help!!! trying to know the probem why its shutting off
Old Aug 14, 2015 | 06:16 PM
romar miranda's Avatar
Icon4 help!!! trying to know the probem why its shutting off
Please help. I have a honda civic ef sedan. The engine is D13B. The problem is when I'm in the road while I'm driving it and I turn on the a/c then when I suddenly press the clutch pedal and I remove my feet on gas pedal. Then the engine will shut off. Please help me to fix my problem. I don't know what to do. Thank you.
Old Aug 15, 2015 | 12:53 PM
tamboo's Avatar
10 Year Member
Default Re: help!!! trying to know the probem why its shutting off
could be a bad coil.
Starting Problems
Old Aug 15, 2015 | 06:46 PM
Starting Problems
But its happen when the a/c compressor was repaired by the a/c mechanics.
Old Aug 16, 2015 | 12:06 PM
tamboo's Avatar
10 Year Member
coil is in distributor not a/c system.
Advanced Ignition Troubleshooting - Team Integra Forums - Team Integra
Old Aug 16, 2015 | 04:52 PM
Ahh, okay. I'll check it. But additional problem. When I press the clutch pedal. Their is too much vibration. If the a/c is on.
Old Aug 17, 2015 | 03:23 PM
tamboo's Avatar
10 Year Member
if you have poor spark the engine will balk at the increased load with a/c on.
you will need a new coil at some point, just buy the standard motor brand for
$15 or so. just put one in mine, now a/c is back to normal.
Old Aug 17, 2015 | 08:48 PM
Okay sir, I will do it. Thanks for the knowlegde that you shared.
romar miranda
Aug 14, 2015 04:34 PM
Screamer
Aug 8, 2001 09:57 AM
Screamer
Aug 7, 2001 02:24 PM
