View Full Version : Honda CRX / EF Civic (1988 - 1991)
- no spark what can it be
- b16a in dx vacuum routing
- Help!!! Temp sensor jumps too high!
- NEED HELP about CRX SI Engine harness
- 1990 crx dx rails...
- vaccum lines ?
- Car burning distributor HELP????
- Es oval.....DID SEARCH
- Thermal wrap on SS Headesr
- were to get JDM SIR HB rear wing 88-91?
- question about tire size and width!
- problem with B16A in an 89 HF
- CRX DX Belt Squeel Help Needed.
- Where My Chicago Land Crx's At???????????????
- 91 crx for sale
- Propane kit???
- jimfab + moroso oil pan
- auto to man
- Battery Relocation/Wiring Q's
- QUESTION: crx HF w\ sunroof and ac???
- I'm tired!!! need an opinion.
- just clipped a car.. need some advice.
- 00 civic Si cluster install preview (pics)
- WTF is going on???
- Need an opinion on a trade - 91 civic y8
- Anyone cut their stock front bumper?
- clutch question
- where can i get rear discs
- how far does a tank of gas get you?
- what gear is this....
- Front Mount Intake
- another jdm question
- Will a del sol dash board fit in a 2gen crx?
- EF Hatch W/ DOHC ZC replacing tranny and clutch NEED HELP
- parts needed (mostly civic wagon)
- SI HARNEST WITH SINGLE CAM VTEC IN 89 DX HATCH (HOW TO)
- pinout for a pwo
- help my car is still to high
- d16a1 pistons in a y7
- Anyone have a stock radio and A/C heater controls out of a 91 CRX?
- Can you operate heat with just heater / air mix cable?
- Will a 75.5mm head gasket fit a stock bore?
- need help on my 91 si b16 sawp
- Motor mount insert install
- brake lights... and horn fuse.. exhaust
- ls or vtec
- 5-Lug Crx??
- DOHC ZC fuel injectors; same as D16A6, D16A1 or neither?
- ? about the tps
- need 91 crx si motor
- exhaust from a crx?
- Question About My Shift Linkage & Shifter
- The hose connecting the radiator cap to the coolant overflow tank is torn
- STARTING PROBLEM!!!fuel pump??injectors??help!!
- No Oil + Racing = Failure (w/ Pics)
- B16 adjustible cam gears on DOHC ZC? question
- CRX Climate controls
- an-r headers in a ef8??
- More early X-mas gifts check it out....
- projectors....
- pg 7 code list i need it bad and quick
- newer bseries flywheel work with small splined trans?
- Crankshaft Knife Edging
- What ECU to make D16a6 OBD-1?
- selling
- sohc zc head on a6 block.
- What alternator belt does a ZC use?
- What do you think of the lip.
- How to adjust jdm ef8 headlights?
- Need help removing CRX steering wheel
- EF si front lip (custom rear lip)
- s2000 seats in a crx EF
- BIG acceleration problem, please help
- HELP, car kind of stutters when i apply slight gas.
- what could be the problem, DPFI ---> mpfi
- just put in the ZC and i got question's
- jdm frontend
- how do I switch from dual point to multi port injection?
- quick question
- siR int shaft work with hydro?
- CRX B18A Help
- 91 headlights and corner lights on 89? HOw to?
- crx problem
- my theory on h22 powered EFs
- ZC/Dseries Tranny bolt up question.
- *pic request* crx with 2.25" drop on 15" rims
- Pic of rear sway bar on car.
- Cluster Swap Question
- b16 not starting no spark please help!!!
- code 15 on a 89 civic si
- 92-95 shocks...
- Exhaust on the passenger side w/ out...
- Just bought a civic need some help
- Hayame-thinking of getting their cam gears & exhaust
- need some help guys
- a b16a 1st help
- Someone with a B series Crx and a Digi Cam do me a favor ?!!
- Does anyone have newer style guages in a CRX???
- Where is the IAT on the DPFI?
- How much is this CRX worth???
- one blink on PM6 ECU trouble code LED = O2 sensor?
- EE9 movie
- oil pressure in CRX...
- Integra console?
- anyone ever rebuilt their calipers?
- crx question
- ZC temp. gauge install.
- hasport shiftlinkage install
- register box
- Toe adjustment or alignment?? (DIY)
- 88 Susp CRX lower arms
- rough idle
- JDM SOHC NON VTEC ZC camshaft
- Ashtray in armrest JDM???
- I need some true criticism of h22 into ED6
- oil pan ? D16Z6_D16A6
- yellow CRX from the UK, nearly finished. what does everyone reckon so far?
- Wheels?
- Anyone with a roll bar for an EF?
- Boost a D15B
- Help with B20 swap into 1990 Civic Wagon
- EF9 & EF8 front lip the same?
- EW1 engine and D series
- not starting!!!! please HELP!!!!!!
