View Full Version : Honda CRX / EF Civic (1988 - 1991)
- e-brake light
- Dont understand problem....
- vtec controller settings for emissions
- B16 o2 sensors how to clean or what to replace w/
- I should use hood pin's?
- how hard would it be...
- Invite to NY Motor Swap on Aug. 17
- Brake pedal goes to the floor...no loss of fluid..?
- B20Z dyno results
- My4Dr CF hood.
- Airmass Warlock Exaust System what ya think about it?
- Where can i get a front bumper lip
- which is better on a d16z6?
- Resetting ECU???
- My bad luck continues!
- stock B20's in a hatch or sedan
- 88-91 Si distributor pinout needed..
- MPFI: Injector resistor from 90 Prelude?
- 87 dx to F.I. how hard???
- puting b16a in crx, where can i get gauge clusters?
- Got my thermal exhaust today - Quick question
- - question about the zc swap -
- screeching on start-up
- Hyperduck Tuning?
- secondary butterfly control in a EF?
- DC2 Dash on a EF Hatch
- How can I trace my o2 sensor wire from the factory harness ??
- intake-air-temperature sensor harness
- are all EF glove boxes the same?
- Where do i hook up the vtec oil pressure on a vtec head???
- does an SiR hood REALLY provide more clearance?
- Big Brake camber problem
- 90-91 EX brakes under 90-91 crx si wheels
- so heres what it comes down to.
- Off Idle Hesitation
- b16 IN crx hf need to know........
- B16A swap mounts Hasport place racing ebay?
- I am throwing code 1 PLEASE HELP
- My New Toy.....
- Fuckin hesistation!!!! :mad:
- Advancing timing???
- EF-9 front end conversion question
- How to run 6PSI on a TDO5H-14B actuator
- Frustraded
- Need help with my zc tranny!!
- Fuel Guage.
- B16A Running Rich (Fuel Curve?)
- For those with a tein suspension setup...............
- whats this car worth? thx.
- Help me decide here...
- H22a into 91 crx si
- Sensor lists
- whats under your hood (please post pics)-(b series motors only) need help
- Idle at 3-4000rpm, WTF and no codes.. Please Help..
- New CRX Body parts ?
- Will 90 Civic hatch side mirror fit on 90 CRX?
- what cams should i get for my mini me?
- Engine damage/no oil??? Help...
- Tech Guru's for CRX's help please!
- B18c5 wiring
- Stock crx si ecu!
- have a question (headlights)
- D16Z6 Hesitation
- burning oil????
- Tweaking the Rear Anti-Sway Bar?
- arp rod bolt for b16a 8mm or 9mm?
- fuel filter???
- How hard to do gsr brake swap in an EF?
- Tourqe specs for oil pan
- CRX Climate Controls stuck in "Upper Vent"...how do I fix?
- Carbed Si?
- Turbo Manifold Question
- Carfax help?
- ZC Hood
- Symptoms for a fuel pumping go bad ...
- Which suspension is closest to stock?
- CRX Si VS Impulse
- What's that site with hybrid honda tech again?
- d16z6 head swap
- So Cal Hybrid Dog Meat
- Updated pictures of CRX
- i have a ?
- Exhaust Piping Transition
- About to change my oil pan gasket...
- Guess my WHP and WIN!!!
- 88/89 VS 90/91 Crx Subtle differences ??
- alternator belt squealing like a pig. that means...
- Civic HX, I have a hesitation around 2500 or 3000 RPM, what is wrong?
- H4 Bulbs...lemme know what you know!
- SpiralMax or Tornado hp/mpg increase???
- 88 integra engine into 90 crx si
- oil pressure ?????maybe a problem
- Oil pressure sensor Loc
- Brake problems
- ATTN Spaceballs, this might interest you
- how do i hookup a itr tb and im to my b16a. where do the vacum lines go and the tps
- strut bar with B16?
- a new front bumper for my 91civic si
- which ignition is better?
- Stuck in the middle of B16 swap
- fiberglass
- What's your HP? N/A and F/I.
- telling what model/type my engine is.
- b16a distributer question
- yes or no? what do you think
- it's official...i kicked ass this weekend.
- Rear trans mount?
- EW4???
- Is 92-95 civic a-arms the same as my 89 hatch?
- Car not even turnning over with battery in back...
- im back on the roads!!!!!
- dfw people....
- Shes Alive!!!
- new intake sound??
- Style vs. Power
- Car Overheating... only at idle
- Mods opinions needed: What next for my B16 '85 CRX Si???
- Will solder work?
- What the heck is a EW2?
- Coil Over Suggestions for a 90 Civic Si
- i need a 91 hb taillight (right)
- 1st Gen CRX--was there a 1500HF made?
- My battery is dead! Help
- Skunk2 im fuel rail probs b16 1st gen please read
- -1 degree camber
- distributor
- anyone done aluminum drums?
