- d16y8 swap wont stay started
- How to fix the wiper hitting the trim?
- Fuel pump wont turn on- No spark
- Honda civic EF9 PLEASE ANSWER
- Window regulator questions
- Idk what it is...
- Transmission Not Shifting
- 91 Ef Hatch
- Alternator Removal
- need details on how trim/molding along top of outside of door goes on ??
- EF Civic Stereo Install Cig Lighter Help!! no juice at harnesses
- EDM CRX foglight switch wiring help
- B18b swap for '88 honda crx HF
- Access Window Visors JDM EF9 vs USDM ED7
- Wtb: 90-91 Honda wagovan parts
- Yuki: The '88 ED6
- ZC vtec conversion with mini-me nauseau
- Dizzy problem with B18C1 in 88 EF please help!
- Cold Wheather
- STOLEN: 88 CIVIC HB
- Battery Light
- 90 CRX starter gremlins
- 91 si 0bd problem.
- 1991 Civic Sedan Lx (Rebirth) Lot of Access parts to be added. :D
- need help with ideas for my swap
- New to Honda - 91 Civic STD HB ( D15B1 )
- big block sohc crx
- Crx tp sensor!! Help
- inner tie rod or rack and pinion? 90 hf ls swap
- a6y8 ecu help plz
- J swap 91 si
- Help!! EF Civic Hatch Intermittent Starting Problesm with Pics and Videos
- 91 lx sedan shifter thread pattern?
- help please! overheating ..
- DC seats in 4dr ef?
- Plz help car won't start.
- What is difference between 88/89 and 90/91
- question about 91crxsi rear disc on 91 lx sedan
- This idle is killing me...88 d15
- i need a dash for my 1988 ef hatch....ANYONE?
- WTF. Rear Toe Adjustment Rotted
- brake booster and master cylinder 1inch
- 88 Sedan H22 Build
- Z6 head head different?
- d16z6 motor harness help
- WRENCHING YOUR EF SEDAN
- what tranny is stock in a 91 civic si?
- cluster question
- low compression numbers
- Gauge cluster minor(?) problem
- Need help with brake lines/Master cylinder!
- Da seats in ef si hatch
- Buzzing noise at highway speeds ?
- Fuel guage needle not on full mark
- pr4 2 codes killing me
- 90 civic doesnt want to start, tried searching? Plz help
- Question??? Yakima bike rack: ef hatchback
- cable to hydro tranny convert question
- Has anybody used integra dc2 tie rod end outer ?
- Need help IDing this plug
- suspension help needed!!
- TPS Code 7 ON and already calibrated.. I need Help.
- sperical bearing in front crossmember
- Failing E-test SO BADLY!
- oBD0 code 11
- D15B Connector Identification please.
- Replaced CRX Main Relay (pic)
- Wiring from A 89 crx si to a 90 crx si? Help
- 89 Crx won't "warm" start
- Obd0 Rex and obd2 sohc Zc
- thermal exhaust vs ebay exhaust
- newly acquired honda enthusiast
- 88-89 si cluster
- no polit bearing on flywheel
- Weird Electrical Problem, help.
- hydro tranny vss question into a 90 civic si
- LS Swap No Spark
- d15b2 pistion rings question.
- Connect battery and ingnition on?
- neeed your opinions:)
- need help please asap b b series ef tranny fluid change
- Help needed tensioning AC Belt
- got raceland coilovers need help
- stage 4 clucth vib and i think starter prob..help
- chasing a phantom ghost problem
- Ef hood swap?
- how possible is 12 second on boosted doch zc
- Cant get car into gear. B20 hydro trans.
- crx with dohc zc swap
- code 4
- Radiator support changing
- GSR short or bad connection?
- Suggestions on adjustable front upper control arms
- Honda finatics from around the Ms area?
- Has anybody ever used these D15b2 rods?
- CRX Brake Bias on track
- 90 dx hatch smokes like a freight train
- rear bumper help
- fuel or spark?
- Dpfi-mpfi
- What is your favorite thing about the crx?
- ef sedan catback fit eg coupe??
- wire harness swap question
- What spindles are these??
- fitment question
