View Full Version : Honda CRX / EF Civic (1988 - 1991)
- TPS problem... (Yes I searched)
- 91 with cage. 88 Doors or just the panels?
- yummy yummy goodness just came in :P
- Look what I got for 300 bucks
- Leak in rear of car?
- code 43 is driving me crazy ..... please help!!!!!!!!!
- damn Honda is gettin shady
- 1991 CRX Si Sunroof Woes
- matt j - honda ef hatch model
- tranny mount for ls swap?
- dizzy wiring
- more horse power for civic hatch cx 92
- *DOHC ZC* upper rad. hose?
- fender rolling your 4x4 CRX???
- i need some d15 vtec info
- question's on WW rs body kit install!!
- 92-95 radiator in hatch
- Remove the triangle pcs (I searched)
- b16 fist gen distributor.
- Just bought a 91 DX Hatch, my Swap options are JDM B16A2 or JDM H22.....
- another rex down
- buy my shit i dont want it anymore!!
- what causes bent valves ??
- SIR bumper w/ a USDM bumper support
- 88 ls crx.... with grinds what is it?
- clutch issues. please help
- CRX was stolen and recovered. Pictures of whats left!
- parts f/s
- i need a 89 civic si shell
- 88dx vs 88std weight?
- coilover question??
- jdm itr cams, valve springs
- it ran great 30 min. ago, now no start?
- question for rex owners in snowy climates...
- quick question about tensioner on timing belt
- mph gauge not work. wtf?
- HELP!!!! Car wont start!
- fuel switch? (56k)
- camshafts for dohc zc
- Do ef civic front and rear shocks fit onto da's?
- turbo setups??
- Is this a good deal Let me know
- automatic ECU
- Hesitation Issues when driving when letting go off gas **SWAP**
- brown to zc
- Crx shocks on Integra
- how to tell OBD0 from OBD1/2?
- 1986 crx engine mounts
- question on 87 crx si
- #3 cylinder not firing.. wtf??
- timming belt tensioner problems
- rev hard turbo kits
- Muffler length?
- headgaskets will not seal!!! Is there something I'm not doing??
- Does an air intake make your car much louder?
- You guys seen this new CRX model by Fujimi? (Glasstop ZC)
- stereo wont work?
- B&M sport shifter for CRX = good
- fuel injector order??
- What color white paint for black plastics?
- Anyone know where to get a glass sunroof panel to replace the CRX painted one??
- yay! im finally a member...
- What is the firing order for f22?
- thinking about progress full coilovers...any opinions?
- Question about VSS and Speedometer.
- CRX front wheels pushed back???
- EM Racing cpillar bar?
- need engine
- axle question!
- CF CRX Spoilers. is there such a thing?
- confuse about my exhaust
- OT: Does older CRX model suspension interchange with the ITR suspension?
- CF wing
- How to remove Door Bars?
- Civic will not START what is wrong??
- just had some questions about putting a sohc vtec obd1 into my crx si.
- Turn Signal Stick broke! replace?
- d16y8
- Y-49 CRX Spotted on Moster House- Discovery Channel
- should i trade
- crx si seats?
- oxygen sensor
- Where can I find lights?
- Could use some help her guys?
- Got my complete JDM front end from HMO and a little something special too! (Large pictures)
- Where to find a good deal on a stock SIR hood?
- Lightening up the stock hood/ cutting the bracing... how far can I go and be safe?
- can a dohc zc intake manifold fit on a d16 sohc vtec head
- Can someone help me out I cant logon, was I banned????
- Could I....CF front bumper
- skunk 2 & H&R spring rates
- Pedal covers?
- fuel injection problems???????
- Water getting in the back
- Aebs/pro products IM on b16a
- help me prove my friend wrong!!
- What should I buy for a B-series swap.
- what is the best traction bar setup 4 a 90 hatch
- a transmission page -- please let me know what you think (mistabone??)
- 92-95 ex/si vtec head swap into d15 (91 civic DX)
- performance quiet muffler?
- fyi: itr suspension bolts right up on an EF..... *TEIN* (56k get bagged and toe-tagged, y0!)
- can b20 motors alone push a lot of power?
- can a ls cluster fit in a crx hf
- where's turning signal fuse??
- replacing hatch struts...
- Oldschoolah back to bring some of you something..
- where to get a stock ls motor
- How to post pics?
- itr rear swaybar on 91 si?
- amber bumper lenses? only on the SI model of the crx or no?
- zc turbo help!!!
- SIR HB Rear spoilers.... post pics
- Quick response 00 si rims
- where can i get a jdm crx fron end conversion
- b16 to a d16a6
- b18c1 hood clearance in 90 CRX
- Want non-lowering front springs for your B-swapped ED Civic/CRX?
- WTH, saw an ef9 with jdm side moldings and possibly sideskirts, how is this be possible?
- B16 swapped but won't shift into reverse.
- NEED pics of civic on Eibach Pro-kit
- milling head to increae b16 CR from 10.2 to 11.07
- almost finished!!!!! but need some help.
