View Full Version : Honda CRX / EF Civic (1988 - 1991)
- dsm injectors to zc?
- swap question
- How much could I get for my Engine/Transmission/ECU/Wiring harness?
- Any ONE with a d16 N/A 13sec????
- good motor for myhatch
- FRONT MOUNT intake system!!!
- Nitto Neo-Gen Tire?
- My first car: ls/vtec crx
- differences with the 94+LS header and a 99-00 SI header
- what parts are compatible for 91 civic
- Do you have $15K? Look what's up on eBay...
- Car smoking? Did a search no answers!!!
- Anyone put a DA dash and center console into EF?
- 90 civic si for sale
- can oem honda rings fit on arias pistons or does it have to be from arias?
- Another B16 problem, help, i need to drive it now!
- what clutch disk does jdm S1 cable tranny use? 90-91 or 92-93 usdm teg
- ****Looky I found a NEW kind of intake mani. Is it any Good??!!****
- what is a cv joint??
- o2 sensor wires
- looking for a crx shell
- jdm fog light bracket mounting
- compression result question
- B16 question......
- engine harnes plug
- for a B16a with bolt ons in a CRX
- ANYONE know the weight of a 3rd gen civic si?
- i have a urethane bodykit i needed some info on installation can someone help out please ?
- temp. questions
- Head Gasket Dead? DOHC ZC
- 3 barrel si?
- codes
- SIDEMARKER wiring pigtail
- ngk plug number
- Where to get..
- This might be kind-of stupid, but...
- Just a quick ???
- Dohc ZC owners?
- new fuel system for the 91 dx
- cooling fans not working...help im overheating...
- 91 hb gas tank Question....!!
- Wiring situation for a Hatch?
- need help with b16
- 90-91 integra AEM alt pulley (B16A1)
- I need help installing Cam and Pulleys on my d16z6
- How much would you pay for LS Rims w/New Tires
- Found a 91 CRX, thinking of getting it.
- Sticky Hood Release
- after zc swap one wire without a home located around oil filter/alternator, please help
- upper ball joint replacement (REAL easy question)
- 4-speed to 5-speed on ZC
- ebay spoon and mugen chip?
- Crx Problems
- Am I being paranoid about the b16a1 swap?
- delta 260 ?
- Cam sprocket?
- header ?
- does anyone know when I can be un-newbed??
- Anybody else purchase Ebay special Coilovers?????
- CAI question for my 88 crx
- $100 for my rims?
- thinking of building my motor
- How loud is it when vtec kicks in on a B16A1
- difference between civic si and crx si seats??? pics would be nice too.
- fuel question
- does an 89 crx si come in green?
- clicking in dash
- new car
- b16 vs b18a (all motor)
- Pic Request Milano Red Hatch
- What does my 88 CRX Si weigh?
- Suggestions
- front mount intake system
- 1988 CRX Si, need some help
- lsd worth the money ?
- Started my sunroof plug project today...
- Best Cams For B16A1???
- Integra seats in a CRX
- How much do u guys think this is worth?
- energy suspension shifter stabilizer bushings
- Anybody have info. on Ebay Manifolds?
- dash/vent removal
- First Time Honda Owner
- Should i get rid of my Rex?
- Does anyone else have one of these?
- can anybody price all of this or some for mini me?
- anyone out there interested in carbon fiber lip?
- Replacement of the HEad Gasket
- anyone have an SE hatch?
- sunroof leaking HELP!!!
- Should this work on my 88' DX running a PR3 ECu????
- Car overheats in stop and go traffic...
- '88 crx si shell F/S
- Fabricating motor mounts...
- Satanic axle hubs
- which is better
- Does a B20 touch the inside of the hood on a USDM 88-91 CRX?
- how to pull an engine out the front of the car????
- can 90 si hatch fender fit an 88 crx si?
- Compressor Difference?
- crx b16 shiftlink
- cel code 16
- greedy sp or mx ?? crx
- FOR SALE: Stainless steel catback MID PIPE
- Apexi SAFC
- Is this a good deal for a DOHC ZC?
- si wiring harness
- SOHC VTEC on the track.... not too bad
- d16z6 and d16a6 HEAD FOR SALE!!
- gas smell
- IACV..Which ones fit?
- indiglo gauges, dash guages, wiring question HELP?
- Engine Swap for my 90 hatch
- Replacing front windshield
- seat belt in door... removal?
- engine question
- Using obd-2 injectors in a 89 hf
- Best suspension for $1000?
- Electronic load detector - function?
- i need help bad plz!
- will a 42 offset fit on a crx??????
- wtb crx in oviedo/orlando florida area
- the next great beater!!!
- b16 in a dual point setup
- 89 CRX <> 4G Civic SI Bumper Enforcement
- crx spotting
- LS-Vtec smog in TX????
