View Full Version : Honda CRX / EF Civic (1988 - 1991)
- Mini Me build (d16a6/y8)
- dpfi-mpfi obd1 code 5 car wont start.
- Another cluster swap question with pics
- 91 civic hatch release cable snapped
- couple dumb questions
- Nut size question....
- Pre- J Series....h23a Intermission..
- distributor help
- obd0 civic ecu flashes 17 short times, NO LONG FLASHES WHAT SO EVER!!!
- coolant gauge not working??????wtf
- WASHER bottle RELOCATED
- D15b2/z6 mini me coolant line issue.
- D16y8 in 88 Hatch Problems!!
- Car starts then dies when i move it
- eBay traction bar
- Pulling my engine, got some questions with pics
- will manual rack on crx si work on ef sedan
- canadian cluster in USDM civic?
- water pump help
- 20 splines on tranny..what clutch?
- Planning DIYHarness cleanup
- Will any 14 inch OEM steel wheels fit over 10.2 inch EX rotors?
- Anyone every relocated washer fluid bottle?
- Different issues with my swap.EF/B18a1
- Fuel Sending Unit
- Check engine light on. 1 solid light no blink
- sedan handles on my hatch AND wire tuck
- EP3 vs. z6 crx your opinion
- Gasoline leaking from #1 Exuast port ZC DOHC
- Cars gauges not working or check engine or signals
- b16a best exhaust
- Electronic Rust Protection
- need help fuse blow all the time
- Making harness for d16z6 swap
- fuel to air ratio?
- '90 CRX Si - What's it worth?
- surging idle?
- ***CRX axle question***
- B18a
- Help with manual Rack for ef sedan
- Need Help With B18A1 Tranny case install
- EF Died.
- Tranny Problem??
- Y7 OBD0 Engine Light
- Dash lights and tailights help
- Holy hell this is no good
- help with mirrors
- 88/89 doors on a 90/91 crx
- what happens when you mix ls waterpump and type r belt
- Speedo squeak help
- Engine Issues Left Oil Cap Off
- Harness Swap Help Questions
- t bracket
- tires help
- Questions that have stumped all.
- Water out of the exhaust..
- Water out the exhaust??
- Different 5 speed transmission help!
- HF crx k20 project
- ef sidemarker install
- okay i give up. i need help with my 88 CRX with DA rear brake/trailing arm
- ek short shifter fit ef?
- fan?
- Help with heater isuess?
- 89-CRX SI -90 CRX HF the whole steering coloum
- got a crx? post the pix here!! =)
- 90 Civic EF Headlight Bulb Install Problem
- First Honda, First Post. Hello!
- Car Doesn't Fully Warm Up - I'm stumped!
- 88' CRX (Hatch wont line up)
- Wiper blade installation...having a harder time then it should be.
- what exhaust for a ef????
- Question about Si Cluster.
- Piant for EF
- CEL #2 need help
- jdm fenders on canada model 91 civic hatch?
- Rebuild a Rack and Pinion Steering Rack
- Quaife Short Ratio Steering/Review Needed
- Fuel pump relay rapid click no start
- Know of any quiet exhausts? with.......
- ignition issue...help
- ef blower motor resistor
- b16 vtec solenoid, new gasket not sealing!!
- head gasket removal
- head gasket questions
- CRX vs CRX SiR chassis
- CRX with obd-1 GSR bogs out at gas gauge reading 1 qtr tank left.
- Will code 6 make my car shut off??
- first mod to b18
- crx front bumper/89 wagovan
- Really lame question
- Short to ground lighting CEL: Are there more than 2 ground lugs?
- zc swap with pm3 head problems
- HELP Save A CRX noone been's able to fix..
- where to get local pipes for a exhaust
- WTB: 89 Civic Si OEM Seat
- Havent seen this question yet.....
- testing resistor box
- Gas gauge is broken need help
- trying to put a d15b in a 89 crx si (NEEDS HELP)
- mini me ? a6 block z6 head
- Yet another idling problem thread
- what is this exhaust tip off of?
- 90-91 bumpers on an 88
- Climate Control Question!!? Help!!
- I got a 1988 Honda civic sedan...
- How do I convert SOHC to a V-Tec SOHC?
- Replacing ball joints on a crx [gsr front suspension]
- The [U]BRAKE[/U] light keeps coming on and off.
- 1988 Crx o2 sensor question
- Code 9. Dont understand
- Hood damper options or how-to link?
- problem starting. what could be causing it?
- sedan hussein build thread
- dpfi to mpfi HELP!!!
- 91 crx si misfire after warming up
- Help please!!! Charging issue 88 dx hatch
- help !! ls swap in a ef
- My 90 CRX b16a
- brake pedal soft
- CULD I PUT A EF SEDAN DX FRONT BUMPR?