- fricken ignitors
- upgrading injectors and pump
- Rebuilding a front suspension on a 1991 Honda Civic DX 3dr hatchback
- Need help guys Code 22
- b16 clutch bracket
- to trade or not to trade, my EF for an 89 240sx hatch + $2k, advice please
- Power steering in an SI?
- taking guesses on what my civic can probably do in 1/4 mile
- Camber kit settings (spc balljoint)
- Any 3rd Gen's in here?
- will the headlights from a 4dr fit a hatchback?
- I just bought an 81 Civiv 1300 DX!!!
- Weight Question, help appreciated
- pics of ingal camber install. front and rear
- HELP! ecu codes
- car won`t go into gear
- jdm sir cluster in 90 crx dx?
- Any point in 20psi?
- Lambo doors w/link.
- B16A 91 CRX SI TACH
- rear crx interior
- Wrecked the 89 si...
- Wheel hop issues... x member or bearings...?
- Quarter Panel Question
- Stainless steel braided Fuel Lines
- D15b2 Build Up?????
- i have a 1990 honda civic si hatch, tell me if this is the ECU wiring diagram for my car, anyone?
- zc help?
- hathback std dash in crx?
- ITR? CTR? im new and confused
- b16a complete changeover 1800
- CRX SHOCKS/SPRINGS COILOVERS (which has the best ride???)
- aem cai alternative w/ battery relocated.
- shocks and strut bars
- crx dash for civic hatch
- whats wrong w/ my idle?
- 195/45/14 or 195/55/14 Toyo T1-S...
- nitrous+ daily driver= good or bad
- Installed y8 head on my d16a6 today and Vtec solenoid is making a exhuast leak noise, HELP?
- Dynomax Super Turbo muffler?
- will a DOHC ZC pass smog?
- Plug and Play? SI harness + civic DX
- 4D handles all the way around...driver's door decides when it wants to open
- Ok so I'm doing a mini-me. Can I stay OBD0?
- CRX Squeeks??
- any pic of ITR header in a CR-X
- does anyone make 15x7 these days!!!
- throttle body
- OBD-0 to OBD-1
- Need expert opinion.
- Heater core removall?
- Alarm install
- Does the upper door panel from 91 si crx...
- Place Racing Crossmember & ground clearance issue?
- MPFI SWAP---> FAST IDLE SENSOR??
- Can someone link me please?
- Da Dash In Ef Hb (in process)
- searched for hours, what the hell do i need to do for reliable crvtec...
- WIRE HARNESS
- Offset for Rims for 90 Civic HB
- Fog lights for WW front bumper
- Need amber bumper lenses!!!..
- 84 CRX to B16A swap.....some questions (quite lengthy)
- intermittenet problem, resulting in 5 differnt codes, someone shed some light!!! zc ecu etc
- So how do you roll back the odometer?
- WHAT MUFFLER TO BUY
- 88-91 sedan color question
- :( How to read ECU Codes
- I love all of you
- D16A skunk2 products? Cant find them!!!!
- Have to apply gas to start car when its cold out, any suggestions?
- mpfi swap question???????? please help!!
- Code 14 and 2
- Suspension
- HELP:Racing seat install on a EF '88 HB
- hood question?????????
- Parting out Civic
- quick question, crx STD vs DX engine harness
- 88-89 and 90-91 civic hb different dashes?
- D16z6 head on d15b2 for door panels.
- jdm crx front end on a hatch.
- 91 CRX: When ignition key is turned, nothing happens, no lights, nothing!
- can someone tell me if a 89 integra axles will work on gsr swap?
- Anyone have engine harness diagrams for '89 DX hatch?
- your ultimate street CRX motor setup?
- Si ECU into 90 DX?
- WAGOVAN Question??! Please help!
- bumper
- Gauge CLuster qUESTION.
- strange things
- 88 Crx annoying Idle problem
- THE brake thread..too many missinformed...(long)
- 2 Questions. Hood latch problem.... and wiring moonroof problems with a converted integra dash set
- 99-00 civic SI swap
- Headlights question!!!!
- need info on swap
- Stolen CRX (Bay Area)
- what kind of rims are these???
- Fender moldings
- d16z6 hesitation in low rpm range...whats the prob?
- 00 Accord engine swap in 91 Si. Worth it?
- Car Just Dies and clicking sound under dash?
- looking for guy
- Thinking about getting a 90-91 crx
- can some one help
- Code 6 when put into reverse
- Piston slap, with rough idle. (long)
- jrsc octane decisions
- wtb d16 A1 p29 pistons
- short shifter with hasport shift linkage?
- fusebox
- stuttering help!!??b16 obd 0
- Want To Laugh At Other's Stupidity? HILARIOUS Video
- Where can i get a front lip
- SAFC wiring for d16a1 ecu
- B16A swap (spoon)
- lightening up the rex.
- ha look at this you'll laugh
- tenzo racing seats?
- Speedometer Gear, how do I put it in the tranny?
- Energy Suspension Master bushing kit?
- CRX D16Z6 vtec install HELP
- NO HEAT HELP I'M FREEZZZZZINGGGGGGGG
- carbon fiber hatch for crx?
- 00 Si lip on 91 Si pic request...
- Need help Code 20
- Looking for a front bumper that removes the bumper filler.
