View Full Version : Honda CRX / EF Civic (1988 - 1991)
- doing obd1 conversion, question on dizzy
- code 9 questions.
- will it fit?????
- climate control options
- The new CRX.......CRZ
- jdm amber lights
- ABS removal - wiring
- the pr3 ecu
- lip question
- b16 crx mounts
- Head transplant
- Original Japan Ads EF9 SiR/DA6 XSi (for the JDM fans)
- Looking for help ordering OEM rod bearings
- Jdm Crx Ef8 Tailights 3 pcs.
- tie bar question.
- faulty computer?
- crx no start...help
- back in the game
- So injector question for you all.....
- 1997 integra cd player into 89 si
- -i need to know the diameter for the bushing for the front sway bar
- how much would you pay
- Larger aftermarket Rad change idle?
- mpfi problem HELP
- fuse 14, not blown but not getting power.
- Which oilpan is compatible with the d16y8?
- b16a vacum hose routes
- another axle problem
- Dowel pins on d16a6 block which holes?
- Highly Considering Purchasing a CRX - Few Questions!
- which tranny used
- Where can I get a front camber kit for my crx?
- Would like your opinions on suspensions.
- BLOWN HEAD GASKET
- stock or body kit
- Weather kits
- Emition problems... NJ (catalitic converter?)
- k20 crx build
- brake swap question
- 88 crx si swap question> expert question here!
- Hasport EF, cable to hydro b series mounts
- QUICK AXEL QUESTION
- GSR tranny
- suspension question
- question about hasport mounts?
- climate control??????
- help with after market fuel line fittings.
- bisimoto header question
- ls in hatch
- .hondaautomotiveparts.com
- Will a B18B1 work in a CRX?
- Tach goes erradic when in vtec.
- Rusted Rex Resurrection! With gory images oh no!
- What steering knuckle, hub, and bearing will work for 88rexsi
- crx and civic hub interchangable???
- Where to get a hex-less d series crank pulley tool?
- apexi world sport exhaust 88 crx
- new here
- I need help with my 88 crx si
- My little Project log
- 1990 civic dx hb w/ EF9 conversion
- Some advice Please 91 civic clutch pedal assembly
- Spark, fuel, air, no start.
- New ED6 owner
- Integra pedal assembly on a Civic
- obd0 ECU codes problems
- _-._.-._My EF Build.-._.-._
- Oil Pan Removal
- syncromesh?
- need some help
- Light trouble
- 4 to 5 speed trans swap---89 ef hatch
- hood pins?
- Engine swap question regarding costs.
- I JUST BOUGTH A EF9 DX FORM MY CUSIN WITH A LS SWAP
- running on 3
- obd0 Dizzy on obd1 B series Engine
- Mud Guard question
- Re-Wiring my EF hatch... where to start?
- d16a1 in a ef?
- CRX Sparco or other seats
- DA exhaust on an EF hatch
- Crank Angle Sensor
- wilwood dynalite front brake setup need replacement rotors & pads
- oil psi sender question
- Tech Note - Climate Control EF's
- mph spindle
- 90 CIVIC HB
- 1991 Civic HB ECU fuse and turn signal/reverse fuse problem HELP me please!!!
- My '90 CRX SiR EF8 and rare JDM parts pics
- DA Knuckles vs Si Knuckles / EX Knuckles Big Brakes
- Project rust
- CRX Vss
- 91 R/T4wd Wagovan Da16a (Engine Troubles)
- intake manifold
- radiator question
- crx w/ b18a no start trouble
- need an exhaust resonator to pass cali smog???????
- doe's anybody know how to get integra seats to fit a 91 crx?
- forgot to ask
- Seat belt assembly for Civic same as Crx?
- EF hatchback dash into CRX
- best fuel manage system
- Blown clutch?
- question about my hub
- ~~~ah motoer is smoking a little>HELP~~~
- just cranking
- speedo help
- What's the best set up for a great handling CRX?
- 88 crx i need help
- DOHC ZC camshaft Question!
- A New Myspace page for All HONDA/ACURA lovers!!!
- B20 in my CRX is extremely complicated. Help plz
- Fuel Pump problem
- Overheating Issues
- project car- Is this a good idea?
- Anyone have a pic of jdm round fog lights on?
- hatch vs. rex
- is there a known cause of these distributors failing?
- CRX b16 CEL light/oil pressure sensor/ no oil in engine...WTF???
- are these fake???
- Firewall swap?
- leaking trans oil
- Weird "overheating" problem
- weird..please help crx b16
- Just bought a project crx, clutch is always engaged
- clutch question
- crx SIR spoiler template?
