View Full Version : Honda CRX / EF Civic (1988 - 1991)
- My build thread
- How much work does it take to change cv joint?
- Honda Crx oem oxygen sensor ?
- Correct a/c compressor. Please help!...searched but no luck
- Can 1990 crx drive axels be used in an 88 crx??
- My First Build Thread Ever!!!!
- Shoes for aluminum drums
- Coolant temperture sensor????
- Dash swap
- DESPERATE OBD0 PR4 ecu pinout
- EF9 4X114 CONVERSION
- Radiator Help
- greddy ultimate on crx?
- Mugen Fiberglass EF8 crx Hood?
- Serious wheel bearing problem....
- fog lights switch
- crx battery light
- strange starting problems d16a6
- How to convert 88 crx rear shocks to 89-91 spec
- IAT Sensor - B16A OBD0
- eBay full gaskets?
- Found a civic I'm interested in.
- d16z6 or d16y8 head?
- what radiators are interchangable....
- GSR into 90 Std
- Removed antenna stereo stopped working?
- planning on buying this 90 si
- Manual to Auto?
- which header will fit????
- obd-0 b16a no 2nd 02, running rich???
- Bumper lights as park lights?
- What spark plug should I use?
- Seat question (passenger to driver)
- blown headgasket/oil ring gone?
- Quick question on which clutch to purchase.
- Dohc zc swap
- **Steering wheel swapping problems???**
- EDM dual carbs
- Two idle problems-1991 Honda Civic DX
- 91 ef cluster bulbs
- crx SI cluster temp gauge not working (help)
- HONDA VETS HELP ME PLEASE!!??!?!!
- JDM B20A w/ GSR head
- any other good Mufflers for EFs
- No start after new rings..
- Idle shakeing
- HF wont start now...
- B18B Into 1990 EF Hatch
- sensor by map sensor
- 4 yellow wires on plug in engine bay
- Best options for ZC automatic ?
- 90 crx dx wont start
- Making a d16a6 vtec
- Bilsten's.. Where?
- engine biuld mot sure where it gose
- Clutch sticks sometimes-engages early
- 2000 d16y8 in 1990 ef HELP plz!!!!
- summit odyssey battery tray for the 680
- need my 91 crx dx w/D15B2 tranny rebuilt
- a few problems im concerned about
- Dimming lights. A normal thing on these old cars?
- Help with intercooler size.
- bringing back the side moldings!
- is this a legit jumper harness ?
- battery light comes on while driving...why?
- engine swapping and the health of the car body?
- Tach issues
- car almost dies when i take turns
- no spark (searched)
- 87 crx help
- Bolt help
- help with 4 inj wires
- mini me swap oil line ques??? mini me on boost?? please look and help
- Need a Electronic Speedo
- car wont idle after wire tuck
- everythings shuts off while moving, but not at stand still
- cooling fan isnt coming on
- CRX/EF/Civic Sidemarkers/Tail lights
- Are 88-89 and 90-91 CRX headlights the same?
- Legal Advice 4 Accident
- D16A runs like crap, new dizzy, plugs wires (srchd)
- First Build thread!! '91 Crx Dx/STD
- No Brakes - All new parts and bled. help.
- dohc zc timing covers
- D16Y8 swap, can't find coolant bleeding screw
- 88-91 roll bar question
- NEED HELP!!!!!
- 89 crx blown fuse
- DA springs on EF hatch?
- h22 ef or eg what will I need?
- Will eg Brake booster fit my CRX?
- will a 93 si tranny work with my d15b1 std motor?
- Code 14 obd1 IACV?
- turn signal question
- lights flash with clutch out
- Brakes Locking up After EX Upgrade WTF
- waGon HELP.
- intake manifold blowing out air?
- MSD question
- my slow si
- brake locking up!
- Changed M/C - Still Issues with Braking
- Weird electrical issues...
- resistor box install
- parts identifying from donor mini-me crx
- Should you be able to move clutch lever by hand?
- oem vs aftermarket ( headers )
- Sir Style Hood
- Name this plug
- D series transmission
- Password JDM batt. Relocation.
- obd2 injectors on obd1 91 civic
- a little shock fork help?
- head gasket
- 89 Civic Ef
- need help my axle this is a werid 1
- Heater Blower Cable Routing
- color change?
- d15b2/d16z6 mini me
- Engine swap question for all you gurus
- will dc shocks fit a 91 si crx
- automatic to manual conversion
- EE9 vs. EF9 front end.
