View Full Version : Honda CRX / EF Civic (1988 - 1991)
- my custom pipings
- Converted from Obd0 TO Obd1 problems !
- y8 head on d15b2 block
- Where to find B-series swap mounts
- Bride Seats
- Looking for recomendations....
- 1st gean crx
- coolradiator.com anybody use them?
- DX to OBD1 ?s
- Need Help...can't get something off my '89 crx
- head porting
- Harry's U-Pull-It
- ZC DOHC Performance parts
- removing engine need help
- tach question
- Another BAR'ed CRX has been born.
- Getting Code 9 Need help
- 89 civic dx coupe tranny change
- grinding nosie coming from front end when it hits 4500rmp
- CRX Engine
- What would be cheaper and easier???
- WHATS A GOOD ALL-MOTOR B16A SETUP ON A 90' CRXHF FOR BOUT $3,000.
- Downpipe Question
- mini me: timing woes
- Removing a dent?
- NEED HELP: INFO NEEDED ON A B18B LS MOTOR SWAP INTO CRX. Anyone done this...& have info or a link.
- Aftermarket rear sway for CRX?
- Quick Q about tranny internals????
- Engine for my CRX
- You've got to see this!
- front well to rear wheel
- crx climate control
- crx hf swap
- honda 2.0
- CODE 9 PLEASE HELP ME!
- emissions test
- simple Question
- seats
- Crx Si Starting problem
- Stolen red Hatchback found SOcal
- What can I do in the summer
- What are HX wheels worth?
- 91SI HATCHBACK B16 SWAP PROBLEMS, PLEASE HELP ME!
- $500 Project car
- Adjust timing after upgrades?
- 91 Civic LX Strange Cold Idle
- where can i find an aftermarket throttle body for crx?
- Clean rotors...
- CRX weights
- anyone install a itr steering wheel, non srs, in there ef8/ef9??????
- b16 problem (sputtering on deceleration)
- fs on hmt- my things, tach, interior, turbo things, ext... check it out- please dont delete
- Drove around all day perfectly fine. Now it won't start...HELP!
- Oil Pressure Switch wire colors?
- B18(?) Hood...!?!?
- NEW TO THE SITE! hello everyone.....
- SPOON SPORTS STRUT BRACE
- P28 to run my B18C5 in my CRX ?
- fast and furious isn't fake
- anybody running a hydraulic D-series trans in their crx/ef civic?
- i need parts
- burning oil
- Are crx and hatch exhaust systems same/close?
- I need power on a buget-90 si rex
- Brake pedal drops to the floor, dunning out of ideas
- will a b18 engine fit a 91 civic hatch
- problems
- DPFI tranny cable question
- ***Official EF Quarter mile Times***
- motor blows smoke after 5200rpm
- Aftermarket Upper Control Arms
- am i wasting my time with mini me?
- 92-95 civic HB or del sol exhaust on CRX?
- crx with an s2000 cluster
- zex or crower?
- Pic request of D16A6 manifold
- Do I need a new bottom end??? Please read!!!!!!!
- tranny questions
- Question on running wires..
- pic request: bronze painted ls wheels
- What parts to buy to build A FAST DAILY DRIVER B16A1
- ok... i know its here but where!!!!?
- H22a into my crx...need tips
- zc motor valve cover gasket question
- cooling/heating
- why is my car sputtering ???
- Another Idle Question
- Engine Code trouble!
- Radius Rod Replacement
- Stock timing on B16?
- New Project car
- HKS sport exh. replacement muffler options
- Please Confirm my Shopping List...
- Will the 92-95 Civic front seats fit 89 Civic?
- where to buy jdm city lights for crx?
- b-series Dc 421 Header owners ???
- ummm... duhhh...
- rimstrader.com
- Dash lights out, tested everything, need some suggestions
- where to find a sir crx front end in northern cal, SF, Sac, San Jose, Oakland?
- i'm always confused between these 2 headlights.....
- EXHAUST!!!!!!!!!!!!!!!
- b16a spoon engine?
- CRX newbie here.
- Accidentally grounded out my ECU now I'm throwing a code 21
- Starter question
- Voting. Turbo/All-motor.
- ZC swap problems.
- WHAT should I do???????????????????
- OBX LSD in a ZC Tranny
- Question about spindles
- Hondata stage 4?
- Need help on color!!! (Rota Slips)
- Axle question for CRX HF's
- crx heat
- si dx hf
- Hesitating ZC
- CRX HELP! Interior Lights going Crazy!
- BRAKE FAILURE
- arp head stud help
- I need LS
- CRX Bezels
- dpfi-mpfi complete just a lil problem please help
- Maaco???