- I need help, power problem..
- V-tec wire to TB
- need help on what kind oil to chose form?
- i've searched everywhere
- crx gas tank
- isolation question
- limp mode
- few random questions
- CRX Returns as the Honda CR-Z
- EF y8 problem
- integra engine swap to 88' CRX
- New owner of a 1988 EF Sedan
- Trash talking tuner kid betting me 100 bucks?
- SIR b16 throws code 7 tps diagnosis??
- Just how bad is this (Wrong ECU)
- water pump slow leak, now ok?
- OBD-0 Dizzy to OBD-1 harness wiring diagram needed. Searched
- b-series in my rex
- EVAC / IVAC troubles obd0 dpfi to obd1.
- EF9 Quetion...
- B20 in my CRX distributor?
- obd1 conversion...???
- Crx engine harness help!
- Where can I get - SiR front turn signals for a 1991 civic VT (SiR)
- Will any b16a clutch and flywheel
- GSR GOIN IN MY EF HATCH.
- I just bought a 1989 Honda CRX
- b18 alternator in a EF
- Foglights?. . .
- Deltaco cluster on 88-89 civic crx
- ECU will not turn on
- cam gear quest
- b18 help, OBD0
- Mini-me swap questions
- 89 and 90 throw out bearing the same?
- New Rex and few ?'s - greddy informeter - oil pan - d15
- sifter rod diameter ?
- 88-91 Civic Blower Motor Help!
- 88 Civic b18b1 Swap help?
- wiring help please?
- DA radiator in EF
- for those with the vafc on your d series
- starter compatability?
- Rhino camber kits..
- Tach stuck
- forged rods ?
- brakes
- CRX DASH AND CLUSTER iN AN EF 4DOOR
- injen cai on zc
- 89 Civic LX with high pulsing idle out of gear.
- help need a thread..
- 89 and 90 si trans case swap?
- neuspeed front swaybar
- Does a B16 bolt onto an HF?
- Interior parts??? help please!!!
- 89 CRX DX with 90 CRX SI rear sway bar help
- Engine rod knock easy to fix or not lol
- 90-91 hatchback doors fit 88-89 hb?
- temp gauge weird reading (0.o)
- painting complete, a question on cleaning replacement cyl. head.
- Pic request: Fastline shifter, in 5th gear
- b20b in a ef civic question
- brake problems
- endlinks
- hood ?
- 1988 EF Sedan
- today is a good day
- race wiring harness
- Seat Pan Swap Problems. EG seats into a EF. Need safety opinions.
- WINDOW TINTS
- rex+winter=?
- b18a1 transmission
- EF Build Thread, all DIY!
- pic request - how does the front bumper mount by the wheel well?
- Burning ECU's, Code 4, Strange dizzy wiring...
- Let the flaming begin!! Had an extra hood and always thought this might look nice.
- integra armrest in crx?
- No turn signals
- Just rebuilt front calipers, bled brakes, do i need to bleed the rear brakes too?
- Which shocks should I buy for CRX?
- b18 in hatch, will only run with foot on the throttle EACV IACV IAC
- First Gen CRX pride
- I need advice on my crx!!!!!
- crx fuel pump not priming checked and did all the normal checks
- AC and a header???
- Car shuts off when warm
- B16 swap in 1990 Civic EX 4DR HELP!!
- Help ym B series wont start
- show pix of clean 4dr ef's
- transmission ID: How-to identify L-3 trannys
- Blown Head Gasket?
- disc brake swap
- doing a obd0-obd1 conversion on my 89 hatch.. help please???
- axle seal?
- What's a reasonable offer for 87 rex?
- E-brake handle
- car won't start, fuel pump works, failed 2 of 3 on the main relay check
- Tps adjustment problem
- Trouble ECU Code 4!!!!!!!!!!
- crap crx looks or speed 1st?
- wire harness
- cable tranny part numbers
- D15b won't start
- shifting without clutch
- Crank Pulley
- Brake Shake! PLEASE HELP ME! Tyson!
- just got an 88 crx!!
- CEL 15.. Problem FINALLY answered
- jdm doors Need help!!
- CRX Raffle for Miltary Charity has failed! refund for purchased tickets???
- i need help asap!! 91 civic si tranny mount??
- 88 CRX confusing the hell outa me
- GSR Swap Issues (TPS)
- quick vafc questions...easy for vafc installers
- i got it for $100
- skunk2 throttle body for dohc zc
- intalling vafc...help
- a/c help 89 ef b16a
- JDM b16a into EF HELP!
- car audio
- Hf or dx
- Throttle Body on D15B1!
