View Full Version : Honda CRX / EF Civic (1988 - 1991)
- How do I tell which model CRX I've got?
- Temp gauge..
- yes another jdm cluster question
- 1991 Civic - Smokey Exhaust & Fume Smell
- crx b16a swap into hf.no place for vtec subharness to plug in
- 1990 honda civic dx electrical relays
- DOHC ZC: Temp Sensor Question.
- DA REAR Seats in EF Sedan? (SEARCHED!!)
- different transmissions
- seat rails.
- DX to Si Interior conversion question - Footrest
- Crx b20 swap
- OBD 0 B16A swap into 91 CRX DOHC MPFI
- EF Sedan Sideskirts and Lips
- connecting the hub to the lower ball joint arm 1990 civic (HELP)
- obd0 to obd1 shopping list
- Boost and a Block
- whats the best turbo kit for a jdm b16 with stock internals?
- Can this be fixed?
- JDM CRX cluster for sale or trade
- ls Swap
- itb's on a crx
- crx b16a swap vacuum lines.disk brakes
- Not running right
- main harness pinouts?
- 91 Hatchback SI (HELP WITH SWAP A B SERIES)
- axle seal question
- D16a6 compression test #'s
- mini-me done, runs, idles, no CEL, but smoke/steam?
- Another Cold idle wows
- EF B20z Swap... Help!!
- Need help choosing some wheels for my ef9 si.
- ef seden help
- corner light signals not working!
- windows
- Crazy Tach.
- Five Lug
- Oil Dipstick Problems??
- TPS Voltages Backwards???
- avid pro series traction bar i bent it wdf
- running ruffffff
- saturn clutch on a civic
- steering wheels
- D16a6 engine harness used for D16z6?
- 90 ef sedan shock feels like its going to fall off!
- Transmission oil seal?
- what is the best name brand thermostat?
- School me on this..
- CRX HF transmission/clutch questions SEARCHED
- Can someone post a pic of either a Crx or Hatchback with a Sunfoor visor(deflector)
- skunk 2 sport shocks with skunk 2 adjustable coilovers????
- D15B2 head on a D16Z6 block..... What head gasket to use?
- VTEC NOT KICKIN IN!!! PLEASE HELP
- civic seats ef
- *catback exhaust for ed*
- Decisions on Suspension........hmmmm
- Y8 manifold and throttle cable bracket.
- axle wont go back in .. please help
- ef hatch wont start or turnover plz help
- what distributor to use for a dohc zc motor?
- Something is wrong with my Turn Signals.
- Isn't the castle nut supposed to thread farther?
- will stock speedo adapter fit a gsr cable trans?
- B16a with ITR intake manifold
- High Idle and Running Rich. (searched)
- Wheel Sizes for CRX
- November 22nd Civic MEET!!!!
- WTFFF fuel problem
- CRX Fuel Injector Questions?
- Vapor line routing (in-cabin)
- Secondary Radiator Fan Doesnt work!!!
- Weird starting issue....
- cluster problem!
- gsr cable trans speed cable?
- *HELP PLEASE* tell me whats wrong!
- CRX suspension from?
- lips that fit and look good on a 91 civic
- 88 CRX HF hub question
- CRX is not GOD's chariot
- Has anyone used REVO front camber adjustment arms?
- what clutch can i use? 89 wagon RT4wd
- Need Help With CRX Front Brakes HF and SI..
- 1991 CRX SI Speed Related Idle Problem.
- Should i trade?
- can 91 civic 4 doors can have a rear lip?
- compatable d-series alternators
- 90 CRX B-series engine swap info??
- Climate control still available from the dealer?
- Honda Crx sunroof visor ????
- tach jumps around in the upper rpm's. Why?????
- Tahitian Green!!!
- Filling in Sidemoldings
- crx civic body harness interchangable?
- civic and crx fuel tank.. HELP
- Code 19 on 88 Civic DX AT sedan???
- Installation (VSS Cable) JDM Gauge Cluster SiR
- leak and need help fast guy!!!!!
- just did DPFI To MPFI now code 7
- Motor Mount question
- what problems should im be looking for when buying a crx
- d15 head on d15b1 block?
- What happens if I run my D15Z1 without the EGR control box?
- Help me out Pleease! (b16 ef)
- motor swap mpfi question yea i know search i have
- Driveshaft questions
- What kind of mudflaps are these??? CRX?
- difference usdm & jdm front ef hatch
- obd0-obd1 engine harness?
- I have a CRV-X>>
- where to buy d16a6 engine?
- Should i trade my 93 dx coupe for a 88 CRX SI
- Questions about battery relocation
- Running light wont turn off! Ive searched...
- K series swap help.
- Injector o-ring question
- b16 oil rings
- WTB: 90-91 CRX SI Parts
- Radiator help!
- Vibration problem
- b16 build What should i do
- CRX fuel pump issue.
