View Full Version : Honda CRX / EF Civic (1988 - 1991)
- CRX with B18C5 engine not starting, please help !!!!
- AC Control Problem
- b18 into 89 hatch si
- b16a not getting enough fuel when reving, bad injectors?
- How did you fix your code one?
- How much did you pay for your EF?
- JDM backseat brackets for CRX
- Fuse Box cover missing under dashboard to the left.
- f@#^ing timing!!!!!!!!!!!!!!!!!!!!!
- HELP: door trim, thin vs. thick what years?
- I wanna get a full combat kit...but where?
- sdfgertdfgesggeyerter:::World of Sin::: - http://WoS.4x2.net
- JDM Amber Clock or am I dreaming?
- tach is jumpy
- CRX w/ B18C: possible to change tranny without removing intermediate shaft/driver side axle?
- Broken rear mount 2 times now... X-member is cracking...
- Diagram/Service manual for Si intake manifold
- fuel pump doesnt activate when it put it in ACC.
- B18C1 SWAP DONE AND BAR CERTIFIED !!
- Looking to buy the Black Widow II kit...
- Block??
- tranny question
- Inside air temperature will not change
- help! locked keys in car
- Selt belt light on beeping every 3 seconds .. . beep
- Anyone have info on Espelir JGT500R catback?
- car clicks but no start help plz......
- need distributor help
- norcalcrx.org not up?!?
- help: jdm b16 stage 2 everything or b18c1 which do u prefer?
- pedal adjustment
- anyone with a gsr cluster in their crx...
- revlimit at 6500 on b18a1?
- JDM CR-X Si
- Need Correct Vacuum Line diagram B16A into '91 civic
- odometer swap??
- Still Vibrating CRX
- HF or Dx
- crx vs. civic hb which is lighter? (pre-92)
- What do u think about 2001 Impreza 2.5RS?
- how can i keep my molding black and shiny..
- cold start problems
- (Off topic, but please keep here) Thanks to all veterans and those in the military!
- lights get really bright @ high rpm
- diffrence in DX and SI suspension
- CRX Ride Height <<search still down>>
- 91 CRX HF Coil/Dizzy problem Help
- obd 1 conversion question
- 6.5K rev limit?
- D15B p08 ecu with boomslang obd-1 conversion harness o2 sensor question
- 88-91 Civic dash clock-Plug-n-Play??
- The Wait is over!
- yo man
- vacum help
- It's wrench time!!!
- b16 ecu...
- Budget Exhuast: OBX Type-H vx Tsudo N1
- Is this legal
- problem wiht trans
- civic coupe 88-91
- B16 Tranny mount Problem..
- WHat is the Proper way to connect a ground?
- vortech - b18c
- OBD0 automatic integra ecu?
- 1988 civic head onto a 94 lx?
- WTB: Need O2 sensors Portland, Or
- 88 CRX DX, CEL Throwing Code 1
- Do you have a tow hitch on your car?
- Should I: Dohc Zc or B16a? -both with boost
- no spark?? help please!!
- getin the bitch painted
- What wiring do i need to complete my swap?
- Difference between civic and crx exhaust
- opinions for daily driver
- FS: Selling my CRX....
- Need motor mount help on 89' civic
- coolant questions
- Power windows on a crx!
- just wanna make sure with 2 things ....radiator and brake question
- 93 integra front end on a crx
- PR3 with jdm d15b?
- My zc dyno results
- gsr dashboard in a 91 hatch
- AXLES
- crx with an b18b1 o1 integra ls motor
- ZC clutch options (already searched)
- O2 sensor help
- WANNA TRADE???
- WTB: 91 CRX Si Center Caps
- Are these block the same??
- High flow fuel pump run rich??
- B16a Powered AWD wagon
- so long my socall jdm crx
- where to find zc motor for cheap?
- just got another rex need advice
- Anyone with turbo D15B2 stock?
- Help! Car is slow and I cant take it anymore! ZC Turbo!
- Let's see your exhaust!
- how much hp does a b18a have
- white smoker
- floormats
- You guys are gonna kill me on this. Wiring diagram for a Z6 motor in a 89 DX.
- crx-integra seat question
- how much is this 87 crx w/ type-r b18c worth?????
- 91 CRX rear disc brakes, pict request
- hasport hydro tranny to cable car kit, same thing for all trannies?
- Need help finding Cable to Hydro kit
- DOHC ZC motor Flooding, burning to rich, please help
- OBD2b D16Y7 into an 89 CRX DX
- B-SERIES wagovan??
- 91 crx si seats
- CRX ZC motor Smoking BAD, please help!
- NTB: D16A6 Tranny Quick
- COMPUTER TROUBLE CAN SOMEONE HELP
- Car TROUBLE
- ZC question
- engine codes
- difference in heads????????
- which alternator do i need for 1 gen jdm B16a running with obd-1???
- pm6 ecu
- B series Turbo kits
- does crx HF speedo gauge overlay appear same as SI one?
- Glass Top CRX
- Crank pulley making noise
- CRX w/UK leather door cards, power window dilemma
- Need to fix radiator before i swap z6
- sideskirts, rocker panels, whatever...i need some ideas!