- Official 4G how to links
- Noise from acceleration
- What parts are interchangble with my d16a6?
- please help fuse amp and ignition problems
- Starter problem help diagnose!!
- Are these an actual JDM CRX Item? NEVER seen these before!
- thinking about AWD
- Adjusting Speedo in a crx si
- What spares would you bring on a long trip?
- Tail/Dash lights not working
- No start (vague to the max)
- 91 hatch running problem
- Whats interchangable d series
- Sedan
- Engine Coolant Sending Unit connector broke
- smokey start
- Loose crossmember?
- Tough delima. 04 f4i or finish crx
- need a b-series harness
- 1991 CRX SI, Black Widow Spyder wide body kit, 1999 B16A.
- Hood Stuck
- 4 speed tranny swap
- whats a fair price for ex/si/da rear brake swap
- Tmfw's Turbo B20 rex project
- ef/eg/dc2 upper control arms interchangable?
- my reverse lights don't work
- Ef side marker help
- Help 91 Civic HB stock d15b1 no injector pulse.
- interior paint
- cable bellhousing on hydro case?
- cap and rotor ?
- EF wiring madness
- Help please with 89 dx sedan 5spd
- need to pass smog with jdm
- DC gauges in 89 Sedan
- Rpms not working
- steering wheel removal
- D16a6 oil pan on d15b7
- traction bar (tow strap & jacking point)
- Lights turn on after ignition !?
- LS turbo CRX won't start
- EF2 with b16a electrical problem.
- Help with my jumper! obd0dpfi to odb1
- Bogging start/won't start
- noise of a fuel pump priming
- Quick question for you 4dr EF owners with power locks
- my new project
- 89 crx engine codes
- Picked up a YS1 w/LSD. Got ??'s
- drove to work, at lunch wont start
- 89 crx si fully stock with 75 shot nitrous has no reverse
- Exhaust Manifold Bolts
- crx seat repair & reconditioning project
- What Front Bumpers Would fit on my 88'ef hatch!!!
- B16a intake manifolds
- keyless door handle ?
- ELD and running rich
- what timing belt do i need for a d15 block with a zc head
- b16a timing intake cam off 4 teeth?
- B18a1 Honda hatch
- 89 crx motor
- d15b7 swap oil light on now booooo..
- Please ID this shift knob
- rear window defroster
- whats so special about the gsr (b18c)
- dpfi to mpfi swap problem
- 6AN to Stock Crx Hard Fuel Line Fitting
- Noob here - ? on rotted rear bumper support on EF hatch
- ARP Stud Kit 208-4301
- Engine websites??
- FOR SALE ?????
- A unique feature to Honda CRX, you prolly never seen this before?
- b series half shafts need help identifying these
- Force Fed Racing Turbo CRX 733 HP Dyno Run
- PLEASE HELP How do I install my innovative B Series Cable to Hydraulic Actuator
- fuel rail
- New Member - Mini Me Questions
- MY 91 SI...CAMBER KIT>>>What kit should I get and how quick can I get it...?
- leaking headgasket?
- this rain is ruining my life !!! help
- EF rear disk prop valve question
- the d16y7 swap save the SOHC
- DOHC ZC axle problem
- No heat!
- frozen fuel door and hatch release cables?
- Need swap help
- What hood do i got?
- Need help finding my relays
- Overheating Troubleshoot Pointers
- Put 4-2-1 in, car won't start.
- new build and i will need help
- DA to EF interchange?
- 91' CIVIC COILOVER HELP
- Heated seats in the CrX
- Help, my Civic needs love
- Water pump OEM or generic?
- Need help pinpointing some issues
- JDM B16A SWAP INTO EF CIVIC SEDAN DX
- b18b1 hard start, hesitation, bogging
- never done a swap. need answers ASAP
- quick question...
- Need help identifying some wiring near battery on '90 Civic Si.
- help with my list.
- Possible electrical issue on '90 Civic Si.
- Are my pistons OK?
- Upper Control arm help
- no fuel out of injectors
- civic si dizzy ????
- Why do my tires go bad so FAst!!!!! =(
- Tranny speedo
- 88-89 tail light
- CRX brake upgrade w/ DA knucles & EK suspension compatibility
- itr header
- Heater Prob!!!HELP!!! (I searched)
- crx ebay clutchs, yay or nay?
- Crx Pedal Swap
- Traction & Power Steering?
- black crx dash
- SURGING IDLE... WTF!
- No floor heat - 91 hatch
- is a gsr harder to swap than a b16
- Will windows from a sedan fit in a hatch?
- d15b7 into 91 ef
- Question about swaping intake manifold
- this 91 DX worth $2200?
- COUPLE QUIK QUESTIONS BEFORE I PUT IN THIS SWAP!
- Project Pretty Bay
- Strut Problem
- HELP 88-91 civic parking light relay?