- 91 hatch build, ls motor build, and everything from start to finish.
- 91 civic wont start
- WTB p30 ecu & door panel
- code 4 b18a1 into civic
- Need help !!!!!!!!
- b20 vtec help
- ***Engine doesn't start, no clicking, no turning, What could it be?***
- tied rod help
- I have a problem
- timing marks diaphram
- Oil Breather Chamber... What is its purpose? How does it work?
- Civic Sedan Rear Window Options, has anyone ever seen a EF sedan with a lexan rear?
- How do you remove the CRX Rear Windshield upper molding
- Cut wires from ECU
- obd0 b16a parts question
- Poor throttle response / low RPM choking
- DEAD ecu? or ?
- code 17 help
- jdm shit.com obd0>obd1 conversion harness!
- Si motor mounts
- main relay question
- wtf is up with this trial crap?!
- shifting at high rpm and (LAGING)
- y7 and the heater isnt working
- jdm itr recaro srd in 1991 crx?
- crx si to 90 civic dx question
- Hard to start when car is semi warm?
- Honda Lanyards?
- a6/y8 mini me timing belt problems
- check engine light
- Which Fuel Filter?
- Crx going in gear, but not going anywhere?
- new to honda-tech
- the front suspention fork
- Gates Belts
- Shaking while idleing or at light
- help with ls swap in ef
- quick swapp question...
- looking for and EF shell !!!
- DA front lip
- d series, mini me, header.... dyno results
- Is it best to remove spark plugs when the engine is warm, hot or cold?
- rear drum to disc upgrade ?'s
- head gasket attempted on z6...
- integra gs 90-91 motor in a crx
- exhaust troubles...
- ??? d16y7 head with d16a6 block, what timing belt should i use??
- what motor?
- civic dx 91 right side mirror?
- CR-X lighted rear center tallight section??????
- crx spoon brakes
- starter just clicks
- b16 cable tranny clutch question
- almost there! gsr swapped crx with skunk2 intake wiring
- Carb.... Need Info
- pressure plate flywheel etc. b series
- Plug Issue on a Obd0 b16a going into a 89 CRX si
- 91 crx si seatbelt help
- WHO SELLS NEW B16A Sir or B18C R'S READY TO INSTALL?
- Ef Sedan SIR Front
- exhaust question, piping too small, restricting airflow?
- how do i flush my coolant system to get air out of the system
- D series intake mani ?
- how do you remove the E-brake handle cover???
- Moldings Help!!!
- Tail lights fitment HELP PLEASE!!
- 90-91 EX hub replacement; 92-00 EX?
- D15b2 block D15b7 Head question
- cranking over muliple time before start
- rpm lags when i shift through gears
- 1990 civic dash wiring problem... Please Help!!!!
- How to remove the steering wheel?
- just changed distributor car wont start
- integra consol in civic hb? (yes searched)
- Retrofit headlights
- Need help with clutch selection, even after looking through the FAQ! :)
- seats
- just got a crx
- *Supposed* $300 CRX Rust Repair
- bumper interchangeability
- crx bumper lights
- Tools needed to remove carpet in a EF DX Sedan
- what temp??
- DA Seats in my EF Hatch
- my ef won't turn off!!!!!!!!!!!!!
- FITV valve removal backing plate made!
- Proper starting technique when a EF is giving you problems
- 89 si fuel tank filler neck ?
- lower kit from a 96' prelude
- REPLACE ENGINE?!!!1989 crx
- HALFSHAFT!????????
- Honda1989 CRX WINDSHIELD>?>
- GSR into 90civic dx, what hubs/spindles?
- does a sedan hood fit a hatchy ? plus bumper question
- post up pics of set ups of your mini me!
- CRX rear window deflector?
- how do i convert my dual point to multi point?
- My collection of CR-X toys
- d series engines
- Speedo cable or VSS in crx problem
- Megan Header meets Magnaflow Cat
- b16 vaccum help? weird
- b16 swap
- how can i make my v-tech kick in harder?
- RHD Carpet ?
- 89 crx si
- Another dpfi to mpfi conversion!!
- B16
- Ef Sedan Tail Lights
- SOHC ZC vs D15b7 bullfrog Gude head b2 bottom block
- i need help with b16 swap into my ef
- Quick CRX Questions
- DOHC ZC
- Integra seats
- Buddy CLub seat rails? JHPUSA.com
- what sensor is this? b series
- Okay to use a universal radiator fan on a stock radiator?
- Wobble sound from front and rear?
- just a question
- Are there any aftermarket companys that make D16A6 roller lifters?
- Need Help! Gas Gauge Problem
- Jdm J1 trans won't go into gear....
- My single cam from a 93 eg chokes at about 5.0 and wont go beyond. Help me out plz!
- MPFI conversion
- wagovan owners, do 13s fit?
- fuel pressure problem......
- New(b) guy
- What is this??
- Vibration around 3k to 4k