- Need pic of Prime wheels style 188.
- 88-89 si rear bumper different from 90-91?
- whats a TW sensor?
- Quick wiring question *PLEASE HELP
- Spark plug firing order for the dumb ..
- Name the Spooms
- Quick Z6 Head ?
- Can anyone get me a vaccum diagram for 90-93 ls motor ??
- B16 head not getting oil!!!!
- Battery Relocation..to the back..
- B20 Injectors/Fuel rail on a 92 LS intake mani?
- Starters
- Will VIS Invader CRX Hood fit over B16a motor?
- Zdyne users lookie here....
- uh 90 tegra seats in my 90 hatchy
- Obd 1 conversion
- Quick cheap mods
- were to get good crx sir frunt clip
- comparing the fast breaks 11" kit to gsr brake upgrade please help.
- Camber Kit for EF/CRX - Which Of These Fit??
- 92-95 front lip on EF
- 1.5L Vtec head on a STD. Block
- OEM 88-91 CRX Si Rear Sway Bar...how to install on an 88 CRX DX
- speedy wheels
- Is LSD good for me?
- OEM Fog light wiring harness
- big prob
- Homemade intake
- Apex wheels
- help crvtec
- will a rear integra seat fit in my 91 si??
- Brake system flush
- Wbat is this problem, distirbutor or another sensor?
- WTB: 88-91 CRX on west coast
- Exhaust for swap
- Thinking about joining the club...
- just a few things to clear up
- glass roof
- opinion
- b17a head on my zc??
- neon rad?
- ZC Parts???
- zc ecu
- does hasport still sell dx to sir wiring harness'
- tailights wiring...HELP ASAP!
- Valve adjustement=loss of preformance?
- Fuel problem (or possibly main relay???)
- some b16 stuff and some crx stuff for sale
- z6 swap is sick
- Battery Relocation ...Yes its been asked....
- Carburetors for a civic?
- 88-91 A/C Compressor
- CRX Rear Bumper on Civic hatch - Will it fit???
- car floor
- short ram intakes
- blitz 3mm headgasket on b16
- PROBLEM!!! Greddy SP Exhaust scraping ground? Any ideas??
- one piece front end??
- Intake
- CRX rear...question
- STD motor VS DX motor ?
- Where to buy front lip??
- will a 91 LS teg clutch cable fit my 89 SI
- Anyone in here from DALLAS OR FORT WORTH?
- check it out what I just bought!!!
- help me now i'm goin to get the part in aobut an hour or 2.......911
- 96 ex starter in 93 dx 15b7?
- Kumho Ecsta Supra 712, 195/50 15's...H-speed rated vs. V-speed rated?
- ZC tranny with LSD - What's it worth.
- B16 ECU. What kind of plugs used?
- Parts
- Avatars
- B16A
- Bottom End Rebuild. I Need opinions/Advice.
- s2000 seats in a 90 crx si?
- Most Beneficial Mods
- can we have a sticky FS post for us EFers that want to sell parts
- ZC overheating problem
- can i put 99-00 civic si rotor caliper for an upgrade?
- parking lights dont work
- Another thieving
- honda-tech go-cart racing &meet
- b17 hb exhaust question
- What mounts for a b16a into an 88 si?
- Mista Bone: need help replacing countershaft bearing...
- jdm cluster woes can i use usdm
- dc metro area, where to rent a cherry picker???
- Clutch cable help..
- D16? / ZC question
- How hard is it to do your own b16a swap??
- d15 and rods pistons in zc??
- crx seats............
- best ignition for my 91 si
- JDM gauge cluster install q's please read if you have installed
- EF7 headlights?
- Need pic: side of ZC head.
- Stock Clutch w/ Zc motor Question!!!
- best street tire....????
- People with LS swaps......
- just converted to obd1, how to check engine codes?
- open headers...
- Should i cut my grill out for intercooler?
- where can i get- need a 88-91 civic/crx charcoal canister asap
- H&R coilovers???
- Pics from CRXPO
- seats who needs them?
- ctr pistons on 1st gen b16..what's the compression?
- Mini-Me: P&P y8 head before installation? What kind of gains?
- can anyone reccomend.........
- What filter for stock SIR air box??
- dx exhaust question need quick answer
- 9 cuts and 8 hours later...
- How come I cant get tire scracth anymore?
- '97 CX supension in an Si?
- VACF for D16Z6
- Anyone from the Northwest (Washington)? Need help...
- michigan people
- Monroe vs KYB GR2
- how much is a good deal for B20B iron big bore sleeves installed in a B18B?
- quick ? for ZC runners!
- Cluster Question
- Feeler gauge design for crx valve adjustment. Yea, I know...pretty exciting topic!
- Broken motor mount effect....tire tread wearing fast....
