View Full Version : Honda CRX / EF Civic (1988 - 1991)
- how much coolent?
- DC front struts on 90 CRX.
- JDM D15 VTEC
- struts/ coilovers
- Aftermarket Gauges For CRXs?
- 88 vs 91 booster
- head bolts.
- strut tower torque spec?
- a chaany good shops in ontario,toronto area?
- what do i need for a b16 swap?
- Engine swap place
- D16a9 engine with lambda.I have that.. is that possible? People who know.. tell me :D
- block bore ?
- OEM gsr tower bar in 90 CRX?
- lower control arm help
- Megan Racing Headers for a CRX DX
- Help Identify tranny PLZ
- jdm bumper conversion
- crx intake maifold upgrade
- where can i find 90 to 93 integra throttle cable?
- invidia ef9 exhaust on crx
- swap..just quick question
- Is this right?????
- lips
- what would happen if i put a hf motor harness on a si????
- how to read codes???
- Stock D16A6 Top Speed?
- wtb-d-series cable tranny
- car wont rev past 6,000 rpm
- CRX with ls swap/hydro tranny?
- 91' civic hb rev limiter?
- Best way to clean carpet while it's out of the car?
- question on mpfi swap
- XSi gauge cluster in crx??????????????????????????????????????????!!!!! !!
- window regulator
- EF Si Underdash and Engine Bay Harness Question
- Automatic D-tranny Starter on a Manual D-tranny?
- D15b Vtec help!!! cant get to stop pulsing!!
- will any other exhaust systems fit a crx?
- B16 swap in progress
- k23 swap
- VSS wiring w/o speedo??
- b16a motor mount bracket
- Sites that sell stuff to my 85 CRX..
- OEM bumper color
- VAFC
- Check Engine light ((Code 9))
- brake caliper problem ... Please respond quick ... Running out of light
- Omni Coilovers ef9
- HELP!!! my zc soch is blown and i need to see........
- Drag Racer
- TPS Calibrate - How to
- crx gauge cluster melting???HELP!
- Will a DX valve cover fit a Si? Pics.
- brake fluid question
- What does white steam mean?
- erl pricing?
- Engine bushings
- Oil leak again?
- +20 offset rims okay for EF
- Detailed my engine now car wont start!!! Pics inside!!!! :(
- Help with JDM EF9 Front Bumper
- Idle Low - Electrical Load Causes 700rpm Difference. What Causes?
- For All Interior Guru's
- 89 civic hatch.. obd1 motor.. lots of questions!!
- Where Did You Get Your ZC Swaps
- b16 exhaust questions
- Are 88 and 90 master cylinders the same? CRX SI's?
- quick question????
- what front lip is this
- will the crx Invidia exhaust fit my ef9 civic
- What car came with OBD1 Bseries stock ? Need quick answer
- DC brakes in my ef
- Timing belt snapped
- ek neuspeed sport springs
- B16 throwing code 4, help!!
- B16 Torque specs
- Moving the alt. on a B16
- Engine Restorer vs CD2 Almite
- Engine rebuild in VA/NC......Where?
- Swap mounts different between cable and hydraulic?
- 88-91 pm6 ecu
- Power Steering Question
- Mix n match transmission stuff
- CF hood came bent, advice?
- just got my ecu back from xenocron and have some questions...
- A few EF B18a TURBO questions/fitment issues.....
- may be switching to honda
- best power out of a dpfi. dirt cheap engine swap.
- Transmission weight?
- Ignition? Vaccum?
- Help dont know what happened
- my ef how much would you pay?
- will a brown top zc fit in a 88 crx
- K20a3 EF
- Engine Overheating- what should I check-D16a6
- what is the deff from a si and ahf motor harness????
- distributor problem can anyone help
- rear disk swap into 90 hatch....are crx rear disks just as good as DA?
- alignment
- Crx Identification
- Are there any 4-rib alternator pulleys that will fit a d16a6 alternator?
- 88 HF CRX B16 Project
- Electrical Diagnosis..
- d16 question?
- where can i get a complete clip with panels
- help lower NoX levels to pass smog
- Getting ahold of JimFab or L-Con Traction Bars
- What offset to use +42 or +45 Buying very expensive MAGNESIUM rims and don't know about OFFSETS.
- help with intake manifold
- pg7 ecu chipping
- zc swap?
- Crank on A6 does not crank for compression test
- best header for a b16 88 crx?
- So I bough 2 Exhausts for my 91 K20 Swaped CRX HKS 50mm and Invidia 60mm Time to choose!!
- dx turbo in a 90 si
- Oil leak to tranny problem?
- B16 problems
- fuel tank filler pipe
- what should the fuel pressure be on a stock b16 in a crx
- Rev Limiter Troubles
- DA distributor for EF?
- RHD engine harness same as LHD?