- anything I can do to help my DD?>
- d16 y8 problems
- 90 91 CRX and EF Civic hatch healight and turn signal are the same?
- front sway bar 90 si
- blox camber kit application
- Camber Wear.
- Stumbling idle issue...
- D15B2 to D16A6 head question
- auto ef wont turn over?
- d15b7 swap?
- Need Help.........Wiring problem......B18c5 swapped crx si
- O2 cell but only around 60mph!
- A few general questions...
- brake caliper bolts?
- Rust in engine
- Oem HF Emblem?
- TO H OR TO K. NEED ADVICE.
- 91 civic hb h22 swap question
- Solid CEL, no spark or fuel
- EX wiring harness on STD?
- Thinking about buying a crx si but got some problems...
- Got a smoker here...
- 88-91 Civic Recall
- **DESPERATE FOR HELP**
- where to buy: hatch oem body parts
- Tiny cracks in flywheel OK?
- crx interior in a '90 hatch??
- b16a
- front crossmember
- do me a favor to all ef hatch owners.
- converting dimmer switch from 88/89 style to the 90-91?
- 88 89 bumper,or jdm front`
- vtec code 16
- A/C Trouble
- ticking valves 90 ef sedan
- EDM center console
- free shipping sale brand shoes 50%-80% off www.ok-jordan.com
- 89 Honda Civic stalls at idle
- Quaife Quick Ratio Steering Rack
- EX Brake Booster Problems Upgrade
- Hello, Folks! 1990 Civic Si Driver Here...
- Are DA teg and EF crx/civic axle back interchangeable?
- ok got two ? b18 and d series ?
- New problem..... gas mixed in with oil
- Could any one get discounts on Quartersportsdrag H2B kit ?
- pass. window pops off track, how to fix?
- I want foglights!
- Is this a bad alternator?
- biggest problems with obd2 swap
- B series, Aftermarket Header, AC, and Racing Radiator?
- comptech air box in crx?
- d15b7...WTF???
- Another MPFI question
- iacv? b18 in ef
- MSD Ignition Problem
- rear crossmember
- i need part numbers!!! Thank you
- A/C in hatch
- EF Civics with B18s+ AC Please Chime In….
- Bolt size for front motormount
- cluster/console problem
- Alternative to Skunk2 Pro series front camber kit?
- new member 90 ef si (video inside)
- d series dizzy
- need someone from Missouri or near Missouri
- CRX B series axles
- WTF kind of suspension is on this thing?
- sputtering problem!! on b16
- Heater A/C blower
- wat color is this
- will a p06 ecu work on an ef thats duel point?
- crx sunroof question
- converting pillar mounted to door mounted seatbelts.
- Factory crx alarm
- Starter/ing Problem?
- will they work
- Emissions
- Temp gauge bouncing, needle moves fast
- multi swap problem
- CRX hiccup problem need help
- Question?
- 1991 honda civic wont start/no spark and lots of new parts
- B16 Oil Leak! Near Hex Nut on top of oil pump!?
- need help with CEL
- Those who know
- starter...I think
- Instrument Panel Question...
- gsr swap
- Highway vibrations, exhausted knowledge bases & searches
- New to the forum thought I'd show you my race car
- ef8 cluster help!!
- Oh where Oh where do i stick the green plug ?
- CRX H&R coilovers - anyone?
- what should i do
- d swap questions
- windshield wipers dont work?
- tach and distributor problem
- Found a ZC
- HELP! MINI-ME OBD0 OBD1 questions!
- how much do Ukdm Crx seats go for Nowadays?
- 88 civic hatch dx seat fitments
- could it still be my starter?
- new to honda tech heres my ef2 sedan
- ls swap Qs
- GSR swap into CRX (noob questions)
- tail lights stay on???
- hf or dx which is it
- B20b High HC? whats the cause?
- Injector Locked Open, Hydra Locked from Fuel
- help! another one i know....
- engine lags power from idle or 650 to 1750 rpm
- what do you track guys use?
- Low idle under load, '91 DX 1.5L
- b16a crx wire tuck WHERE TO BEGIN??
- Here is what I am trying to do....
- Door help
- effeciency of a d16y7
- B18 Swap
- build thread
- D16A6-D16Y8 Swap
- bigger brakes
- vtec solenoid ?
- How to install Power windows and Locks in your 88-91 Civic/Crx 56k time to upgrade
- 89 crx w/b18 swap..need major help
- sway bar help on 91 lx
- Thought Some Would Appreciate This