- raced a sweet 90 ef hatch anyone on honda tech? (2.2xdreams)
- a little roll out
- piston to valve clearance
- Rev too high on my baby
- b16 to gsr
- h22 crx questions
- Hi folks, I am back!!!! with questions....
- cold air intake
- y8 motor with which ecu to keep obd0
- why am i burning oil??...HELP
- Thanks
- b18a troble starting
- h22 w/ b16 tranny or turbo b16
- integra axles 4 crx?
- setting up d16a6 turbo on my crx
- i need a diagram
- B16 question
- swap
- wheel question
- What temp do you consider "overheating"
- Problem Please help.
- Input...
- JDM Taillights
- Heres a "Ingition Switch Replacement" How to (88-91)
- Drive Shaft seal?
- EDM importers? I want glass h4 euro headlights.
- Quick question about mods to motor...
- Auto to manual swap questions
- part searching advice
- stereo doesnt turn on.
- H&R Springs for an 88 CRX
- HB shell?
- What is my car worth???? Any input would be great....
- NO POWER CAR SHUT OFF searched need help rex on the side of the freeway
- jdn crx sir motor swap for sale/ partingout 90 ls integra
- DIY : Bore A6 Intake Mani... Best Way?
- ne one know where i could get dpfi to mpfi swap? ne one have one laying around?
- b16 or ls
- Bumper lights on in pics
- How many splines?
- ***The long wait is finally over--JDM parts arrived***
- How I eliminated wheel hop - front engine mount mod - CHEAP
- still rockin stock exhaust
- bumper lights
- Parting Out My 96 EK......
- PCV valve?
- I need CRX Bumper/ trade
- what could i do to my crx dx w/mpfi swap
- EF Si ?question?
- which clutch to use now ?
- a few q's about custom exhaust set ups (not the usual q thread)
- Carfax for a crx please
- Need help with correct downpipe 91 civic hatch B16
- where can i buy a 2" gauge that can tell me how much oil i have in the car
- help! d16z6 in an ef runnin obd1/hondata ecu.. cant go past 4 k!!
- should i use my skunk2 p28?? or not??
- which camber kit?
- stock 88 pgm-fi 1.5.. idle loping
- lets see some WHALE TAILS on some CRX's!!
- uber clean hatch in AU $1350 buy it now EF9 front check it out
- ignition switch, electric rad fan, wiper switch - which will fit in 91 civic cx?
- sohc power!
- ABS on our 4th gens
- steering wheel sqeek
- want to trade for 88-91 crx si or 92-95 civic hatch
- whats with kill stories
- Hiss from brake booster
- whos got flaowmaster
- if my thermostat is not open will my heatercore wont heat up ?
- Need info on this engine - 1st gen CRX
- DA door panels on crx?
- Mugen VS Mugen Flared Kit
- OBX Lsd, who is using them?
- car just went into safe mode...
- Valve cover question
- Track time today
- new intake bypass fitv?
- Parts for my car
- Whats the going price for EX civic knuckles?
- D15b water pump
- cleaners
- could this be the problem?
- What should i do?
- D16Y8, which mounts?
- Strong Civic Engine
- help me fix my idle! d16y8 swap
- did i do this right
- A few P28 OBDI chipping questions
- b16a1 secondary o2 elimination
- GSR or Ls-Vtec??
- 91 Civic Dx ( b16 with LSD )
- Distributor Question!
- 89 CRX HF--project tuner (FOR TRADE FOR A '92+ civic hatchback) South Dakota
- options for DOHC ZC flywheels.....
- Horrible B16 Gas Milage
- 87 CRX steering wheel
- 4 dr 91 4dr -b16a
- JDM D15b vtec Vs Mini Me D15A?
- How are CRX's stolden ? HELP PREVENT THEFT !
- 1988 CRX Si trivia
- A/F Guage or Apexi VAFC2 (for n/a)
- wont start, help
- sorry wrong forum but need help b16a1 turbo help
- What spark plug wires for this set up?
- Oddometer and trip are off
- sohc zc help please
- Radio and interior lights dont work?
- Put tokico hp's back on?
- history of the crx
- Seat belt light/chime
- new brake booster or bleed the lines?
- Power windows / Power locks
- Bigger brakes on EF/ED...worth it?
- oil pan question.
- check out my CRX Street Drag car pictures from Pomona, CA
- DPFI to MPFI engine harness
- My New CRX
- new to honda-tech tell me if i did good
- More stupid problems.. Reguarding Lug Studs..
- zc runs but really rich
- need to wire vtec
- 12A Bridgeport Rotary EF civic... wtf...
- bumper lights
- How much Are SI rear seats worth?
- WTB: Alumn Flywheel
- loss of power/sputtering???