- how much to expect to pay for hx wheels
- What parts from ls will work for my gsr swap?
- just bought an 89 civic HB.
- Metal z3 fenders
- Looking for a 1 inch master cylinder for CRX w/Intergra booster
- SUB BOX
- Headlights
- glass sunroof and trim
- Gauges
- How easy is it to do a rear disc brake conversion?
- B16B swap for an 87 crx
- clutch disc installation 87 civic
- Anyone with temp gauge problems..
- Anyone have experience with aftermarket stock replacement Cat converter?
- Anyone ever replaced the Fuel Sender part of the Fuel Tank??
- problem with rear suspension
- I am looking into a b16a1 swap for my 89 civic dx sedan :) any help would be awesome
- help with my h22a in crx
- all motor d16y8
- engine help
- NEED INFO!!: Puting a 97' GSR motor in my 89' civic CX
- question for mini me people - rev limit
- I need to boost (help)
- car was sitting, and now clutch fells full of playdo!
- battery light is on.. searched but still stumped.
- comon guys I NEED NUMBERS!
- no power
- CRX Si Gas tank help
- window trouble, anyone know?
- CRX door question
- What's the name of the rear door things that hold up the rear door?
- tire question
- Newest crx concept. Not a repost
- finally could work in a body shop at tech school...
- Front sway bar
- code9 HELP
- Anybody using hasport conversion kit with hydro tranny? Adjusting clutch pedal?
- ANYBODY HAVE SUPERCHARGE ON THEIR STOCK CRX ?
- H22 SWAP CRX, B SERIES TRANNY ADAPTER, QUESTIONS AND ANSWERS!!!
- Inneed of Stock 90 Crx CAT converter.
- need help h22
- help crx -h22
- 90 Civic Starter on JDM Tranny.
- Oil catch can options
- si rear hatch and dx rear hatch is there a difference
- looking for swap shops in orange county area
- how do make adjustment to my koni yellow shocks
- *P|CS* Update on my CRX
- just bought 87' crx--i have questions?
- painting engine bay, and interior. What to clean with.
- crx with 92-95 moon roof??
- need swap in ef hatch
- Removing and Installing Windshield Wiper Motor
- will a 88 HF alternator work on a 90 SI?
- Mini-Me description?
- Identifying Engine Year. Grabbed All Codes I Could See
- 4 dr vs 3 dr :: REAR TAIL LIGHTS
- DC2 Type R steering wheel Does it bolt on 90 si hatch?
- 90 ef hatch
- crx w/ b18a1 on sprint extreme springs? clearance?
- alternator woes?
- gsr swap in a crx
- howdy
- y8 mani onto EF???
- Crank Pulley noise
- Rod Question
- vandals strike!
- AWD EF HB... Can it be done?
- tried searching need picture pictures obd0 how to wire vtec ecu
- LOOKING FOR HATCH
- B20 longblock
- What motors come in which crx's?
- please help crx is in trouble wiring trouble because of zc swap
- Help! Car cut out, RMP Gauge quit, Oil light came on, ECU Code(1?).
- DIY Testpipe.
- plugged cat vs new cat.
- how do you do a crx d15 to d16 z6 i was wondering what parts i will need to complete
- 88 CRX DX dash fit into 89 Civic LX?
- just a quikie question
- JDM d15b + USDM Dx trans, which clutch and flywheel?
- Moderations: We have a Pic thread, why not a Vid thread?
- no key hole
- obd 0 question, keep having distributor problems????
- d16y7 is it worth it?
- radiator fan
- 84 CRX MODS ~ NEED HELP ~ WASHINGTON (Seattle)
- Aftermarket rods.
- Like Whoa! Holy Sunday block!
- Y8 'Mini ME' on ad D16A6 - need some help.
- What would you rather have? Rust or Salvaged title?
- I got a CHEAP Crx Si!!
- head bolts
- OBD1 swap gurus, lend me your fingers
- CRX HF with B16A starting problems
- low key porsh gauge cluster
- Clutch kit
- Going to the Smog Ref tomorrow for my CRX...
- CRX SI Red line
- b16 hella slow...please help someone
- B18c5 on Ebay..........Shady?
- eg civic radiator fit CRX?
- how to fix my camber and hatch
- Pacmans REX
- Banlance wheels
- Questions for the experts (With Pics)
- EF front lip
- b18c crx JRSC
- I cant shift into gear.Teach me.
- fitv on the aebs!!!!!!!!
- Fuel in the #1 Cyl Need help ASAP
- Can I use siR knuckles with DA6 Driveshafts
- get a dohc zc vs. 1stgen b16?
- Anyone have itr in 90 crx si
- CRX STOLEN REWARD!!!!
- Not getting spark to #1 Cylinder
- fast idle valve need some help
- question about my completed DOHC ZC swap
- LOOK!!! new trade sell site tradersoup.com
- question about those Halo/projector headlights
- My crx Vid
- What wing is this?
- Hasport b16a crx header worth the $
- Post pics of JDM civics and crx's HERE