- PROJECT TIME
- who has the part # for this?
- I NEED HELP BAD!!! My cars idle is completely F*cked
- running obd2 sensors on a obd0? is this my problem?
- Why god why me
- D16Z6 INTO 91 HATCH
- wiring help needed, please read.
- head gasket remains.
- I have a pain in the civic.
- headers!!
- which engine...
- POWER STEERING
- Megan Racing Headers 88 CRX
- differance between hf-2 and hf-3 mpfi?
- conversion to multiport dx
- B16A 92-95 (SiR-II)
- Changing cams in a B16
- D16z6 Cam Gear Question ??
- My car is STUCK in second gear!!! HHEELLPP!!
- CRX alignment
- Question on buying an ECU
- air pressure sensor- dash mounted gauge for tire pressure
- EF hatchback Sir Front end conversion
- B16 MANIFOLD ON A D16Z6 HEAD, WILL IT FIT?
- greddy or neuspeed FRONT TOWER BAR
- gauges dont work any ideas
- still have code 4 after new distributor...
- crx for sale
- lexan windows
- help speedometer don't work
- which is the better tranny?
- crx help
- Just got ef8 front end
- code 8 AGAIN??
- super afc 2
- need a diagram
- Pillar mounted? Door mounted? HELP!!!!!!!
- blower motor ????
- 91 CRX exhaust choices
- is camber good or bad
- i am new to this
- s2000 hub swap?
- need help wireing a b18a1 into a 91 crx hf
- Relocating battery car not starting...
- distributor problems
- Passing Washington State Patrol question???
- <D16 boost suggestions>
- Battery light on... Please Help
- anyone know the weight of a CRX hatch?
- Tranny Troubles.... HELP ME
- Strange noise..balljoint? shocks?
- Getting my car alightment solved with my camber kit.
- i got work in 20 min and i need a car to go work
- power windows in a wagon?
- question about turboing my crx
- Code 13 on 91 LS
- Want to do a Front convesion on my 91 civic Si
- running lean need help!!!
- Air con help
- for all you guys with SLAMMED rex's
- ecu codes
- need some help
- comp ratio
- can i swap Front rotors to the back?
- New ZC engine from HMOTORS bad?
- Tuning for boost.. 90 CRX Si
- Seat rail differences, 88 compared to 89-91 CRX
- ? on compression ratios
- 91 SI ZC swap: ECU code 20: Load detector-- US has one, Canada doesnt? Plz Help!!
- NEED SOME TROUBLE SHOOTING HELP
- How do I install my S2000 head unit into my CRX?
- Crashed my CRX Need help!
- stroking a b16
- Will clutch for DOHC ZC also work on d15b2 SOHC?
- So I was going down the road and heard a freight train comming my way...
- 90 crx with j1 trans, clutch cable too short?
- Deltacam 272 - wrong regrind?
- replacing the EF rack and pinion steering
- were silver & yellow crx si's limited in production?
- ls vtec si crx
- TRANNY PROBLEM
- motor mount insert
- Si or Sedan exhaust fit?
- Orange VAFC wire and "Sensor In and Out" question.
- The oxygen sensor from hell
- what is the best tranny fluid and motor oil for a y7 t25 HMT setup?
- Pats fake ef9 project.. start to finish?(ehhhhhhhhhhh)
- wtf is wrong with my car?!
- greddy motor oil?
- si tranny
- alinement problem???
- Look what I got in today.
- mud flaps?
- Good Deal on a 1990 CRX?
- Cleaning Engine Bay?
- New project Just picked a 1991 CRX SI
- B16 MANIFOLD AND D16Z6 HEAD WILL IT FIT?
- help with price on a price a 89 si
- 1990 crx si for sale ls/vtec turbo
- Bad Injector causeing no start on new swap... can I...
- swapping b18a into crx. HELP!!!!
- will a A6 Dizzy for a Y7 head,
- does energy suspension make a sway bar for the rex?
- how do i add pics to forum
- Need some help with ECU codes
- what is this?
- here she blows!!!
- Best resource for SWAP
- mounts
- what should i do ls or d-series
- 1990 CRX A/C tension pulley install
- Input needed from EF guys with H22's
- EF budget Turbo D build
- Loserkidwac's CRX Power Mirror Write-Up (Using 4 Dr Civic Mirrors)
- EG climate control swap
- FS:GREDDY TURBO KIT w/ intercooler
- How can I tell what kind of head I have?(searched)
- IM under brace bracket???
- What's my 90 hatch worth
- Video - 9500rpms, front straight away. short clip.
- Help problems with Rev limit on my B16A powered CRX
- intermitent starting problem...help!
- 88 Hatch LS Swap - Wires left over...
- Alternator's Pivot Bolt won't budge for love or money
- 91 dx fuse layout
- Vanity plate
- Looking for new suspension
