View Full Version : Honda CRX / EF Civic (1988 - 1991)
- B16 swap injector wiring ?
- D15B2 With Y8 head mini me question...
- d- series?
- Speed Calculations...
- Cold Air intake and gas mileage
- the stock temperature gauge on all vehicles- what is it for?
- TSX dash
- Real notice in suspension
- IM
- jdm transmission
- b16n/a queston
- Need new carpet......Whats best?
- how many hp gained on my b16 w/these upgrades??
- Looking for CRX buying advise, what is the benifit of buying si over lower models
- Camber kit for 89 Honda CRX Si
- Beware of this eBay scam!!!
- b16 swap into ef, what throttle cable?
- Car For Sale
- Brakes: How big is too big?
- zc missfire
- Car just click click and won't start
- Yellow and White wire ?
- auto to manual. Can it be done????
- O2 Sensor??? Controls?
- Tranny Sensor???
- will g2 integra intake fit crx?
- looking for a nice/clean rear spoiler for an EF hatch....
- i'm workin on a ef website
- b-series questons
- JDM Front End help.
- DOES anyone use wedge brackets? in there civic or crx got a question
- got a question...
- my first BIG swap b16 a1 cable
- mounts help on crx
- HEADERS ON B16 2ND O2?
- Help!!
- tell me about the stock 1987 crx SI
- Picking up my CRX monday.
- Exhaust questions?
- most recent pic
- What do you think of an LS Vtec?
- Clutch\Flywheel combo
- need help with hooking up the obd1
- Converting to Integra Brakes? Fit 13in wheels?
- crx h22 queston
- Sedan prep
- my friends 88 crx is throwing ecu codes 7 and 16
- the most important guages on an NA motor
- Hybrid Radiator options
- Gonna paint the Rex
- PG7 or PM6 for MPFI Swap?
- how to check cel's
- 89 Crx hf with ls forsale
- Removing brake booster??
- Trying to diagnose the problem
- Type R intake manifold
- Need help asap. Need a CRX shop manual for 1990 not 91. 90!!!! HELP
- okay fellas help me out on a jdm front ....... finally can buy one ...
- Removing power steering- worth the extra hp or more hassle?
- websites for pacman crx k20 videos...
- Purge cut off and dashpot
- CRX HF Transmission into Civic Sedan
- car shipping
- SI wheels on a CRX
- how to check engine light code???
- crazy integra/rims/accord stuff for trade or sell (must see) looking 4 serious buers or deals
- Reman or New Crank
- rear trailing arm bushing, where can i get it cheaper?
- Radiator in Back By Trunk
- my catback is making a real loud noise
- Opinion on APC adjustables for 91 Hatch?
- D-series: What size/thread pitch are the oil pan studs?
- Fun Fun Fun.. Building my CRX...
- Adjusting Timing
- cv boot torn...what kind of labor involved?
- car not starting
- clutch question for s1 tranny...
- wuts the difference?
- unexpected turbo gift
- how to search for a zc motors
- crx radiator question
- So you lowered your ride, what about the roll centre?
- Suspension settings- which is more important, adjusting the front or rear
- Should I buy this CRX?
- buzzing reley
- Dsm Injector CLIP wiring
- CRX Different Model Transmissions??
- How can i tell what tranny i have ?
- B-series clutch replacement - Easier with the engine in or out of the car?
- Major problems with the crx.
- 91 SI hatch Problems
- will my headers fit?
- help installing/setting up apexi auto timer
- Competition Engineering Drag Shock
- What to look for when buying a crx?
- cluster help
- Should I buy a HEMI for my CRX?
- Serious Smog problems!!! Need Help
- RMF in my EF, cooling fan ideas.
- First swap difficulty
- horsepower dyno gains with cam gear anyone?
- Hiding Nitrous Poll
- bumper trade...
- Greddy turbo timer not working correctly on my 88 HF?
- how to wire a ciol blaster2 to the stock D16A6 dizzy
- 88 crx si problems!
- auto b16 tranny
- Ways to clean fuel tank???
- d16a6 bearing question
- BRAKE's related problems...Sticking pads...
- zc problem! help ASAP
- body help
- good news for omni-power owners
- need help with lcon traction bars. loud clunk when braking and accelerating.
- B16A bogging
- 1/4 mile time?
- obd1 dist plug conversion
- Exhaust manifold
- Torque Specs (D16A8)
- Is my timing off?
- Code 20, starter won't engage, and whats a ecu test harness?
- ? Rust on slevees ?
- help on b16a intake manifold
- brake question
- GS-R swap into a '88 4-door
- my car stalled today!!!!
