Electric load lowers idle, advances timing... this normal?
Old Jul 5, 2015 | 06:51 AM
crxguy406's Avatar
Default Electric load lowers idle, advances timing... this normal?
I warmed up the car to the point where the fans were kicking on and off on their own, and checked my timing.
I noticed that while idling with the fans off, the timing was perfectly at the center of the 3 marks. Then I noticed that when the fans kicked on, the idle dropped by about 150 rpm, and the timing advanced about an inch past the group of 3 marks.
Is this normal? My understanding was that the idle is supposed to increase under electrical load? (I've already replaced the ECU, ELD, IACV and alternator while troubleshooting a different problem.)
Old Jul 7, 2015 | 07:01 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Electric load lowers idle, advances timing... this normal?
Ignition timing does NOT stay static unless you jump the service-check-connector on your drivers side shock tower (plug under the yellow rubber cover). Yes this is normal. The ELD inside the engine bay fuse box tells the ECU to switch the alternator between one of two different charge settings. When the fan kicks on, it most likely boosts the alternator output which effects the idle and the timing.
Old Jul 7, 2015 | 08:25 AM
crxguy406's Avatar
I had the connector jumped with a thick piece of soldering wire. I must not have had it shoved in there far enough to make a contact.
Old Jul 7, 2015 | 10:45 AM
94eg!'s Avatar
#1 Super Guy
Loved
Hmmm. Allegedly jumping that connector is supposed to lock the timing for the purpose of check & adjust. I still wouldn't be surprised if the fan had some effect on timing when it comes on. I would definitely set my base timing when the fan is off. :D
gooblinn258
Dec 12, 2013 06:21 PM
AnAccordIsForever
Nov 25, 2006 09:23 AM
NoVALude
Nov 20, 2006 11:02 AM
SOHCMAN
May 31, 2005 03:10 PM
non-VTEC
Jan 27, 2002 12:15 PM
