View Full Version : Honda CRX / EF Civic (1988 - 1991)
- what dizzy's can i use with b18a1 motor ?
- i came across this hatchback..yay or nay?
- anyone have pics of neon radiator on a crx?
- Improving throttle response
- Wiring my brothers civic with a water temp guage.. got some questionsss
- tranny question?
- Best series tire for 15" slipstreams
- 90 LS distributor same as 88-91 DX ?
- Keep the N/A B16a, or Sell it and built Turbo Mini-Me?
- Have a broken LS tranny? Have B series bolts/parts? LETS TALK!
- fs: 99 civic si rims w/tires (mint) $450. midwest
- Sparco fuel lid wanted
- brakes problem
- 89 CRX doors?
- Ghetto intake??
- SOHC VTEC into 90 HF
- Nitrous
- speedometer cable broke?
- need 1gen CRX help
- o2 dc question
- antone selling a dx motor??
- 95 gsr fuel pump work in 89 crx hf?
- Header Question
- hey
- street imports vs. hondamotorsonline
- possible b18c1 swap for 2k!
- 90-2000 integra shift linkage
- have a problem
- 1st gen si motor
- 2 gen crx seat...
- Junkyard CRX (2 Gen)
- radiator question..........
- CRX Item for sale...
- how rare is ???(3rd gen question)
- stereo installation
- I need a passenger seat by tonight,anyone in los angles help me out??!!
- Hasport Mount kit help ?
- Broken TPS???
- brakes are squishy, help please
- crxaddikt
- Do I need a flex pipe for exhaust?
- Confused about vtec
- 1990 Civic DX hatch question..
- What kinda motor????????
- another b16a question for my rex
- type r control arms/jdm control arms/ 88 crx control arms, I NEED SOME!!!!
- Where can I get some jdm tailights today??? in los angeles???
- BC CRX/EF Meet 2002, Vancouver, BC
- AG-Engineering Traction bars are DONE!!! PICS INSIDE!!!!!!!!!!!!!!!!!
- why is my gas pedal sticking?
- Whats up with this civic
- wtf? my cai is exposed :(
- Cross-drilled and slotted rotors???
- guage cluster & dash bulb change
- I got extra resistor boxs
- main relay...
- got the rollcage in and it helps stiffen everything up so much! i love it!
- ATTN:daniel89civ
- Help out with the swap!!!
- has anybody tried this brand of coilovers?
- Anyone know when/where in San Jose,Ca the track is?
- Anyone have any tricks gettin a trenny back on ??
- will a d16y8 head be able to fit on a d15??
- 90-91 CRX bumper/signal lights
- Raising Compression
- Mugen Twin Loop Soundbite anyone?
- timing?
- upper controller arm resting on top of wheel well???????????????????????????
- Whats causing my car to bog...
- ls swap
- Tire question. Anyone riding on Falken Azenis?
- Ability of two bored guys doing an engine swap.
- what can you guys warn me about doping in this b18c1?
- Reasonable price to pay for swap into a EF civic
- one piece coilovers
- Cleaning injectors on B16a CRX???
- Anybody in DFW wanna help me install a new axle?
- Got my brakes fixed.
- No. 1 cylinder Postion Sensor...
- hks exhaust
- ef8 front end problems....need your help
- Fuel pump location
- Stupid ass Hasport Mounts!! Help NOW!
- Question for you guys with adjustable spring kits, how low is your car and how does it ride?
- When does VTEC kick in for PWO/PR3?
- jdm ef8 or ef9 bumper lens part numbers?
- wings west
- Titanium
- 92 LS intake manifold on B20?
- Where can I aquire a LS/Vtec Swap
- Steering linkage broke
- Need help with my swap.....
- the majority of you guys..
- jg edlebrock intake man. in 4thgen hybrid
- Build the vtec or save for a B16?
- Suspension gurus! Got a question for ya!
- Tokico coilovers...
- Questions about ECU for ZC
- i heard...
- zc interchangeable parts?
- hf head on a si block
- is there still any kind of D/FW meet? at the races 9/10 of AUG?
- h22 into ef hatchback....
- strering problem?
- d15b2 & d16z6 timing belt and water pump interchangable?
- Is there such thing as a ZC-G?
- What tranny do I have!!!
- I need help installing my Y8 Intake manifold, help plz?
- guages fo the rex
- What to do about rust on fly wheel ?
- Anyone install a ST Rear Anti-Sway Bar?
- n8.75
- Brake lines suck!
- Gauges Install
- Post pics of your Stripped civic
- Clear this up:94+ Axles in B-series EF swap?
- mb
- what is need to use integra brake in a crx?
- Will 94-00 Integra Type R shocks fit on my 91 EF,if so...
- where can i find back seats for my CRX?
- 1st gen ZC compared to 2nd gen ZC
- Code 1 we've got a problem
- Help me get this axle nut offf!!