- Help!!!!!! with timing on a b18a1 asap
- CRX MEET this Sunday
- results from the traction bar/crossmembers
- No heat from the heater
- Whats the most power your running on the street reliably
- jdm d15b swap
- Will 89-91 crx rear 1/4 panel fit onto 88 crx?
- 91 Hatch
- help need new clutch and tranny is hard to put in first second and grinds reverse
- Ground control, skunk 2- coilover with tokico illuminas?? which one better setup
- Front fender
- Is there a sunroof relay in a Dx?
- crx swap
- Starting Trouble. Please HELP!!!
- Overheating issue! PLEASE HELP!!!!!!!!!!!!!!!
- Custom Exhaust help?
- 89 civic not turning over
- springs and shocks fitment
- does anyone have a b18a turbo setup on their ef? i got a few questions
- ZC 5 speed Axles in a 91 DX Hatch?
- What is the best engine swap for an 88 Civic?
- question on d15b2?
- 87 CRX Not Starting HELP!!!
- Which Seats will fit an 89 CRX Seat pan?
- 4-speed in a DX?
- Manual Steering Rack diffrences? Si, DX, HF?
- obd 1 intake question please!!!!!
- 90 ef b16a b18c5 block install help!!!!!!!!!!!????????????!!!!!!!!
- Installing 2000 Civic Si seats in Crx
- Newer AC from 96 Civic fit in CRX?
- Stop topcoat chipping?
- Difference in CRX rails
- Creating a B16A Axle For a CRX
- very high engine idle
- Removing lost motion assembly OBD-0 B16
- need help, d16y8 vacuum diagram
- engine??
- " COME AND GIVE ME YOUR OPION..... "
- OBD1 wiring, get rid of subharness?
- 14x9" wheel on a Crx ?
- zc tranny question
- clutch question, guys help me out
- clutch job on 89 civic sedan lx
- Starting a Crx or civic EF without pressing clutch ?
- Is there a ignition relay
- OBD0 -> ODB1 conversion questions
- how much nitrous can a D16Y8 breathe
- JDM B16 WIRING PROBLEM
- what makes the car stop priming?
- anyone tried using a civic hatch rear bumper support on a CRX?
- gsr swap
- Guys i need some help
- code 4 Crank Angle Sensor (already researched)....
- throwing code 14
- How to get better 60 foot times?
- Shift linkage pin??
- Automatic 1990 civic 4 door problem with shifter in park.
- Replacement Urethane for my mounts
- need help with a rear brake disc conversion asap!!!!
- dsm injectors
- brake recomendation
- ? lowering civic 1986 si with torsion bar????
- crx for sale...
- Name that Body kit!
- Need help with a VTEC harness (mini me)
- obd1 conversion - resistor box w/'94 injectors?
- Installing DSM 440's On OBD 0 B16
- help! car has no power
- Do i need a new main relay??????
- My 89 EF HB
- 15/16 master cylinder?
- adjusting F.camber with ball joint slider
- Repairing broken door pin?
- question about zc swap
- Sohc zc axle problems HELP!!!
- wheel bearings
- where is the clutch switch?
- Rear 1/4 window busted out...
- radius rods a camber?
- Rear fenderwell rubbing with 205's?
- skunk 2 exhaust
- Swap questions....
- rear hub?
- intake install ls crx ?
- No one understands my love for my Car
- Tire Pressure 205/40/17
- my civics track times on new setup
- How to tell if this is an obd1 delsol b16a dohc intake manifold?
- Question about dx and si tranny???!! help
- Starting Problems
- How to Instal OIL PRESSURE SENDING UNIT?????
- Tips when dropping b-series in
- zc cam in a d16a6?
- Has anyone tried this conversion?
- Long time, no type... (Project updates, 56k, enter at your own risk)
- My BUILD PAGE! (since very1 has 1) a whole shitload of pics! 56k take a shit n beat ur meat!
- Car sometimes wont start...
- What is this part? Just got my mini-me running and this is leaking!!!
- JASMA, what does it really mean?
- NEED HELP B18c crx
- axel question
- My EF summer project.
- gsr swap into crx few ?
- need help on getting a new cluster.help!
- Car died on the road Help!
- axle pulling out from boot problem
- ef8 ef9 yellow fog lights, new
- ZC SOHC vs ZC DOHC
- Engine trouble... Help me! Possibly fuel pump?
- need 1st gen pre obd distributor
- how to take off rear quater windows for ef
- engine question.
- When do i change a timing belt?
- b16a ecu code 14
- How much does the Wings West body kit typically cost?
- EXHAUST!!!
- exhaust questions
- thermal catback on hatch
- crx camber
- Thermostat housing help
- do i need to change the fuel pump in my b16a1 crx dx?
- help with tranny fliud!
- help amplifier install
- for sale