- anyone have a crx/civic with a maxrev intercooler?
- who makes wire harness's
- Integra Center Console?
- HKS Exhaust Question
- 89 or 90 tranny in a 88 crx?
- crx with 88-91ish acura integra motor, ready for rebuild: need part help??
- JDM CRX SiR Front End Question
- crx with b16a1 swap or mustang 5.0?
- How much timing advance with milled head and thinner gasket??
- A/C Blower just not cutting it
- what i need for a mini me in my 90 hatch?
- need help car spudders bad
- CRX stick shift diameter
- cnew motor, which axles to use
- Question about my clutch.
- Another Crx Dead :(
- <><> IF MY CRX SAT FOR SIX MONTHS..<><>
- identify parts?
- my crx seemed down on her luck... so i got her a present to cheer her up!
- ****Anyone Using a Apexi VFAC with their supercharger???****
- For those who are running CRVTEC - times?
- north jersey-need help on my b16 swap wont start!!
- Car Starting problems.....
- First time at track..whats your opinions???
- Please help- I can't get the Steering Wheel all the way in
- Whats some fast times for All motor LS
- B18a into 88 CRX Si ....easy??
- wondering about the b16
- anyone with a DIY intake on their EF..lemma see!
- any LS n/a or turbo 91 hatches here
- Rumbling coming from back tire on 91 CRX
- pics of jimfab installed?
- Need Some FeedBack
- How strong is a ZC block???
- Which SOHC in CRX
- Mounts for d16 in CRX
- california smog
- B16>>no vtec, no CEL, and my temp gauge pegs to full hot after warmup!! HELP!
- question
- 99-00 si cluster in a 89 si??
- JDM GSR seats
- My fogged up EF. Please help!
- wouldn't start .. but then it did?!?! tech help :-)
- anyone in Maine experienced with b series swaps?
- Tociko illuminas vs. Koni Yellows
- vss and o2 heater
- any quick tricks to make exhaust quiter???
- LSD question
- Tranny Oil Change
- reccomended ecu chip for PR3 ecu? (B16, jun 3 cams.)
- Interior Job for CRX
- idle problem
- How do I get Scrapes Off my Projection head lights
- Stock B16a Dyno Run Graph Comments
- $$$ for parts car??
- 85 crx 1 need a turbo kit! any sugg?
- key ignition somthings wrong
- Quick Question....
- **HELP** Front caliper won't pivot out
- one hot CRX SiR wanabe for sale - in "vehix for sale" section ;) *link*
- honing cats
- ZC Compression
- New CRX!
- 90 teg dist. on 89 teg motor
- mini-me questions?
- Where can i get a b16 lsd tranny???
- what throttle cable are you suppose to use..
- anyone have a ballpark price for shipping a fender from west to east coast?
- ?Can you adjust the Clutch Cable on an 89 CRX?
- knock-knock!
- anyone have any pics of sir front lip......
- car won't crank unless i reset ecu?
- west coast B16a1
- JDM frontend Conversion For a 91 hatch Si
- sir bumper on 91 hatch...
- block question urgent
- Zc motor problems...
- Y8 intake manifold worthed?
- obd q's
- b18 or b16
- b16 or b18 into 88-91 hatch????
- aligning shock tower
- ZC in HF
- >>88 and 91 crx doors interchangable??<<
- 00 si rear suspension into a 91 dx hatch
- jdm parts
- D16y7witha Z6 head>>>will it work??????????
- guage cluster question
- b16 still wont start,have fuel and spark!!
- HondaClassifieds.com - Anybody done any deals there yet?
- b16 setup in CRX: I have a clunking noise over rough road, pass. side
- bumper question,crx
- Y8 Mani fo dpfi to mpfi
- interchangeable suspension ?
- CRX with ZC engine??
- what parts do I use?
- Need HELP ASAP cant find high beam switch wire
- Electric Load Detector
- JDMhondaparts.com logo, anyone have the old logo?
- Rear Swaybar
- How do I remove the rear bench seat in a civic?
- Fish tail effect ..Help
- just ordered new intake
- Model Designation for all the EF's?
- About to get this car. Part 2.
- Post Pics of Your Crx/hatch
- can i use 94+ teg e-brake cables for rear disk conversion
- what would you offer
- Going to look at a 88' CRX Si, What should I look for?
- zc?
- Question about YS1 Tranny
- june bug under the valve cover
- my input shaft is wobbling and leaking how do i fix?
- Simple headlight question
- No Electricity
- Does changing a fuel filter reduce emissions?
- Question
- motor mount inserts vs. honda motor mounts...
- i think its normal .....?
- rear running lights?
- ID dohc zc motor?
- crx si spark plug gap?
- zc guys