- sunroof
- synthetic or non synthetic oil?
- Brake problem?
- no spark...help?
- Can anyone run this Vin# for me?
- tranny question
- question for the turbo zc guys.....
- hmm tricky
- web sites for clutches
- My car is dieing!!!???
- Need some help guys, will a d16b7 intake manifold and distributor fit on a d15b2?
- shiping cost for zc
- Car Died again
- anyone put crx climate controls into a civic?
- where can I get..
- What spring/shock combo on your CRX and ride quality
- civic almost broken into...
- please help me w/ my tach!!!!!
- WTB: D16 turbo manifold with 14B flange
- b16 clutch w ls tranny?? will it work.
- Did I just get the wrong springs?
- zc gears in si tranny?
- Finally passed my smog test
- Anyone have 87 CRX Si wiring diagrams?
- Anyone have 87
- zc engine
- Will 91 CRX si gauge cluster work in 88 CRX dx?
- CRX JDM rear seat
- CRX interior swap
- CRXPO... last call
- CRX rear upper stut bar, who likes what
- Cutting Shifter?
- guys im seriously hurtin
- Goign from b16a to b18a help!
- How to polish intake mani/TB/fuel rail?
- Looking for Hasport Products in Sacramento, CA
- Integra crank bearing help.. for b18 ls vtech
- help
- Should i go LS?? B16A?? or LS/VTEC????
- Civic Body kit on 1G CRX
- ! Need help ASAP with brake caliper rebuild
- OK VERY weird problem
- any break front LCA ball joints??
- rattles when pedal is slammed, and...
- Increasing Compression in D16A6
- whats the spaces for in my ef?
- got a question about removing carpet
- inside of your rides!!!!!
- Boost Question?
- Will a 92-95 Civic Radiator work in a 88-91 crx?
- could the O2 be my problem??!
- anyone interested in ex knuckles?for the bigger rotors up front?
- Anyone install springs or struts before?
- How hard is it to replace a break line?
- difference in cams?
- What are these going to cost me (Hybrid 4g HB/2g CRX)
- auto b16?
- b16 idle question
- nx nitrous on my zc??
- What should I ask for my B16a CRX + Mods?
- Weight of a hatch w/ glass and wing anyone ?
- 88-91 Civic SiR front end fit on CRX?
- quick way to clean air filter
- damn, friggin' alternator!
- quick question about rebuilding head
- Mugen SOHC
- b16 intermediate shaft....?
- Axles for B16a in 90 CRX
- aftermarket rotors for the hf...
- whats the ecu in
- anyone here running CTR cams in their b16?
- Need HELP...Throtle body coolent line needs to be bypassed ...
- Y-49 Curse??
- b16a Hesistation problem found for my car!!!!
- Standard, DX, Si?
- how much is this worth?
- Best Shocks for 91 crx?
- 88 or 89??
- What Dist. and cam sensor will fit on 2nd gen ZC?
- fuel pump bad??
- LSD for D series
- OOOPS!!! Need Some Help....
- Picked up my new drag wheels today....
- any1 runnin b18 nonvtec allmotor?
- 89 si tranny vs. 91 si tranny - which one's stronger?
- ls into 96 ex coupe come on people!!
- dyno a mini me? (tried search)
- Rotting rocker panels: what to do?
- tranny: weird diff bearing problem
- any one useing the 99si/ ITR AEM cai on their EF?
- Using the JDM B16B crank pulley
- Help Don't Know What to Do??
- torque for shift arm retaining bolts? (inside the tranny)
- Anyone here from Minnesota?
- Will vx wheels.....
- who is running zc tranny?
- anti sway/roll bars
- question on a head swap??
- Main relay or distributor?
- i want hp gains but i dont have much money w/ my ef civic si
- Need help installing Del Slow seats in my EF. Ill pay $.
- B18c in crx hf ( how to )
- some body need a crx ?
- Where can I get professional lexan windows for a 89 hatchback?(fal have em)
- Which would you choose? 91 CRX Si w/B16 or stock 92 Si hatch??
- HELP!!!!!!
- what motor do you have in your 88-91 civic/crx
- D16Z6 Question?
- where to find wiring diagram for power folding mirrors
- ground control coilovers help!
- obd1 ef, and sir swap headaches..
- My newest problem...
- front end question
- Read and help me please
- Z6 is finally running..... + 2 questions, lol
- Is there a big Difference
- b16 starting problems
- vafc wiring/tuning
- care about goin fast then the brand name.........
- help!!!!!!!! i need a/c
- B16 THERMOSTAT?? where is it ?? what usdm parts do i replace them with?? from what motor??
- torbo project car need help
- Good price for a 89 Civic Si?
- will sparco EVO's fit in a crx?
- where can I get....??
- thermal catback owners read
- cheap engine parts