- remove crossmember if i go B?
- CF CRX lips!!?
- 89 crx si axles fit in 91 dx???
- Complete 96-00 civic suspension arms..spindle..ect on a 91 crx si?
- removing intector harness
- :: sohc vtec d16y8 swap into an 89 crx dx questions ::
- Good EF sites?
- Code 21 after Y8 swap
- Detatchable steering wheel for CRX?
- Speedo cable help
- What Year are These Gauge Clusters??
- 345cc prelude injectors into EF?
- 90 crx si
- what swap to choose....cable b16 vs hydro ls (long)
- Need Carfax (crx) Please!
- Code 11 on a PM7
- ebay upper strut tower bar for 89crx?
- To those that have IM'd me
- i'm lookin for a white crx 90,91 passenger side mirror assembly
- Mazda Miata wheels on CRX si
- D series hydro tranny on 91 si?
- Mini me swap... used search
- Differences between Dx and Hf motors
- alteezas for 88-91 hatch
- 90 crx - and i'm sitting on a gsr swap-question?
- brake lights and reverse lights
- 89 Civic Hatchback Problem
- what clutch do i need?
- What head gasket to get...
- Prop valve question?
- will the 92 civic sedan lx master cylinder ????
- need info quik!! help please!
- CRX PARTS I NEED...
- jdm bumper lenses???help needed
- WTB: d Series turbo kit
- 94 and up teg dash in ef?
- stupid b16 swap ?
- speedo cable broke today
- code 9: #1 cylinder position (cyp sensor)
- Lighting problem....
- THERMAL VS. GREDDY EXHAUST
- 91 si back up signals dont work, ***help***
- front tow hook install??
- swapping dashboard
- 91 CRX Axle swap
- code 16: maybe main relay?
- whats the difference between a pm7 and a pg7 ecu?
- my current set up vs my future setup...
- Im fucked..
- does anyone have pics of Rear Strut Bars on CRX?
- OK what else could it be????
- Just got a GSR, WHAT NEXT
- Worth it?
- FREE CRX SHIT IN WASHINGTON STATE
- Door Swap Compatibility *english please* searched
- Buying winter tires for the stock '91 DX wheels
- Good deal/will work/do you have one?
- d15a2 needs more power
- not firing
- window wiper ??
- stroked b16
- Valve Adjustment Specs for B16a1
- Install Power Windows into 1990 Honda CRX si
- Need help on dx harness to b16 (1st gen)
- Drivin' in the snow with aftermarket wheels??
- For those of you who think their sunroof is bad! *Pics*
- EF9 Oem Foglights?
- rear wiper plug????
- b18a turbo in my si
- Ecu pin tool
- just got a new crx have some ?'s
- stock lift on d16z6?
- crx dash in civic Hatch si?
- would like to know the differences in two transmissions?
- '91 civic auto to manual finally done!!
- Pics needed for LS v-tec Turbo Swap?
- I need help with an engine problem?
- Second axle change car still shudders and vibrates!!
- Integra brakes on CRX
- HELP QUICK! B16A3 CHINA MOTOR?!??!?!? PROVE MY FAT FRIEND WRONG!!!
- Radiator / can I use a AT one in my MT CRX?
- Anyone got a pic of a Mugen spoiler?
- Main Relay EF vs. DA
- My crx is takeing awhile to catch the gears
- JDM CRX tail Lights
- need some ideas on exhaust or some sound clips.
- Check out my new beater...
- Need help fast!! gsr cluster install gone wrong.............
- Convertable Civic HB
- 98 b18b swap for 91 si
- 96-00 civic conversion on crx??
- 3 gauge pillar replacement???
- 1991 accord lx turns over slow on cold morn.
- Axle stuck in my inter. Shaft!
- Signs of Bad VTEC solenoid
- electric superchargers??
- Smog Referee ticket.. Sell the car? =[
- 92-95 civic 2 dr coupe
- Help with shipping..anyone here shipped an engine?
- Milky coolant
- alternative honda
- b18a1 head on a b16 block...
- D16z6 build up or turbo?
- b16 crx v. b16 hatch
- help with ride height and wheel size
- eg suspension fits ef???
- ef carbon fiber hoods?
- DOHC Carbed motor - need help finding one
- ef8, ef9, bla blah whats the diff...
- Brake Lights DONT WORK!!! HELP!!
- a6 with y8 HG
- 450cc's with a14b please tell me yes/no!
- Identify After Market B Mount.
- Turbo for D series ?
- pulling code 4 (Crank angle sensor)
- What makes the zc d16 sohc so potent??
- FS: 90-91 crx si tranny 90k
- carfax request
- pcv valve
- Crx modifier
- Run d16z6 off CRX Si ECU
- Questions on building a B18A for my '88 hatch.
- Some gauge Qs
- Anyone rollin in a 4 door ef??? got pix??
- CAI or drop in KN
- blower motor
